Calling all Polkies:Official Polk thread - Page 1377 - AVS Forum | Home Theater Discussions And Reviews
 556Likes
post #41281 of 41310 Old Yesterday, 07:01 PM
zpatter1's Avatar
Quoted: 251 Post(s)
Liked: 137
The center plays something like 70-80% of the movie sound track. It and the sub are the most important. I was running 2.0 for a while while I saved up for the center, and I'm shocked at how little the fronts do in comparison to the center. I auditioned both the A4 and A6 centers, and the A6 just sounded so much fuller and robust.
Geoff4RFC, VikenK and yanks1 like this.
Front L&R: Polk RTi A3 (cherry finish)
Center: Polk CSi A6 (cherry finish)
Surrounds: Polk FXi A6 (black finish)
Subwoofer: SVS SB12-NSD
Receiver: Yamaha RX-V673
TV: 55" LCD
zpatter1 is offline
post #41282 of 41310 Old Yesterday, 11:11 PM
mknecht01's Avatar
Quoted: 18 Post(s)
Liked: 29
Originally Posted by EndersShadow View Post
The only issue I'm aware of with pre-out voltage problems with any AVR is the use of a pro-amplifier. Some AVR's cant provide enough to fully drive the pro amp.. So if your planning on using a Crown, Behringer, etc amp then you need to pay attention a bit more.
If your using a regular home theater amp (Adcom, ATI, B&K, etc) thats not an issue so I would ignore it.
Personally I went Denon not for that reason, but that I prefer Audyssey XT32 over YPAO, MCACC and barely over ARC....
Originally Posted by Alex F. View Post
Yamaha rates their receivers' preamp outputs very conservatively. The RX-A840 you are considering, like my RX-A2020, is rated at 1.0V output. The 2020's preamp section has far more than enough output to drive my Adcom GFA-5503 (1.4V input sensitivity rating) power amplifier. The Rotel RB-985 has a rated input sensitivity of 1.0V, so you will have no problem driving it to full output.
Originally Posted by Sean Spamilton View Post
The new crown series (XLS 1502 etc) has variable voltage control, so you're pretty much guaranteed not to run into problems as such.
Originally Posted by James McCarty View Post
Im using a Yamaha tsr 7790bl and running 2 crown xli amps. A 1500 going to 2 polk tsi 500 and a 2500 going to 2 rti12's. Plus 2 subs with absolutely no problems but pissed off neighbors!!!
I was AWOL for a couple of days while you guys chimed in on my question - thanks! I'm glad to hear that the Yamaha AVR shouldn't present an issue with most amps. I was looking into Crown and Behringer iNuke for the really decent prices, but this Rotel is coming to me from the guy I'm getting the LSi9s from at a nice price (and a MUCH better THD figure at the rated max power output). If I can score a (relatively) cheap pair of LSi15s for the front stage and feel like I need more power for the front channels, there are quite a few used Emotivas floating around out there right now so I think I'm good either way.
Now I just have to decide whether to go with the Denon or spend the extra bill on the Aventage 1040. I'm leaning towards the Yamaha right now just for familiarity's sake; it'll work just like my 720 but with built-in wifi, Spotify, a better DAC, and upgraded YPAO. Don't know much of anything about differences between the EQ packages but even on the low-end 720 I've got, YPAO seems to do good things for my space. Maybe somebody in the know could expound a bit on YPAO vs. Audyssey?
I've come a long way from the RM6750 HtiB system I bought in 2008, hahaha.
mknecht01 is online now
post #41283 of 41310 Old Yesterday, 11:31 PM
mknecht01's Avatar
Quoted: 18 Post(s)
Liked: 29
Good Lord yes, when my satellite HTiB system died three years ago and I replaced it with towers and a real center, I couldn't believe how much better it was, especially in the summer with a window AC in the room. No more "turn it up for dialog... now turn it down so the soundtrack and the explosions don't piss off the neighbors..." every time I watch something.
And you can't really beat dialog that is coming from the same general vicinity as the picture, rather than off to the sides and then MAYBE assembling into the illusion of a stereo image in the right place IF your L/R are good enough AND they are set up right AND your room doesn't screw up the imaging...
