Calling all Polkies:Official Polk thread - Page 1426 - AVS Forum | Home Theater Discussions And Reviews
 1295Likes
post #42751 of 43518 Old 08-28-2016, 10:09 AM
Ted99's Avatar
Quoted: 473 Post(s)
Liked: 154
I'm using the Lsim 703 and LSim706c, in place of RTi12's and CSi6--"Brightness" gone
yanks1 likes this.
Samsung UN75HU8550FXZA, SEK 3500 OCB in den, Sony XBR79X900B in LR, JVC RS600, Grandview 120" 1.3g curved screen in Batcave Mancave
Polk LSiM703 fronts, RTi-12 rears, LsiC and LSiM 706 centers, Monitor 40 Heights, Monitor 60 FW, ED A6t sides, Oppo 203
Two Emotiva XPA-5's for the Beds and TC, BasX-7 for the tops, Marantz AV7702MKII in Mancave until consumer-grade 13+ ch Pre-pro is available.
Ted99 is online now
post #42752 of 43518 Old 08-28-2016, 12:21 PM
confinoj's Avatar
Quoted: 137 Post(s)
Liked: 79
Upgrade assistance with center channel
Making some HT upgrades starting with my front setup. Currently have front L/R in walls, rc55i. The rest of the system is from an older Polk RM-705 set. I decided to replace in walls with 65RTs. Ideally would like the larger 265RT but too big for my wife. Center will be free standing and the issue is space. The matching free standing center is CSiA4. It' just too big for our setup. Picture attached. The TL3 and TL2 work either sitting in front of TV or better on top of tv via a shelf so they are closer to height of in wall L/R. The TL3 is not a match timbre wise for the 65Rt. The step down TL2, according to Polk support, is however a much better match due to similar tweeters. I'm trying to decide what is more important, better quality sound of TL3 vs better matching TL2. Any thoughts? My other thought is that I may be able to put CSiA4 behind the TV if I move it up a bit. The issue with that is the center tweeter will be blocked by the TV stand. Don't know the significance of that but doesn't seem like a good idea to me. Any thoughts on that one? Pic of tv stand attached as well.
ID:	1627833   Click image for larger version
confinoj is online now
post #42753 of 43518 Old 08-28-2016, 12:30 PM
Greg Samples's Avatar
Quoted: 27 Post(s)
Liked: 48
What about wall mounting the TV just a tad higher than it is now, removing the stand and putting the center on the entertainment center? You could hide all the wires going up the wall to the TV in a white cable management track that then could be painted to match the wall.
Sent from my SM-N930T using Tapatalk
mr266 likes this.
Greg Samples is offline
post #42754 of 43518 Old 08-28-2016, 12:44 PM
confinoj's Avatar
Quoted: 137 Post(s)
Liked: 79
Yes that's another option. I asked my wife if she'll be ok with wall mounting and she is thinking about it. As many all decisions have to go through her for aesthetic reasons. Seems like the better looking option to me. Only issue is that the tv is already pretty high as its a tall piece of furniture but a few inches shouldn't matter too much. Also will be another 10-12 inches further from sitting position but probably not a big deal. If she doesn't go for mounting any other thoughts?
post #42755 of 43518 Old 08-28-2016, 12:51 PM
Quoted: 27 Post(s)
Liked: 48
What about wall mounting at the same height to remove the stand. How high will the center come up on the bottom edge of the TV? With the stand gone it frees up the space for the center.
Aarghon likes this.
post #42756 of 43518 Old 08-28-2016, 12:52 PM
Aarghon's Avatar
Quoted: 160 Post(s)
Liked: 380
Not an expert by any means, but I would think that the reflections from the tweeter being behind the tv stand would hurt dialog and overall clarity and prevent them from being as clear as they should. Think you should go for the better match, since a better speaker sounding to its best while not matching the other speakers will negate the benefit of it being alone and sounding better...
and yes, I think like Greg Samples on that one... Raising the tv with a wall mount could let you have best of both worlds.
