Paradigm Owners Thread - Page 798 - AVS Forum | Home Theater Discussions And Reviews
 883Likes
Old 02-23-2012, 12:05 PM
Venomous's Avatar
So they no longer sell the dome portion of the tweeter separately, so I have to buy the entire mid/tweet section for the cc690 for about $350. He also said they would sell me the beryllium tweeters if I wanted them for my 100s.
Venomous is offline
Old 02-23-2012, 12:15 PM
MKaram's Avatar
I have LCR Sig V1's
Anybody know if I can upgrade the tweeters to Be?
EDIT: Update from Paradigm, they say no.
MKaram is offline
Old 02-23-2012, 01:22 PM
weird 23's Avatar
Quoted: 12 Post(s)
Nice, are you going to go for it? When I owned the 100's and 690 I seriously debated doing the same thing.
weird 23 is offline
Old 02-23-2012, 03:12 PM
Venomous's Avatar
Yeah I am, just sucks that I'll know the current crossover isn't the proper one for the beryllium tweeters. At least the mesh around the tweeter makes the upgrade appear to be a safety feature, lol
Venomous is offline
Old 02-23-2012, 04:36 PM
mbfleming's Avatar
Liked: 52
Today I went to a local Paradigm dealer in Calgary to order a new blu-ray player only to find they're closing their doors in two weeks. Calgary is down to one dealer with a single store - General Audio on Centre Street. What's unclear is who is going to sell the lower product lines because General Audio has only carried the Reference and Signature lines until now.
This might be an opportunity to get a good deal on their remaining inventory of Paradigm speakers.
Calgary's Soundsaround Closing For Good
http://www.marketnews.ca/LatestNewsH...ngForGood.html
mbfleming is offline
Old 02-23-2012, 04:38 PM
Bboy_jonno's Avatar
Hi guys I have a question -
I am getting a Monitor 11 set up and I am going to have front height and wide channels too. the highs are Atoms and the wides are Mini Monitors.
My question is regarding the driver, the Atoms match the Monitors 5.5" mid driver, while the Minis match the Monitors 6.5" woofer. Is this a good match or should the wides match the Monitor 11s mid driver instead of the woofer?
Bboy_jonno is offline
Old 02-23-2012, 04:56 PM
cjsiv's Avatar
Liked: 33
I don't think it really matters. Highs as wides are just for effects. Not very crucial to your overall setup. I would be most concerned with the L/R/C.
cjsiv is offline
Old 02-23-2012, 05:04 PM
xSoMBrAx's Avatar
Originally Posted by mgproudfit View Post
Your top pic is V6, bottom is V7. A lot of folks think the V7 changes are worth the price increase, but the V6 is still an outstanding speaker.
-Matt
Thank you mgproudfit
I will try to find the V7 around here and check the prices and If I can't find them will just order the V6.
Would you recommend an amp for them?
I would like to complete the system with a Paradigm cherry bass?
xSoMBrAx is offline
Old 02-23-2012, 05:33 PM
weird 23's Avatar
Quoted: 12 Post(s)
Do they carry the Sig line? I'm looking for a set of ADP 3's in cherry.
weird 23 is offline
Old 02-23-2012, 05:36 PM
Bboy_jonno's Avatar
cool, thanks for your reply.
Old 02-23-2012, 06:00 PM
mbfleming's Avatar
Liked: 52
Soundsaround doesn't carry the signature series.
Old 02-23-2012, 06:29 PM
Screen Shot's Avatar
What size room is the listening area ?
The room is 14 x 23.
I think my post asking for opinions on the Cinema 5.1 system were lost in all the posts on punctuated tweeter domes.
Screen Shot is offline
Old 02-23-2012, 06:35 PM
weird 23's Avatar
Quoted: 12 Post(s)
Thanks for the info.
weird 23 is offline
Old 02-23-2012, 07:18 PM
txsteel's Avatar
I could use some feedback from some knowledgeable people.
I have an opportunity to purchase a set of Studio 100 V3 and a CC690 for a great price. I have a dedicated movie room of 13x16 with a 104 projection.
