Calling all Polkies:Official Polk thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 1447Likes
post #361 of 43985 Old 06-20-2006, 06:26 PM
redwing3139's Avatar
Hello I also have a question regrading the Polk Mains, What would most people recomend Rti8 or the Monitor 70's since they are some what close in price. Thank You for your help
redwing3139 is offline
post #362 of 43985 Old 06-20-2006, 09:27 PM
panndder's Avatar
Paired with a sub? Rti8. I have them and they sound wonderfull, and have better tweeter than the Monitor line. They also are made of solid wood.
panndder is offline
post #363 of 43985 Old 06-22-2006, 03:33 PM
whats are you powering them with?
post #364 of 43985 Old 06-22-2006, 03:35 PM
fireshoes's Avatar
Actually they are made of mdf and have a real wood veneer.
fireshoes is offline
post #365 of 43985 Old 06-22-2006, 04:50 PM
panndder's Avatar
Sorry, I shouldn't have said solid wood. They do, however have the look of real wood and the consistancy (from a manufacturing perspective) of fiberboard.
panndder is offline
post #366 of 43985 Old 06-23-2006, 02:58 PM
Monster Jam's Avatar
Originally Posted by Monster Jam View Post
I can't wait to hook them up and drive my AVR to protection mode!
Well, it didn't take long to get to the promised land called "Protection Mode". Strangely enough, it didn't happen during the operation of the speakers.
Maybe one of you experts can discuss how or why it (my Harman Kardon AVR 525, rated at 70 watts x 7 all channels driven) went into Protection Mode.
I can't exactly tell you how it happened, because I wasn't there: I was downstairs. I just heard my wife say that the receiver wasn't working. I went upstairs and saw that some of the lights were on, but the LED screen didn't look right and the DVD was playing but no sound was coming out of the receiver. I turned it off, and thats when it went into the protection mode.
My theory is that the speakers are drawing power from the amp when the DVD player is on but not sending audio signal. Am I crazy?
(Incidentaly, I am driving 4 LSi15s and a LSiC)
Monster Jam is offline
post #367 of 43985 Old 06-23-2006, 06:12 PM
Don1959's Avatar
Lsi15s are a very difficult speaker to drive.... they are 4 ohm and 86 db... I don't think that the Harman Kardon AVR 525 has enough current to drive these speaker well..... check the owners manual to see what it says about 4 ohm speakers...
Don
Don1959 is offline
post #368 of 43985 Old 06-25-2006, 07:44 PM
Mmcguire's Avatar
Originally Posted by fergusonv View Post
The 10's and 12's are 4ohm speakers (Polk lists them as 8 but they are not) and require a hefty amp, only flagship recievers and dedicated amps should be used with them with means more $$ on the electronics side..
Now I read this...lol. Oh well, I just ordered a pair of 12's and have a Yamaha HTR5280 100wpc x 5 @ 8 ohms AVR. If they are really 4 ohm speakers should they be run at 4 ohms? At least that would be 200wpc on the fronts. I also have a set of Fxi5's. With the fronts in the 4ohm slot, the rears are going to get 6 ohms and the Fxi5's are 8 so that should work.
It seems highly irregular that the manufacture would list an incorrect nominal impedance and from what I understand it varies with frequency so when they list nominal as 8 that's not necessarily incorrect. Thoughts?
Mmcguire is offline
post #369 of 43985 Old 06-25-2006, 09:42 PM
Holydoc's Avatar
The manufactorer did not post incorrect info. I own the RTi12's.
Holydoc is offline
post #370 of 43985 Old 06-26-2006, 06:35 AM
Buckeyefan's Avatar
Quoted: 14 Post(s)
The Polk RTi and CSi series are 8 ohms nominal, 4 ohms dc resistance. What that means in real world situations is that you need a hefty amp to power these speakers, or at minimum use bass management. If you call Polk's tech service, they'll tell you the same thing. If you connect just the top half (upper binding posts unstrapped) of an RTi12 or RTi10, your AVR will see ~7.3 ohm dc resistance. Your top half (no 7" drivers) will open up like you've never heard them before (assuming you're using a mid-fi AVR).
http://i19.photobucket.com/albums/b1.../9-4-05042.jpg
http://i19.photobucket.com/albums/b1.../9-4-05041.jpg
http://i19.photobucket.com/albums/b1.../9-4-05040.jpg
A man meets a genie. The genie tells him he can ask for whatever he wants, but his mother-in-law gets double of what he gets. The man says give me a million dollars and beat me till I'm half dead.
