New NHT Classic line to replace Super Audio - Page 373 - AVS | Home Theater Discussions And Reviews
 80Likes
post #11161 of 11189 Old 03-23-2015, 07:45 PM
Randall.White's Avatar
Quoted: 115 Post(s)
Liked: 36
^^^ Lol, I think you may of found me out.
I know the UPA-200 isn't ALL that powerful but didn't know if my receiver could handle 7 speakers at once. In my head I was thinking that it would allow my receiver to power the 5 speakers (like it has been doing), maybe I'm over-thinking this whole thing
I'm negotiating the price with him right now. At what price would you guys say it's a good deal and to go for it?
Randall.White is offline
post #11162 of 11189 Old 03-24-2015, 04:09 AM
Transmaniacon's Avatar
Quoted: 736 Post(s)
Liked: 609
I wouldn't pay more than $200 for it.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | BIC F-12
Transmaniacon is online now
post #11163 of 11189 Old 03-24-2015, 06:11 AM
cavchameleon's Avatar
Quoted: 75 Post(s)
Liked: 101
Agreed, don't pay more than $200.
Keep in mind that Emotiva amps have a higher gain structure (higher output for the amount of input) so you'll have to re-run Audyssey with in in your system before making comparison or it'll 'seem' louder for a given volume level. Once you re-run Audyssey, the level's will be the same at each volume level as it was before adding the amp in (and if you remove the amp, you will again have to re-run Audyssey - unless you record the trim levels and adjust them manually - pretty easy to do). There won't be a difference in the frequency/time-domain correction or distances as those are not affected by adding in an amp.
Ray
"Listen with an open heart and mind."
cavchameleon is online now
post #11164 of 11189 Old 03-24-2015, 06:54 AM
Barneyb's Avatar
Liked: 3
Originally Posted by jhughy2010 View Post
I have the TwoC and it pairs nicely with the Three's. If you can afford the ThreeC then go for it... but I think the only real difference is the driver size (which will produce slightly more output). As far as the Threes go... I am more than happy with them. I watched "3 Days to Kill" last night and was absolutely blown away at the output (low end) of the Three's! I have no sub's yet (V1500's will be here tomorrow) and I have the front Three's set to Large whilst the rest of the bunch are set to small with XO at 80Hz. The Three's surprisingly filled the room (which is approx 4300 cubic feet).
I have the Classic Two's to the rear of me cieling mounted... It would be very nice to have those replaced with the Three's... Also, if my space for the center could accommodate the ThreeC I would likely have bought it as well. Unfortunately my entertainment center is just big enough for the TwoC.
Thanks for the reply. I think that confirms My reasoning and I will pull the trigger on the Three's, which is at the top of my list of speakers I'm debating. In the long run it will be the right decision. Enjoy those new PSA subs, can't wait to hear what you think of them!
Barneyb is online now
post #11165 of 11189 Old 03-24-2015, 07:36 AM
jhughy2010's Avatar
Quoted: 407 Post(s)
Liked: 117
I'm stoked... waiting for Fedex right now to deliver!
Gear: Pioneer VSX-1124-K, NHT Classic Three (L/R), Classic Two (rear) TwoC (center).
PSA V1500 (x2)
HTPC/server (MB3), Fire TV Stick, Chromecast
OTA Winegard HD7698P
Sharp LC-60SQ15U (HCFR calibrated)
jhughy2010 is offline
post #11166 of 11189 Old 03-24-2015, 09:10 AM
DonnyKerabatsos's Avatar
Quoted: 31 Post(s)
Apologies if this has been posted/discussed previously, but I wasn't able to locate it in the thread (posts int he thread seemed to slow to a trickle a few months after it was published for whatever reason):
http://www.audioholics.com/tower-spe...absolute-tower
Curious as to whether anyone experimented with any mods to their ATs to correct the "issue" that the reviewer attributes to the chamfering around the tweeters? That's far beyond my level of understanding/expertise, and if it ain't broke, don't fix it, but it did pique my curiosity, given the nature of folks in this hobby to try to wring every ounce of goodness they can from their ssystem.
