Calling all Polkies:Official Polk thread - Page 1376 - AVS Forum | Home Theater Discussions And Reviews
 543Likes
post #41251 of 41277 Old 02-03-2016, 07:44 AM
EndersShadow's Avatar
Quoted: 140 Post(s)
Liked: 603
Originally Posted by ray0414 View Post
About 15 minutes ago I ordered a regular y adapter with 2 female ends and a 35 ft sub cable for 25 bux shipped. I love amazon.
Its too late at this point, but I'd honestly suggest buying some non bottom of the barrel stuff off Amazon, and instead use a single of the adapters I mentioned (which is one solid piece and really nice) and a pair of LC-1 sub cables from Blue Jeans Cable. They let you custom order the number of feet you need, and the cable isnt super pricey (IMHO) and is MUCH better than your basic monoprice/Amazon interconnects. And if you feel like really upping your game, look at the Audioquest Black Thunder
I recently got 2 psw505s for 169 each, excellent subs for a normal home theater system. I put my older 12" sony on craigslist for $50, but now knowing that I can add it to my system via the Y adapter I'm gonna just keep it. Maybe I'll stick that one behind my couch or option 2 is behind the tv (I've got a corner set up).
I'd highly suggestion you just sell it.
Non-matching subs can wreak havoc on your system. Since you have 2 matching subs coming in anyway, the Sony is likely the weakest link and your system will probably sound better without it.
Getting multiple subs of different make/models/spec's to play nice requires some serious skill, and honestly the Sony you have doesn't IMHO warrant that type of effort for what will largely be little to no gain, and likely a loss in sound quality.
My Setup
There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #41252 of 41277 Old 02-03-2016, 11:35 AM
mknecht01's Avatar
Liked: 25
Hey folks,
Adding a pair of LSi9 to my LSi7s I got in December... so of course I now need an upgraded AVR with pre-outs. I was just going to step up to the Yammie Aventage 840 from my 720, which Amazon had at the really nice price of $499.95... but that was apparently an after-Christmas deal that ended at the end of January and now it's $50 more - still not bad, but then I went looking at A4L and found some refurbished Aventage units but also some refurbished Denons at similar price points. Also, the research I have done has indicated a concern about Yamaha's low pre-out voltage being a problem for some brands of external amp... so the Denons seem more attractive for that reason. I'm considering picking up a used 5 channel Rotel RB-985 from the guy I'm getting the 9's from next week, and I want to make sure my AVR doesn't introduce any extra problems into that equation.
Any input from the group? Looks like Yamaha Aventage A840 ($480) or A1040 ($550) vs. Denon X3100W ($450). Ready... GO!
--Matt K
mknecht01 is offline
post #41253 of 41277 Old 02-03-2016, 01:16 PM
Quoted: 140 Post(s)
Liked: 603
Originally Posted by mknecht01 View Post
Hey folks,
--Matt K
The only issue I'm aware of with pre-out voltage problems with any AVR is the use of a pro-amplifier. Some AVR's cant provide enough to fully drive the pro amp.. So if your planning on using a Crown, Behringer, etc amp then you need to pay attention a bit more.
If your using a regular home theater amp (Adcom, ATI, B&K, etc) thats not an issue so I would ignore it.
Personally I went Denon not for that reason, but that I prefer Audyssey XT32 over YPAO, MCACC and barely over ARC....
My Setup
post #41254 of 41277 Old 02-03-2016, 02:16 PM
Alex F.'s Avatar
Quoted: 255 Post(s)
Liked: 134
Yamaha rates their receivers' preamp outputs very conservatively. The RX-A840 you are considering, like my RX-A2020, is rated at 1.0V output. The 2020's preamp section has far more than enough output to drive my Adcom GFA-5503 (1.4V input sensitivity rating) power amplifier. The Rotel RB-985 has a rated input sensitivity of 1.0V, so you will have no problem driving it to full output.
Theater room: Panasonic TC-P65S60 plasma television; Yamaha Aventage RX-A2020 (preamp section); Adcom GFA-5503 and GFA-5400 amplifiers; Polk LSi25, LSiC, and LSiF/X loudspeaker system; Velodyne FSR-18 servo-subwoofer; Sony BDP-S6500 Blu-ray player.
