Calling all Polkies:Official Polk thread - Page 1294 - AVS Forum | Home Theater Discussions And Reviews
 1261Likes
Old 06-08-2014, 11:39 AM
grigorianvlad's Avatar
Quoted: 120 Post(s)
Liked: 611
Playing with my Polk LSiM 703s. Found an extremely demanding soundtrack that most 4 ohm speakers cant handle even at mid volume. I know, I know - the LSiMs are 8ohm. That is the whole point.
I wanted to see how big of a difference this 4ohm/8ohm would make with a track THIS demanding without a power amp. A whole lot, as it turns out.
The track is the bass intro from Lins Lofgren's live album. Nothing complicated - very heavy bass guitar, drums,cymbals. But it is very dynamic, there are a thousand notes crammed in every millisecond! It sounds like there are 10 guys playing with 20 fingers on that bass guitar. You gotta have mad speakers with an insane power amp to reproduce this faithfully at high volume without any distortion. Plus it is a loud recording to begin with.
So, I remastered two versions in addition to the original stereo.
1) Original , but in 5.1 surround
2) Original +5dB 5.1 surround
3) Original+15dB 5.1 surround
Played this BluRay in
1) Pioneer Elite AVR + Polk LSi-9 (no power amp)
2) Pioneer Elite AVR + Emotiva XPA5 + Polk LSi-9
3) Pioneer Elite AVR + Polk LSiM-703 (no power amp)
4) Pioneer Elite AVR + Emotiva XPA5 + Polk LSiM-703
The Polk LSi-9s without power amp exhibited distortion at -30dB volume even while playing the normal version, a few seconds into the song. If you want to know what that distortion sounded like listen to the track with +15dB recording . It sounds bad even with a power amp at a normal listening level.
The Polk LSiMs handled normal version even at reference level WITHOUT a power amp. They even played +10dB version decently until the cymbals and drums clashed with the bass guitars, then the high frequencies started to sound washed out and bass guitar skipped a note or two. About a minute and a half into the song which is about 3 minutes long. Not enough juice! Sounstage was a bit flat, but still - not so bad. Listenable. Of course the +15dB version sounded pathetic, but that was expected.
The Emotiva allowed the LSi-9s play more effortlessly . These speakers NEEDED a power amp to play this crazy track loud, no question about it. They handled the song just fine with the power amp at normal and +10dB recording.
The LSiMs, on the other hand, improved somewhat while playing the +10dB version of the same song, but not as much as the power hungry 4ohm LSi-9s. No skipped notes, no washed out treble, imaging and soundstage as good as they can be! You would be hard pressed to catch the difference between the normal and +10dB versions, but it is there.
So,lesson learned - this 4ohm/8ohm upgrade in the LSiMs makes a difference with this demanding test track! Now I gotta delete it so I dont destroy my speakers inadvertently if I play it loud by mistake! biggrin.gif
zuluwalker, Aarghon and pokeme like this.
DAC: Wyred4Sound DAC1LE || Processor: Marantz AV8801 11.2 Ch || Power Amps: Audio Research VS110 (100W tube) || Emotiva XPR-2 (600W), Emotiva XPA-5 Gen 2 & UPA-500 (200W/80W) || L/R Speakers: Eminent LFT-8b , Magnepan 2.7, Center : Polk LSiM-704C, Sur: Polk LSiM-703 || Sub 1: Rythmik F25 (800W). Sub 2: Sunfire True Signature TS-EQ12 (2,700W) || Cables: MIT terminator 2 Biwire, 4, Exp; Cardas Crosslink || Power: Panamax M5300 || HP: HifiMan HE560
grigorianvlad is offline
Old 06-08-2014, 11:57 AM
viper186's Avatar
Quoted: 18 Post(s)
Liked: 240
Originally Posted by KJSteward View Post
Send me a PM if you want some pointers. I'm not going any further in open forum with my comments, but I have quite a bit of info stashed away if you want to use it.
On another note, I'm wondering if it's a worthwhile exercise buying another pair of Monitor45s to use as front presence on my Yamaha, or whether I should use a smaller set?
I'm sure 45's would do great, maybe even the 35's. I had 30's as mains for a bit and they worked well enough. Then I used them as side surrounds in a 7.1 configuration and they worked great there so I don't see why something similar wouldn't work as presence speakers.
KJSteward likes this.
viper186 is offline
Old 06-08-2014, 12:06 PM
Quoted: 120 Post(s)
Liked: 611
If anybody wants these 3 test tracks please PM me. You gotta know how much juice you have/need! smile.gif
Old 06-08-2014, 12:07 PM
bumprunlogan's Avatar
Liked: 355
+1 on that.