Having now lived with the ATs for several months (and having purchased them with out hearing them first), my impressions were similar in several respects to those of this reviewer, in that I had hoped (wished?) for better imaging and soundstage, that they were brighter (though not overly so) than the PSBs and B&Ws I grew up listening to, but that the overall sound quality was excellent and without any real flaws/weaknesses, they are very well made, and an excellent value, particularly if they can be had on sale.
Just wondering if folks in the thread had any impressions or disagreements with the opinions/measurements in the Audioholics review.
DonnyKerabatsos is offline
post #11167 of 11189 Old 03-24-2015, 09:12 AM
Quoted: 75 Post(s)
Liked: 101
Should sound awesome!!!
Ray
post #11168 of 11189 Old 03-24-2015, 09:25 AM
Quoted: 75 Post(s)
Liked: 101
The only real issue would be if your room is too bright (lots of reflective surfaces). This would be true of a lot of speakers that produce a flat frequency response in the upper ranges. Room correction software such as Audyssey, should tame the upper region fairly well. I've heard the newer PSB's next to the NHT's and they sound fairly similar in the treble. How do you have your room set up with them? Towing them in a little can help if you have reflective walls to the sides.
Transmaniacon likes this.
Ray
post #11169 of 11189 Old 03-24-2015, 09:35 AM
Quoted: 31 Post(s)
I've run Audyssey, and in 2 channel, I don't notice a ton of difference in the way they sound between stereo and pure direct mode, so I guess that indicates Audysssey isn't doing anything really drastic, at least to those channels.
I've described my room in previous posts, but while the room is oddly shaped and open to other areas of the house, there is a recliner, a large rug, a couch, curtains, etc to help with refections, so I'm likely not experiencing reflections too terribly off of anything except the coffee table (I know....).
The speakers are towed in slightly and are not very close to the side walls, so that probably helps as well.
Most of my PSB comparisons come from my nearly 20 year old Century 300i book shelf speakers and some listening I did in the early 2000s, so I've not heard any newer PSBs made in the last decade.
post #11170 of 11189 Old 03-24-2015, 09:37 AM
Quoted: 736 Post(s)
Liked: 609
Try pulling the coffee table out and listening, just to see how it's effecting the sound. With a smaller tower like the ATs, the tweeter is closer to the table surface.
post #11171 of 11189 Old 03-24-2015, 12:55 PM
Quoted: 31 Post(s)
Yeah, it sounds somewhat better in pure direct without the table, but even moving it aside a bit is battle that's been fought and lost, unfortunately.
Talking about an addition that would yield a larger but closed room that I could put some treatments in and that would not include a table, so maybe by fall my system will have a new home, but I will have to live with it until then.
post #11172 of 11189 Old 03-24-2015, 05:22 PM
Quoted: 75 Post(s)
Liked: 101
That would be the best - having a dedicated closed room that is acoustically treated.
Ray
post #11173 of 11189 Old 03-24-2015, 07:58 PM
Quoted: 115 Post(s)
Liked: 36
So $200 for a UPA-200? What about a XPA-200? One of those just popped up on CL.
post #11174 of 11189 Old 03-25-2015, 04:38 AM
Quoted: 736 Post(s)
Liked: 609
That would be a better buy in my opinion, maybe $300 depending on how old it is and if there is any warranty left.
post #11175 of 11189 Old 03-25-2015, 11:33 AM
Quoted: 75 Post(s)
Liked: 101
Randall,
The XPA-200 would be more noticeable, that would give you the 3db increase (if your system needs it - if you're within the power range of your AVR, you won't notice the difference). I have the XPA3 power my fronts (L/R/C) and cannot tell the difference at normal listening levels. If I really crank the system, then yes, I can tell because I'm using more power than my AVR can supply. But I wouldn't listen at those levels often (only just to try out). I appreciate my hearing and don't want to listen to things at ear bleeding levels. As Transmaniacon stated, if a good price, go for it. I'll at least quench your thirst on trying out an outboard amp at an affordable price.