I will be replacing my front stage that is made up of Polk in walls LC265I and matching center. They sound good, but the Studio should e a big improvement.
Concern 1: I currently am using a Denon 2808CI which from what I read will struggle to drive the 100's. I'm thinking of bi-amp them for now with the 2808 and later adding a separate amp later. What do people think on here of using a Behringer pro amps? Do not want to spend more than $500 for a new amp if not needed.
Concern 2: My screen is on the 13 wall next to the door opening, so the speakers almost have to be a couple inches from the back wall and less than 12 inches from the side walls. I will toe them in, but concerned on their response being so close to the wall.
Thoughts and opinions welcome.
txsteel is offline
Old 02-23-2012, 08:37 PM
cjsiv's Avatar
Liked: 33
Ok. I haven't heard the Cinema setup so take this with a grain I salt. If it were me, this is my thoughts before I buy:
If you just want nice sound with movies and something better than the TV speakers it will probably be ok. If I'm dropping $1000, I want better than ok. The sats are kinda small and the sub only goes down to 32hz. That is a pretty good size room to fill. I have not heard it, so this is my speculation. If someone else has heard the cinema 100, please chime in.
I would probably buy mini or atom monitors and pair it with a center-1. Then buy a sub from someone like Hsu. I do believe the center is $350 and the minis are $500. You could go with atoms and they would give you a little more cash for the sub without going over your initial $1000. You could use almost anything for surrounds for now and upgrade them later. I don't feel they are that important. Or if you went with atoms or minis, you could move them to surrounds and upgrade to monitor towers later. You get the point.
I think you will be happier performance wise with both movies and music. But if aesthetics or the WAF is what counts, if I were buying a small sat/sub setup, it would be high on my list as long as you are ok with the price.
My 2 cents. Good luck!
cjsiv is offline
Old 02-24-2012, 10:14 AM
JohnAV's Avatar
Quoted: 299 Post(s)
Liked: 449
I have an opportunity to purchase a set of Studio 100 V3 and a CC690 for a great price. I have a dedicated movie room of 13x16 with a 104” projection.
Concern 1: I currently am using a Denon 2808CI which from what I read will struggle to drive the 100’s. I’m thinking of bi-amp them for now with the 2808 and later adding a separate amp later. What do people think on here of using a Behringer pro amps? Do not want to spend more than $500 for a new amp if not needed.
Concern 2: My screen is on the 13” wall next to the door opening, so the speakers almost have to be a couple inches from the back wall and less than 12 inches from the side walls. I will toe them in, but concerned on their response being so close to the wall.
The AVR-2808 thread has posts of people using 4 ohm speakers without issues. Like other large speakers they say studio 100's are 8 ohm compatible, but most vary down to 3 to 4 ohm at lower bass frequencies. No different then say a B&W 683/CM9 for example. The studio 100's are rated sensitivity 93db in room, 90db anechoic. This doesn't mean that it takes a powerful amp to drive them, just that because of their power rating of 230 watts input, you can drive them louder with a powerful amp. Your 2808 is rated at 110 watts/ch 8 ohm, 140 watts/ch 6 ohm should be fine considering only one watt produces approx 93 db at 1 meter in room. When your ready for a more powerful amp, these speakers will open up better dynamically.
There is no problem with the studio 100's fairly close to the wall, as there is no port on the rear like the studio 60's. The CC-690 does have two ports on the rear so try to have that a few inches away from the wall if you can.
Skip the bi-amp, not going to buy you anything.
Oppo Beta Group
JohnAV is online now
Old 02-24-2012, 10:28 AM
Venomous's Avatar
I don't know if Struggle is a proper word. I think people fail to realize that if they are going to step up to nice speakers, they should step up the equipment to drive them if it's questionable. They end up driving the receiver/amp so high that it begins to clip, damaging the speakers. It doesn't take a lot of wattage to drive the 100s for them to get loud.
