Paradigm Owners Thread - Page 1070 - AVS | Home Theater Discussions And Reviews
 377Likes
post #32071 of 32091 Old 05-14-2015, 10:00 AM
almo89's Avatar
Quoted: 38 Post(s)
Liked: 39
New concept for a series that replaces the Signature perhaps? Looks interesting.
almo89 is offline
post #32072 of 32091 Old 05-14-2015, 11:40 AM
rwheelwright's Avatar
Quoted: 57 Post(s)
Liked: 27
That's my guess. With bigger woofers and beryllium tweeter, I would say Sig replacement.
rwheelwright is online now
post #32073 of 32091 Old 05-14-2015, 10:07 PM
Tank_PD's Avatar
Quoted: 38 Post(s)
Liked: 54
The woofers are active --built in amps from Anthem and includes ARC. Similar to Kef's Blade, I would guess this is more like a flagship above the Sig.
Tank_PD is online now
post #32074 of 32091 Old 05-15-2015, 12:05 AM
tritiumglo's Avatar
Quoted: 174 Post(s)
Liked: 99
Oh goody. Electronics stuffed in a speaker cabinet just waiting to fail. Then the chariot turns into a brick.
NAD M15 /NAD M25 / PSB STRATUS GOLD / PSB STRATUS 6C /DENON AVR 3300/CARVER TFM 45/35 - ANTHEM MCA3 / NAD T163
IMAGE DYNAMICS / INFINITY RS3 / POLK MONITOR 10/ALTEC 501 / INTEGRA 50.3/PARADIGM DSP 3400 / GOLDENEAR AON3 / HK AVI 200
An Observer of many philosophies, a slave to none.
tritiumglo is offline
post #32075 of 32091 Old 05-15-2015, 12:06 PM
JKR1963's Avatar
Quoted: 68 Post(s)
Liked: 42
This proto design is in response to competitors..........Digm "fear of the GoldenEar".
JKR1963 is offline
post #32076 of 32091 Old 05-15-2015, 12:09 PM
Quoted: 32 Post(s)
I've heard both and they have no reason to fear Golden Ear! Some of the most overrated overhyped products I've heard!
mmcelyea likes this.
NextLevel217 is offline
post #32077 of 32091 Old 05-15-2015, 12:12 PM
JKR1963's Avatar
Quoted: 68 Post(s)
Liked: 42
I also have heard all of them at the same store......GE, PARADIGM SIG'S, 95's.....Studio's etc.
JKR1963 is offline
post #32078 of 32091 Old 05-15-2015, 12:15 PM
Quoted: 32 Post(s)
In the same store also!!
post #32079 of 32091 Old 05-15-2015, 12:32 PM
JKR1963's Avatar
Quoted: 68 Post(s)
Liked: 42
Cool, it is called a difference of opinion !!!
JKR1963 is offline
post #32080 of 32091 Old 05-15-2015, 02:00 PM
grasshoppers's Avatar
Quoted: 356 Post(s)
Liked: 217
I'm betting a pair of these speakers would cost
Some MAJOR bucks!
Probably make a pair of Sig 8's look like a bargain!
NextLevel217 likes this.
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is online now
post #32081 of 32091 Old 05-15-2015, 03:00 PM
519audiofan's Avatar
Paradigm is definitely moving up market.
I am glad I grabbed a pair of v3 S6s a couple of weeks ago while they're still available.
I bet these concepts will sound amazing though!
519audiofan is offline
post #32082 of 32091 Old 05-15-2015, 06:06 PM
rolfeskj's Avatar
Quoted: 17 Post(s)
I am looking at possible buying a used pair of Paradigm Titans. I would prefer the version that is front ported as they will be set on a bookshelf.
Can someone explain the diffrent versions of the Titan line? v1, v2, v3, etc? I know v5 has is front ported, as I have seen photos, but at what version did that change from rear to front port?
