New NHT Classic line to replace Super Audio - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 207Likes
post #121 of 11710 Old 10-12-2005, 02:19 PM
Alimentall's Avatar
You're still a good 6 weeks away for a Three or Four.
John
Alimentall is offline
post #122 of 11710 Old 10-17-2005, 08:46 PM
dwong's Avatar
This from NHT FAQ:
My SW10ii / SW12 subwoofer has a loud hum when I turn it on.
What can I do to get rid of the hum?
The DSS system and all cable TV systems have a ground wire connected to the shield of the signal on the outside of the house and driven into the earth with a metal rod or water pipe. The SW10II/12 is grounded to the power outlet through the third prong of the power cord. The AC wiring in the building has the ground conductor connected to a metal rod or water pipe outside the building. Once a patch cord is connected between the DSS system and the subwoofer, a complete circuit is formed called a ground loop. Current flowing in the ground loop can cause very large amounts of noise in the system.
To legally install cable TV or a DSS system, there must be a ground conductor from the dish or cable tied to the earth outside of the building. This guarantees that if struck by lightening, the current will flow to ground (earth) outside of the building, never endangering someone's life inside or damaging any equipment. Removing the ground from the DSS or cable system is not a legal or safe option. We use a grounded power cord on our powered subwoofers and amplifiers to ensure that the customer is always safe. If there is ever any internal short in the subwoofer amplifier between the power supply and the chassis, the current will be shunted to ground (earth) through the power cord and the fuse will blow. The customer will never be in any danger of electric shock.
The proper way to break the ground loop in the system is to do it at the signal level. This should be done at the output of the device that is causing the ground loop. In this case it is the DSS or cable system. The best way to do this is with a ground loop isolator. A good one is available from Jensen Transformers.
my question is why only NHT sub have that prob?
(all my other sub don't hum)
I see the atoms free and fine,
That bubble like a sparkling wine;
I see the songs Electrons sing,
Jumping from ring to outer ring;
              - Lister, The Physicist
dwong is offline
post #123 of 11710 Old 10-17-2005, 09:06 PM
Alimentall's Avatar
It is not only NHT. All subwoofers with which I am familiar can do this. It is a common problem and is system related, not product related. The grounded design is a safety feature. There are ways around this. You can eliminate the ground on the sub, it's just that NHT won't be the one to recommend it. We do this all the time. The ground loop isolator is technically the better way to go, though.
John
post #124 of 11710 Old 10-17-2005, 09:18 PM
dwong's Avatar
i have 2 sys, and i have another sub(hsu stf2) that don't have hum on both....
maybe the hsu sub is not ground?
edit: btw, how to eliminate the ground on the sw10? tia
dwong is offline
post #125 of 11710 Old 10-17-2005, 09:27 PM
Alimentall's Avatar
Just get a three-prong to 2-prong adaptor at the local home store for 39¢. It should do it.
John
post #126 of 11710 Old 10-17-2005, 09:40 PM
dwong's Avatar
cool, thx....want to hear the sub and that hum is killing me, almost cut off that ground pin
LOL
edit: weird, even i turn off sub, w/ pw cord plug in, sw10 cause rest of sys to hum
removing ground work, thx
dwong is offline
post #127 of 11710 Old 10-26-2005, 02:01 PM
b4z
b4z's Avatar
Quoted: 18 Post(s)
Will the sale of NHT to Vinci labs change the timetable for the new Classic line?
b4z is offline
post #128 of 11710 Old 10-26-2005, 02:21 PM
Alimentall's Avatar
Nope, it shouldn't. The first of Classic should be on a ship right now, maybe even at a port. Not sure exactly. I know the cabinets went into production a few weeks back.
John
post #129 of 11710 Old 10-26-2005, 03:25 PM
Jack Hidley's Avatar
The sale of NHT isn't having any affect on the production status for Classic. We've already shipped at least four models to dealers (Absolute Zero, Two, Ten and Twelve).
Jack Hidley
Jack Hidley is offline
post #130 of 11710 Old 10-27-2005, 01:47 PM
Alimentall's Avatar
Silly engineers
Word I'm getting is that there were only a few rep samples sent out so far, that the first major containers start arriving at NHT tomorrow with more coming each week, so shipping to dealers would start next week and at least some dealers should have them by end of next week.
And here I was standing by the door waiting for UPS to show up!
John
post #131 of 11710 Old 10-27-2005, 01:59 PM
BachToRock's Avatar
What is the time status of the THREE and FOUR?