Venomous is offline
Old 02-24-2012, 10:35 AM
txsteel's Avatar
Thanks for the replies. The Polks I'm driving are 4 ohms and have had no issue driving them hard, which I barely do. From the comments I'll not worry about getting them and up grade to seperate amps later in the future.
txsteel is offline
Old 02-24-2012, 10:44 AM
Blackdevil77's Avatar
Quoted: 229 Post(s)
Liked: 118
I definitely need some better power in the room I have now. I'm not too worried about it because everything will soon be moved into a dedicated theater room, but for the past 6 years or so, the room I had my home theater system in, must be suffering from severe voltage drops. I'm driving my Paradigm Monitor 7 V3's with matching center and surrounds with a Marantz SR 7500 and whenever someone turns the lights on or off, or if I even change the input on my TV (go from HDMI 1 to HDMI 2 for example) The sound will drop for a split second and the display on the Marantz will read "no audio." Then it'll come back on. This happens EVERY TIME I turn the lights on or off, the fan on or off, or turn anything on or off in the room. Before the Marantz, I had an Onkyo receiver (forget the model) and these voltage drops did it in. My Marantz seems to hold up stronger to this, but I still hate it and have no way around it really for the time being.
At least the theater room will have a dedicated circuit just for the receiver/future amp/amps.
Seaton Sound Catalyst 12C's and Sparks For Sale
http://www.avsforum.com/forum/209-au...yst-12c-s.html
Blackdevil77 is offline
Old 02-24-2012, 10:50 AM
cjsiv's Avatar
Liked: 33
Unlike the studios, the monitors are relatively efficient, correct? I am driving mine with a Denon 1910 and I was under the assumption that it had plenty of power for my monitor v6 setup since they are 8 ohm 94 db speakers. I am kinda torn right now between getting a new sub or a new receiver and a separate amp. I'm happy with the receiver and was leaning towards the new sub.
cjsiv is offline
Old 02-24-2012, 11:38 AM
JohnAV's Avatar
Quoted: 299 Post(s)
Liked: 449
Probably the improved power supply in the Marantz being able to operate for a second during a voltage drop, still that's a awful situation due to the room wiring and loading.
Should make quite a difference.
Oppo Beta Group
Old 02-24-2012, 11:41 AM
brianlsu's Avatar
While a voltage drop is normal when high load or amperage equipment is turned on. What you have is not normal. You need to check the outlets first for good connections, or change them out. Then check your main for a good ground connection. Have an electrician over and do a check on both for you.
I had the same thing after redoing my house and it was the main. The ground, which probably hadn't been touched in 30 years, was loose.
brianlsu is offline
Old 02-24-2012, 11:48 AM
rnrgagne's Avatar
Quoted: 49 Post(s)
Liked: 56
1. The 2808 should be fine in that sized room, bi-amping them shouldn't be needed but won't hurt. For $500 you might get more mileage out of adding a sub and crossing over your mains to it.
2. The closer to the corners you put speakers the more the bass is enhanced, Audyssey will be able to help compensate a bit. A good rule of thumb is you shouldn't have your tweeters the same distance from side walls as the back wall. Since you can't play with width, the only option you have is moving them forward/backward and toe-in.
The best way to postion your mains is to sit in the main listening position, put on a 2ch CD you're very familiar with, use pure direct and start experimenting with their placement . Try to get the best bass balance and imaging, you want it to almost sound like you've got headphones on at that postion. Then run Audyssey and you're good to go.
Assuming of course you can move them forward and not interfere with the line of sight to the screen, otherwise toe-in is your only option.
rnrgagne is offline
Old 02-24-2012, 12:14 PM
Yes, aesthetics and looks are very important in the family room. For serious music listening and movie watching I have a separate home theater.
I am looking at both the Cinema Series and Millennia One Series. I listened to the Millennia One and liked it a lot, however, I'm not sure I want to spend almost $3K. The $1K price point of the Cinema Series is obviously much more attractive.
Old 02-25-2012, 03:34 AM
xSoMBrAx's Avatar
Hello everyone.
