Paradigm Owners Thread - Page 779 - AVS Forum | Home Theater Discussions And Reviews
 1052Likes
post #23341 of 34890 Old 01-21-2012, 08:14 PM
mjpearce023's Avatar
Quoted: 36 Post(s)
Liked: 38
Originally Posted by CHASLS2 View Post
Here is the Millenia One setup in my bedroom. They replaced my Klipsch RF7 5.1 setup.
They really rock for being so small.
That looks great. I have been considering the millenia ones for a bedroom setup for a while. I already have a receiver and a sub so I just want some speakers to replace my monitor 3. What receiver are you using with them? The pic looks like you have a Pioneer SC model but I wasn't sure.
That VT30 looks sweet. I had to go with the ST30 and it's a nice TV but I can only imagine how good the vt30 must look.
mjpearce023 is offline
post #23342 of 34890 Old 01-22-2012, 12:33 AM
ank.agarwal's Avatar
Audio gurus, I have a difficult question:
If I sell my Paradigm Titans and CC190 (since they are too big and cannot be wall mounted), how much can u expect? They are around 2 years old in great condition.
Also can you suggest me good Paradigm/non paradigm 3.1 or 5.1 speaker setup with small good looking speakers? I am thinking $1500 for this system.
Please help as my wife is not happy with these big wooden boxes. (that's what she call them)
ank.agarwal is offline
post #23343 of 34890 Old 01-22-2012, 04:24 AM
CHASLS2's Avatar
Quoted: 800 Post(s)
Liked: 343
The AVR is a Pioneer Elite SC35 and the sub is a Sunfire true signature.
These little speakers really sound good and free up lots of floor space. Looks like i will have to remount the rears as they are facing out from behind me.
I think they need to be facing left to right toward me as i don't get much effect with them facing out.
Sony 65" A1E Sammy 8500 UHD player
OPPO 83 &103 Sony BD player
Pioneer Elite DV 59AVI
Paradigm 490cc B&W 685 S2's
Pioneer Elite SC61 SVS SB13Ultra
Acurus 200A3 Paradigm studio 60 V5's
CHASLS2 is offline
post #23344 of 34890 Old 01-22-2012, 04:26 AM
CHASLS2's Avatar
Quoted: 800 Post(s)
Liked: 343
The Millenia One's will fit the bill very nice, see my pic of them just above you.
CHASLS2 is offline
post #23345 of 34890 Old 01-22-2012, 07:13 AM
I saw your setup, the speakers are really small. They are probably 1/4 in size compared to Titans or CC190. Do you think they will rock the room? I am happy with these speakers but space is an issue.
Also I need rear/surrounds? Do u recommend Millenia for rear too or Surround 1? As you mentioned above, you are not feeling the effect from rear ones. Can I add ceiling speakers for rear?
post #23346 of 34890 Old 01-22-2012, 07:26 AM
CHASLS2's Avatar
Quoted: 800 Post(s)
Liked: 343
I don't know what size room you have, my bedroom is 14x16 foot. They do plenty for my small bedroom. I just need to remount my rear's so they face left to right instead of facing toward the tv. I had Klipsch RS7's mounted as rears when i first hooked up the front three Millenia speakers. They are a different kind of sorround speaker than the Millenia.
CHASLS2 is offline
post #23347 of 34890 Old 01-22-2012, 09:11 AM
johnfusco's Avatar
Originally Posted by The_Spyder View Post
Ok guys
Is it worth the upgrade from studio to signature?????!!!???
Currently
Marx 700, studio60s, sub 12, cc 590, sa15r in ceiling rears
Would It be worth an upgrade to s6s and a c3?
Would I need an a2 to power those puppies as I feel I need an a2 already
I wouldn't be able to buy a sub for a long time either
My signatures were worth every penny I spent on them! Awesome speakers!
johnfusco is offline
post #23348 of 34890 Old 01-22-2012, 09:21 AM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 168
How come Paradigm so drastically reduced the Series 7 Monitors' sensitivity?