NHT CLASSIC FOUR's Front & Rear, CLASSIC 3C, Classic 12 Sub, Panasonic TC-P65VT30, DVD-3800BDCI, HD-XA2, SONY TA-P9000ES Preamp, BRYSTON and Marantz Amplifiers...
BachToRock is offline
post #132 of 11710 Old 10-27-2005, 02:18 PM
Alimentall's Avatar
I'd say 5 weeks.
John
post #133 of 11710 Old 10-29-2005, 07:59 PM
Jerrym303's Avatar
Has anyone seen a picture of the 2 or 3 with the grill on?
Jerrym303 is offline
post #134 of 11710 Old 11-03-2005, 02:52 PM
Alimentall's Avatar
Jerry, I haven't, but I just saw them in person as they have arrived! The grill looks great. Very pretty in person. I'm also happy to report after some quick A/Bing that they do *exactly* what they need to do and a bit more. The Absolute Zero has tonal balance that is brighter and more detailed than the SB1, with a bigger soundstage, but with a marginally warmer balance than the M5. It is very nearly the performance of the M5, but less than half the size and price. It pays a wonderful tribute to the original SuperZero. The Two offers deeper bass and output. Compared to the SB3 at the same price, it is clearly more detailed, a little lighter but tauter in the bass and, again, a bit warmer than the M5. I'd argue that the Two matches the performance of the M5 in most ways and may have a better overall tonal balance. It has more of that "fun" sound, somewhat missing on the SB2, that made the SuperOne a classic. What is most obvious is how they clearly enunciate vocals and pick up every syllable. And they haven't broken in yet, they're being tortured as I type. The look is just beautiful. The cabinets are also notably more rigid. Rapping on the front baffle is almost like rapping on a granite kitchen counter top. The cones are the other major upgrade while the excellent tweeter from the Super Audio is appropriately carried over. I can't wait to hear the rest of the line as these are a bigger upgrade than I'd expected.
BTW, just to be clear, it's the Absolute Zero, Two and Ten that have arrived. Nothing on the others so far.
John
post #135 of 11710 Old 11-09-2005, 11:46 PM
Quoted: 16 Post(s)
Liked: 27
Wow. I just saw the new lineup in person at EHX. Those are some stunning looking speakers in person. Especially the Three and Four. The iW4 looks to be an impressive inwall. Too bad I couldn't listen to them. Can't wait to audition them.
Greg
Mad Chemist is offline
post #136 of 11710 Old 11-11-2005, 05:17 PM
b4z
b4z's Avatar
Quoted: 18 Post(s)
Any update on the Three's availability?
Also, how can the Two have deeper base than the SB3?
Wasn't the SB3 rated down to 39Hz?
Granted it was ported and fell off quickly......
b4z is offline
post #137 of 11710 Old 11-11-2005, 05:27 PM
Alimentall's Avatar
Same as ever, last I checked. Still 2-3 weeks away.
The Two doesn't have deeper bass than the SB3, it's about the same as the SB2. Even the Three doesn't have as deep a bass as the SB3. The bass, however is more detailed in the mid/upper bass than on the SB3, so this should address any issues that came up with the SB3s for most people.
No, it wasn't ported. NHT doesn't port midranges. It's why their bookshelf speakers can sound as good as very expensive towers and others can't.
John
post #138 of 11710 Old 11-11-2005, 09:28 PM
schellhase's Avatar
In an earlier post(s) on this thread Jack said the NHT center speakers were designed to be put on top of a television and not on a stand.
My question is: when you say: "on a stand" are you talking about an individual speaker stand OR a television stand that has a top shelf which could be used for a center speaker?
Those of us with LCD or plasma monitors really cannot set a speaker on top. I am quite interested in the NHT speakers, but if I cannot put the speaker on the top shelf of a Bell'O TV stand below the monitor without sacrificing sound quality I will look at other brands.
Larry
schellhase is offline
post #139 of 11710 Old 11-12-2005, 01:05 AM
ermc's Avatar
These speakers are exceptionally ugly. I'm a 20 something straight as an arrow hetrosexual male but these things look fairly horrible by eye. Definitely not WAF material. Also, funny how this thread comes about a few days after slining so much feces and mud in the Axiom speaker thread (aliminium speakers at nearly the same pricepoint)
ermc is offline
post #140 of 11710 Old 11-12-2005, 06:27 AM
Alimentall's Avatar
Larry, you can place in anywhere, what Jack was saying was that the bass is optimized for placement above, below, near a TV, or up against a wall rather than in free space. Every speaker is optimized (in theory) for one placement or another, so it's not like NHT was trying to limit the flexibility, it's no less flexible than any other center speaker. Your placement is perfectly fine for the speaker.