Buckeyefan is offline
post #371 of 43985 Old 06-26-2006, 10:53 PM
Mmcguire's Avatar
Gotcha, now on to Amp settings. This 500 wpc amp has a two way speaker impedance switch one position for 8 ohms f/r and the other for 4 ohms front, 6 ohms rear. I'm guessing that would put 200wpc on the fronts and 50wpc on the rears or 175 on the fronts and 75 on the rear. Granted still underpowered but alot better than 100wpc.
Since these are 4 ohm speakers shouldn't you configure your amp to drive them at 4 ohms?
Mmcguire is offline
post #372 of 43985 Old 06-27-2006, 09:36 AM
wbart4's Avatar
I'm currently finishing up my home theater that is 15x19.5. I have the Polk RTi70 for mains, CS400 for the center and FX300 for surround. Also two 10" 120 subs. These speakers sounded good in my last room with lots of doors and windows. My new room being totally dedicated with just one door and zero windows. I'm going with 7.1 and bought the R15's for the back surrounds. Now I'm having second thoughts. Should I stick with this set up or maybe think about RTi4's or inwalls. I'm not into spending the extra money for hardly any difference in sound.
What's your opinions
wbart4 is offline
post #373 of 43985 Old 06-27-2006, 09:53 AM
cneely8's Avatar
Did you mean should you use rti4's for the 6th and 7th channel? Probably overkill. If you meant should you use them for the side surrounds? Yeah, they are pretty good there. It's where i have mine. Rti4's will sound better than most any in-walls you would consider. But as 6th and 7th channels, due to the lack of material that gets sent back there, I don't know if it would be a waste of money. My 6th and 7th are cheapy single-4.5" driver speakers from my first "upgrade" years ago....
cneely8 is offline
post #374 of 43985 Old 06-27-2006, 10:05 AM
wbart4's Avatar
CNEELY8,
Would you replace the FX300's with the RTi4's and go with the R15's for the back channels?
wbart4 is offline
post #375 of 43985 Old 06-27-2006, 04:31 PM
cneely8's Avatar
Is the fx300 the older version of the fxi3? If so, is it dipolar? or bipolar? or whatever they call it? I haven't experimented with anything but direct radiating speakers, like the rti series, so if the fx300's are di/bipolar, then I can't tell you which to use. Some folks claim the additional drivers add depth to the soundstage.
About the r15's, like I said, I'm not real particular about my 6th and 7th channels, so I'd say use "whatever" since so little sound gets sent back there. It complements the other 5, but never seems to be a big deal that I use my really "bad" speakers there. If you get a chance to listen to the rti's, r15's, and the f300's, that's your best bet. Then you can make the call based on position in the system, price, and your preference on the sound.
cneely8 is offline
post #376 of 43985 Old 06-28-2006, 10:46 AM
compgeek's Avatar
I know this is a noob question, but here goes. I just purchased the m40's for fronts and m30s for rears however I don't know is I need the thing that connecting the binding posts. What is that and what is it for. I am not bi-amping my system. Please help.
compgeek is offline
post #377 of 43985 Old 06-28-2006, 11:00 AM
Hairyfoot4's Avatar
The piece of plated metal connecting the two sets of binding posts is there so you dont have to bi-amp the speaker. If you remove those pieces you will have to bi-amp the speaker. Those peices connect the two sets of binding posts so you only have to connect speaker wire to one set of posts.
hope this makes sense
Hairyfoot4 is offline
post #378 of 43985 Old 06-28-2006, 11:06 AM
PULLIAMM's Avatar
Polk makes a series called "M". I think you have the Monitors, which are a definite step up from the M's.
PULLIAMM is offline
post #379 of 43985 Old 06-28-2006, 11:34 AM
compgeek's Avatar
Hairyfoot4
Thanks I removed them so I guess I now have to put them back. Does removing them in anyway affect the sound.
Pulliamm:
You are right I do have the Moniter series
compgeek is offline
post #380 of 43985 Old 06-28-2006, 11:43 AM
Hairyfoot4's Avatar
Removing them only powers the speaker(s) that specific pair of binding posts is connected to inside the speaker cabinet. So you probably want to put them back on unless of course your planing on bi-amping the speaker, then leave them off.
post #381 of 43985 Old 06-28-2006, 11:43 AM
Don1959's Avatar
With out the metal straps between the two sets of binding post (or some other connection) you will only power either the tweeter or the woofer depending on if you connect to the top pair (tweeter) of bottom pair (woofer).
