Paradigm Owners Thread - Page 780 - AVS Forum | Home Theater Discussions And Reviews
 883Likes
Old 01-23-2012, 08:31 PM
The_Spyder's Avatar
Originally Posted by Kalani View Post
Do you mean instead of your Denon 1911? The 1911 does not have pre-outs, so you can't just add an amp, you'll need to entirely replace the entire AVR if you want an upgrade.
Marantz and Denon both use the same amp... they're both part of the same company. Very minor differences between them.
Onkyo AVRs have a more robust amplifier section than the Denons do, and otherwise similar features (not entirely, but you have to decide which features you want most). Or if you went with a Denon 3312 you could see how well that does for you, and add an external amplifier like an Emotiva, for instance, to have all the power you could want. Both Denon and Onkyo use Audyssey, considered the best room correction out there.
Sorry big guy best room correction easily goes to anthem arc. Its not even close
The_Spyder is offline
Old 01-23-2012, 08:42 PM
BuGsArEtAsTy's Avatar
Quoted: 326 Post(s)
Liked: 148
Originally Posted by Snoopy10 View Post
I'm purchasing 2 monitor 7s with a center 3 and want to know if I'm making a good choice on receiver . I'm thinking about purchasing a Pioneer 1021 or 1121 are they good choices? I fill like I'm not spending enough considering the speakers will come out to $2200.00 compared to the unit $300.00
This may be sacrilege to some, but I tend to spend less on receivers and more on speakers. Those Pioneers will be fine, unless your usage is out of the norm.
Hell, I've got a Sony STR-DG800 hooked up to Studio 60s and a Studio CC, Titan surrounds, and an SVS PB-13 Ultra and it all sounds great together. Mind you the room isn't huge, and I don't crank to crazy volumes.
BuGsArEtAsTy is offline
Old 01-23-2012, 08:44 PM
Snoopy10's Avatar
I can always downgrade the speakers to titan monitors and center 1 so I can buy a more expensive receiver.
Snoopy10 is offline
Old 01-23-2012, 08:47 PM
Snoopy10's Avatar
Do you guys think I'm getting a fair price? Dealer wants
$782 + tax for monitor 7s FMV 900.00
$1042 tax for monitor 9s FMV $1198.00
$520.00 + tax center 3 FMV $600.00
Snoopy10 is offline
Old 01-23-2012, 09:40 PM
rishitiw's Avatar
Kalani,
What I want is to have an integrated amp (pre + power, not an AVR) to allow for a more "musical" experience. Hence, not looking to upgrade my AVR to a higher version. I would like to go for a separate integrated amp altogether which I can keep switching to for my music needs.
Cheers
rishitiw is offline
Old 01-23-2012, 09:50 PM
grasshoppers's Avatar
Quoted: 802 Post(s)
Liked: 506
Check out the Outlaw Audio rr2150. I use it for 2 channel music listening
with a pair of Paradigm Studio 40's (v4).
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is offline
Old 01-23-2012, 10:05 PM
Quoted: 326 Post(s)
Liked: 148
Nah. If you have limited funds, get the better speakers. You can always upgrade the receiver a few years from now, and it will be a cheaper upgrade, and by that time there will be some new format that you might want. Electronics often go out of date in a few years, but good speakers can last decades. 20 year old speakers can play Dolby Pro Logic, DD 5.1, DTS, and uncompressed audio via HDMI. However, to support those in your receivers over that same period you would have had to upgrade your receiver several times.
I've been out of the loop for a while, but are we allowed to post discounted pricing now? I thought it was just MSRP.
Old 01-23-2012, 10:11 PM
rishitiw's Avatar
Originally Posted by Venomous View Post
You need a big boy avr. I would look at the Denon 4311CI.. It has enough power not to need a external amp. If down the road you choose to add one, it has the ability to assign internal amps to whichever speakers you choose. Yamaha can't do this like the Denon can. It also has audyssey xt32 room correction. High quality avr that will fit your needs. What exactly is your budget for an avr?
Thanks for the inputs. However, as mentioned to Kalani too, I am looking to add a separate integrated amp for pure stereo sessions. So not sure if I want to upgrade my AVR. I have heard (pun unintended) that stereo amps are so much better for 2.0 than the AVRs and I want to check that path.