I went from the puny little RM6751 HTiB center to a CS400 and then a CS400i, which is roughly the equivalent of the CSiA6, but three or four models older. And I'll always vote for the biggest possible center speaker that timbre-matches the fronts.
post #41284 of 41310 Old Today, 12:02 AM
Geoff4RFC's Avatar
Quoted: 117 Post(s)
Liked: 1433
[/IMG]
Can anyone open these for pics?
http://i168.photobucket.com/albums/u...psrfhloywa.jpg
http://i168.photobucket.com/albums/u...psycezz3xx.jpg
http://i168.photobucket.com/albums/u...psjanu6mry.jpg
http://i168.photobucket.com/albums/u...psr9d8lbtm.jpg
http://i168.photobucket.com/albums/u...pswn9frwkn.jpg
http://i168.photobucket.com/albums/u...psjmjadapn.jpg
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is online now
post #41285 of 41310 Old Today, 12:25 AM
mknecht01's Avatar
Quoted: 18 Post(s)
Liked: 29
Affirmative - the links UNDER your question I can click through and see.
It looks like the images you attempted to link immediately above your text have a spurious "http://www.avsforum.com/forum/" appended to the beginning of them. Then there is HTML code that shouldn't be there which is preventing them from rendering in the bulletin board software.
I can see the code in my edit window where I quoted your post, and I massaged it for you to display in this reply. It looks like anything in between the image tags should be just a straight up URL starting with "http://..." - no angle brackets or "a href" or any of that HTML stuff.
Geoff4RFC likes this.
Fronts: RT800i -- upgrading to LSi9
Center: CS400i -- upgrading to LSiC
Surround: RT800i -- upgrading to LSi7
Sub: Infinity BU-2 - Don't judge me, it was free and I have neighbors.
AVR: Yamaha Aventage RX-A720
post #41286 of 41310 Old Today, 12:26 AM
Geoff4RFC's Avatar
Quoted: 117 Post(s)
Liked: 1433
I might have finally figured it out?????
ID:	1233873   Click image for larger version
ID:	1233881   Click image for larger version
ID:	1233889   Click image for larger version
ID:	1233897   Click image for larger version
Aarghon likes this.
Set up:
post #41287 of 41310 Old Today, 12:28 AM
Geoff4RFC's Avatar
Quoted: 117 Post(s)
Liked: 1433
Ahhh, thanks for the heads up!!! Man, what a chore to load pics from what it used to be a few years ago
Set up:
post #41288 of 41310 Old Today, 12:35 AM
mknecht01's Avatar
Quoted: 18 Post(s)
Liked: 29
Were you dragging them from a Google Drive the first couple of times? Cloud storage interacts... unpredictably... with forum software like this. I think it was choking on the super long "googleuser" URLs - there's probably a hard-coded character limit for web addresses in the forum software.
post #41289 of 41310 Old Today, 12:40 AM
Geoff4RFC's Avatar
Quoted: 117 Post(s)
Liked: 1433
Yes sir, that's exactly what I was "trying" to do
Have you decided on an AVR yet?
Set up:
post #41290 of 41310 Old Today, 12:40 AM
mknecht01's Avatar
Quoted: 18 Post(s)
Liked: 29
Anyway, the thumbnails came through just fine on the most recent post, and when you click them expanded versions pop up, so looks like whatever you did there is the way to go.
Also, holy crap, that's a lot of gear. And I know you've got more. Way to keep Emotiva and Polk in business there, all by yourself.
Geoff4RFC and yanks1 like this.
post #41291 of 41310 Old Today, 12:50 AM
mknecht01's Avatar
Quoted: 18 Post(s)
Liked: 29
I try not to make large-ish spending decisions after 2:30 AM, especially when I've been drinking.
Went and read more about the Denon earlier and now I might be leaning that way though... sounds like the amplifier is a little more robust and they claim it's rated to operate 4 ohm speakers on "all channels," whereas the Yamaha user manual downloads say the Aventage units only really should run 4 ohm in the front L/R. If I get a pair of LSi15s for front L/R then the 9s will go to side surround and the 7s will go to rear surround or front height and I'll need to run the 7s off the AVR at least for awhile until I can get a second external amp.
My God, this is a money pit.
post #41292 of 41310 Old Today, 01:09 AM
Geoff4RFC's Avatar
Quoted: 117 Post(s)
Liked: 1433
LOL, I can relate!!!! Yeah, I like to call this "quicksand"
It sounds like you have it narrowed down pretty well on your AVR direction. Not to cause you more trouble, but.........have you looked at A4L? I got my Integra from them, heck of a deal, I went from an Onkyo 807 to the DTR-70. Nice little upgrade and I paid half price on A4L. They might have what you're looking for at a much lower cost.
