New NHT Classic line to replace Super Audio - Page 383 - AVS Forum | Home Theater Discussions And Reviews
 164Likes
post #11461 of 11482 Old Yesterday, 05:08 PM
jhughy2010's Avatar
Quoted: 569 Post(s)
Liked: 179
Originally Posted by cavchameleon View Post
I do use REW just for verification of my frequency response and room response (decay, etc.) but do not use it to EQ the room. For me, I think Audyssey really is the best auto room correction at the moment (XT32 that is). Yes, XT32 is pretty awesome! At the moment I'm still using the A100 (same as the 4311CI) with XT32. It does a great job of EQing 2 subs. I've set up MCACC (Pioneer), YPAO (Yamaha), Sony's version, and H&K's version and still prefer Audyssey. It does a great job. Many feel that you loose some bass, and that's because most folks are used to very hot bass. Easy fix- after running Audyssey just add +3db or more to the subs. I do use Audyssey Pro. I'm waiting to upgrade my AVR when all the newest formats are added. The process is happening now, so I will wait until next year. If not using Atmos, I think the best deal is the AVR-4520CI which was originally their flagship AVR with XT32 when it came out. It was $2500 at the time an can be had new for $1100 from accessories4less:
http://www.accessories4less.com/make...-150wpc/1.html
I think your pair of V1500's would be pretty awesome and in most rooms won't be any different than a pair of S3000i's. The output specs are pretty close. I can't wait to have them in, as you stated, I don't think I'll be disappointed at all.
I too keep hearing that XT32 is far and above the best solution here. I am likely going to try a Denon or Marantz especially considering how much support there is here at AVS for those two brands.
Considering I am a stickler for the latest and greatest... and that I want 4k and/or atoms in the future, I'm going to only be looking at their newer offerings. This year is definitely out of the picture so it will have to be next years offerings (Denon x4300w?)
Gear: Pioneer VSX-1124-K, NHT Classic Three (L/R), Classic Two (rear) TwoC (center).
PSA V1500 (x2)
HTPC/server (Emby), Fire TV Stick, Chromecast
OTA Winegard HD7698P
Sharp LC-60SQ15U (HCFR calibrated)
jhughy2010 is online now
post #11462 of 11482 Old Yesterday, 05:47 PM
ghstudio's Avatar
Originally Posted by green giant View Post
Get these from Steve. They are EXCELLENT, he also provides great instructions on how to really clean up and replace them. I bought some for my 3.3's . Between a very good cleaning and waxing (car polish and car wax), putting on new grill covers (get the good stuff from Parts express, the cheaper stuff looks brown) and these foams... my 3.3's are honestly looking like a 9.5/10 scale.
The foam may be relatively cheap, but getting the ends round like that is no small task. If you want, I'll post up some pictures of mine after putting them on there.
http://www.ebay.com/itm/NHT-2-9-3-3-...item43e021a226
Steve is the sellers name, these foams are the real deal.
I can't imagine that these have to be perfect. I already have the parts express foam and I should be able to cut reasonable oblongs that will be hidden by the grills. Steves solution would be easier but the price is a pretty high.
ghstudio is offline
post #11463 of 11482 Old Yesterday, 08:12 PM
green giant's Avatar
Quoted: 35 Post(s)
Liked: 31
True.
It's a form vs function thing. It's hard to get those ends to not "squish" down, but functionally they would still work.
For me - 50 bucks was worth it. I also dumped 30 bucks into the high end grill cloth from parts express to re-do my grills (the cheap stuff had a brown cast to it).
green giant is offline
post #11464 of 11482 Old Yesterday, 08:33 PM
Answer Seeking / Sharing
cavchameleon's Avatar
Quoted: 137 Post(s)
Liked: 158
Yes, XT32 is amazing! I have other AVR's in the home with lesser renditions and they just don't compare. Like you, I'm waiting for all the newer formats, so hopefully next fall. I've had my current main one since 2011, so it's about time (the lesser ones are in the other room and suffice for them). I'm also waiting for displays to hash out their issues.
jhughy2010 likes this.