I am not looking for a very high end integrated amp so I would ideally like to keep my budget within 30K Indian rupees (INR) which translates to ~600 USD. Unfortunately, the pricing in India sucks vis-a-vis US. One way to look at it is that the Denon 1912 retails for 45k INR which is ~900 USD
So may be if you can give me some pointers to suitable integrated amps (NAD 326?) I can do the further auditioning.
Cheers
rishitiw is offline
Old 01-23-2012, 10:14 PM
rishitiw's Avatar
Unfortunately, Anthem is way way outta my budget
rishitiw is offline
Old 01-23-2012, 11:45 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
I've heard good things about that, of course, but since the poster was coming from a Denon, I was giving him the lay of the land with the more traditional brands, in case that's what he's looking for.
That said, do you have any links to reviews that out ARC head to head with Audyssey MultiEQ XT or XT32? I'd be curious to read them.
Kalani is offline
Old 01-24-2012, 12:29 AM
DenonLover's Avatar
Quoted: 176 Post(s)
Liked: 40
+1 I too would love to read up on the differences Arachnid.
Samsung 75” 4k UHD 8550 | Oppo BDP-105D | Paradigm Studio 100's v5 (Mains Bi-amped) | Paradigm Studio CC-690 v5 (Center) | Paradigm ADP-590 v5 (Back) | SVS PB13-Ultra (x2) | Marantz AV-7702 mkII pre/pro | Emotiva XPA-2, XPA-3, XPA-5 | Harmony Ultimate Home Remote
DenonLover is offline
Old 01-24-2012, 07:30 AM
oztech's Avatar
Liked: 101
The thing that bothers me is the amps in the Anthem receivers being somewhat anemic compared to Pioneer and Marantz for the price of these things and this is from a company that makes some of the most powerful separate amps in the industry.
oztech is offline
Old 01-24-2012, 10:02 AM
PlethoraGreen's Avatar
Agreed.
Before I bought the 809 I looked into the Anthem's because my local dealer recommended them with the Paradigms I purchased. A few things didn't sit right with me as I had a hard time spending $2k for a receiver that needed to be updated via computer to USB and that required the user to set speaker distances manually. I listened to them and they sounded great, however, would never fly in my home network because the features just aren't up to the current times yet. Maybe the next line will be more modern.
PlethoraGreen is offline
Old 01-24-2012, 11:45 AM
hays0023's Avatar
I am curious for any one to chime in....
I currently have a 5.1 system with Paradigm Signatures S8, C5 and S2. I have been contemplating going to a 7.1 system and found a great deal on a pair of S4's. Would this be overkill? Would it be best to hold out for a pair of the Signature ADP's? All of mine are V1, so I am concerned that if I go with either V2 or V3 that the sound will not be matched.
Any input is greatly appreciated!
Thx in advance!
hays0023 is offline
Old 01-24-2012, 11:47 AM
mjpearce023's Avatar
Quoted: 34 Post(s)
Liked: 38
Kal Rubinson did a test with ARC and Audyssey and they both did a great job. Its a good read if you want to check out the article. It didn't seem like either one has a big advantage over the other. I have seen Kal post that he prefers XT32 over the ARC version found in the MRX receivers but I don't have time to search for the thread right now.http://www.stereophile.com/musicinth...itr/index.html
mjpearce023 is offline
Old 01-24-2012, 12:57 PM
Venomous's Avatar
Thx in advance!
If you listen to any multi channel music, those adp's are gonna kill it for you.
The beauty about surround setups is, you don't need large speakers for anything but the main LCR channels. I run studio 20s for my left and right wides and 10s for front height, rear height and rear surrounds. The best thing is with multi channel music, it all matches.
If you want to save some cash and music isnt going through the system, mirage omd5s work well for 7.1 additions.
Venomous is offline
Old 01-25-2012, 08:07 AM
mde8965's Avatar
Quoted: 24 Post(s)
A couple of questions:
I have Studio 100's V1 in one setup and Studio 60's V2 in another setup.
Right now I run a couple of Studio CC2's for centers.