That, combined with low power handling, suggest that they are not suited for the high dynamics of home theater.
I've been a fan of Paradigm and own five of their speakers, but this move leaves me confused.
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is offline
post #23349 of 34890 Old 01-22-2012, 09:48 AM
cjsiv's Avatar
Liked: 40
If anyone is using mini monitors as right and left with a sub, what do you cross them over at? I've tried both 60 and 80 and I kind of like the 60 better for music, but is that too low for them? I know what they are rated down to, but I was just curious what others have used and liked. I have them paired with a Hsu STF-2 and a Denon 1910.
cjsiv is offline
post #23350 of 34890 Old 01-22-2012, 10:16 AM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 168
More important than crossing over at what the speaker CAN do, you should cross over where you SHOULD do, in your room with your sub and your amp.
If you listen at high levels and your receiver is weaker, then you may well do better crossing over higher.
If the standing waves are such that sending more bass to the fronts mean you cannot mitigate them by positioning the sub for smoothest response, then you should cross over higher.
Eyleron is offline
post #23351 of 34890 Old 01-22-2012, 10:57 AM
cjsiv's Avatar
Liked: 40
Right now I am still adjusting things. I really wanted the monitor 9s, but the wife said that was out of the question. The Minis fill my room quite well and the CC-290 is awesome, but on some tracks with 2 channel stereo and music, the sub seems a little too overpowering. I know the monitor 9s would be smoother, but I am very satisfied with the sound I am getting. Major upgrade over my Jamos even going from towers to bookshelves. I wouldn't have even considered the minis without the Hsu. I had a BIC F12 before and it was boomy with bookshelves. The Hsu is definitely more musical. I know there is the age old debate of floor speakers vs bookshelves with a sub but that just was not an option at this point. 80 hz seems to be my sweet spot. I have always preferred that even with towers. It just gave a little more impact to my ears. I guess on the few tracks that are mixed a little heavier, I can just drop the channel level on the sub a notch or two. Thanks for the input.
I actually have 30 days to exchange the minis for full credit if I wanted larger speakers. They have a few new 9s and 11s left. If I did that I would have to sleep in the boxes they came in.
cjsiv is offline
post #23352 of 34890 Old 01-22-2012, 11:12 AM
Tooley's Avatar
Upgrade and sleep in the boxes it will be well worth it and the wife will call you back to the bedroom after a few days anyways to keep her warm. LOL
Tooley is offline
post #23353 of 34890 Old 01-22-2012, 11:19 AM
How does Millenia compare to KEF T series? They are also sleek good looking speakers.
post #23354 of 34890 Old 01-22-2012, 12:01 PM
pg_rider's Avatar
Quoted: 78 Post(s)
Liked: 33
I cross my Studio 10s over to my Hsu VTF-3 Mk III at 100 Hz. I've experimented with both 80 and 120, and keep coming back to 100...
LSA One Monitors, LSA LCR Center, LSA On Wall surrounds, dual Hsu VTF-3 subs, Denon AVR-X4000, Adcom GFA-6000 amp, UTurn Orbit turntable, Samsung UN75HU8550
pg_rider is offline
post #23355 of 34890 Old 01-22-2012, 12:51 PM
Quoted: 36 Post(s)
Liked: 38
Thats a nice receiver. I have heard the millinea ones and I thought they sound fantastic. I have heard they have some impedance dips and require a decent receive to get the most out of them. I have a Denon 1508 that I wanted to use but I will probably have to use the Denon 3310 that I was planning to sell since it has a better amp section. I am still trying to decide on what to do but I would like to have a nice little music system.
post #23356 of 34890 Old 01-22-2012, 01:08 PM
CHASLS2's Avatar
Quoted: 800 Post(s)
Liked: 343
I have no clue as the only brand of speakers i have ever owned was many of Klipsch line of speakers. I plan to try as many diff speakers brands as i can over the next few years.