Just a fella who loves good sound.
bumprunlogan is offline
Old 06-08-2014, 12:12 PM
Liked: 355
Originally Posted by Tom Grooms View Post
It's a custom DIY 3/4" MDF piece. I actually made it years ago as a way to angle down from the top of the old school CRT rear projection displays
By the way Tom I like your setup and I checked out your website. Very classy and detailed if I live in the area I would be contacting you for some products.
Polk products that is, mainly Lsi series.
Tom Grooms likes this.
Old 06-08-2014, 12:13 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
I want to post something but it'll be "off topic" so I'll just lurk for now.....boy how avs has changed.....
sheshechic likes this.
I don't need snobs to tell me how to think, thank you!
67jason is offline
Liked: 355
I will make sure every post in this thread will have something Polk related in the body of the message.
pokeme likes this.
Old 06-08-2014, 12:24 PM
KJSteward's Avatar
Quoted: 205 Post(s)
Liked: 586
Originally Posted by pokeme View Post
Thanks the presence speakers are sort of like an enhance height speaker right?  I found that the tl2 I was using for the task were fine in the PLiiz mode but there isn't as much information going to them as would be in your case so maybe something larger would be nice.
Thanks. I purchased the first pair of 45s for $168, and the 65s for $300. If I had room, I'd consider moving the 45s to the Front Presence position and buying another set of 65s, or even 75s. Unfortunately I'm out of space, so another set of towers is out of the question.
Spoiler!
KJSteward is online now
Old 06-08-2014, 02:09 PM
PretzelFisch's Avatar
Quoted: 396 Post(s)
Liked: 262
I would think the 30-35 would be a good choice for presence speakers since they should be higher then the mains. They are very easy to mount compared to the 45t
XStanleyX and KJSteward like this.
PretzelFisch is online now
Old 06-08-2014, 02:33 PM
KJSteward's Avatar
Quoted: 205 Post(s)
Liked: 586
That's a good point. The 45s are pretty heavy. Thanks.
Spoiler!
Old 06-08-2014, 03:27 PM
JyveTurkey's Avatar
Liked: 126
As promised
Unfortunate about the loading scratches but we'll repair it somehow. Again can't complain at $475
XStanleyX likes this.
JyveTurkey is offline
Old 06-08-2014, 04:04 PM
mr266's Avatar
Quoted: 117 Post(s)
Liked: 722
Originally Posted by JyveTurkey View Post
As promised
great deal on those. You can probably just use a wood floor marker on them. You really just don't want to notice the scratches, and with the markers it would be hard to see the blemish unless you were right on top of it.
WDTV Live SMP with WD EX4100 NAS
Polk RTI8 Front, Polk CSI5 Center, Polk RTI4 Surround
MTX SW2 12” SUB, Sharp AQUOS LC-70C6400U
URC-WR7 Universal Remote
Motorola QIP7232 (P2) FIOS DVR, Sony BDP-S590 Blu Ray Player
Marantz SR5010 AVR,Technics SL-B20 Turntable
mr266 is offline
Old 06-08-2014, 04:29 PM
Just add water and stir
zuluwalker's Avatar
Quoted: 46 Post(s)
Liked: 490
Rocked out hard with my RTi-A series this morning.
Fantastic way to start the day. Delivered a brilliant bit of fun watching Die Hard (original).
Having a BBQ now at the in-laws.
zuluwalker is offline
Old 06-08-2014, 05:27 PM
JyveTurkey's Avatar
Liked: 126
That's a good idea. I'll give it a try. thanks
Old 06-08-2014, 05:39 PM
swarm87's Avatar
Quoted: 111 Post(s)
Liked: 87
As promised
there's something i saw on tv a few nights ago dont remember what it was called but it comes in a pen and they showed someone drag a key over a wood table and then used it to fill it in. might be on one of those "as seen on TV" websites; could also look at a furniture store for wood furniture repair/restore stuff
pcm=potato
bitstream=patato
swarm87 is online now
Old 06-08-2014, 05:46 PM
pokeme's Avatar
Liked: 486
That's a good call. Depending on how deep, and how much, an autobody shop might be able to quickly buff it out too.
pokeme is offline
Old 06-08-2014, 05:57 PM
KJSteward's Avatar
Quoted: 205 Post(s)
Liked: 586
Damn. I forgot there were cannons in the 1812 Overture. That must have hit about 130dB.
Spoiler!
Old 06-08-2014, 06:30 PM
Quoted: 120 Post(s)
Liked: 611
Geoff4RFC likes this.
Old 06-08-2014, 06:32 PM
KJSteward's Avatar
Quoted: 205 Post(s)
Liked: 586
Originally Posted by grigorianvlad View Post
I'm relieved. I thought that was going to take my head off. I swear I felt the cannonball zip past my ear.
Spoiler!
Old 06-08-2014, 06:43 PM
Quoted: 120 Post(s)
Liked: 611
Realism is the sweetest quality in music. Congratulations! Your gear rocks. I myself always listen to the overture from the safety of trenches, with a helmet on, just in case . You never know where the darn cannon is pointed!
