Paradigm Owners Thread - Page 817 - AVS Forum | Home Theater Discussions And Reviews
 883Likes
Old 03-28-2012, 07:57 PM
The_Spyder's Avatar
Originally Posted by jamie ford View Post
Hello all.
I am considering a used pair of Studio 100 v3's for 2 channel music listening.
Musical tastes range from jam band to jazz to classical.
My concern is whether or not my Pioneer VSX-23 (7.1 a/v reciever with 100 WPC) will be enough to drive them. I don't anticipate running anymore than one set of patio speakers at them same time and would more than likely be just powering the Studio's when doing any critical listening.
Thanks for any and all help/sugestions.
No the pioneer doesn't have the jam. I have a mrx 700 and studio 60s and when I want to do 2 channel and turn it up the amp struggles to deliver
Just add a 2 channel power amp and you'll be fine
The_Spyder is offline
Old 03-28-2012, 08:02 PM
Venomous's Avatar
Originally Posted by rnrgagne View Post
Well no doubt it's to cut costs, but because something is plastic doesn't automatically make it crap.
I'll go out on a limb and suggest that with the plastics of today, you might be able to create a better "acoustically" designed enclosure than with wood. Computer modelled to reduce resonance, maximize/enhance dispertion then injection moulded for a pretty consistent product.
You can make plastic to pretty much any density & rigidity now, so I wouldn't be surprised if a plastic cabinet could be made to perform like the S1's all-aluminum cabinet.
I cant say i agree here, but i have to ask, have you heard the difference between a adp590 and a studio 10? Especially at the same power level? They resonate and distort whether they are playing surround or music at nominal listening levels. The 7 inch woofer is the cause of it.
How much are adp590s again? much are studio 10s? How does paradigm price the adp590 at $800 a pop? Paradigm is making a killing off the cost vs msrp on them.
The 10s are made from wood not plastic and easily outperform the plastic adp's. I know plastics quite well and the density of the plastic paradigm uses isn't exactly stellar. You can tune a plastic enclosure for removal internal resonance. What you can't do is remove distortion and outside flex from the drivers. Even plastic bracing has its limitations.
When I see plastic speakers with acoustic chambers, I automatically think Bose... And we all know how good those sound right?
Venomous is offline
Old 03-28-2012, 09:33 PM
brianlsu's Avatar
ADP's and direct firing speakers like the 10's fit in completely different room's.
Simple examples;
Big room where the distance between the back wall and side walls is somewhat equal to or greater than the viewing distance, you're better off with direct speakers.
Small room where the side walls and back wall are closer than the viewing distance, ADP's work better due to sonic reflection.
I have a small room and the reflection really works well, especially on my front highs, 9.2 setup. The sound in non directional and gives you the impression it's coming from a particular direction but not directly from the speaker.
Big rooms with ADP's create an echo effect that is not preferable, hence direct firing speakers yield much better sonic clarity at the listening position.
And yes, it works wonderfully for multichannel music in my small room.
brianlsu is offline
Old 03-28-2012, 09:39 PM
brianlsu's Avatar
But I do agree, the ADP's are not as pretty as the 10's and 20's. I wish the ADP's came in matching colors.
In my small room, I had no choice. Direct firing speakers would have been hard to fit and would have created a very small optimal position.
brianlsu is offline
Old 03-28-2012, 10:53 PM
Tank_PD's Avatar
Quoted: 114 Post(s)
Liked: 68
Originally Posted by 04rex View Post
Nice set up Tank. That's my dream set up. Any pics at all?
Originally Posted by Tank_PD View Post
I have a few -- I'll try to post some in a bit.
Here are a few from early on that aren't a total mess. Don't have the TV setup in all of them. The other ADP is on the far side of the couch & Sub 1 is over near the far wall. Yes, I know my pictures are crooked.
Tank_PD is online now
Old 03-28-2012, 11:54 PM
Venomous's Avatar
Simple examples;
I understand their use in small room because of furniture that's butted up against walls and such. I think they could of used wood and met the same target weight is all.
Perhaps you do not listen at the same levels I do, but i can shake the **** out of the adp's and make them distort. Recently they have had some issues with the drivers being jacked up as well.
Venomous is offline
Old 03-28-2012, 11:58 PM
Iccy's Avatar
Good question, how much is a pair of 10s?
Iccy is online now
Old 03-29-2012, 06:19 AM
JustBusiness's Avatar
Quoted: 43 Post(s)
I would contact Paradigm/retailer if you are having that big of problem with your adp. I listen fairly loudly, in a large room, and haven't experienced any of this. Have mine crossed at 80hz. I listen to surround music, and movies, and couldn't be happier. I think a vast improvement to the direct/adp setup I was using, now adp/adp
I don't know much about plastic, but I do know that slot of time/money/research goes in to each product digm makes, so I trust their judgement on plastic over wood.
JustBusiness is offline
Old 03-29-2012, 06:34 AM
pstrisik's Avatar
Quoted: 33 Post(s)
Liked: 31
What is this about wood? Do you thing 60's and 100's are made of wood? They typically use MDF and now use cheap vinyl veneer (unless you pay extra for the piano black) instead of wood veneer. I suspect the ADP's have similar construction underneath the plastic "veneer". The 590's are very heavy. Plastic isn't that heavy. Unless they just put a few bricks inside for effect, the construction is substantial.