I picked up a couple of CC-570's V3 for next to nothing without grills and one with a bad tweeter. For $100 in parts I can have them up to snuff. Then I would have less than $350 total into both center speakers.
1) Would these be a good enough match for my 100's and my 60's?
2) Would it be worth the upgrade considering the low price point?
One other question - I currently run Polk Monitor 40 surrounds in a 5.2 system with my 60's. I can get a pair of Studio 20's v3 which need some repairs ($40 in parts) and have some cosmetic issues for $100. Would this be a worthy upgrade? I listen to a lot of multi channel music. Guessing this is a Yes.
Main System: Denon AVR-4311ci; Emo XPA-5, Panasonic TC-P65ST50, Oppo BDP93, PS2&3, Wii, Sonos Connect, Mede8er, Roku 3
Ascend RAAL Towers, RAAL Horizon Center, Sierra 2's (surround), Def Tec SM350's (rear surrounds), 2 Rythmik F15's
2 other systems: 1 Onkyo, 1 Denon, Paradigm Studio V1 and V2 speakers, Panasonic Plasmas, etc.
mde8965 is offline
Old 01-26-2012, 01:31 PM
Stylz25's Avatar
Hey guys I was wondering if it is well worth it to upgrade from the Paradigm Monitor line to the Studio line???? Can some people who have done this comment on the improvements??? Hard to justify the $ if the difference in sound quality is minimal! I am very curious or is it just worth it to jump right to the Signature line? lol Thanks guys! I will have to go demo some Stuidos at my local shop!
Oh and what do you guys use for your Receiver to run the Studio's? Curious since my local shops just say Marantz and Anthem are good since they carrey those of course!
I am currently using an Onkyo AVR to power my Monitor line and the salesman told me to change my AVR immediately! lol thought it was sort of funny! Salesman I tell ya!! haha
Stylz25 is offline
Old 01-26-2012, 01:47 PM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1800
I upgraded from Monitor 7v4s to Studio 60v4s and I would say that, overall, it was worth it.
The S60s aren't as "bright" or "open" at the top as the M7v4s, but they have better midrange and a stronger bottom end, so the sound is a bit "warmer" and they're much better for the occasional straight (i.e., "Pure Direct" mode) two-channel listening. Also, the S60s can be pushed harder/louder than the M7v4s before becoming shrill or fatiguing.
The most satisfying part of the upgrade from Monitors to Studios, however, was the move from my old CC-370v3 - a solid CC speaker - to the CC-690. It's a beast and it sounds beautiful!!
I run the S60s off my Marantz SR6003, and the CC-690 plus my Studio 20v4s off my Emotiva UPA-5. The Marantz has no trouble handling the S60s.
eljaycanuck is offline
Old 01-26-2012, 03:05 PM
The_Spyder's Avatar
I upgraded and it was worth every penny. Music in movies comes out magnificant while still carrying that big punch. I would never go back to the monitor line after having these babies. You do need to up the amp to make them work properly. if you are heavy into music you need a 2 channel power amp forsure like an A2 from anthem.
studio 60s, cc590, sa 10r in ceiling rears, sub 12 and mrx 700
Old 01-26-2012, 10:52 PM
Quoted: 326 Post(s)
Liked: 148
I got the Center 3 today. The sizing is really nice for my setup as it's about the same width as my previous CC-150. It's hella deeper, and somewhat taller, but it's nowhere near as humungous as the CC-390 was and it's not even as big as the CC-290.
Not surprisingly, it sounds way, way better than the CC-150. Very clean-sounding, and it doesn't fade to bleah at the low end like the CC-150 did. It's not quite in the same class as my Studio CC in the other room, but nonetheless I'm quite pleased with the Center 3 given the huge difference in price between the Center 3 and the Studio series.
Before I got this I was wondering why Paradigm didn't release an in-between Center 2. However, it does seem to make sense to me now. In terms of street pricing it is a couple of hundred $ more than the Center 1, but it's also a huge jump in specs, and I suspect a significant jump in quality and range, but without the huge jump in width. In that context, the hypothetical Center 2 becomes somewhat redundant.