Set up:
post #41293 of 41310 Old Today, 01:29 AM
mknecht01's Avatar
Quoted: 18 Post(s)
Liked: 29
Yeah A4L is where I found those two or three different models at acceptable prices. I'm not able to pay retail for those babies when they are new! The Denon seems like a particularly good deal at $450.
post #41294 of 41310 Old Today, 06:13 AM
RobLee's Avatar
Quoted: 130 Post(s)
Liked: 181
Interesting cooling solution you have there on the right... for the Emo's I'm guessing?
Polk RtiA9's, Denon 4520 & Emo XPA-5, CsiA6, RtiA7 surrounds, FxiA6 rears, twin Klipsch Synergy Sub-12's. Family room: RtiA3's & Rti4 surrounds, Csi3, Klipsch SW-450, Yamaha 565... Bedroom: Lsi9's on an Onkyo TX-8050
RobLee is online now
post #41295 of 41310 Old Today, 06:58 AM
Aarghon's Avatar
Quoted: 73 Post(s)
Liked: 326
That's a lot of power Geoff, and your cables look neat! And it reminds me I need to buy one of those pangeas powercables... I've been upgrade less for way too long =S
Polk Audio LSIM703, Polk Audio LSIM704c, Polk Audio RTI-A1 surrounds
Dual Reaction-Audio BPS212 turbo subwoofers
Marantz AV8801 preamp, Rotel RMB-1095 power amp
Pioneer Elite n50 network player
Marantz CD6004 cd player, Marantz UD5007 Blu ray player
Panasonic Tcl55dt60 led tv,Playstation 3 and a lot of old consoles
Aarghon is offline
post #41296 of 41310 Old Today, 07:10 AM
climber07's Avatar
Quoted: 253 Post(s)
Liked: 1187
Geoff dusted... HE DUSTED!
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One, and custom DIY media console...
climber07 is offline
post #41297 of 41310 Old Today, 07:41 AM
PretzelFisch's Avatar
Quoted: 259 Post(s)
Liked: 227
I like my Yamaha, and I like being consistent with the app and remote. When we had different things in two rooms life was much more of a headache.
What I notice is YAPO calibrates flat and some times that makes you question where the bass went. where as the other software calibrates for the movies and puts a little pop into the bass.
PretzelFisch is online now
post #41298 of 41310 Old Today, 08:16 AM
audiofreak38's Avatar
Quoted: 27 Post(s)
Liked: 31
I noticed that YOU mentioned the Yammy A1040. Not too sure how much that avr will cost YOU. But, here YOU can get a factory refurbished Yammie A1040:
http://www.accessories4less.com/make...uced-50/1.html
For only $550 w/free shipping it really is a good deal. I just recently bought a Marantz SR6009 from acc4less and could NOT be any happier. Have had no issues so far. I did, however, purchase a 3-year extended warranty. Have owned Yamaha in the past and know first hand just how good they are. Just thought I would mention this as acc4less is great to deal with. Highly recommend.
Cheers,
Phil
It isn't about the product(s) YOU use but Rather how YOU use the product(s) that makes ALL of the difference!!!
audiofreak38 is offline
post #41299 of 41310 Old Today, 09:01 AM
EndersShadow's Avatar
Quoted: 146 Post(s)
Liked: 603
I'm going to be brutally honest here...
NEVER TRUST A AVR TO RUN 4 OHM SPEAKERS. I DONT GIVE A FLYING F#LK@# WHAT THE RATINGS SAY.
If your running 4 ohm speakers, there is a very good chance at some point they dip down to 3 ohms or even lower and NO AVR can handle that decently. Your slowing killing your AVR on that load.
Buy a AVR for its features, and with pre-outs. If you have 4 ohms speakers, just BUDGET an amp in the mix. I wont even THINK about running my LSi's off an AVR even if it means I have to use the TV speakers while my amp is in the shop. If you have standard 8 ohm speakers, then your ok to look at the power ratings UNDERSTANDING they are with 2 channels driven and each speaker you add subtracts from the total wattage you can provide to a individual speaker.
I bought my Denon totally ignoring its ratings for my 5 channels and looking at it more from a perspective of driving in wall heights, and maybe some Atmos speakers but would go with 8 ohm speakers so no LSi off the Denon.