CHASLS2 is offline
post #23357 of 34890 Old 01-22-2012, 01:30 PM
Anyone else who may have heard them?
post #23358 of 34890 Old 01-22-2012, 02:02 PM
BuGsArEtAsTy's Avatar
Quoted: 386 Post(s)
Liked: 170
Originally Posted by Mkard View Post
BGAEAT,
I have monitor 7's and have been looking at things here and elswhere for a while. I'd have a hard time suggesting the 190.
I've been trying to run a cc-170 with original Monitor 7's in a large high-ceilinged room. No go. The cc just couldn't keep up. Couldn't do it whith Monitor 7 v.2's either. With the v.2's I took the opportunity to take the center speaker out of the system and re-calibrate. Imaging across the screen is probably better than with an inadequate cc inplace. Shrug.
The Paradigm site is very annoying. I usually have to send an e-mail support request for questions or data sheets on older equipment. Some folks there are very decent to persons like myself who know little. Often, not even what the question is.
Looking at data sheets for the cc0150 vs. cc-190, I am pretty sure that you would hear an improvement. The real difference, IMHO, would be getting into a cc-290 or better. The data sheets and photo's show that they are made very differently from the cc-190. I would be tempted to break out the saw and some sandpaper and stain, install the 290 (wth, while you're at it), or even the impressive Monitor 390, and just let them all figure it out. Or, save a little coin and see your your sytem responds to a phantom center using just your excellent L/R's. I am impressed with both my Yamaha AVR's and their abillity to create center effects and dialog on both my Monitor's and on Monitor v.2s. I put the cc speaker "for sale" on the local market. Yes, that is when us mere mortals notice, really see the clarity and image effects that are taking plac.
Well, the second cone in that CC-150 has blown. However when I checked, it seems the first blown one I "fixed" last year has acquired a slight tear in the foam. The problem is that Krazy Glue acts as a solvent for the foam rim, thereby weakening it. However, I have fixed the second blown cone the same way for interim use.
Luckily Paradigm has since updated the centers to deal with the size issue. I am now leaning towards replacing it with a Center 3 to match my 1990s Monitor 7s, unless you guys and gals have better suggestions (or if the price is insanely high).
After drilling new shelf holes I now have about 8.75" x 24" for space in my AV cabinet. (Depth is not really an issue.)
BuGsArEtAsTy is offline
post #23359 of 34890 Old 01-22-2012, 03:11 PM
Quoted: 386 Post(s)
Liked: 170
P.S. I am trying to figure out which series of of Monitor speakers I have. I bought them in the 90s. My Monitor 7 speakers just say "Monitor 7" with no v.X anywhere. Same goes for my CC-150. Does that mean they're the original Monitor 7 and CC-150? What year did they come out?
The Monitor 7s say they're compatible with 15-175 Watt, with a max of 120 on typical material. At least in that respect they seem like a match to the Center Channel 3.
The spec of the CC-150 is similar to the Center Channel 1, compatible with 15-120 Watt, with a max of 80.
post #23360 of 34890 Old 01-22-2012, 03:27 PM
mgproudfit's Avatar
Quoted: 40 Post(s)
Originally Posted by mgproudfit View Post
How do people feel about the Monitor 7 vs. Monitor 9. Ive heard some reviews actually state they thought the 7 sounded better. Im talking in the most recent Version 7. I will be getting a pair to go with my Atom Monitor V7's within a few months and wanted to see if anyone has feedback. Thanks!
Matt
reposting for insight
mgproudfit is offline
post #23361 of 34890 Old 01-22-2012, 10:48 PM
rishitiw's Avatar
I went through the dilemma of M9s vs. M7s (series 7). Ended up picking M9s for the following reasons:
  1. More detailed sounding than M7s
  2. Better/punchier bass
  3. I prefer the rule of getting a bigger speaker, if possible
rishitiw is offline
post #23362 of 34890 Old 01-22-2012, 10:52 PM
rishitiw's Avatar
I have paired Monitor 9s (series 7) with Denon 1911 AVR and am keen now explore a stereo amp. Would the folks on this forum have an opinion on which stereo amp should I check out? I have heard NAD goes well with Paradigms while some people say Marantz makes them appear brighter. I am fine with a bright sound (though not on the lines of Klipsch).