Also I see alot of v2 on ebay for around $100-$150. How old are these speakers? Are the newer verisons that much better? Will the rear port sound that funny in a book case? Thanks.
rolfeskj is offline
post #32083 of 32091 Old 05-15-2015, 07:35 PM
Quoted: 356 Post(s)
Liked: 217
Can't speak much about the different Titan versions,but,
If you are going to put them in a bookcase you really
Should get front ported!
Rythmik F12 subs
post #32084 of 32091 Old 05-16-2015, 10:29 AM
csilverstein's Avatar
Hi,
I currently have a Studio v.3 system (20s and 490 in front), and was considering now replacing the 490 with the new 55C. Anyone have thoughts about how well this will blend in with my current system, if I might not replace the rest of the speakers for a while? Thanks!
csilverstein is offline
post #32085 of 32091 Old 05-16-2015, 06:49 PM
decibels's Avatar
Quoted: 144 Post(s)
Liked: 33
Originally Posted by csilverstein View Post
Hi,
The 20's are a fabulous speaker and even though I use them in a surround capacity, I would believe that they will go nicely with the 55C. I have a 690 and they match well with that and the 55C is supposed to match as well with previous generations as the 690.
HT: Pioneer SC-85, Anthem MCA 50, Oppo BDP-103, PS3
OSD ATM-7
2CH: Pioneer Elite SX-A9-J, Pioneer PL 518 turntable, Pioneer PD M455 CD, Pioneer CT-WM77R Tape
SP: Paradigm Studio 100's, CC 690, Studio 20's SR, Studio 20's SB, Ultracube 10 SW
decibels is online now
post #32086 of 32091 Old 05-18-2015, 06:42 AM
Liked: 2
OK guys, the new in walls are throwing me through a bit of a loop here. For my dedicated theater space the plan was to buy 3 of the AMS LCR and 4 of the AMS-100 for my in ceiling rear/surrounds.
They are all being replaced.
Now I am deciding between the H65-SM vs the H65-R for surround/rear speakers. Are we gaining anything by going with the 'dual directional soundfield?'
As for the fronts/center I will probably go with the Pro series. E80-IW. Unless you guys really think that $600 is worth it to step up to the elite?
IndecisivePurchaser is offline
post #32087 of 32091 Old 05-19-2015, 03:42 PM
Quoted: 57 Post(s)
Liked: 27
I wish I could help you but I have no experience with in walls or on walls. Looking at the specs I would say that it might not be worth the extra cost but you would have to give a listen to ultimately make that choice. I didn't audition my S8s, C5, ADP3s or S2s before I bought but... I had heard S6s before so I knew what I was in for so I figured I would probably regret it more if I got S6s instead of S6s instead of saving more and getting S6s. I saved long enough that even know a good amount more, I'm not left with that "what if" or I should have" feeling. However, I am second guessing my ADP3 purchase due to Atmos but since it will be a while before I go to Atmos and a new house later I can deal with it. I would like a second Sub 2 though...
post #32088 of 32091 Old Yesterday, 09:06 PM
JKR1963's Avatar
Quoted: 68 Post(s)
Liked: 42
they are showing that concept speaker discussed above at the Munich show:
http://www.hifiplus.com/articles/bak...d-2015/?page=3
JKR1963 is offline
post #32089 of 32091 Old Today, 12:24 AM
decibels's Avatar
Quoted: 144 Post(s)
Liked: 33
Interesting, Studio design meets space age look...it did not mention if they were powered or not as they are working on a signature powered unit as well.
BTW, who buys these ridiculously priced systems and the cables with some of them...
OSD ATM-7
post #32090 of 32091 Old Today, 11:48 AM
Tank_PD's Avatar
Quoted: 38 Post(s)
Liked: 54
It does mention this on the Paradigm website. Four powered woofers, passive midrange and tweeter. This is likely the speaker you are referring to.
post #32091 of 32091 Old Today, 09:51 PM
decibels's Avatar
Quoted: 144 Post(s)
Liked: 33
Okay thank you for that update, I have not looked on the website recently.
OSD ATM-7
Reply Speakers
Paradigm , Speaker Systems