John
post #141 of 11710 Old 11-12-2005, 04:55 PM
DJ_JonnyV's Avatar
Quoted: 26 Post(s)
I buy speakers for their sound, not their looks. In my man-cave, what I say goes. Maybe you should get the keys to ranch back if you're that worried about looks of a speaker.
DJ_JonnyV
DJ_JonnyV is offline
post #142 of 11710 Old 11-14-2005, 08:59 PM
KRiS1's Avatar
Liked: 25
Very interested in 3's
KRiS1 is offline
post #143 of 11710 Old 11-22-2005, 05:04 PM
rsmeanie's Avatar
Jack,
Does NHT have a showroom or listening room that's open to the public? I'm about 10 mins from you guys in Benicia and would LOVE to check out the new 3's. I'm a long time Definitive Tech fan (Been using DR-7's and a C-1) and was considering the Aperion 532's before I started reading about the Classic 3's.
btw~The new 3's are visually stunning. Can't wait to hear them.
rsmeanie is offline
post #144 of 11710 Old 11-22-2005, 08:18 PM
Alimentall's Avatar
Speaking of which, I got the white Absolute Zeros and the Twelve subwoofer today. Looking forward to the rest of the line showing up!
John
post #145 of 11710 Old 11-23-2005, 12:24 AM
Danabw's Avatar
Quoted: 794 Post(s)
Liked: 382
Still no info on price? Scanned the thread and didn't see any...
2015 Sony X850C FAQ: Recommended Picture settings, 3D FAQ, HDR FAQ, DirecTV 4K Ready FAQ, Troubleshooting & common problems; Dropbox Link || Alternate Google Drive FAQ Link. FAQ is frequently (often daily!) updated, check back often! || My gear: TV - Sony XBR75X850C, BD - Sony BDP S350, AVR - Pioneer VSX-1020, Speakers - RBH MC-616C MKII Center Channel, RBH MC-6C MKII Bookshelf (fronts), RBH MC-615 In-ceiling surrounds, RBH TS-10AP 200W self-powered sub.
Danabw is offline
post #146 of 11710 Old 11-23-2005, 01:19 PM
b4z
b4z's Avatar
Quoted: 18 Post(s)
$800 for the Threes(pair).
I believe all of the pricing is in this thread or there are links in this thread that will take you to a price list.
b4z is offline
post #147 of 11710 Old 11-23-2005, 01:59 PM
Alimentall's Avatar
I thought I'd posted this earlier somewhere, but here goes:
Absolute Zero monitor - $200 each
Two monitor - $300 each
Three monitor - $400 each
Four tower - $1800/pr
2C center- $500
3C center - $600
Ten sub - $600
Twelve sub - $850
John
post #148 of 11710 Old 11-30-2005, 09:52 PM
DASharp1's Avatar
Best location for my HT mains in front will be on bookshelves that are only 10 3/8" high, so only the Absolute Zero would fit (I think they would fit!), standing up. I like the SB2 & SB3 because their basic rectangular shape allowed side positioning with no "obvious" signs. But on the new Two and Three, with the tapered top end, it seems they would look, well, awkward lying on their side. May be a stupid quesiton, but would it compromise the sound to position either of those on its side? Seems hard to believe the Ab Zero would almost equal the M5; so maybe I wouldn't be sacrificing too much to go with all Zero's instead of Twos or Threes? Thoughts?
DASharp1 is offline
post #149 of 11710 Old 11-30-2005, 10:17 PM
Alimentall's Avatar
You could do the speakers sideways if need be. It's not ideal and the dispersion won't be as good, but you can do it. How big is the room? I find the Two to be a bit better balanced than the AZ and handles high power a little better and more smoothly. Another option would be to get dual Ten subs with the AZs and then cross over a bit higher to give the AZs a bit more freedom to rock out.
John
post #150 of 11710 Old 12-01-2005, 11:24 AM
DASharp1's Avatar
Thanks, Alimentall. The room measures 13' x 14', with doorways on two walls, a fireplace diagonally in one corner, and 9'5" ceilings. Would you really need two Ten subs to drive 4 AZs and a center channel? FWIW, the system in reality will be used more for TV than DVD watching, and for music infrequently. My local NHT dealer sells Marantz receivers & separates, and am seriously considering this combo, though I still need to add a DVD/CD player. Recommendations? I would like to stay under $3K total budget for receiver, all speakers, and player. Thanks!
DASharp1 is offline
Reply Speakers
