Calling all Polkies:Official Polk thread - Page 1341 - AVS | Home Theater Discussions And Reviews
post #40201 of 40217 Old Yesterday, 02:13 PM
chi_guy50's Avatar
Quoted: 674 Post(s)
Liked: 307
Originally Posted by Barrettmr View Post
Thanks guys, all this advice and experience sharing really helps me! I think I'm going to go with the 80F/X LS. Once I have it all installed I'll report back and hope my experiences can help others
While it's certainly not a "show-stopper" factor, ideally you'll want to use the same speakers for your Atmos (or DTS:X or Auro) front and rear top arrays in order to achieve seamless front to back panning.
I think your current RC80i would serve just fine, but the 80F/X-LS are better speakers FWIW.
chi_guy50 is online now
post #40202 of 40217 Old Yesterday, 03:43 PM
Barrettmr's Avatar
Quoted: 47 Post(s)
Agreed, with the FF discount I ordered the 80F/X-LS and I also ordered the Emo 5 channel amp - can't wait to get this new gear in and hear the upgrade
Barrettmr is offline
post #40203 of 40217 Old Yesterday, 04:39 PM
chi_guy50's Avatar
Quoted: 674 Post(s)
Liked: 307
Just make sure that:
(1) you give careful study to the Dolby Atmos (and soon to be unveiled) DTS:X speaker layout recommendations before you start cutting holes in your ceiling;
(2) the AVR/SSP you get is capable of processing both both Atmos and DTS:X (wait for the 2015 or 2016 models to hit the streets);
and (3) you position the listener-level speakers no higher than 1.25 times ear-height to allow for adequate separation between the base and overhead layers.
post #40204 of 40217 Old Yesterday, 07:21 PM
Geoff4RFC's Avatar
Quoted: 77 Post(s)
Liked: 1399
Congrats! What kind of interconnects did you order?
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
post #40205 of 40217 Old Yesterday, 07:46 PM
Barrettmr's Avatar
Quoted: 47 Post(s)
Oh - I didn't order anything that sounded like that - what is the interconnects? Did I miss something... oh is this the phono/RCA cable that goes from my receiver pre-out to the unbalanced RCA on the AMP? If so I purchased some RCA cables when I got my Oppo 103 to connect the analog outs to the receiver thinking that would be better than HDMI or something odd like that, but ended up using the HDMI out on the Oppo for sound and video so was planning on using those to rig up the new AMP. Please let me know if I over looked something.....
post #40206 of 40217 Old Yesterday, 07:50 PM
AnnapolisSony's Avatar
Quoted: 55 Post(s)
Liked: 123
Congrats man. That's exciting about the XPA-5.
Just do me one favor. Listen to your L-C-R Polk in-walls after you get them installed but BEFORE you hook up the amp. Then hook up your Emo and have at it. #ampporn
Displays: Epson 5030UB | 100-inch Elite Sable Fixed Mount | Samsung UN46F5500 LED TV
Sources: Yamaha RX-A1010 | Emotiva XPA-3 | OPPO BDP-103 | Panamax M5300 | Pro-ject Carbon Debut Turntable | Sonos Connect | Apple TV
Speakers: Polk 265-RT (L/R) | Polk 255C-RT (C) | Polk 65RT (L/R SUR) | Polk RC80i (L/R REAR SUR) | Subwoofers: PSA XV-15se X 2
Controls:Wall-mounted iPad AVS Forum Thread: 904WMC Media Room Thread
AnnapolisSony is online now
post #40207 of 40217 Old Yesterday, 07:51 PM
Barrettmr's Avatar
Quoted: 47 Post(s)
I already have holes for the RC80i's so that is done but if I add a second pair for Atoms I will need to know where to put them, see the diagram of my layout as it is attached. I will go google Atmos speaker placement - do you have any good links? Oh and point 3, are the listener level speakers the front main LCR?
Name:	Home Theater.png
post #40208 of 40217 Old Yesterday, 07:54 PM
Barrettmr's Avatar
Quoted: 47 Post(s)
That sounds like a good plan! And thanks so much for pointing me in the right direction, the guys over at Emotiva should give you a voucher for the referral
post #40209 of 40217 Old Yesterday, 08:02 PM
Geoff4RFC's Avatar
Quoted: 77 Post(s)
Liked: 1399
LOL, sounds like you have it covered! The best kind of interconnects you can use are shielded ones, there's single, double and triple shielding. By all means, use what you've got now, you can look into cables some other time. The interconnects that Emotiva sell are pretty good, that's what I use, they're double shielded and don't cost an arm and a leg, you're going to get a shock when you see what companies charge for cables if you haven't already.
Just remember this, the cable is responsible for transferring a signal, with all cables (interconnect) you get signal degradation. A cable with decent shielding can degrade the signal "less".
You have now fallen a little further down the rabbit hole my friend
Here's something else for you to play with, either your amp or your AVR came with a "trigger" cable, you can connect the trigger cable from your AVR's 12v Trigger out to the 12v Trigger in on the amp. That way, you can turn the amp on and off with your Onkyo remote. I don't have any of mine hooked up, I just leave my amps on 24/7
Set up:
post #40210 of 40217 Old Yesterday, 08:08 PM
Quoted: 55 Post(s)
Liked: 123
This is what I use to connect the pre-outs on my AVR to my Emo. The price is right:
http://www.monoprice.com/Product?c_i...seq=1&format=2
I use MP for most everything audio/video cable related. You'll never EVER have to buy HDMI cables, speaker wires, power cords or TV mounts at a big box store again
post #40211 of 40217 Old Yesterday, 08:15 PM
Geoff4RFC's Avatar
Quoted: 77 Post(s)
Liked: 1399
I've used those, they are a great bargain however, I've gone back to non digital coaxial cable.
