Paradigm Owners Thread - Page 1105 - AVS Forum | Home Theater Discussions And Reviews
 561Likes
post #33121 of 33140 Old 02-02-2016, 01:45 PM
djgcue's Avatar
Originally Posted by mdchaser View Post
Those would definitely kick arse as surrounds. I set up a 5.1 system using their milleniaone speakers in my room and while they probably won't go as loud as my studios they sound every bit as good at normal volumes (minus some blending with the sub due to their crossover requirements, time to replace the old dsp-3100 I think). I call them mightymites, great little speakers considering they are tiny. I would love to get some cherry finish studio speakers to use as surrounds to match the fronts but I couldn't find any used that were in the shape I wanted for the price I wanted and the tech never recommended the 15bs.
+1 > I have M1's w/ a SVS sub setup in my bedroom and they sound every bit as good as my Studios (100s, 20s, ADP590s and CC690) & SVS sub setup downstairs. However, I wouldn't use my M1's as Atmos speakers with my Studio setup since I'm running Pro Amps to the Studios. I don't think the M1s could handle all of the power.
djgcue is offline
post #33122 of 33140 Old 02-02-2016, 02:52 PM
Liked: 4
Another member PM'd me regarding my impressions of the Salamander Designs cabinet. I tried to reply to the PM, but apparently you must have a minimum of 15 posts in order to send a PM. I'm going to post my response here so that my fellow forum member doesn't think i'm ignoring their request. Apologize if it's inappropriate to post something that isn't directly related to paradigm in this thread. Mods feel free to delete as you see fit.
I purchased the Synergy model 345. Below are my thoughts:
Pros:
- Super sturdy aluminum frame
- Very nice quality wood (doors, top, bottom)
- End panels and dividers are a wood laminate, but still well done
- Very modular design allowing you to adapt to various equipment needs
- Shelves are well made and extremely heavy duty
- All hardware is high quality (door hinges, pull knobs, shelf mounts, feet, etc...)
- Very large center channel location
- Perfect height for a TV to sit on top without having to crane your neck up/down for viewing
- Excellent ventilation
- Easily removable rear panels for equipment insertion/removal
Cons:
- Assembly required. There are a lot of parts and the directions are less than optimal
- Cabinet depth is too shallow for some equipment (e.g. Emotiva amp). You can work around this be leaving one or more of the removable rear panels off. This can only help ventilation, so I didn't see it as a serious drawback. I think I read somewhere that they offer deeper rear panels.
- Soft close door dampers lack adequate compression resulting in less than "soft close"
- No wire management system. I decided to drill holes in the divider panels to allow me to route all connections internal to the cabinet. I used a 1.5" paddle bit and drilled the holes in an inconspicuous location. The other option would have been to run the cables all the way to the bottom existing below the removable rear panels and
around the frame support and back into the cabinet. I didn't like the thought of doing that and preferred to have all the cables (with the exception of my furman power conditioner AC cord and main/sub wires) enclosed within the cabinet.
I'm very happy with my purchase. The AV cabinet looks beautiful. Assuming it stands the test of time (and I have every reason to believe it will) I would have ZERO reservations recommending Salamander Designs products.
HTH...
Jonas2 likes this.
quick66 is offline
post #33123 of 33140 Old 02-02-2016, 02:55 PM
Liked: 4
Pros:
Cons:
HTH...
quick66 is offline
post #33124 of 33140 Old 02-02-2016, 04:53 PM
mdchaser's Avatar
Quoted: 40 Post(s)
Originally Posted by 04rex View Post
The MilleniaOnes have me intrigued. Would they be too small for overhead duty?
How big is your room? If your ceiling is 100' above your head then you might want to go bigger . Otherwise I would think they would do great. Personally I would go with some in ceiling speakers unless you are renting or have a specific reason not to. If you need the portability the milleniaone's do come with wall mounts which you could use to mount them to the ceiling, they have some degree of freedom with which to angle them.