Ray
post #11176 of 11189 Old 03-25-2015, 04:40 PM
Quoted: 115 Post(s)
Liked: 36
Thanks guys. So I'll just rely on Audyssey to calibrate everything? I was just worried that sending that much power to the L/R channels would over power the center channel. It's not that I can't afford the XPA-3, I'm just always looking for the best deal and buying quality products at the same time.
post #11177 of 11189 Old 03-25-2015, 04:42 PM
Quoted: 115 Post(s)
Liked: 36
I think he said there was 3 years and some change, close to 4 years remaining on the warranty. Has all the paperwork to verify this. We just started talking and he's about 3+ hours away, could be 5 or more depending on traffic.
post #11178 of 11189 Old 03-25-2015, 04:45 PM
Quoted: 75 Post(s)
Liked: 101
Audyssey will re-set all the levels so you won't even notice the amp being there. Once rerun, your volume levels will be the same as before. The trim levels will be a little different.
Randall.White likes this.
post #11179 of 11189 Old 03-27-2015, 08:46 PM
Quoted: 115 Post(s)
Liked: 36
Offer submitted
jhughy2010 likes this.
post #11180 of 11189 Old 03-28-2015, 06:20 AM
Quoted: 75 Post(s)
Liked: 101
Originally Posted by randall.white View Post
offer submitted:d
Awesome!!!
Ray
post #11181 of 11189 Old Yesterday, 12:03 AM
Quoted: 115 Post(s)
Liked: 36
Working on negotiating the price. He actually responds fairly quick.
Since you guys have been about coffee tables messing up the sound. Do ottomans also screw things up?
post #11182 of 11189 Old Yesterday, 07:49 AM
Quoted: 75 Post(s)
Liked: 101
Basically as a rule, you don't want anything between the speakers and your listening position. But, If the ottoman is not reflective and too large, it should be fine. Comfort while watching a movie is important and if you use the ottoman, just keep it there.
Keep us posted on you negotiations!
Ray
post #11183 of 11189 Old Yesterday, 08:37 AM
DS-21's Avatar
Quoted: 418 Post(s)
Liked: 297
Soft squishy things (ottomans, futon mattresses, really thick rug pads, etc.) can actually help with floor bounce issues. (Not in the bass, but from 1kHz or so up.) It's hard, reflective surfaces between speakers listeners that should be avoided whenever possible.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #11184 of 11189 Old Yesterday, 10:54 AM
Quoted: 115 Post(s)
Liked: 36
Thanks! Well since we ordered a new sectional the wife has been looking at ottomans to go with it. I talked her away from a coffee table but just wanted to make sure before we buy anything that it won't affect the sound.
Just sent back a counter to his counter, so far it's better than all the dealers around me.
post #11185 of 11189 Old Yesterday, 12:34 PM
Quoted: 75 Post(s)
Liked: 101
Depends a lot on the material. If cloth, microfiber, or other soft material I totally agree. If leather, that can reflect a lot of the treble region.
Ray
post #11186 of 11189 Old Yesterday, 12:36 PM
Quoted: 75 Post(s)
Liked: 101
Just answered above. Bottom line, if the ottoman will enhance your comfort and watching experience, then it's more important.
Sounds like your wheeling-n-dealing for the Fours. Seems like buying a car. Most audio dealers won't do that.
Ray
post #11187 of 11189 Old Yesterday, 12:42 PM
DS-21's Avatar
Quoted: 418 Post(s)
Liked: 297
Agreed completely. Leather ottomans are little different from wood or glass.
Serious Audio Blog
DS-21 is offline
post #11188 of 11189 Old Yesterday, 07:56 PM
Quoted: 115 Post(s)
Liked: 36
I know, I was shocked when he said how about xxx? I said ehh I can wait awhile then and he said let me know what you can pay.... I don't mind negotiating
Well she has found a couple. One is all fabric (microfiber?) and another is wood bottom, kinda like a table frame and has a large cushion on top. All fabric one a better option?
post #11189 of 11189 Old Today, 09:56 AM
Quoted: 75 Post(s)
Liked: 101
The ottoman will be so close to you, it probably won't matter much which one you get. The upper portion of both is a type of fabric and that's the most important part. Let your wife choose what she wants, it'll give you brownie points...
Ray
Reply Speakers