My Setup
There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #41300 of 41310 Old Today, 09:27 AM
viper186's Avatar
Quoted: 14 Post(s)
Liked: 236
Lol
viper186 is offline
post #41301 of 41310 Old Today, 09:43 AM
mknecht01's Avatar
Quoted: 18 Post(s)
Liked: 29
Cheers,
Phil
Phil,
Yeah, that's where I was shopping. They had the A840 -- which is the model I was originally going to pick up when it was on sale at Amazon -- for $480, but then I saw the A1040 for only $70 more and the Denon I'm also considering is only $450. Amazing prices - I would think this is too good to be true, but so many of you guys on here have mentioned them positively over the last three years that I think this is the way to go.
--Matt
post #41302 of 41310 Old Today, 10:19 AM
Quoted: 146 Post(s)
Liked: 603
Phil,
--Matt
For me Denon v Marantz v Yamaha comes down to this
IF EQ = Audyssey
-IF quality > price
--Marantz
-ELSE
--Denon
-END IF
ELSE IF EQ != Audyseey
-Yamaha
END IF
I think I wrote that right lol...
What say you pretzelfisch?
My Setup
post #41303 of 41310 Old Today, 10:46 AM
mknecht01's Avatar
Quoted: 18 Post(s)
Liked: 29
Enders,
I hear you, I hear you: the used 5 channel Rotel I'm picking up next weekend along with the LSi9s is solving that problem for me. I only plugged the 7s and the LSiC into my current AVR long enough to 1) play music and decide that I MUST keep them rather than resell, and then 2) for light duty a couple of days to test run them on TV/movies/games. I don't have room for two systems so if the LSi's didn't cut it for the home theater experience then I was going to resell them anyway. But even on inadequate power with a bottom of the line Aventage unit, music is brilliant and in my small space they still do a nice solid job with the home theater stuff.
I only mentioned maybe running the 7s off an AVR as a fallback position for a week or so until I can get another amp, if I can score a cheap pair of LSi15s for the front. I certainly wouldn't consider doing it for any length of time. I could hear my Yammie whimpering with these three plugged into it, in the sense that I had to turn the dial up from -30 to almost -20 to get roughly the same volume out of them for movies that it would run the 8 ohm RT800i towers at.
If the "local pickup only" LSi15 towers on eBay keep getting relisted for $100 less every time they don't sell, then that day may come sooner rather than later, so I'm also keeping my eyes open for a used two or three channel Emotiva.
--Matt
post #41304 of 41310 Old Today, 10:51 AM
Geoff4RFC's Avatar
Quoted: 117 Post(s)
Liked: 1433
NEVER TRUST A AVR TO RUN 4 OHM SPEAKERS..
Originally Posted by viper186 View Post
Lol
WOW!!!!!! And all of these "posters" on the same page
Don't get too excited Dave, I dusted for "the shot"
Set up:
post #41305 of 41310 Old Today, 10:53 AM
Quoted: 259 Post(s)
Liked: 227
IF EQ = Audyssey
-IF quality > price
--Marantz
-ELSE
--Denon
-END IF
-Yamaha
END IF
Make sure the Yamaha is an avavtage line. To me they have always sounded better.
Other wise I ageree with Enders.
Also 1040 has two good things over the 800. You can edit crossover per speaker and amp design is better.
post #41306 of 41310 Old Today, 11:01 AM
Geoff4RFC's Avatar
Quoted: 117 Post(s)
Liked: 1433
LOL, yeah..........actually, I have laptop fans I use on the both of the XPA-2's and the 70.4. Dave recommended the Thermaltake brand to me and it works great. The Emos don't get quite that warm since I stopped using them as monos
Thanks Jesse, the Pangea's are a cheap(er) way to help keep the noise floor out of the set up. I use two different power cords, line level for the BRP and CDP which are triple shielded, and heavy 7g cables for the amps and AVR which are double shielded.
I also use Pangea and Emo HDMI cables. The shielding makes a good deal of sense, especially when you've got a freak that just starts adding more and more gear to his set up
Set up:
post #41307 of 41310 Old Today, 11:06 AM
mknecht01's Avatar
Quoted: 18 Post(s)
Liked: 29
IF EQ = Audyssey
-IF quality > price
--Marantz
-ELSE
--Denon
-END IF
-Yamaha
END IF
Yeah the Denon has the Audyssey Gold package apparently. And it's the cheapest of the three at A4L. The Yamaha 840 and 1040 have multipoint YPAO, which is an upgrade over the YPAO in my existing model. I've just become very comfortable with the Yamaha I have, and I have this silly brand loyalty thing sometimes.