I just set up two 5.1 systems, one using the milleniaone's and another using the cinema ct 100's. I like them both, they are both great little speakers and I think you would be happy with either. The Millenia speakers are definitely a step up however, for the mid/high range they sound as good to me as my studio speakers. They don't put out much bass but then again you will be using them for overheads and I'm making the logical leap that you already have a sub for the lows. I didn't think I could be impressed by such a small speaker after using my studio 60's but damn those little things sound good!
mdchaser is online now
post #33125 of 33140 Old 02-02-2016, 04:59 PM
mdchaser's Avatar
Quoted: 40 Post(s)
Which SVS sub do you have? I'm using an old dsp-3100 and am not terribly impressed by it so I'm looking for something that will mesh well with the M1's. My thought right now is to grab a monitor sub 12 since I have a pbk kit and it would be nice to calibrate it to the room. I have to run my crossovers a bit too low because the dsp-3100 can't seem to handle anything above 100hz which is crazy.
post #33126 of 33140 Old 02-02-2016, 05:23 PM
mdchaser's Avatar
Quoted: 40 Post(s)
04rex, read this:
http://www.soundandvision.com/conten...speaker-system
post #33127 of 33140 Old 02-02-2016, 06:30 PM
04rex's Avatar
Quoted: 92 Post(s)
Liked: 26
Great review on them. They seem like they would actually be a great choice.
The reason I am looking at something like those is where my system is, it is unfinished. It's in the basement. So there is no drywall or anything and there are no plans in the immediate future to finish the basement. Since there's no drywall, I don't think or don't know if traditional in ceilings would work good. With the MilleniaOnes, I can just mount them on a stud and angle them and be done.
04rex is offline
post #33128 of 33140 Old 02-03-2016, 10:18 PM
wiyosaya's Avatar
I'm still planning on my audition of the 95Fs on Friday, but I noted that people were talking about the Cinema series as being a good match to the studio series for surrounds/rears. At this point, I'm finding the 25s and the Millenia ADP to be a bit too pricey for my comfort. I was looking at the Paradigm site and specs of the various lines, when I noted that the Monitor Surround 3 v7 seems to be constructed with drivers that are similar (i.e., all aluminum) to the Prestige series line and has a wider published frequency response than the 25s. This leads me to think that they might be a good match for rear/surrounds. Plus the price makes for a better WAF.
So, I'll open myself up to members questioning my sanity and ask does anyone out there think this might be a good combination Prestige LCR, Monitor 3 v7 surrounds and / or rear? Also, what benefit does the center bass driver in the 25s/Millenia ADP offer over the Monitor 3 v7 layout?
wiyosaya is online now
post #33129 of 33140 Old 02-04-2016, 09:32 AM
taxman48's Avatar
Quoted: 189 Post(s)
Liked: 199
Anyone have the Monitor Surround 3 speakers and comments about them? I am looking to upgrade some ADP surround speakers and I am taking a look at these to replace them. I can demo them at my local hi end store but wanted actual owners reviews. Is anyone using separate amps for them? Notice that the 3's can handle 120 Watts.. thanks in advance
taxman48 is offline
post #33130 of 33140 Old 02-04-2016, 10:29 AM
mdchaser's Avatar
Quoted: 40 Post(s)
I have both cinema speakers and the milleniaones. I use a pair of milleniaone's as the surrounds for my studio system and they match very well, much better than the mini monitors I was using. I would look at the milleniaones before any of the others after having owned all of them. Good luck!
post #33131 of 33140 Old 02-04-2016, 02:26 PM
djgcue's Avatar
I have the Ultra13 in my Great Room and a SB12-NSD in my bedroom. I have both sitting on Auralex sound isolation pads.
I'm very happy with the blending of the SB12 and the M1's. The SB12 since its sealed doesn't over power the M1's by being overly "boomy".
djgcue is offline
post #33132 of 33140 Old 02-04-2016, 04:18 PM
mdchaser's Avatar
Quoted: 40 Post(s)
I've been looking at the SVS subs, they seem to provide some great equipment for the price. I may be stuck with something from Paradigm as my local audio shop owes me a significant amount of credit and that's what they carry so I may just end up with another seismic 110 or a sub 1. I'm intrigued by the isolation pads, did you see any difference? I didn't know anything like that existed but for $50 I think I may try one.
post #33133 of 33140 Old 02-04-2016, 08:02 PM
djgcue's Avatar
I really haven't noticed a difference with the isolation pads. To me, its snake oil. I use both the Great Gramma and Subdude2 from Auralex mainly to keep the subs off my hardwood floors.
djgcue is offline
post #33134 of 33140 Old 02-04-2016, 08:51 PM
Quoted: 552 Post(s)
Liked: 238
The MilleniaOne is a better match sonically but the bipole Monitor 3 will cover a greater area and play louder. It depends on your needs which I would use.