Ray
"Listen with an open heart and mind."
cavchameleon is offline
post #11465 of 11482 Old Yesterday, 08:37 PM
Quoted: 137 Post(s)
Liked: 158
Another product you can use is a felt ring for the tweeters (which is really the main area you are trying to deal with). I mentioned it before, but here is the link:
https://www.madisoundspeakerstore.co...-for-tweeters/
If you want to cut your own 'strips', then this would also work:
https://www.madisoundspeakerstore.co...-running-foot/
They won't have the same issues as foam degradation.
I used to put the felt rings on all my speakers. I still have some with them from years ago and do not have any problems.
Ray
post #11466 of 11482 Old Yesterday, 10:47 PM
Randall.White's Avatar
Quoted: 308 Post(s)
Liked: 77
@Cav , how big was your room again? Those subs are going to be killer!
@jhughy2010 , did you custom build that box or ? I was looking into that exact sub, want something small and sealed to go in my bedroom.
Randall.White is online now
post #11467 of 11482 Old Yesterday, 10:51 PM
Quoted: 308 Post(s)
Liked: 77
Figures, I finally buy some Fours and something new and improved is coming out. Before I ordered I asked if there was anything "new" coming out in the near future (6-12months) and was told nope.
Question about 2-channel listening.
Would you guys rather have Absolute towers with RA Echo 18 or Fours with Echo 18?
post #11468 of 11482 Old Today, 03:55 AM
ghstudio's Avatar
I am about to set up my sound system in our new home. I'll have NHT 2.9's as the left and right fronts, an AC-2 center and a James EMB-1200 Sub. That's the easy part. The hard part is getting wires to install rear speakers .... and side speakers are just out of the question given the furniture layout.
My thought is that I could use a wireless link to the "rears" and put them on either side of the sofa pointed either towards the wall behind or towards the ceiling. I'm thinking of using an Amphony wireless speaker kit to drive two small speakers for the rears. I have two NHT Super one's but they are pretty inefficient (87db) given the meager power of the amphony receiver but again, not much room for another amp in the rear....the sofa pretty much sits in the middle of a "great room"....so I'm open to suggestions.
The use of this system is just TV/Movies and occasional background music which won't use the rears at all. Fortunately, I have xt32 and a Pro Kit to help with whatever I install.
Has anyone used the Amphony or Rocketfish wireless for sides or rears? Any suggestions on a small speaker for the rears (I've even thought of Bose cubes although I dislike Bose)?
Is it even worth the investment $'s to have 5:1 vs 3:1?
ghstudio is offline
post #11469 of 11482 Old Today, 11:00 AM
jhughy2010's Avatar
Quoted: 569 Post(s)
Liked: 179
Originally Posted by Randall.White View Post
@Cav did you custom build that box or ? I was looking into that exact sub, want something small and sealed to go in my bedroom.
I got the kit (driver plus knock down mdf) from Parts Express.... very affordable. I'll post a picture of the finished product in the next few weeks. I just did a couple coats and am going to sand then do last coat in a day or two.
I would definitely use the Fours with the Echo 18. I'd still cross them over at 80Hz though.
PSA V1500 (x2)
post #11470 of 11482 Old Today, 06:56 PM
Quoted: 137 Post(s)
Liked: 158
I'll be looking forward to those pics!
A also agree, use the Fours with the Echo 18. I'd try both 80Hz and 60Hz to see what sounds best for music/movies in your room.
Ray
post #11471 of 11482 Old Today, 06:59 PM
Quoted: 137 Post(s)
Liked: 158
You might be safe regardless. I'm really curious what they are coming out with. I'm hoping still some standard type of tower and not only Atmos capable towers (where they put speakers on the top - I'd rather mount or put in-ceiling speakers than have that format).
Again, I agree with Jhughy: Fours with the Echo 18. That's one HUGE capable sub and paired with the Fours will give you some incredible sound!!!