Unfortunately for your second conditional above, in the general cost territory we are talking about, quality cannot always trump price in my world. Particularly when all of the choices are at least a little better than what I have already anyway. And when this whole project has been spurred on by the fact that in a moment of weakness I allowed quality to trump cost as far as these damn speakers are concerned hahaha.
My OCD gene says that for programmers everything after "ELSE" on the third-last line is redundant. Definitely makes it easier to read for normal people though.
post #41308 of 41310 Old Today, 11:07 AM
RobLee's Avatar
Quoted: 130 Post(s)
Liked: 181
Dan, I bought a 2 channel Onk specifically to use with my 4 ohm Lsi9's. Mainly I bought it because it for the pre-outs, and intended to use my Crown stereo amp, which IIRC I had quoted specs to you a couple years ago. But as it turns out, the Onk also has a speaker impedance selection as part of the setup options. The choices are 4 ohm or 6 ohm. So I just went with the 4 ohm setting and didn't bother to hook up the Crown. It has performed well for two and a half years so far. Of course, I do not play them very loud, they're in the bedroom. Your observation is likely correct in the case of a 5 or more channel setup, and especially if there are more then two 4 ohm speakers in the mix.
Anyway, the Onk was a refurb from A4L, and I was a little skeptical initially, but it was only $200, so I figured it was worth a shot. It appears to be essentially brand new, not used. Perhaps it was merely an open box item that had been "re-certified" rather than refurbished. Long and short, I am happy with it all around.
Based on that experience, I also went to A4L when I wanted to upgrade my main HT AVR from a Denon 3312 to the 4520. I had selected a refurb for $900 and when I went to checkout a popup suggested a NEW 4520 for $1100. After some consideration I did choose the brand new model, and what's more, after a couple weeks their price dropped to $999, and I used the price protection provision of my credit card to be refunded the $200 difference. Long story, but the bottom line is I've had good experiences with A4L.
post #41309 of 41310 Old Today, 11:29 AM
Quoted: 146 Post(s)
Liked: 603
Rob, I'd hazard a guess your a bit smarter than the average consumer on this , so you are keen to keeping the volume low, and only running 2. Most folks would see 4 ohms, assume they can run all their speakers off it, crank it and smoke everything within 10 minutes....
My Denon has the same options IIRC, but you will never find me running my setup off it, even for a short time.
So while your proving it can be done, your scenario is only applicable to a very small percentage of enthusiasts.
And I remember that Crown amp spec's quite well. IIRC its 150 wpc and not very deep at all.
My Setup
post #41310 of 41310 Old Today, 11:37 AM
RobLee's Avatar
Quoted: 130 Post(s)
Liked: 181
Given that it is possibly older than you are, I'm not even sure it would still work if I were to hooked it up. But in 2010 it was still driving my LST's quite respectably.
Heck, while we're just shootin' the breeze here (I'm guessing the weather today is as crummy elsewhere as it is here in Florida, or quite likely even crummier)... I should mention that the AR's were 4 ohm speakers and my little D150 touted better specs into a 4 ohm load than did the legendary DC300.
http://www.manualslib.com/manual/337...?page=2#manual
For anyone into vintage non-Polk gear:
AR/LST's: http://www.vintage-speaker-review.co...-2-ar-lst.html
and
Progenitor of the LST: http://www.vintage-speaker-review.co...3a-review.html
Reply Speakers
Polk Audio , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Polk Audio Rti4 High Performance Bookshelf On Wall Speakers , Polk Audio Csi5 High Performance Center Channel Speaker , Polk Audio Rti6 High Performance Bookshelf Speakers Pair Black , Polk Audio Three Way Vanishing Rt Series In Ceiling Speaker 70 Rt , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio Monitor 30 Bookshelf Speakers Cherry , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Cherry , Polk Psw108 10 100w Psw Series Powered Subwoofer , Polk Audio R50 Floorstanding Speakers Each , Polk Audio Surroundbar 4000 Iht Virtual Surround Speaker Bar With Wireless Su
