Calling all Polkies:Official Polk thread - Page 1305 - AVS Forum
post #39121 of 39131 Old 09-17-2014, 07:47 AM
laserjock II's Avatar
Quoted: 38 Post(s)
Liked: 49
Originally Posted by jackforceus View Post
All,
Need some advice. I'm putting together the home theater components for my soon to be finished basement. Please advice me if you have a better recommendation. I'm thinking of setting up a 9.2
Front: Polk RTIA9 (2) - I already have this
Front Wide: Polk RTIA3 (2)
Center: Polk CSI A6 - I already have this
Side: Polk RTI A1 (2)
Rear: Polk RTI A1(2)
Sub: SVS SB2000 (2)
Receiver: Marantz SR7008 - I already have this
What do you think about this? Do I need a amplifier?
How big is your room and how far away will you sit from the front 3?
laserjock II is online now
post #39122 of 39131 Old 09-17-2014, 11:04 AM
viking74's Avatar
Liked: 0
I'm looking to upgrade/update my HT and need some advice. Currently have H/K avr310 running four polk rt800's and a psw650 sub with a cheapo center channel in a 20'x20'x7' room open on one end. My plan was to purchase a Denon x5200 when they are more available here in Canada then find speakers. However, FutureShop Canada has RTiA5 on sale for $250 and RTiA7 on sale for $350. Is this too good to pass up? How would they pair with my Harmon until I can get the Denon?
viking74 is offline
post #39123 of 39131 Old 09-17-2014, 11:25 AM
EndersShadow's Avatar
Liked: 544
All,
Sub: SVS SB2000 (2)
Amp the A9's with a nice amplifier and you will be fine. The rest of those speakers wont really strain your AVR and you will have lots of headroom.
For the A9's spend money on a good nice high powered amp for them. I'd suggest at least 300wpc or more if you can swing it. The A9's LOVE LOVE LOVE power. The more you give them the better they sound.
Personally I am against using pro-amps in a HT enviornment (unless you have a dedicated equipment closet), however some folks have used the Crown XLS amps which run cool and the fans rarely kick on (one reason I dont like pro-amps in a home environment).
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is offline
post #39124 of 39131 Old 09-17-2014, 11:46 AM
jackforceus's Avatar
- The room dimensions are 250 * 180 inches. I'll be sitting at 180 inches from the front speakers.
- I'll be having a dedicated equipment closet
- Can you kindly recommend some amps that can best use these speakers? Do I need just a stereo amp for the A9's or 7-channel amp?
Thank you..
jackforceus is offline
post #39125 of 39131 Old 09-17-2014, 02:02 PM
That opened me a whole new world for me after you suggested that Crown XLS can be used. I was thinking that amps like Emotiva, Marantz, Onkyo can be used.
- I didn't know that PRO amps can be used for HT purposes. They seem to carry a lot of watts. Won't that damage the A9's? Can anyone suggest me some models?
- Are there any similar amps that I can use for the SVS subwoofers?
post #39126 of 39131 Old 09-17-2014, 02:06 PM
xFreshEntrailsX's Avatar
Quoted: 17 Post(s)
Liked: 372
I'm running my A9's with a QSC GX5 500watt PRO stereo amp.. and the sound is clean, powerful and the A9's love it.. I bought it second hand from a friend who did a fan mod on it so it runs silent.. my pc is louder than the amp is..
You can find videos on the fan mods for pro amps.. and the pro amps are much much cheaper than others..
Onkyo TX-NR929, QSC GX5, Polk Audio RtiA9's, CsiA6, F/XiA6's, RtiA3's,PSA xs30se, Xbox 360, PS3, hopper w/Sling, Samsung 55" LED, All controlled with a Harmony One
xFreshEntrailsX is online now
post #39127 of 39131 Old 09-18-2014, 07:17 AM
GusGus748s's Avatar
Quoted: 53 Post(s)
Liked: 594
An amp is an amp. You can even use a car amp to power them.
Media Server: UnRaid Server: 15TB of storage and growing :).
Home Theater Set Up:
GusGus748s is offline
post #39128 of 39131 Old 09-18-2014, 08:28 AM
I own a Onkyo A-9050 Integrated Stereo Amplifier now and powering my A9's. Is that a good idea to sell it and purchase a Crown XLS 1500? Is Crown XLS 1500 a overkill? Any thoughts?
post #39129 of 39131 Old 09-18-2014, 08:55 AM
How about Crown Audio XLS1000?
post #39130 of 39131 Old 09-18-2014, 06:03 PM
Liked: 544
You can use pro-amps some prefer not to, others dont care.
It can be a touchy subject.
I am of the use a HT amp rather than pro amp for my speakers unless your talking DIY subs.
But the Crowns will work and some have used those or similar amps.
Like ALL things audio YMMV
post #39131 of 39131 Old Yesterday, 08:31 AM
wglong's Avatar
HT front stage. Tsi400's, vs RTI8's, vs RTIA5's. L/C/R will be same
I'm building out my new HT and have a 120" acoustically transparent screen and will be putting the L/C/R speakers behind the screen. I plan to use the same speaker as my L/R for my center due to the feedback that this is the best option (is it?).
I'm going to Fry's this weekend; however, I'm not too hopeful I'll be able to test all three of these options there. Best Buy here is hopeless and doesn't have any Polk's on display.
I need 3 of the same speaker, and right now through the ebay Polk store I can get the RTI8's for $149 refurb and then a pair at $399 that are new. That seems like a great deal. I'll worry about my surrounds when I pick my front stage.
I hear the RTI's are better for HT and Tsi400's are better for movies. Just need to make sure the RTI/RTIA can be powered properly with my 95W Denon.
Is there a real difference between the RTI8 and RTIA5. I keep reading conflicting information around the woofer and tweeter. I don't care about appearance since they will be behind the screen.
Room: Multipurpose 14x22x9, 100% movie viewing
Equipment: Denon AVR-X2100W, no plan for amp (AVR doesn't have pre-outs)
Sub: BIC F12
Help me decide!
wglong is offline
Reply Speakers
Polk Audio , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Polk Audio Rti4 High Performance Bookshelf On Wall Speakers , Polk Audio Csi5 High Performance Center Channel Speaker , Polk Audio Rti6 High Performance Bookshelf Speakers Pair Black , Polk Audio Three Way Vanishing Rt Series In Ceiling Speaker 70 Rt , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio Monitor 30 Bookshelf Speakers Cherry , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Cherry , Polk Psw108 10 100w Psw Series Powered Subwoofer , Polk Audio R50 Floorstanding Speakers Each , Polk Audio Surroundbar 4000 Iht Virtual Surround Speaker Bar With Wireless Su
Gear in this thread - Psw108 by PriceGrabber.com
