Calling all Polkies:Official Polk thread - Page 1297 - AVS Forum | Home Theater Discussions And Reviews
 1261Likes
post #38881 of 43409 Old 06-17-2014, 05:02 AM
Tom Grooms's Avatar
Quoted: 123 Post(s)
Liked: 205
Originally Posted by Skidoo23 View Post
I have the denon x4000 that supports wides, I was wondering if the wides could be the a7 and the monitor 70. I'm not sure how matched they are and don't want to mess up the sound. Also I'd like some advice on setting up wides in a narrow room. The wides would have to be put closly to the mains, would this just defeat the purpose?
Yes, that would defeat the purpose. More is not better, it's just more. I see so many people on this forum trying to cram rear surrounds in a room with the couch on the back wall or trying to fit wides in a room with a 10-12 foot front wall. Save your money or use those funds to upgrade your main speakers. Gimmicky dsp channels are way overrated
mr266 likes this.
Tom Grooms is offline
post #38882 of 43409 Old 06-17-2014, 06:46 AM
enricoclaudio's Avatar
Quoted: 1101 Post(s)
Liked: 1127
I have the DSW 660wi, which is fantastic, and was wondering which speaker would be better to pair with it. Im willing to go with the a9's if I actually will hear a difference. I think my bass is cover with my sub. So i was wondering, paired with the sub should I go with the a7 or a9, it there a difference in the high or mids between the two or mostly bass?
The A9s are a bit better for music because the top (mid woofers and tweeter) is a sealed cabinet. But the A9s are not easy to drive, they are power hungry so most probably you will need an external amp to get the best out of them.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #38883 of 43409 Old 06-17-2014, 07:37 AM
PretzelFisch's Avatar
Quoted: 396 Post(s)
Liked: 262
the a9 is also a big speaker which is why I never opted for getting them.
PretzelFisch is online now
post #38884 of 43409 Old 06-17-2014, 11:48 AM
YDR05's Avatar
You could try bookshelf speakers from the series to match your mains. I have A1s with A5s as mains and the sound from the wides adds a lot to the front sound stage. I have a wide room though.
Also, the distance is not as important for the wides as much an angle of 60 degress from the MLP.
YDR05 is offline
post #38885 of 43409 Old 06-17-2014, 12:09 PM
RobLee's Avatar
Quoted: 261 Post(s)
Liked: 268
Most folks who have been regulars here much prefer the A9's to the A7's. I have all of the above, and can honestly say that the A9's project better than the A7's, due to the twin 5" midrange drivers. The A7 is basically the same as the A3 with the added two 7" bass drivers. The third 7" driver in the A9's let them go all that much deeper. Only drawback to the A9's is that they really do need to be powered by an external amp, not an AVR (some may disagree, most would agree).
BTW I use direct stereo mode on the A9's for music, without the subs. The built-in triple 7's produce nice, articulate bass. And I also have the DSW660wi paired with Lsi9's upstairs. The sub is decent but not all that great. Usually I leave it turned off as well.
Long and short, I'd say go with the A9's if you can afford a separate amp. Or you can do as I did, which is start with the A7's and eventually move up to A9's, moving the A7's to surround. Beware, the A9's will sound anemic if powered only by an AVR (again, some will disagree) but I can tell the difference. Your 660 sub will be fine for HT, but someday you may want to upgrade that as well. Good luck! and have fun!
bumprunlogan likes this.
Denon AVR-4520ci, Polk LsiM703's, 704c, Rti4 surrounds, some Klipsch subs. Bedroom: Lsi9's, Onkyo TX-8050
RobLee is offline
post #38886 of 43409 Old 06-17-2014, 12:20 PM
Skidoo23's Avatar
Thanks for the great reply, I have another question. You said that id need an external amp to power the a9's. Is this still true if I have the denon x4000. I know that has more power that other receivers but not sure if its still enough for the a9's without amp.
