New NHT Classic line to replace Super Audio - Page 368 - AVS Forum
 54Likes
post #11011 of 11017 Old 12-22-2014, 02:34 PM
DonnyKerabatsos's Avatar
Quoted: 27 Post(s)
Just checking in to give some impressions of the AT and TwoC set up (though I have yet to install the mounts above my TV, and just have a temporary set up with the TwoC a coupe of feet off the floor, angled up), now that they are broken in and Audyssey has been run and I've lived with them for a bit.
It's not really a fair comparison to the Def Techs I had, since the placement of the fronts (ProMonitor 1000s) was not ideal (on a mantle), and the Center was a smaller 2-way (Procenter 1000). The detail and clarity of the ATs is well above what I was getting before, dialogue from the center is much clearer and I was able to lower the crossover for my sub, so that it integrates better. Overall, very happy with the upgrade, all for a little over $500 out of pocket after finding new homes for the old LCRs.
So far, I've sold off my Promonitor 1000s, but still have the ProCenter to unload, as well as the wall mounts for it.
That brings me to a question for the thread: will I see a benefit from swapping out the Def Tech Promonitor 800s I have as surrounds for Absolute Walls the next time there is a sale? I am going to more properly place the PM800s (currently, only one is wall mounted, and the other is on a table, so I need to wall mount and raise both from ear level to a couple of feet above ear height). If that is just temporary until I get the NHT AWs, I would just use the key hole mounts on my current surrounds (since that is how I would mount the AWs), but if I am sticking with the Def Techs long term, I would hang on to the mounts I have and use them so that I can angle the PM800s toward the MLP. There are hardly any reviews of the AW, but people act like they are nearly identical to the AZs, which do have reviews and measurements.
DonnyKerabatsos is online now
post #11012 of 11017 Old 12-22-2014, 06:54 PM
Randall.White's Avatar
Quoted: 70 Post(s)
Liked: 33
@DonnyKerabatsos , You went about this the same way I did. By upgrading the LCR first and then once I adjusted to the sound of them my surrounds really were awful. They started really standing out that they weren't timbre matched (I know it doesn't matter for surrounds to be) but once they went on sale I bought some more and I couldn't be happier.
I'd say listen to them for awhile and let your self see if you NEED them. I myself would do it all over again. If you listen to music it'll really show then.
Randall.White is online now
post #11013 of 11017 Old 12-24-2014, 08:30 AM
cavchameleon's Avatar
Quoted: 42 Post(s)
Liked: 89
^^^ I totally agree, try what you have first with room correction. You may just be fine with it. If you play multi-channel music, you'll really notice the timbre not matching, but for movies they may just be fine for surrounds.
Also, take a look at both the AZ and the AW's closely. The AZ's are deeper, but smaller in stature. The AW's have the same sound, but are shallower and much taller in stature. The AW's can only be mounted one way, hanging on a screw/nail. The AZ's can use a mount that will allow both pitch and tilt adjustments (this is a big plus as you can aim them towards the listening position). I have both and prefer the AZ's because of this. The choice is yours.
Randall.White likes this.
Ray
"Listen with an open heart and mind."
cavchameleon is offline
post #11014 of 11017 Old 12-24-2014, 08:31 AM
Quoted: 42 Post(s)
Liked: 89
Happy Holidays to You All!!! Have a safe and fun one!!!
jhughy2010 likes this.
Ray
post #11015 of 11017 Old Today, 03:16 PM
CRAW's Avatar
So I want an amp for my Classic 3's... Any cheap suggestions? I'm thinking about Emotiva's UPA-200, but I have the 3C center too. Should I save up for Emotiva's three-channel amp (for movies)? Movies in my opinion sound just fine with my AVR powering the LCR speakers, but for music, the L&R are missing that punch.
Thoughts / suggestions welcomed. TY
CRAW is offline
post #11016 of 11017 Old Today, 04:57 PM
Quoted: 70 Post(s)
Liked: 33
What receiver are you using right now?
I've been eyeing the XPA-3 especially since they've been on sale lately.
post #11017 of 11017 Old Today, 06:20 PM
jhughy2010's Avatar
Quoted: 297 Post(s)
Liked: 88
I don't really think an amplifier is necessary unless you are running anything more than a 9.1 set-up. What AVR do you have? Perhaps invest the money you would in an amp into a newer receiver?
Living room theater set-up:
AVR: Pioneer VSX-1124-K.
Speakers/Sub: (4) NHT Classic Two and an NHT TwoC center + PSA-XV15 subwoofer.
HTPC: z97 mobo, 16GB mem, i5-4440, SSD+HD, LG BD drive, Win 8.1 pro w/WMC + MB3.
Content sources: OTA Winegard HD7698P, Amazon Fire TV Stick, Netflix etc.
HDTV: Sharp LC-60SQ15U (ehhh).
jhughy2010 is online now
Reply Speakers