Any suggestions?
rishitiw is offline
post #23363 of 34890 Old 01-23-2012, 07:18 AM
mgproudfit's Avatar
Quoted: 40 Post(s)
very cool. thanks man!
post #23364 of 34890 Old 01-23-2012, 09:27 AM
Kalani's Avatar
Quoted: 113 Post(s)
Liked: 26
Any suggestions?
Do you mean instead of your Denon 1911? The 1911 does not have pre-outs, so you can't just add an amp, you'll need to entirely replace the entire AVR if you want an upgrade.
Marantz and Denon both use the same amp... they're both part of the same company. Very minor differences between them.
Onkyo AVRs have a more robust amplifier section than the Denons do, and otherwise similar features (not entirely, but you have to decide which features you want most). Or if you went with a Denon 3312 you could see how well that does for you, and add an external amplifier like an Emotiva, for instance, to have all the power you could want. Both Denon and Onkyo use Audyssey, considered the best room correction out there.
Kalani is offline
post #23365 of 34890 Old 01-23-2012, 11:28 AM
Quoted: 386 Post(s)
Liked: 170
SE Center vs. Center 3...
What are their manufacturer recommended sales prices?
I had thought the MSRPs in the US for the two are $499 and $599 respectively.
However, in Canada, I think the MSRPs are $649 and $619.
Is that correct?
BTW, I have room for either of these models. Which would you consider?
post #23366 of 34890 Old 01-23-2012, 12:02 PM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 168
SE is 2 db less sensitive, requiring 40 watts less power.
Eyleron is offline
post #23367 of 34890 Old 01-23-2012, 01:26 PM
Venomous's Avatar
Any suggestions?
You need a big boy avr. I would look at the Denon 4311CI.. It has enough power not to need a external amp. If down the road you choose to add one, it has the ability to assign internal amps to whichever speakers you choose. Yamaha can't do this like the Denon can. It also has audyssey xt32 room correction. High quality avr that will fit your needs. What exactly is your budget for an avr?
Venomous is offline
post #23368 of 34890 Old 01-23-2012, 05:22 PM
Kalani's Avatar
Quoted: 113 Post(s)
Liked: 26
Is that correct?
I have the SE Center, and like it. MSRP for the SE Center, late 2011, was $600 (or $599, whatever).
Kalani is offline
post #23369 of 34890 Old 01-23-2012, 06:59 PM
Quoted: 386 Post(s)
Liked: 170
It turns out the Canadian MSRPs for the Center 3 and SE Center according to my local shop are CAD$599 AND CAD$679. That meant that the actual take home price for the SE Center ended up being a fair bit more costly. Also, since it's going into an AV cabinet I was hoping for a sealed box, but none had it. All of them - the Center 1, Center 3, and SE Center, are rear ported.
So, I ended up just ordering the Center 3. I hope to have it in a few days. Hopefully it should match up with my Monitor 7 speakers well enough. I believe they're the original Monitor 7s, because they don't have the v.X on the label anywhere. That makes them, what, 15 years old? (I can't remember exactly when I bought them, but it was in the 90s.)
I will admit though I'm a wee bit disappointed they're no longer made here, since I live in the same province as where Paradigm is located.
You mean the SE requires more power. My Sony receiver isn't so strong, so having less power requirements would be a good thing, so advantage Center 3... unless I'm totally confused.
post #23370 of 34890 Old 01-23-2012, 07:25 PM
Snoopy10's Avatar
Hello
I'm purchasing 2 monitor 7s with a center 3 and want to know if I'm making a good choice on receiver . I'm thinking about purchasing a Pioneer 1021 or 1121 are they good choices? I fill like I'm not spending enough considering the speakers will come out to $2200.00 compared to the unit $300.00
Snoopy10 is offline
Reply Speakers
Paradigm , Speaker Systems