Ellebob is offline
post #33135 of 33140 Old 02-04-2016, 08:55 PM
Quoted: 552 Post(s)
Liked: 238
Isolation pads work great for subs that like to walk or you can feel the vibrations through the cabinet of the sub. Well designed subs should have enough bracing and mass that they don't walk or vibrate the cabinet. For better subs isolation pads will not be a big benefit if at all.
Ellebob is offline
post #33136 of 33140 Old 02-04-2016, 10:23 PM
Tank_PD's Avatar
Quoted: 74 Post(s)
Liked: 57
You will not need isolation pads with Sub 1. It has isolating feet and the cabinet/driver design is force canceling. The cabinet doesn't vibrate / move.
TL;DR: Basically what everyone else is saying. Too good of a design / too expensive to have that problem.
Tank_PD is online now
post #33137 of 33140 Unread Today, 04:39 PM
wiyosaya's Avatar
Originally Posted by quick66 View Post
Vocal clarity is amazing. Norah Jones, Allison Krauss or other vocalists sound like I've never heard them before. I don't want to sound like a 95F cheerleader, but I really can't overstate how great these speakers sound. I will be keen to hear your thoughts once you've demoed them.
I auditioned both the 85Fs and the 95Fs, side-by-side yesterday. I brought along a variety of material: a DSF of Handel's Water Music / Fireworks Suite, Julia Fordham, Baba Maal, Lush for challenging vocals, Madonna (since the piece is very-well engineered IMHO), and some Gandalf.
I guess that I was not expecting as much of a difference between the 85Fs and the 95Fs, but I thought that there was a big difference. The 95Fs sounded much more open and natural to me than the 85Fs on most of the material that I brought. On some portions of the material, the difference was minimal, however, the Handel, and Baba Maal selections in particular, had portions that sounded much more natural on the 95Fs. There is a didgeridoo like drone in the Baba Maal selection that sounded much more natural on the 95Fs. The tympanies in the Handel selection also sounded much more natural to me. The Julia Fordham piece was equally as open and natural sounding on the 95Fs. I was hoping that the vocals on the Lush piece would be more understandable than they are on my 11se MKIIIs, but they were not much more intelligible. However, I'll chalk that up to a not-so-well engineered recording.
Though I have described particular portions of the selections I brought along as sounding more open and natural, in general, the 95Fs sounded more open and natural to me than the 85Fs. Even though I did not get the chance to A/B my 11se MKIIIs, on listening to the same material at home afterwards, it sounded muffled - as if the response and dynamic range of the 11se MKIIIs was severely restricted over the 95Fs.
I auditioned Studio 100 v5 a few years back, and I have to say that I am glad that I did not get them. Though I did not compare them side-by-side with the 95Fs, I don't remember being as impressed by their sound (though they were better than my 11se MKIIIs) as I am by the 95Fs. The 95Fs seem to be more evolutionary than an incremental improvement.
FWIW - I have a friend who bought used v2 S8s and I think the 95Fs sound better than those - though I think my friend is driving them with an under powered amp.
Anyway, I have a pair of 95Fs on order along with the 55C promotion. I'll be picking them up next Friday, and setting them up next Saturday.
I've decided against upgrading my rear speakers at this point since I'll be investing in an OLED in the not too distant future, and my seating distance might change. My wife is OK with ceiling mounting the rears, so I want to be sure that I only have to locate them once.
Here are the selections I used for anyone interested:
quick66 likes this.
post #33138 of 33140 Unread Today, 05:41 PM
Liked: 4
Gandalf - Many Roads Many Choices
Gandalf - Wandering Amongst Green Hills.