The only issue with the Center 3 I've noticed is the slight boominess I can sometimes get with it located in my AV cabinet. As I suggested earlier, I suspect it's due to the rear porting of the Center 3 - not necessarily ideal for a partially enclosed space. I suspect the Studio CC-490 would be better in this regard, but then again it is also rear ported, and it costs almost twice as much. Considering my Center 3 already cost as much as my 42" plasma TV, I figured its pricing was much more appropriate for that system.
P.S. The GF really loves the Center 3, because of its musicality. The CC-150 was simply lacking at the bottom, and the Center 3 fills that range in nicely. It's also quite responsive, without being overly bright. In fact, I think it's crisper than my Monitor 7 speakers. However, my speakers are I believe the first version of that model from 15 years ago or so.
Old 01-26-2012, 11:49 PM
Venomous's Avatar
Hey bugs, just make sure to keep the rear ports away from the wall,,it will reduce the boomness you hear. My cc690 is a monster and I had to keep a good foot away from the wall not to have any boom. Glad our happy with the new center
Venomous is offline
Old 01-27-2012, 12:01 AM
gerald-gt's Avatar
If its not possible to keep the rear ports away from the wall (in your AV cabinet), you could try stuffing some old socks in the ports to tame the boom.
gerald-gt is offline
Old 01-27-2012, 06:45 AM
Quoted: 326 Post(s)
Liked: 148
Yeah, I think the rear of my Center 3 is about 8 inches or so from the back of the cabinet, but even if it was 12 inches away, it wouldn't account for the fact that it's an enclosed space.
This is what the CC-150 looked like in the cabinet.
(Click to enlarge)
I raised the top shelf an inch to fit the Center 3, but otherwise it's the same configuration.
Actually, one solution I suppose would be to cut a hole in the back of the cabinet, but I don't really want to do that. I'll try stuffing some cut foam into a port (or two) to see what happens. Hopefully it doesn't negatively affect the bass too much. Actually, the boominess isn't that bad as is. I just notice it when the volume is cranked up, but at lower volumes it's much less of an issue. With the CC-150 it didn't seem to be a significant issue, probably because it was missing much of the bass to begin with.
Old 01-27-2012, 07:32 AM
Quoted: 326 Post(s)
Liked: 148
My SVS PB13-Ultra has three front firing ports, and came with foam port plugs to help attenuate boominess in rooms susceptible to it.
I went searching for foam speaker plugs on the net and came across a thread discussing how some speaker manufacturers will include custom sized foam plugs for rear ports of their regular speaker lines too (not just subwoofers). In fact, one even provides plugs that are hollow in the middle so they attenuate less than what a solid plug would.
So I went searching around the department and found some shipping foam that's perfect for this. One shipper has 0.8 cm thick foam sheets (on right of picture below) that they use to ship fragile stuff to us.
You could roll those up to create hollow port plugs. Plus, depending how much of the sheet you use, the hollow portion could be very small, or bigger. Perfect.
Old 01-27-2012, 09:24 AM
angryht's Avatar
Plugs in the ports. That is interesting. Would this be a good idea for a small room in my CC270 (rear port) and Focus (also rear port). Are there some links that discuss this?
-Greg
angryht is offline
Old 01-27-2012, 10:02 AM
Quoted: 326 Post(s)
Liked: 148
http://www.avsforum.com/avs-vb/showthread.php?t=1315831
http://www.stereophile.com/content/p...-playing-ports
Old 01-27-2012, 10:21 AM
ttodd1's Avatar
I have a quick couple of questions. I have a cc-190 v4 and came accross some Mini monitors v1. Will these work ok together or will there be a noticable difference. Also if these would work together what would be a good sub for me to look at to add to this?
ttodd1 is offline
Old 01-27-2012, 10:31 AM
angryht's Avatar
angryht is offline
Old 01-27-2012, 11:13 AM
Quoted: 326 Post(s)
Liked: 148
I'm guessing they should work fine together.
http://www.paradigm.com/joomdoc/prod...eater/download
As you can see from my previous posts I'm now using v.1 Monitor 7s with the new Centre 3, and they are quite different in design, but nonetheless sound pretty good together.
Paradigm , Speaker Systems