. . . . . . . . . . . Peter
pstrisik is offline
Old 03-29-2012, 09:15 AM
rnrgagne's Avatar
Quoted: 49 Post(s)
Liked: 56
Better than you'd think for small plastic cubes, and something you couldn't emulate with wood. They get a really bad rap here, and it's mostly value for dollar where Bose craps the bed, but I've had them in my home and their actual performance isn't massively worse or better than most sub-sat systems I've heard.
You can make speaker cabinets out of virtually anything, or nothing, as in open baffle speakers. All I'm saying is the cabinet material can be engineered to taste, and that plastic is not an automatic indicator of lack of quality.
rnrgagne is offline
Old 03-29-2012, 09:24 AM
rnrgagne's Avatar
Quoted: 49 Post(s)
Liked: 56
Right, so the drivers are the problem then not the plastic cabinet?
I haven't heard the ADP590, but that's not relevant to my point. I wasn't saying it would be better than the S1's or Studio 10's...
rnrgagne is offline
Old 03-29-2012, 09:35 AM
John1400's Avatar
Liked: 26
The studio 100s, 60s, 20s and 10's are mdf with a real wood veneer and not a vinyl veneer
John1400 is offline
Old 03-29-2012, 09:44 AM
John1400's Avatar
Liked: 26
I believe the studio's have 7 coats of lacquer and hand sanded 6 times between coats. The rosenuts have a smooth finish and the plain black has a grainy look and feel to them. A vinyl wrap would not produce this effect. Take a micro cloth and it will glide over the rosenut but will catch on the standard black.
John1400 is offline
Old 03-29-2012, 12:25 PM
Venomous's Avatar
Msrp went up a little bit, but they used to be $399 each, but I was able to get my pair for 700 jalapeños, you get a pair of 10s for the price of one adp590
Venomous is offline
Old 03-29-2012, 01:09 PM
BigCoolJesus's Avatar
Quoted: 684 Post(s)
Liked: 378
Just ran PBK on my Sub 25 (along with ARC on my new MRX700)......WOW. Just WOW.
Can I say WOW again?
I only had a chance to demo a few scenes of Tron Legacy before going into work, but it was an experience that bordered on religious in it's own audio meaning. I don't even know how to put into words the new sensation (and new it was, never have I felt the air being energized like this in my room before) that was experienced during "The Grid" scene. I am still somewhat speechless while I am sitting at work typing this.
Definitely going to go home and hook this thing up to it's own dedicated 110v/15amp outlet so it doesn't have to share power with my receiver and projector.
BigCoolJesus is online now
Old 03-29-2012, 01:27 PM
pappaduke's Avatar
Quoted: 137 Post(s)
Liked: 133
BCJ are you done upgrading for a while. Just go home an enjoy
Yamaha 2010
Oppo 103D,ATV3,PS3, Samsung UN60ES7100F, Bluesound Vault 2 and Pulse Mini, Harmony One, Paradigm Monitor 9's, CC-390, 2ADP 390's/190's, 2 PDR 100's. B&W P5
Zone2-Paradigm SE-1's, Zone3-Paradigm-Stylus 370-SM
pappaduke is offline
Old 03-29-2012, 01:32 PM
Quoted: 684 Post(s)
Liked: 378
lol, for the price I got this Sub 25 for I couldn't help but upgrade. Once I sell my Integra DTR-70.3 (which is currently listed on the classifieds) I will have only paid $300-400 out of pocket for this *upgrade*
Not bad if I say so myself. But yes, I am enjoying (well, will be once I am off work).
Old 03-29-2012, 02:19 PM
rwheelwright's Avatar
Quoted: 99 Post(s)
Liked: 33
This is something I need to do but don't have available. Well, that ore a 240v. But before all of that, I need to upgrade my box and get a new line from the street.
rwheelwright is offline
Old 03-29-2012, 02:20 PM
pappaduke's Avatar
Quoted: 137 Post(s)
Liked: 133
In your opinion does PBK make a big difference with any sub or just the higher end subs? I don't know much about this subject.
Yamaha 2010
Old 03-29-2012, 03:26 PM
Quoted: 684 Post(s)
Liked: 378
Even on my DSP and Monitor SUB's of past, it made a pretty significant difference on it's own: coupled with something like ARC or Audyssey, it's even that much better of an end result
Old 03-29-2012, 03:27 PM
Quoted: 684 Post(s)
Liked: 378
I was actually just told otherwise that hooking the subwoofer up to it's own 110v circuit will not make a difference, plus leaving it plugged into the same circuit as my components will help eliminate potential ground loop problems.
FYI.
Old 03-29-2012, 04:19 PM
rnrgagne's Avatar
Quoted: 49 Post(s)
Liked: 56
FYI.
Well in truth it's like eveything else, it depends on a whole lot of factors like room size, listening distance and volume you listen to etc...
But in general that's reasonable advice.