Set up:
post #40212 of 40217 Old Yesterday, 08:37 PM
Quoted: 55 Post(s)
Liked: 123
It is obvious that you have done a lot of research on this topic. Would love to hear your reasoning for going back to non digital. I've often wondered if I might be selling myself short by using these digital coax cables from MP. I'm all ears man! Any links for non digital cables or are they usually DIY? Thanks in advance...
post #40213 of 40217 Old Yesterday, 08:39 PM
Barrettmr's Avatar
Quoted: 47 Post(s)
Yeah I think I am well and truly falling into that rabbit hole I was googling and found a lot of people had one of these things Panamax M5400-PM - so do I need that as well for the AMP to connect or is that another extra if you want to go that extra mile?? It looks cool but would have to start working out loads etc. I guess.
Edit, @AnnapolisSony - I just saw in your sig that you have the Panamax M5300 would that be ok for the Emo XPA-5 do you think - they have them at my local BB so I could pop down tomorrow and grab one. If it helps provide a clean sound to my new Polk's and protect the Emo I'm happy.
post #40214 of 40217 Old Yesterday, 09:51 PM
Geoff4RFC's Avatar
Quoted: 77 Post(s)
Liked: 1399
Right on, DIY interconnects and power cables are two areas I haven't delved into as of yet. I do however LOVE making my own speaker cables.
I want to save money just like the next guy, and I don't put any stock into the whole "cable" debate, like when I hear or read of someone adding a power cable to their system and they go off about the sonic improvements, I just yawn and say good for you and your money
When you're moving electrical current from the wall to your gear, or from your amp to your speakers, I just look at resistance and connections. Shielding is good, but I don't see it affecting the sonic signature of your gear or speakers.
Your interconnects transfer a digital signal. If you want to use the DAC in your CD player, BRP or other source material with a DAC, use a non digital cable. If you want to hear the DAC in your AVR, use a digital cable. This was the recommendation from a tech rep over at Emotiva. Those cables are nice from MP and are double shielded, but I'd love for them to make non coaxial version. Dielectric Teflon is another great product for shielding.
I'm unable to swallow someone telling me that cable x and cable y makes their system sound way better, but if they tell me that it improves the signal degradation, then it sounds more plausible. Check out "noise floor".
Set up:
post #40215 of 40217 Old Yesterday, 10:05 PM
Geoff4RFC's Avatar
Quoted: 77 Post(s)
Liked: 1399
Yeah I think I am well and truly falling into that rabbit hole I was googling and found a lot of people had one of these things Panamax M5400-PM - so do I need that as well for the AMP to connect or is that another extra if you want to go that extra mile?? It looks cool but would have to start working out loads etc. I guess..
Wow, that M5400 looks way nice. I just got a free Panamax MR4300 for free for just ordering my AVR. I don't use it for much, I have my internet cables going through it and my BRP.
I started out with a Tripplite HT10DBS surge protector with 10 outlets. It was just fine (as a mega power strip) before I got my first amp, then it started to hum. I put the AVR and amp plugs at opposite ends of the strip and minimized it, but it was still there.
Then I got the power strip from Emotiva, this bad boy has some serious outlets. I have all three amps and my AVR plugged into it and there's no hum whatsoever.
So, is a power conditioner necessary?? I've gone five years without one. I suppose it would be nice and could come in handy, especially if you're running a lot of high current gear, or if you've got a lot of lightning strikes in your area. Yeah, if you've got the extra dough, hook it up.
Set up:
post #40216 of 40217 Old Yesterday, 10:28 PM
zpatter1's Avatar
Quoted: 41 Post(s)
Anyone need a 50% off code? After I was given one to use and ordered my speakers, Polk sent me a code. AnnapolisSony was kind enough to share his with me, and I'd like to do the same for someone else. Just PM me!
zpatter1 is offline
post #40217 of 40217 Unread Today, 04:45 AM
Quoted: 55 Post(s)
Liked: 123
I absolutely love my PANAMAX power conditioner but it is strictly for power/surge protection. It really just gives me an extra piece of mind about protecting all of my components. I have my PJ, AVR, Emo, OPPO, 2 DVRs, a Sonos Connect and a Samsung TV running thru it.
You can also run your cable and Ethernet lines thru it as well but I do not do that. I have an Ethernet switch on the back of my rack so I can run lines directly to my AVR and my OPPO.
A fellow forum member, Carlos, told me to call Panamax to see if they had any refurb units for sale and they did. I think I saved 50% and the unit was virtually brand new! If you dont mind springing for a new and you have room in your rack, DO IT. Again, it is not necessary to have but it will surely give you a piece of mind.
Also, I have a trigger hooked up from my Emo to my AVR. So when I turn my AVR on and off, my Emo turns on and off as well. Very handy.
Reply Speakers
Polk Audio , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Polk Audio Rti4 High Performance Bookshelf On Wall Speakers , Polk Audio Csi5 High Performance Center Channel Speaker , Polk Audio Rti6 High Performance Bookshelf Speakers Pair Black , Polk Audio Three Way Vanishing Rt Series In Ceiling Speaker 70 Rt , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio Monitor 30 Bookshelf Speakers Cherry , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Cherry , Polk Psw108 10 100w Psw Series Powered Subwoofer , Polk Audio R50 Floorstanding Speakers Each , Polk Audio Surroundbar 4000 Iht Virtual Surround Speaker Bar With Wireless Su
Gear in this thread - Psw108 by PriceGrabber.com