I do not use the metal straps that come with the speakers... I use jumper cables with banana plugs between the two sets of binding posts.... this really opened up the top end... larger sound stage and better imaging....
Hope this helps...
Don
Don1959 is offline
post #382 of 43985 Old 06-28-2006, 11:58 AM
compgeek's Avatar
Thanks for all the responses it has been helpful.
Don1959
Could you elaborate on the jumper cable setting. I currently have banana plugs going into the top post. I have not heard of jumber cables before. If this could possibly give me a better sound I am all for it.
compgeek is offline
post #383 of 43985 Old 06-28-2006, 04:51 PM
Don1959's Avatar
Don1959
They say a picture is worth a thousand words....... The cables create a much better connection between the two sets of binding posts...
I run my speaker cable to the bottom set of posts and connect them with spades.... then the jumper cables carry the signal to the top set of post where they drive the tweeters...
Don
Don1959 is offline
post #384 of 43985 Old 06-28-2006, 05:50 PM
panndder's Avatar
IDIOT QUESTION.
I have RTi8's (and a CSi5) and I have them connected to just the top. Would it sound better (from a HK 635) to have it hooked to both somehow?
panndder is offline
post #385 of 43985 Old 06-28-2006, 08:03 PM
jkg123's Avatar
Hey Everyone,
For a 7.1 System, price not being a problem, I am thinking about getting either the Polk LSi 7.1 or the Energy RC 7.1 set-up.
For the Polk System I would be doing:
(2) Polk LSi 25
(2) Polk LSi 9
(2) Polk LSi FX
(1) Polk LSi C
(1) Energy RC-SUB10
(1) Sunfire Cinema Grand Seven TGA-7200 (Amp)
(1) Pioneer Elite VSX-84TXVi Receiver (Preamp)
(1) Monster HTPS 7000 (Power Conditioner)
Or if I do the Energy RC System I would be doing:
(2) RC-70
(2) RC-10
(2) RC-R
(1) RC-LCR
(1) Energy RC-SUB10
Which one do I go with for a Home Theater/Rec Room? Movies/Music = 75/25 Any suggestions? Please help! Thanks
jkg123 is offline
post #386 of 43985 Old 06-28-2006, 10:16 PM
Hairyfoot4's Avatar
panndder - either like don1959 shows on his picture or to bi-amp ("have it hooked to both somehow") them.
yes it sound alot better.
post #387 of 43985 Old 06-29-2006, 08:35 AM
compgeek's Avatar
Thanks Don1959
I will try setting up mine like your setup
compgeek is offline
post #388 of 43985 Old 06-29-2006, 09:25 AM
jonnythan's Avatar
Thanks Don1959
You need both sets of terminals hooked together. The plates that came on the speakers work fine. There's no need to create jumper cables when you have the originals.
jonnythan is offline
post #389 of 43985 Old 06-29-2006, 09:50 AM
PULLIAMM's Avatar
Right. The plates and the jumper cables do exactly the same thing.
PULLIAMM is offline
post #390 of 43985 Old 06-29-2006, 11:41 AM
Don1959's Avatar
They do perform the same function..... but, in my setup, there is a very noticeable improvement in sound quality, The cables "seem" to create a better (cleaner?) connection.
I really noticed the difference when I switched to the cables.... the top end opened up the image became bigger, tighter... maybe a bit smoother....
I was thinking of bi-wiring, but it was suggested to try this relatively inexpensive solution...
anyway... just make sure that you have a good connection between the two and I believe that it is best to connect the speaker cable to the lower set.
All this is just based on what I hear... your ears may vary...
Don
Don1959 is offline
Reply Speakers
Polk Audio , Polk Audio Csi5 High Performance Center Channel Speaker , Polk Audio Monitor 30 Bookshelf Speakers Cherry , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Cherry , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio R50 Floorstanding Speakers Each , Polk Audio Rti4 High Performance Bookshelf On Wall Speakers , Polk Audio Rti6 High Performance Bookshelf Speakers Pair Black , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Polk Audio Surroundbar 4000 Iht Virtual Surround Speaker Bar With Wireless Su , Polk Audio Three Way Vanishing Rt Series In Ceiling Speaker 70 Rt , Polk Psw108 10 100w Psw Series Powered Subwoofer