Skidoo23 is offline
post #38887 of 43409 Old 06-17-2014, 12:31 PM
Liked: 1127
I have a Marantz SR7008, which is basically the same X4000 with more bells and whistles. Before upgrade to LSiM 705s I had A9s and I was driving them with a Emotiva XPA-3 because I felt that the Marantz wasn't enough. I still using the XPA-3 to drive the LSiM 705s. My advice is if you get the A9s then get an external amp most if you listen at reference levels.
Skidoo23 likes this.
post #38888 of 43409 Old 06-17-2014, 12:39 PM
Skidoo23's Avatar
At the moment I dont really want/cant get an amp. So Should i either get the a9's use them with the denon x4000 and wait to get an amp, or just go for the a7's?
Skidoo23 is offline
post #38889 of 43409 Old 06-17-2014, 12:43 PM
Liked: 1127
Get the A9s, you can add the amp later when funds come available. The important thing here is that you have a very good receiver with pre outs and good power, just not enough to drive properly the A9s. But hey they are gonna sound killer with the X4000 and much better when you add the external amp to your system.
post #38890 of 43409 Old 06-17-2014, 12:59 PM
RobLee's Avatar
Quoted: 261 Post(s)
Liked: 268
I've been considering the X4000 as my next upgrade, mainly for the 9.2 capabilities, and being more affordable than the 4250. But even the 150wpc of the 4250 falls short of the "recommended" 200wpc minimum the A9's really need to come alive. As Enrico said, already having an AVR with pre-outs puts you halfway there. You can pick up a used amp for around $500 if you keep your eyes open. I recently scored an XPA2 on eBay and it's pretty much just sitting idle until we move when I'll have the room for 9.2
Oh BTW, if you get the A7's you'll always wonder what the A9's might have sounded like... and yes, they are that good!
RobLee is offline
post #38891 of 43409 Old 06-17-2014, 01:28 PM
Tom Grooms's Avatar
Quoted: 123 Post(s)
Liked: 205
Buy the A9's and don't worry about an amp yet. You may find you don't even need one at all unless you like the volume above -10db.
post #38892 of 43409 Old 06-17-2014, 02:47 PM
Skidoo23's Avatar
Well then I'll get the a9's. I just want to make sure that even without an amp they will spound better than my monitor 70's. Which I'm sure they will. But what does getting an amp actually do? Will it just allow me to turn them up louder?
Skidoo23 is offline
post #38893 of 43409 Old 06-17-2014, 03:37 PM
Liked: 1127
Like Tom said, if you listen below -10dB, then you may don't need an external amp. But if you listen above -10dB which is not even close to reference levels then get an external amp. What is gonna happens if you get the A9s and you try to listen at reference levels (0dB) without an external amp? Worst case scenario your receiver is gonna shutdown and goes into protection mode.
post #38894 of 43409 Old 06-17-2014, 05:57 PM
Skidoo23's Avatar
I don't think I've gotten close to 0 with my monitors.
Skidoo23 is offline
post #38895 of 43409 Old 06-17-2014, 06:03 PM
RobLee's Avatar
Quoted: 261 Post(s)
Liked: 268
Well then I'll get the a9's. I just want to make sure that even without an amp they will sound better than my monitor 70's. Which I'm sure they will. But what does getting an amp actually do? Will it just allow me to turn them up louder?
What happens is is the speakers can draw more power than the amp can provide. And the problem with an AVR is not actually the amplifiers in it, but the common power supply that powers all channels. The PS is usually pared back to cut down on both cost and weight.
The problem happens with multi element speakers that will have two or more drivers active at some frequency range. If you do someday get an external amp, and you still happen to have your M70's you might be surprised how great the M70's will sound with more power. But the A9's, or even the A7's, will sound much clearer than the Monitors.
RobLee is offline
post #38896 of 43409 Old 06-17-2014, 06:06 PM
Skidoo23's Avatar
I don't think I've gotten to 0 when using my monitors. Is running the a9 without an amp kinda like the a7's then? I just want to make sure that the a9 will sound good until I can get an amp.