Ground loops aren't all that common, so it wouldn't hurt to try a different circuit if it's convenient.
I wouldn't go out of my way to go to 240v though. When their literature states "maximum continuous volume" it's not really indicative of real world application. No one would listen to 9hz at 125db for any prolonged amount of time... you'd puke... then you'd go deaf...
My room is 14' x 24' with a large opening on one side and I've got everything on the same circuit, my amps total 2250w (3750w if I include the sub) with no issue.
rnrgagne is offline
Old 03-29-2012, 04:37 PM
Stylz25's Avatar
When I use my PBK on my DSP subs it's seems to tame them low too much and it seems to lose its punch! When I take the PBK measurement out of the sub it seems to get my subs alive and have more impact!!!! I think I might be missing something but I paid 100 bucks for my PBK and don't like the results it gives me!! Anything I am missing would be greatly appreciated!
Stylz25 is offline
Old 03-29-2012, 05:00 PM
Scarriere's Avatar
Quoted: 75 Post(s)
Liked: 37
Random question from a random Dude.
I'm getting Monitor 9's, Center 3 and Atoms very shortly *crosses fingers*. I am wondering if a break-in period is recommended. If so, how long and what type of source? Will my ipod on random be enough?
Thank You!
Scarriere is offline
Old 03-29-2012, 05:24 PM
pappaduke's Avatar
Quoted: 137 Post(s)
Liked: 133
Thank You!
You'll probably get a bunch of opinions on this subject. When I purchased mine several months back I was told/read everything from 4 hours to 40 hours. I don't think the source matters but you should break them in. I listened to my set- up for several hours at a moderate volume and then I left the system on over night at a slightly lower volume. Sorry I can not give a more definite answer, but maybe someone else will give some advice based on some facts. BTW the owners manual states several hours before critical listening.
Yamaha 2010
Old 03-29-2012, 05:44 PM
Scarriere's Avatar
Quoted: 75 Post(s)
Liked: 37
You'll probably get a bunch of opinions on this subject. When I purchased mine several months back I was told/read everything from 4 hours to 40 hours. I don't think the source matters but you should break them in. I listened to my set- up for several hours at a moderate volume and then I left the system on over night at a slightly lower volume. Sorry I can give a more definite answer, but maybe someone else will give some advice based on some facts. BTW the owners manual states several hours before critical listening.
Thank you!
I don't think the excitement will reign me in but I don't want to wreck them either. I believe I read here somewhere that 8 hours was essential. Your reply helps me confirm that a break in should be done.
After connecting everything, I'll leave the house for a while with music playing.
Again, thank you!
Old 03-29-2012, 05:48 PM
519audiofan's Avatar
Quoted: 29 Post(s)
Liked: 36
I finally made the jump to the Signature line! This past Tuesday started like a normal work day but an ad on CAM for a pair of v2 S4s and a C3 finished in Cherry caught my eye. As it turns out an installer had these speakers sitting in his warehouse area in their original packaging after to a change of plans during a HT installation a couple of years ago. I made it to his business just after lunch and was pleasantly surprised - these speakers had not been used and even looked brand new. After making sure everything was in working order we boxed them up and I was on my way home. I can't believe the difference over my v4 Studio 40s and CC590. The sound is more detailed and the clarity is amazing - not to mention they look spectacular. The sound for both music and HT are improved. I didn't expect a noticeable improvement for HT but we have watched a couple of HD cable shows and in certain situations like glass shattering or water dripping in a warehouse the sound is more life-like. I haven't stopped smiling yet.
519audiofan is offline
Old 03-29-2012, 05:51 PM
weird 23's Avatar
Quoted: 12 Post(s)
Originally Posted by 519audiofan View Post
I finally made the jump to the Signature line! This past Tuesday started like a normal work day but an ad on CAM for a pair of v2 S4s and a C3 finished in Cherry caught my eye. As it turns out an installer had these speakers sitting in his warehouse area in their original packaging after to a change of plans during a HT installation a couple years ago. I made it to his business just after lunch and was pleasantly surprised - these speakers had not been used and even looked like new speakers. After making sure everything was in working order we boxed them up and I was on my way home. I can't believe the difference over my v4 Studio 40s and CC590. The sound is more detailed and the clarity is amazing - not to mention they look spectacular. The sound for both music and HT are improved. I didn't expect a noticeable improvement for HT but we have watched a couple of HD cable shows and in certain situations like glass shattering or water dripping in a warehouse the sound is more life-like. I haven't stopped smiling yet.
Congrats 519! I'm glad that you found a smoking deal.
What are you doing with your Studio's?
weird 23 is offline
Old 03-29-2012, 06:30 PM
grasshoppers's Avatar
Quoted: 802 Post(s)
Liked: 506
Lucky dog. I'm jealous... Always wanted S4's...ended up
with Studio 40v4. But they are pretty damn good, 2.1 music
set-up.
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is offline
Old 03-29-2012, 07:00 PM
Quoted: 29 Post(s)
Liked: 36
Thanks Weird. I am pretty pumped.
Studio's are for sale on CAM.
Paradigm , Speaker Systems