Handel - Music for the Royal Fireworks Overture
Baba Maal - Souka Nayo
Julia Fordham - Love & Forgiveness
Lush - Sweetness and Light
Madonna - Rain
Wiyosaya,
Glad to hear that you enjoyed your audition. I noticed the same traits when comparing the 95 and 85. The 85 is a great speaker to be sure, but the driver configuration, cabinet or both with 95 make a significant difference. I'm not familiar with many of the pieces you listened to during your audition, however I plan to give them a listen. I'm always open to listening to new music or artists that I haven't heard before. I'm super excited for you, I absolutely love my new speakers. My 55C center will be here next week. I added an SV Sound SB13 Ultra to the mix last week and once I got it dialed in sounds fantastic. I feel like a kid at Christmas
quick66 is offline
post #33139 of 33140 Unread Today, 07:31 PM
Jonas2's Avatar
Quoted: 102 Post(s)
Wiyosaya,
Glad to hear that you enjoyed your audition. I noticed the same traits when comparing the 95 and 85. The 85 is a great speaker to be sure, but the driver configuration, cabinet or both with 95 make a significant difference. I'm not familiar with many of the pieces you listened to during your audition, however I plan to give them a listen. I'm always open to listening to new music or artists that I haven't heard before. I'm super excited for you, I absolutely love my new speakers. My 55C center will be here next week. I added an SV Sound SB13 Ultra to the mix last week and once I got it dialed in sounds fantastic. I feel like a kid at Christmas ������
Hmmm. This is interesting. The 85F is one of the speakers I'm considering for an already fairly tight space, but it sounds like I might be selling myself short by not considering the 95F - unfortunately, my local dealer does not have the 95F, just the 75 and 85. (Granted, haven't been there for a while, so maybe they've picked it up.) I'm going in tomorrow so I'll find out - but man, the size seems almost like they'd be awkward-looking in my space, over kill. One of the reasons I liked the 85F - just about at the size limit of what I wanted to accommodate! They've gotta fit along the length of a 10' wall in a 13' x 16' space with a 70" wide A/V cabinet - leaves just under a foot away from a side-wall that I can't avoid. Not ideal whatsoever - but no choice.
Just a put together a new "demo disc" for auditioning, sand I hope to compare the Prestige to the Totem Acoustic Forest (which would fit much better in my space, but not as aesthetically pleasing as the Prestige to me anyway). Also considering the Revel Performa F206 (but I guess the F208 would be similar to the 95F), but this is proving to be more of a challenge to audition simply due to lack of their existence at any close-by dealer. But they must be considered nonetheless for my budget range.
Jonas2 is online now
post #33140 of 33140 Unread Today, 10:59 PM
wiyosaya's Avatar
Wiyosaya,
Did Paradigm end up giving you the promotional 55C? Awesome deal if they did. I'm excited for you, too. it sounds like you are putting together quite the system.
They did have a 55C at the shop on demo, but I did not listen to it.
I bought a Servo-15 from the same shop a few years after I bought the 11se MKIIIs. For me, all I can say is that though it is tempting to dream of a newer sub, it seems unnecessary as the Servo-15 is a very capable sub that I find it hard to think of replacing at this time even though the newer reference series subs have fantastic specs.
I have not heard of the SB13, but a good sub makes quite the difference for some movies. My wife and I started watching Interstellar on Amazon, and I told my wife the sound sucked. We ended up renting the Blu-ray from Redbox, and our entire theater room was shaking during some scenes. My wife said, "I'm convinced!"
In fact, if anyone out there can find a used, but fully functional Servo-15 v1, my opinion as an owner is that it would be hard to beat for the price that you might find one.
I have not heard Nora Jones before, but after listening to her on YouTube, I would have to say that she is similar to Julia Fordham in some ways.
I have a similarly sized room, and my setup is also along the 10' wall. However, I have an older 2U wide 3U high Salamander Designs cabinet that is 44" wide. At that size, it is a nice fit. I have an HTPC along with my RX-A1050 in the cabinet, so you might say that I'm running a sparse system.
I have not heard of the other speakers that you are talking about. In fact, I am not sure that there are dealers in my area that carry them. When I bought my 11se MKIIIs, I shopped around to at least two other upper end A/V dealers. It would have been nice to have one dealer that had all of the speakers I listened to at that time, but I had to kind of hold what I heard in my head and make a decision based on that. I felt that the Paradigms sounded the best of what I heard, but part of what swayed me was that the sales people at the shop where I bought the 11se MKIIIs were not the pushy type. I've been pretty much exclusively buying from them ever since. I now have a long-time relationship with them, and even though I might find things cheaper elsewhere, I bring my business to them. IMHO, building a long-term relationship with a shop like that is the way to go. It has paid off for me many times over the years. If I am not mistaken, the two other dealers that I mentioned are no longer in business.
I think you are doing the right thing by auditioning the speakers. Unless one can afford to buy new speakers every few years, speakers are something that you have to live with for a long time, and that the sound is what you like is the most important thing as I see it.
I may never buy another set of speakers, but I think I made the right choice. I have to say that I am partial to Paradigm though. I like their sound and the philosophy behind their design. I wish you the best in your quest, and I would be interested in knowing your choice and why.
Reply Speakers
Paradigm , Speaker Systems