Music room: McIntosh MA6500 integrated amplifier, Audible Illusions (tube) preamp, Quad 99 preamp, Quad 909 amplifier, Acoustic Research AR9 and Dahlquist Prelude loudspeakers, Onkyo DX-7555 and Melos (tube) CD players, Phase Linear 8000II turntable.
Alex F. is online now
post #41255 of 41277 Old 02-03-2016, 02:28 PM
Sean Spamilton's Avatar
Quoted: 246 Post(s)
Liked: 320
The new crown series (XLS 1502 etc) has variable voltage control, so you're pretty much guaranteed not to run into problems as such.
Sean Spamilton is online now
post #41256 of 41277 Old 02-03-2016, 04:16 PM
Aarghon's Avatar
Quoted: 71 Post(s)
Liked: 326
Originally Posted by Geoff4RFC View Post
Thanks man! And for the record........you ARE from the core group
So um, you want fire power? I have already gotten permission to grab the XPA-7 once we're settled into a new place. My wife is dying for me to have a dedicated room so she doesn't have look at foam
I will employ an 11.2 for starters, eventually moving up the sub chain. I will have my four A9 front stage again and powering the mains with 400wpc and the wides with an XPA-2.
The other stereo amp will go to a dedicated 2ch rig. Oh yes my friend, I have plans that include firepower and lots of it
Awesome, more amp porn And keep a part of the budget for strenghtening the foundations!
Polk Audio LSIM703, Polk Audio LSIM704c, Polk Audio RTI-A1 surrounds
Dual Reaction-Audio BPS212 turbo subwoofers
Marantz AV8801 preamp, Rotel RMB-1095 power amp
Pioneer Elite n50 network player
Marantz CD6004 cd player, Marantz UD5007 Blu ray player
Panasonic Tcl55dt60 led tv,Playstation 3 and a lot of old consoles
Aarghon is online now
post #41257 of 41277 Old 02-03-2016, 04:35 PM
Quoted: 140 Post(s)
Liked: 603
I'm aware but that's one brand from a sea of options so it's still a problem...
And the new models are pricey for what little they added over the original models....
post #41258 of 41277 Old 02-03-2016, 09:03 PM
Geoff4RFC's Avatar
Quoted: 113 Post(s)
Liked: 1432
Some of my latest solid oak construction, able to hold heavy amps
[IMG]https://lh3.googleusercontent.com/LlcxnBB5IRlr7sl26JSsfPOh5ULTWBGsTOYOndSiUMUSfjs0MK ucoFT7TClMDLV6LJ9P3PFxLE5C4ezb20-cvdoC27UcEIpczupax5nwVytPQXswe2AooDGG0PqzD7hma3Fhc _G_cJ-avSbHuNFg0nDZmZgSEivEoAlqclOdcmgZKVfDmNAI21KtSDfqE MW-n0nV2NIEbCRnvT-rBKfTMsrJDmS5iyXs9-5mwhmQys1opzMvyMUnDIPC6fgfBkVUbwZNBAQ22NJOaIpAVswE 7RB1m4tQN5vRF8fDpKKfrz6fLQWZNjyV_UKhIkpmnNHmLuM2bk gNmZbzqfokMTTcD2PaWC4wNVEnHk****PLvQJxHzBKW7iWVH9h eqVVgonoh_UDp4cJN8iQjjHIjlnH1H9JeUPuoboPiEZ9Mp2_Yw R0_nz06ejpvcxYnXs9zAApNIyUTi_fMerdNdW2INfqGwxbRAGn NkJee2OQCfauCyGOyAycHXycmj7yakOcER46yLF0DnR-sWzYMRAdnkTq3xw7FL5cRfqeKwwHvcV_zMvDUy5eLSGWYBwx2Y eagbctno8n=w1694-h953-no[/IMG]
yanks1 likes this.