Skidoo23 is offline
post #38897 of 43409 Old 06-17-2014, 06:30 PM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
You won't notice any difference between the A9 on an AVR versus a dedicated amp until you start approaching reference level. Especially if you have the crossovers set to 80Hz on the mains. RTiA9s will sound great unless you push them really hard with music (-10dB or so) or are playing ultra-powerful content on movies at high volumes. If you were to listen in pure 2.0 stereo mode (full range) then you are going to start to notice a bigger difference with an amp even at moderate volume levels due to the A9s reproducing low bass at the cost of power.
Playing my RTiA9s on an Onkyo NR3009 and on an Emotiva XPA-2 I noticed no difference sonically until I started getting to around -20 dB on the volume.
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One, and custom DIY media console...
climber07 is offline
post #38898 of 43409 Old 06-17-2014, 08:45 PM
Skidoo23's Avatar
Thinking about 6.1 setup
So i've decided i'm going to get the polk a9's. I will have 2 left over monitor 70's and was thinking maybe I would use for 6.1 setup. The only reason I cant do a 7.1 is I don't have enough room, as you can see in the photos. My current rears are the FXi a6's. The monitor would go behind the couch. My main question is, is it worth it, and would the sound not be so great? the monitors are not perfectly matched to the FXi's. Also would the 6.1 work with the monitor being only about a foot behind the listening position.
ID:	123218   Click image for larger version
Skidoo23 is offline
post #38899 of 43409 Old 06-17-2014, 09:06 PM
Liked: 1127
In that room you would be better putting on sale the Monitors 70 and the CS2 and get a CSi A6 and the A9s. Also if you don't have the plan to get the external amp it's better if you stay in a 5.1 setup so you don't need to take power out of the X4000 to drive one or two extra speakers. The 125 watts per channel on the X4000 is with two channels driven, not with 5 or 7.
mr266 likes this.
post #38900 of 43409 Old 06-18-2014, 12:23 PM
AlphaPie's Avatar
Quoted: 145 Post(s)
Liked: 373
I've been to -0 with my monitors many times with denon and pionner elites, I noticed that Audyssey had them turned down by -5.5, so you may check to see how far the EQ has turned down each channel before you go above -10.0, you may find adjusting their trim will get you the desired volume while staying clear of clipping volume.
AlphaPie is offline
post #38901 of 43409 Old 06-18-2014, 12:36 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
I don't disagree, but I was at -17 and a gunshot in the movie book of eli blew a tweeter in one of my monitor 70's. That was the second blown tweeter and when I decided to get an amp. Clipping kills drivers, and too little power aids in increasing chances of clipping.
67jason is offline
post #38902 of 43409 Old 06-18-2014, 12:47 PM
AlphaPie's Avatar
Quoted: 145 Post(s)
Liked: 373
From what I gather, the lack of sensitivity coupled with the, well, inexpensive crossover used in the monitor series makes it a difficult speaker to drive with clarity to reference without an amp. I'm about to try my inuke around 300 watts with my 75t, even with the build in DSP I doubt I'll find an enormity of clarity.
AlphaPie is offline
post #38903 of 43409 Old 06-18-2014, 02:04 PM
viper186's Avatar
Quoted: 18 Post(s)
Liked: 240
I remember when I had 50's I would try reference for a bit, -15 to 0, never had any problems. I can imagine 70's are a different story though.
viper186 is offline
post #38904 of 43409 Old 06-18-2014, 05:29 PM
BNestico's Avatar
Quoted: 152 Post(s)
Liked: 221
Hi guys,
My RTi8's showed yesterday and I hooked them up and I'm a big fan, I haven't watched a movie with the yet but I listened to some music with them and I fell like I can hear some bass guitar parts better than I could with the RTi6's (which have been moved to surround duty) even with my two SVS's. Also, have any of you guys taken off/not put on the big spiked feet that come with the RTi8/10/12's? I didn't put them on mine cause I think they look rediculous. I did put the other piece on though, the wide plastic part they screw into.