Geoff4RFC and KJSteward like this.
Old 06-08-2014, 06:48 PM
KJSteward's Avatar
Quoted: 205 Post(s)
Liked: 586
I've chickened out and resorted to "British No 1s of the 1980s". Figured that might be safer.
The Goombay Dance Band??? Wonder where THEY are now?
Spoiler!
Old 06-08-2014, 07:54 PM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
Take a good picture with your phone, then go down to Lowe's or Home Depot and ask if they have anything. They might have something on the shelf that will work wonders.
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One, and custom DIY media console...
climber07 is online now
Old 06-09-2014, 01:29 AM
rfolkes's Avatar
Liked: 94
Actually my dad used to have a record recording of the 1812 that used real canons.
It was awesome ... Played that on his Polk SRS SDA speakers
rfolkes is offline
Old 06-09-2014, 08:47 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Finally did a fast install and calibration for my HT and Denon X4000. Wow Audyssey XT32 + Sub EQ is just awesome. Much better sound than my SC-1522-K, and I liked the 1522. I didn't have much time to mess with it, but I know it can only get better. biggrin.gif
pokeme likes this.
GusGus748s is offline
Old 06-09-2014, 08:54 AM
RobLee's Avatar
Quoted: 261 Post(s)
Liked: 268
Originally Posted by rfolkes View Post
Actually my dad used to have a record recording of the 1812 that used real canons. It was awesome ...
I had - or rather my Dad had, then I inherited, that same recording. I remember it had an "extra" track that detailed how they mic'ed the cannon. As a kid it sounded great on our Voice of the Theater, but I unloaded all that vinyl before moving up to my current Polks.
Denon AVR-4520ci, Polk LsiM703's, 704c, Rti4 surrounds, some Klipsch subs. Bedroom: Lsi9's, Onkyo TX-8050
RobLee is offline
Old 06-09-2014, 09:53 AM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
Originally Posted by RobLee View Post
...but I unloaded all that vinyl before moving up to my current Polks.
Man, that's a bummer. I had a lot of vinyl years ago too. Wish I had "hoarded" it for a while longer.
Old 06-09-2014, 10:16 AM
RobLee's Avatar
Quoted: 261 Post(s)
Liked: 268
Not a bummer IMO. I just got tired of maintaining all the storage space devoted to vinyl. We are approaching retirement and need to cut back on all the junk we will have to move into our retirement condo. Even now I realize that I don't listen to CD's anymore either. What music we enjoy either we've ripped to USB or we just stream internet radio (no "subscription" services, again too much upkeep involved).
So now I've traded several hundred pounds of vinyl for instead all our accumulated A/V gear. Recently we moved the last of our lower end Monitors to one of our rental properties, so at least that's out of the house. So now I'm left with like four or five complete audio systems, and not entirely sure how we will ultimately stage what we have once we move.
RobLee is offline
Old 06-09-2014, 10:35 AM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
I hear ya on the space. I only had about two one cube boxes of vinyls. I don't do physical CDs any longer either. I rip everything. It's so much easier and takes up the space of a removable HDD or a micro thumb drive.
Old 06-09-2014, 03:38 PM
AlphaPie's Avatar
Quoted: 145 Post(s)
Liked: 373
Moving tomorrow, including my polk speakers. Up to the 3rd floor eek.gif At least att will be there the same day to hook up my uverse. Calling for rain all week, really dont want to rent a uhual, rather use my truck. We'll see. Quiet movies, no bass, pretty much going to suck. rolleyes.gif
7.2 w/front wides - Pioneer Elite SC-85 - Polk Audio RTi12/CSi3/RT25i - DIY Dual 12" subs/Behringer Inuke3000 - Monster Power 2500
Sharp Aquos 60" - Xbox One - Sony BRP - Plex Server
AlphaPie is offline
Old 06-09-2014, 05:30 PM
laserjock II's Avatar
Quoted: 703 Post(s)
Liked: 378
Y'all were very helpful on my question about the Polk center channel beast I was trying with my Energy RC-70's.
Gonna miss the regulars.
laserjock II is offline
Polk Audio , Polk Audio Csi5 High Performance Center Channel Speaker , Polk Audio Monitor 30 Bookshelf Speakers Cherry , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Cherry , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio R50 Floorstanding Speakers Each , Polk Audio Rti4 High Performance Bookshelf On Wall Speakers , Polk Audio Rti6 High Performance Bookshelf Speakers Pair Black , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Polk Audio Surroundbar 4000 Iht Virtual Surround Speaker Bar With Wireless Su , Polk Audio Three Way Vanishing Rt Series In Ceiling Speaker 70 Rt , Polk Psw108 10 100w Psw Series Powered Subwoofer