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
post #41259 of 41277 Old 02-03-2016, 09:04 PM
Geoff4RFC's Avatar
Quoted: 113 Post(s)
Liked: 1432
Hmmm, let's try again
Set up:
post #41260 of 41277 Old 02-03-2016, 09:05 PM
Geoff4RFC's Avatar
Quoted: 113 Post(s)
Liked: 1432
Set up:
post #41261 of 41277 Old 02-03-2016, 09:06 PM
Geoff4RFC's Avatar
Quoted: 113 Post(s)
Liked: 1432
Set up:
post #41262 of 41277 Old 02-03-2016, 09:18 PM
Quoted: 74 Post(s)
Liked: 40
Hey folks,
--Matt K
Im using a Yamaha tsr 7790bl and running 2 crown xli amps. A 1500 going to 2 polk tsi 500 and a 2500 going to 2 rti12's. Plus 2 subs with absolutely no problems but pissed off neighbors!!!
Geoff4RFC likes this.
James McCarty is offline
post #41263 of 41277 Old Yesterday, 09:04 AM
RobLee's Avatar
Quoted: 127 Post(s)
Liked: 179
Geoff, I'm not seeing any of your images, just a minus sign inside a circle. And Google says the above link does not exist.
When you post there is a rectangle below the text box where you can drag your thumbnails. That's all I know about posting images.
Polk RtiA9's, Denon 4520 & Emo XPA-5, CsiA6, RtiA7 surrounds, FxiA6 rears, twin Klipsch Synergy Sub-12's. Family room: RtiA3's & Rti4 surrounds, Csi3, Klipsch SW-450, Yamaha 565... Bedroom: Lsi9's on an Onkyo TX-8050
RobLee is online now
post #41264 of 41277 Old Yesterday, 12:21 PM
John Megadeth's Avatar
Cheating on my other forum just to check in and say hi to a couple guys.
You monster.
John Megadeth is offline
post #41265 of 41277 Old Yesterday, 03:53 PM
ray0414's Avatar
Quoted: 5406 Post(s)
Liked: 3059
got it all hooked up.
and honestly IMO it sounds excellent.
I have the 2 polk subs in front of me, and the 12" sony behind my couch (3 feet away). It sounds pretty dam awesome and the only people who may be able to tell any negatives would be the super high audiophiles and even then it would be competely nit-picking. My couch now rumbles and can completely feel it in my chest and i am completely surrounded by bass, a very nice compliment to the system i just set up. a much better option than simply selling the sony sub for $50.
TV; samsung 65JS9500(great deal from cleveland plasma) SAMSUNG 65 HU9000+sek3500(7 months,sold) SAMSUNG 65 8550 4k (30 days) SONY XBR65X850B 4k(owned for 2 weeks), SAMSUNG 65 F7100 1080P(11 months) AVR: sony 1040 7.2 OPPO 103D
MASTER LIST OF HDR CONTENT THREAD HERE, UPDATED OFTEN
ray0414 is online now
post #41266 of 41277 Old Yesterday, 05:14 PM
Aarghon's Avatar
Quoted: 71 Post(s)
Liked: 326
yes, geoff we can't see your pictures
post #41267 of 41277 Old Yesterday, 05:24 PM
Aarghon's Avatar
Quoted: 71 Post(s)
Liked: 326
Well if you are happy with it, it's all that counts. But if I may add a little something, I think Enders was right. You can feel some more boom with your Sony sub behind you, and it might be good...But to say that only super high audiophiles could tell any negatives is quite a big assertion. Did you EQ your subs? Did you take any measures? Because I'm pretty sure your Sony sub, that isn't in the same league of your Polks maybe be only bringing more bass, but probably boomy bass. And if it does, it will hurt your overall sound detail... And while it may sound good, maybe it could sound better. I'm not saying that to sound condescending, but Enders is a really knowledgeable person and I'm pretty sure he's right. I would lend an ear to it's advice for sure.
post #41268 of 41277 Old Yesterday, 05:40 PM
ray0414's Avatar
Liked: 3059
I would consider Enders and yourself to be of the higher end audiophiles. You guys could probably hear negatives, luckily I won't be having you guys over any time soon
I do like how having the sub behind the couch (which is also against a wall), creates a box-like effect.
I haven't really had a good chance to test out movies because my blu ray player remote is broken and I'm awaiting the replacement. So far I've only listened to youtube music and a few movies via the tvs built in app.