Could someone give me some amp suggestions to pair with Atom Monitor V6?
This is going to me my first amp and passive speakers ever so still quite lost, read a lot but still a lot to choose from and I don't have local shops to audition (live in a island :s)
Thanks...
xSoMBrAx is offline
Old 02-25-2012, 05:50 AM
DenonLover's Avatar
Quoted: 176 Post(s)
Liked: 40
Originally Posted by xSoMBrAx View Post
Hello everyone.
Thanks...
There is a lot we don't know like your budget, and if you meant an AVR or Amp? If you are looking for a AVR I like the Denon 3312 and if you are looking for an Amp I like Emotiva for the price and would take a hard look at the XPA-5.
Samsung 75” 4k UHD 8550 | Oppo BDP-105D | Paradigm Studio 100's v5 (Mains Bi-amped) | Paradigm Studio CC-690 v5 (Center) | Paradigm ADP-590 v5 (Back) | SVS PB13-Ultra (x2) | Marantz AV-7702 mkII pre/pro | Emotiva XPA-2, XPA-3, XPA-5 | Harmony Ultimate Home Remote
DenonLover is offline
Old 02-25-2012, 06:26 AM
xSoMBrAx's Avatar
Yes, sorry about that, I did post all that info but into another section and totally forgot to mention it here
Budget is around 600€ for speakers and stereo amp, 2.0 setup, might add sub sometime but not soon.
I was thinking pairing Yamaha AS500 with Atom Monitor but haven't seen that combo or heard of from owners...
Thank you again
xSoMBrAx is offline
Old 02-25-2012, 06:45 AM
Superman07's Avatar
Quoted: 52 Post(s)
Hello, first post on this forum.
I am looking for a 5.1 speaker system in the $1K range for my family room. Display will be a 50" Pioneer Kuro, and a Pioneer Elite AVR will drive the speakers. This will be used for general television watching, sports, possibly a movie on a rare occasion, and daily music via airplay.
What do you guys think of the Cinema 100 series?
http://www.paradigm.com/products/pro.../cinema-series
I went and listened to the new Cinema series a month or so ago. The sales rep also showed me the Millenia series.
As some background, I really have my eyes set on Studios, but I was looking for something as a stop gap to listen to some music and watch tv/movies that I could eventually shift to another area if/when I purchase some floor-standing speakers (that's an entirely different post).
Anyway, I agree that for the money the Millenia series doesn't seem like the best value. If you're pressed for space and want a good sounding set of speakers than sure you're good. Within your $1k budget I thought the Cinema sounded good as well (with the .1), but then as we moved to the 200s and the 400s I quickly found the 100s lacking. You could always opt for a 200 as the Center and/or the LR as well. However, the 200s and 400s require wall mounting (I believe the bracket is included) and can't be placed on stands unlike the previous Cinema series.
Maybe look at some of the Monitor series to blend in? Does anybody have some thoughts on how a Mini Monitor, CC-190 (v7s) and Cinema 100s (v4s) as surrounds would work out?
Not trying to dissuade you from getting the Cinemas, but I feel like somebody would buy them and then almost immediately be itching to get something more.
Superman07 is offline
Old 02-25-2012, 07:30 AM
philb37's Avatar
Hi,
I have been looking at the milennia 20's, basic quick question, whilst i look through the thread?
Are they any good?
Easy see?
philb37 is offline
Old 02-25-2012, 02:18 PM
BigCoolJesus's Avatar
Quoted: 684 Post(s)
Liked: 378
Update on my Studio upgraditis:
Spoke with my salesman today after he spent most of Thursday talking with his Paradigm rep. My salesman told the rep that he had a client interested in upgrading to the Studio line but was hesitant to do so if a new Studio version was in the works. His answer "We plan on rolling out a new Studio version at CES 2013 which will have trickle down additions from the reference line (one of which should be the corrugated woofers)"
So there ya go, new Studio's will be available at/around this time next year. Looks like I will begin saving up
BigCoolJesus is offline
Paradigm , Speaker Systems
