Calling all Polkies:Official Polk thread - Page 1329 - AVS | Home Theater Discussions And Reviews
post #39841 of 39856 Unread Today, 06:18 PM
NODES's Avatar
Quoted: 355 Post(s)
Liked: 114
Originally Posted by Lindros88 View Post
I'm returning my Polk speakers. The ear fatigue is not something I'm willing to overlook. I'm switching back to my energy take classic system. The whole reason I upgraded to the cs2 and monitor70s was because I wanted a little more power. Would I be better off just buying a new subwoofer instead?
I know that by pushing my RTI A9's into the corner the sound was tamed when compared to moving them out 12 inches from their corner.
Who needs 4K?... just go see your optometrist.
NODES is online now
post #39842 of 39856 Unread Today, 06:20 PM
NODES's Avatar
Quoted: 355 Post(s)
Liked: 114
what sub do you have now? how big is your room you are trying to fill with sound?
NODES is online now
post #39843 of 39856 Unread Today, 06:28 PM
PretzelFisch's Avatar
Quoted: 79 Post(s)
Liked: 162
he has an energy take system now in an irregular 13x13x8 ish room.
this very much sounds like a placement issue. I would like to get a pic of the setup and the distance of speakers from wall and MLP
PretzelFisch is online now
post #39844 of 39856 Unread Today, 06:31 PM
Quoted: 79 Post(s)
Liked: 162
he complained of boomy base when the speaker was set to large. which sounds like they are close to a wall. how much of the fatigue is do to the monitor being a little bright or a first reflection point is the big question he needs to figure out.
post #39845 of 39856 Unread Today, 06:32 PM
Lindros88's Avatar
Originally Posted by PretzelFisch View Post
what does a little more power mean? louder or more chest punch?
Chest punch. Is that even possible to accomplish without spending a fortune? I actually like the sound quality of the energy take classic system, it's just that I wanted the sound to have more punch to it.
Lindros88 is online now
post #39846 of 39856 Unread Today, 06:43 PM
Lindros88's Avatar
Yes, the left monitor70 is close to a wall. Within a foot. Unfortunately due to the shape of my room, this can't be avoided. When I adjusted the crossover, it did help with the boominess, but not the ear fatigue. The weird thing is that the monitor70s don't sound bright at all, yet I'm still experiencing ear fatigue. Usually within about 20 minutes of listening.
post #39847 of 39856 Unread Today, 06:44 PM
Quoted: 79 Post(s)
Liked: 162
chest punch is mid bass not so much subwoofer. but you won't get much of it from a 3 inch driver like what is in the energy take. you probably need to look at 5 or 6 inch drivers. you should get that from the monitor 70 if your not you managed to put them in a location causing a null in the 60-300 range.
post #39848 of 39856 Unread Today, 06:52 PM
Lindros88's Avatar
So if I were to pull the left speaker far enough away from the sidewall (maybe a foot?) and rerun calibration, it should eliminate ear fatigue and achieve chest thumping bass?
post #39849 of 39856 Unread Today, 07:03 PM
NODES's Avatar
Quoted: 355 Post(s)
Liked: 114
I do not see chest thumping bass from the 70's, I have the A9 and I cannot get it from them running 200 RMS to each one.
NODES is online now
post #39850 of 39856 Unread Today, 07:09 PM
Lindros88's Avatar
Is it true that chest punch is more dependent on mid bass like pretzel said, rather than a good subwoofer?
post #39851 of 39856 Unread Today, 07:20 PM
chi_guy50's Avatar
Quoted: 516 Post(s)
Liked: 236
I know that a number of long-time (and knowledgeable) posters here are down on the Monitor series--and there is no disputing that the RTi(A) and LSi(M) series are superior--but just to give you another data point I wanted to let you know that I am running a 11.1 Monitor setup with 75t's (a newer but essentially identical version of the 70's) as mains and I never get fatigued listening to them. I generally play music all day long when I am home, and both music and movies sound fantastic on my system (powered by a 140W/ch AVR-X5200W). I consider my speaker system a great value for the relatively modest cost.
I hope you find the solution that is right for you, but you've already gotten a lot of good advice here on avenues of investigation. Good luck!
chi_guy50 is online now
post #39852 of 39856 Unread Today, 07:29 PM
Lindros88's Avatar
Thanks. I would be thrilled if I could get the performance that I wanted out of these speakers. Do you think pulling the left speaker a foot away from the wall could make the difference?
post #39853 of 39856 Unread Today, 07:31 PM
NODES's Avatar
Quoted: 355 Post(s)
Liked: 114
try it and let us know.
NODES is online now
post #39854 of 39856 Unread Today, 07:33 PM
Lindros88's Avatar
Do you get chest thumping bass with this setup?
post #39855 of 39856 Unread Today, 07:34 PM
Quoted: 79 Post(s)
Liked: 162
not sure where you sit rough estimate fl at 2ft from wall and 1.5 into the room with fr 2.8 from the wall and 1.5 in. with main seating at 1.4 from back wall and 6.5 from side wall or 5.8 from the front wall. otherwise you have probably a dip in the 80 to 120hz range. you might try putting the cross over at 120 with the energy and move the subwoofer into each corner for better response.
this is just based on a 13x13 room simulation
post #39856 of 39856 Unread Today, 07:34 PM
Lindros88's Avatar
I'll do it now. I'll post my results soon.
Reply Speakers
Polk Audio , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Polk Audio Rti4 High Performance Bookshelf On Wall Speakers , Polk Audio Csi5 High Performance Center Channel Speaker , Polk Audio Rti6 High Performance Bookshelf Speakers Pair Black , Polk Audio Three Way Vanishing Rt Series In Ceiling Speaker 70 Rt , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio Monitor 30 Bookshelf Speakers Cherry , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Cherry , Polk Psw108 10 100w Psw Series Powered Subwoofer , Polk Audio R50 Floorstanding Speakers Each , Polk Audio Surroundbar 4000 Iht Virtual Surround Speaker Bar With Wireless Su
Gear in this thread - Psw108 by PriceGrabber.com