Panasonic P60U54
Marantz SR-7009
Polk Audio RTi8's, CSi5, RTi6's, OWM3's
SVSound PC12 Plus, PC Ultra (12")
Sony BDP-S7200
BNestico is offline
post #38905 of 43409 Old 06-18-2014, 08:11 PM
bumprunlogan's Avatar
Liked: 355
Originally Posted by BNestico View Post
Hi guys,
I have the rti 8's and hardwood floors and installed the feet that came with them. To me not installing the feet would look like they would become unstable and maybe wobble not to mention get scratched on the bottom so for me the feet is choice.
Just a fella who loves good sound.
bumprunlogan is offline
post #38906 of 43409 Old 06-18-2014, 08:53 PM
BNestico's Avatar
Quoted: 152 Post(s)
Liked: 221
My floors are hardwood too and they're not unstable without the feet. I might get some round felt pads to put where the feet would screw into the plastic outriggers. I woulda put them on and forgot about it if my wife hadn't walked in as I was screwing them in and said "you're bat**** crazy if you think you're putting those ugly-ass spikes on the bottom of those speakers!"
Panasonic P60U54
Marantz SR-7009
Sony BDP-S7200
BNestico is offline
post #38907 of 43409 Old 06-19-2014, 07:50 AM
Liked: 355
You'd be surprised at how much more stable the speakers get with the spikes on them. I'm cheap and I use the foam that came with another pair of speakers. I cut out the foam into feet and sit the spikes on them for a cushion and it's ultra stable from there and is soft on my floor to boot.
But check a few pages back this subject came up and there are some products you can buy that will provide more cushion.
post #38908 of 43409 Old 06-19-2014, 08:01 AM
mr266's Avatar
Quoted: 117 Post(s)
Liked: 722
Hi guys,
Glad to see you're diggin' those 8's. I think they're outstanding and really bring music to life.
WDTV Live SMP with WD EX4100 NAS
Polk RTI8 Front, Polk CSI5 Center, Polk RTI4 Surround
MTX SW2 12” SUB, Sharp AQUOS LC-70C6400U
URC-WR7 Universal Remote
Motorola QIP7232 (P2) FIOS DVR, Sony BDP-S590 Blu Ray Player
Marantz SR5010 AVR,Technics SL-B20 Turntable
mr266 is offline
post #38909 of 43409 Old 06-19-2014, 03:19 PM
AlphaPie's Avatar
Quoted: 145 Post(s)
Liked: 373
I just sold my marty sub in its massive box. The guy came to pick it up and was completely unprepared for the size. Waiting to receive funds for the amp from a member and I'll be bassless... Now all I have are 3 polk subs fml
7.2 w/front wides - Pioneer Elite SC-85 - Polk Audio RTi12/CSi3/RT25i - DIY Dual 12" subs/Behringer Inuke3000 - Monster Power 2500
Sharp Aquos 60" - Xbox One - Sony BRP - Plex Server
AlphaPie is offline
post #38910 of 43409 Old 06-19-2014, 03:24 PM
AlphaPie's Avatar
Quoted: 145 Post(s)
Liked: 373
How do you like the OWM3? I assume you're using these as surrounds?
AlphaPie is offline
Reply Speakers
Polk Audio , Polk Audio Csi5 High Performance Center Channel Speaker , Polk Audio Monitor 30 Bookshelf Speakers Cherry , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Cherry , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio R50 Floorstanding Speakers Each , Polk Audio Rti4 High Performance Bookshelf On Wall Speakers , Polk Audio Rti6 High Performance Bookshelf Speakers Pair Black , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Polk Audio Surroundbar 4000 Iht Virtual Surround Speaker Bar With Wireless Su , Polk Audio Three Way Vanishing Rt Series In Ceiling Speaker 70 Rt , Polk Psw108 10 100w Psw Series Powered Subwoofer
