Paradigm Owners Thread - Page 1074 - AVS Forum | Home Theater Discussions And Reviews
 407Likes
post #32191 of 32205 Unread 06-29-2015, 09:46 AM
audio4life's Avatar
Liked: 208
Originally Posted by tritiumglo View Post
Their parlor tricks limited by DSP 3400s to a 24hz response. They specd at 18 hz according to Pdigm.. A 20hz test tone will not even play through them. Garbage. After learning the hard way and $2000 later, I found that most of their subs use this to avoid warranty claims. You cannot trust Paradigm sub ratings.
My respect for Paradigm is now limited to some of their better speakers. None for their subs.
I will take HSU or SVS if I have to buy a box sub that I didn't build myself. I have heard/felt HSU subs play 16hz.
I can attest to the fact that HSU subs will play down to what they say!
tritiumglo likes this.
audio4life is offline
post #32192 of 32205 Unread 06-29-2015, 09:49 AM
ambesolman's Avatar
Quoted: 693 Post(s)
Liked: 606
+1
Sent using Tapatalk since the mobile version is still
ambesolman is offline
post #32193 of 32205 Unread Yesterday, 03:29 AM
dvcdude's Avatar
I am moving up to Studio 100's, CC690, ADP590 from Klipsch Reference 7 system. My question regards power needed. I have an Emotiva MPS-1 7x200 wpc amp and suddenly everyone i know who is familiar with Paradigm Studio line says I need at least 300 wpc to the front stage. The specs do not seem to support this. Looking for some feedback from experienced owners.
Thanks in advance.
ISF Level II Certified Calibrator
CEDIA Member
Serving Central Indiana
www.indyvideocal.com
dvcdude is offline
post #32194 of 32205 Unread Yesterday, 04:09 AM
orcrone's Avatar
Quoted: 92 Post(s)
Thanks in advance.
I have the same front three speakers. I was driving them with a 200 wpc amp. When it started to have some issues I purchased a Sunfire 400 wpc amp. They sound great, but honestly I am not sure they sound any better. If I were starting from scratch I might suggest a more powerful amp, but already having your amp I would suggest staying with your Emotiva. I think the combo will keep you happy for a long time but you can always upgrade if you're not happy. But at least give the combo a try.
orcrone is offline
post #32195 of 32205 Unread Yesterday, 05:48 AM
Red99's Avatar
Quoted: 568 Post(s)
Liked: 369
Thanks in advance.
Im interested in what you think of going from Ref 7 to the Studio 100's. Are these the newer Ref 7-II's?
Looking at the specs, 32 WPC should get you to ref level at 1 meter. So I guess it really depends how far you listen from your speakers, room size, and how loud you listen to music/movies.
Going from 200 WPC to 300 WPC will only gain about 1-1/2 dB. Doesn't seem worth the cost to me.
Sensitivity Room / Anechoic
92 dB / 89 dB
Impedance
Compatible with 8 ohms
Suitable Amplifier Power Range
15 - 350 watts
Maximum Input Power
230 watts
1 watt 92 dB
2 watts 95 dB
4 watts 98 dB
8 watts 101 dB
16 watts 104 dB
32 watts 107 dB
64 watts 110 dB
128 watts 113 dB
256 watts 116 dB
SOUND: Marantz AV-7702 Pre/Pro, McIntosh MC1706 Amp,
(2) Klipsch RF7-II's, (2) Funk Audio 18.0 subs
VIDEO:
Samsung PN64F8500 Plasma TV, Oppo 103D Blue Ray Player
Red99 is online now
post #32196 of 32205 Unread Yesterday, 06:56 AM
dvcdude's Avatar
Thanks for the quick responses.
I have the original or classic RF-7, RC-7 front stage with RS-62 sides and RB-35 rears. Heard the Studio 100 sustem at CEDIA EXPO the year they released v5 and said that is a system that i would replace my Klipsch system for.
CEDIA Member
dvcdude is offline
post #32197 of 32205 Unread Yesterday, 06:57 AM
grasshoppers's Avatar
Quoted: 384 Post(s)
Liked: 240
Thanks in advance.
200 watts is plenty for the Studios. They are pretty sensitive
And an easy load. With the Emotiva you will have ample
Amount of reserves. This is applicable as long as you do
Not reside in the Superdome!
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is online now
post #32198 of 32205 Unread Yesterday, 11:44 AM
dvcdude's Avatar
Thanks, I can honestly say i have only seen the inside of the Superdome on tv
CEDIA Member
dvcdude is offline
post #32199 of 32205 Unread Yesterday, 04:50 PM
audio4life's Avatar
Liked: 208
Thanks in advance.
I had the XPA-3 with Paradigm Sigs and found the resulting sound too bright and harsh. Emotiva can be a bad combo with Paradigm, I've read other owners who found the same. Anthem, Paradigm's sister company, has a different approach than Emotiva, and it's a good synergy. But being that you already had Klipsch, I expect you'll not find the sound distracting.
NextLevel217 likes this.
post #32200 of 32205 Unread Yesterday, 07:40 PM
Civik99si's Avatar
Agreed. XPA-5 was plenty of power to push my v5 100s,690,and 590s as loud as I wanted in a 14x20 room.
Civik99si is online now
post #32201 of 32205 Unread Yesterday, 07:44 PM
Civik99si's Avatar
Interesting. I thought my XPA-5 and later added XPA-2 sounded great with my old Studio setup and still think they sound great with the upgrade to S8s/C5.
post #32202 of 32205 Unread Today, 03:29 PM
witchdoctor's Avatar
Quoted: 103 Post(s)
Sub Advice Needed
My room is 14 x 16 and I have a Sunfire TQES10 subwoofer. My home theater is a 9.4.1 system using all Paradigm Active speakers which all go down below 36 hz. I can get a pretty good deal on a Paradigm PW 2200 sub but I am afraid a 9.4.2 system might be overkill for my room. I live in a condo and the Sunfire sub can put out 107 db. Should I add the second sub? Why or why not?
witchdoctor is online now
post #32203 of 32205 Unread Today, 04:54 PM
Red99's Avatar
Quoted: 568 Post(s)
Liked: 369
Having at least 2 subs should be a standard for anyone. I would recommend getting a pair of matching subs also. You get the best sub for the $ with the ID companies over in the sub section part of the forum.
So, I would recommend either selling the sunfire, and buying two other subs, or buying another sunfire. Some people has mismatched subs and got them to work. But that's a gamble.
witchdoctor likes this.
VIDEO:
Red99 is online now
post #32204 of 32205 Unread Today, 04:58 PM
Red99's Avatar
Quoted: 568 Post(s)
Liked: 369
Are you sure its not your room being overly reflective?
VIDEO:
Red99 is online now
post #32205 of 32205 Unread Today, 05:24 PM
Quoted: 103 Post(s)
Excellent, thanks for the feedback and I will pass on the Paradigm and wait until I find another Sunfire.
Reply Speakers
Paradigm , Speaker Systems