Ray
post #11472 of 11482 Old Today, 07:11 PM
Quoted: 137 Post(s)
Liked: 158
This is all dependent on how it works. 5.1 is definitely better than 3.1, but if you can't run wire you'll have to try the wireless options. I've tried different ones and it was all dependent on interference in the area for wireless transmission. Most use 2.5GHz and that is a highly used band so where you live will matter. I've used powered speakers and added wireless transmitter/receivers to them. They can work depending on the room size and length of the transmission signal.
http://www.amazon.com/Wireless-Trans...r+and+receiver
Ray
post #11473 of 11482 Old Today, 07:20 PM
Quoted: 308 Post(s)
Liked: 77
Thanks. Been thinking about going fully dedicated even if the room is smaller. It's around 100 sq ft. So the Threes will be massive in there as surrounds.
I'm looking forward to pics of your sub and what you think of it. Especially compared to your PSA sub.
post #11474 of 11482 Old Today, 07:30 PM
Quoted: 137 Post(s)
Liked: 158
Just Do It. You won't regret having a dedicated room, even if smaller. You'll have to do some treatments to get the best out of it, but it'll all be worth it in the end.
Ray
post #11475 of 11482 Old Today, 07:35 PM
Quoted: 308 Post(s)
Liked: 77
How should I setup the speakers? Threes or Absolute towers for L/R? I'm planning on running all 7 remaining NHT speakers that I have.
post #11476 of 11482 Old Today, 07:43 PM
Quoted: 137 Post(s)
Liked: 158
Aesthetically, the Absolute Towers would look better (and my wife would agree with that). Acoustically, they would sound pretty close to the same, especially after running Audyssey. My room is not much larger than what you're working with so it's tight, but works pretty well once treated and room correction run.
Ray
post #11477 of 11482 Old Today, 08:09 PM
Quoted: 137 Post(s)
Liked: 158
So, I got the PSA's in today and finally took a pic (not where they'll be of course, have to swap them out behind the couch and can't get to that since we're leaving to Portland for a week). They are much bigger than I had thought. The W1s are (D x W x H): 16.65" x 13.5" x 22" and the S3000is are 18" x 24" x 22.5. So they are pretty equivalent on the height set up will be the same from the back of couch to wall (W1s at 16.65" and S3000i at 18" - so less than 1 1/2" ). The wider part is of course very different (going from 13.5" to 24"). That'll be a LOT of sub for the size of the room, but will pressurize it well (kinda like a sub in a car). Here is a pic with them in front of the Fours (would pretty much look like your Echo 18 Randall - actually your's is bigger!).
Ray
post #11478 of 11482 Old Today, 08:14 PM
Quoted: 137 Post(s)
Liked: 158
Pic Attached(last one was degraded).
Ray
post #11479 of 11482 Old Today, 09:13 PM
Quoted: 308 Post(s)
Liked: 77
^^ Hold on, you got (2) 3000i in a 100 sq ft room!? You are crazy! In a good way lol.
post #11480 of 11482 Old Today, 09:15 PM
Quoted: 308 Post(s)
Liked: 77
Alright, I wasn't sure if it would make much difference. I still have my VTI stands and a pair of Vantage Point wall mounts. Sell the stands and go wall mounted all around?
One plus is a 65" TV looks massive in that small of a room.
post #11481 of 11482 Old Today, 09:41 PM
jhughy2010's Avatar
Quoted: 569 Post(s)
Liked: 179
I'm honestly thinking that is going to be hard to ever go back to a speaker that I didn't build. The quality of components for the price is just so great.
Don't get me wrong, NHT makes some beautiful speakers that sound good. But I just wish they were louder. What I mean is that they just are so not sensitive compared to other options or there especially the DIY kits. I just wish that I had the skills to paint that piano black finish.
There is a member here that pulled it off but he had a buddy at the auto body shop.
Cav, you are in for a treat! Your set up looks great! Did you get the veneered subs in ash black?
Are you implementin anything besides XT32? I got the mini dsp from PSA and am excited to use it. Just have not had the time lately. I need to learn REW but to be honest the guide kind of sucks (sadly).
post #11482 of 11482 Old Today, 10:21 PM
Quoted: 308 Post(s)
Liked: 77
So you're building more than just the sub? I think the finishing would be my biggest issue, cause I'm so picky. It would have to be perfect for me to approve. Or in a total blacked out room where nothing could be seen
I was looking at some veneer options but it gets pricey and wouldn't want to screw it up.
Reply Speakers