If the polk psw505 ever drops to a ridiculous low price, maybe I'll get it so all 3 match. But til then I've spent quite a bit upgrading my towers and subs. I've got a uhd blu ray player on order along with almost 10 uhd discs. Sh*ts getting expensive around here!
post #41269 of 41277 Old Yesterday, 06:42 PM
Quoted: 140 Post(s)
Liked: 603
If couch rumble is what your after just buy a Buttkicker or two or three.
I did and it gave me the tactile feel I was lacking and takes up no space at all.
And it goes down to 10hz and lower east which in sure is a lot lower than your subs lol....
post #41270 of 41277 Old Yesterday, 09:59 PM
Geoff4RFC's Avatar
Quoted: 113 Post(s)
Liked: 1432
Okay, let's see if I can do this time;
Set up:
post #41271 of 41277 Old Yesterday, 10:02 PM
Geoff4RFC's Avatar
Quoted: 113 Post(s)
Liked: 1432
https://photos.google.com/u/0/photo/...HHExfmoFiKZQ6Y
Set up:
post #41272 of 41277 Old Yesterday, 10:03 PM
Geoff4RFC's Avatar
Quoted: 113 Post(s)
Liked: 1432
Can anyone see anything in the last two posts? Are you able to open the link?
Set up:
post #41273 of 41277 Old Yesterday, 10:34 PM
PretzelFisch's Avatar
Quoted: 258 Post(s)
Liked: 227
No the forum does not like your pictures link.
basshead81 likes this.
PretzelFisch is offline
post #41274 of 41277 Old Today, 06:43 AM
Quoted: 40 Post(s)
I need some advice...
Over twenty years ago, I bought four PolkAudio Monitors, s/n MR29xyz and a Klipsch KV-2 CC speaker to use with a Yamaha RX-V480. A few RS 12" passive subs were added over the years and the AVR was replaced by a newer Yamaha and it by an Onkyo 7.1 AVR. The old Monitors just didn/t have the LF of the Infinity P163 bookshelves I tried, so I replaced them with four of the P163's, the old passive subs having given way for a powered Sony 10" sub. I moved right after that and replaced the bookshelf Infinity's with P363 towers. My problem is hoarding old audio equipment - among other items. My spare/hobby room now has a pair of Yamaha AVR's, four each Polk Monitors and P163's, and a Klipsch KV-2, among other things. I can Craig's List most items - but the Polks have some sentimental value. Are they worthy of keeping... and, if so, should I update the crossovers? Are the crossovers more than just a high pass capacitor to the dome tweeter? The 6.5" LF drivers' have vg surrounds. I believe these speakers were made in the US, too - a verification on that would also be appreciated. Thanks!
Stainz is offline
post #41275 of 41277 Old Today, 11:13 AM
VikenK's Avatar
Quoted: 27 Post(s)
Polk CSi3 vs CSiA6 size comparison
Hello Everyone,
OK. A second try. A size comparison between Polk Csi3 and CsiA6 center speakers, for those who may find it useful. The CSiA6 being the bigger one.
ID:	1231753   Click image for larger version
Viken K.
VikenK is online now
post #41276 of 41277 Old Today, 12:02 PM
Quoted: 249 Post(s)
Liked: 99
Wowza!! Thx, I have the Csi3 in one of my set-ups and its fine
yanks1 is offline
post #41277 of 41277 Old Today, 04:38 PM
RobLee's Avatar
Quoted: 127 Post(s)
Liked: 179
Yeah, we use a Csi3 under the TV in a video console and it works fine. It is compact and can be easily placed due to its sealed back, and has the Rti's signature clarity and definition. But the Csi5/A6 is 50% larger and easily twice the weight and puts out a HUGE amount of sound, helped in part by the double rear ports.
Reply Speakers
Polk Audio , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Polk Audio Rti4 High Performance Bookshelf On Wall Speakers , Polk Audio Csi5 High Performance Center Channel Speaker , Polk Audio Rti6 High Performance Bookshelf Speakers Pair Black , Polk Audio Three Way Vanishing Rt Series In Ceiling Speaker 70 Rt , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio Monitor 30 Bookshelf Speakers Cherry , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Cherry , Polk Psw108 10 100w Psw Series Powered Subwoofer , Polk Audio R50 Floorstanding Speakers Each , Polk Audio Surroundbar 4000 Iht Virtual Surround Speaker Bar With Wireless Su