Polk Audio LSIM703, Polk Audio LSIM704c, Polk Audio RTI-A1 surrounds
Dual Reaction-Audio BPS212 turbo subwoofers
Marantz AV8801 preamp, Rotel RMB-1095 power amp
Pioneer Elite n50 network player
Marantz CD6004 cd player, Marantz UD5007 Blu ray player, Modded Rega RP1 turntable
Panasonic Tcl55dt60 led tv,Playstation 3 and a lot of old consoles
Aarghon is offline
post #42757 of 43518 Old 08-28-2016, 01:04 PM
confinoj's Avatar
Quoted: 137 Post(s)
Liked: 79
I also wonder that even if the TL2 has a closer matching tweeter it still doesn't have nearly the frequency range as the 65Rt so will it really be any better or they both just won't match well. I agree wall mounting and getting the csia4 is certainly the best option if I'm allowed. One other concern. As you can see by the pic the in walls are rather high. I do have them mounted upside down so tweeter is on bottom and will do the same with 65rt plus tweeters are aimable. Still the center under the tv is much lower. I've gone back and forth with current center below and above tv and think it probably is better above but that would not be an option with csia4.
post #42758 of 43518 Old 08-28-2016, 02:25 PM
confinoj's Avatar
Quoted: 137 Post(s)
Liked: 79
Well bottom edge of tv is actually lower than I thought. I think I was remembering to screen. Bottom of tv is only 3.5" and csia4 height is 6 3/4 so option behind tv is out. Wasn't a good one anyway. Leaning towards wall mouthing a bit higher and putting csia4 below it. Anyone see an issue with the big height difference between L/R and center in this setup? I have a denon 1912 avr which does have audessey so maybe that will help?
post #42759 of 43518 Old 08-28-2016, 06:16 PM
mr266's Avatar
Quoted: 120 Post(s)
Liked: 726
Wall mounting would be my first choice, followed by building a small riser to raise the TV stand and put the Csia4 in front of it.
WDTV Live SMP with WD EX4100 NAS
Polk RTI8 Front, Polk CSI5 Center, Polk RTI4 Surround
MTX SW2 12” SUB, Sharp AQUOS LC-70C6400U
URC-WR7 Universal Remote
Motorola QIP7232 (P2) FIOS DVR, Sony BDP-S590 Blu Ray Player
Marantz SR5010 AVR,Technics SL-B20 Turntable
mr266 is offline
post #42760 of 43518 Old 08-28-2016, 07:44 PM
AlphaPie's Avatar
Quoted: 145 Post(s)
Liked: 373
Originally Posted by climber07 View Post
Shouldn't be a problem at all. 125W is more than enough at moderate listening levels (say -20dB). When watching movies with 5.1, however, you may experience some clipping on intense scenes with low bass without a subwoofer.
If you are crossing them at 80 Hz or above with a good sub, you should be fine. If you listen anywhere near reference, you'll need an amp with 250W - 300W to power them full range.
I'm at -10 to -8 during movies using a crown amp @300 watts right now cross at 60hz, so the 7008 probably wont cut it for me.
7.2 w/front wides - Pioneer Elite SC-85 - Polk Audio RTi12/CSi3/RT25i - DIY Dual 12" subs/Behringer Inuke3000 - Monster Power 2500
Sharp Aquos 60" - Xbox One - Sony BRP - Plex Server
AlphaPie is offline
post #42761 of 43518 Old 08-28-2016, 08:58 PM
climber07's Avatar
Quoted: 335 Post(s)
Liked: 1340
Yeah, I remember now. You probably won't be happy with just the AVR powering them.
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One, and custom DIY media console...
climber07 is offline
post #42762 of 43518 Old 08-29-2016, 08:41 AM
Ted99's Avatar
Quoted: 473 Post(s)
Liked: 154
I used a plywood top and two 2x8's on the side to make a small platform that fits over my CSiA4 and the TV sits on top. 8" total height increase for the TV. Selling my CSiA4 because I substituted a CSiA6.
mr266 likes this.
Ted99 is online now
post #42763 of 43518 Old 08-29-2016, 09:48 AM
enricoclaudio's Avatar
Quoted: 1132 Post(s)
Liked: 1177
Mount the CSi A4 on a shelf on top of the TV with some down angle.
climber07, mr266 and Aarghon like this.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #42764 of 43518 Old 08-29-2016, 11:47 AM
RobLee's Avatar
Quoted: 276 Post(s)
Liked: 281
Actually I need something like that isoaccoustic stand to hold up my center, but I'm not quite prepared to spend $100. Presently using four (full) soda cans and a piece of carpet.
lizrussspike and climber07 like this.
Denon AVR-4520ci, Polk LsiM703's, 704c, Rti4 surrounds, some Klipsch subs. Bedroom: Lsi9's, Onkyo TX-8050
RobLee is offline
post #42765 of 43518 Old 08-29-2016, 05:51 PM
Quoted: 1020 Post(s)
Liked: 483
Nothing new about the new Polk speaker coming out in the next few weeks?
New24K is offline
post #42766 of 43518 Old 08-30-2016, 11:32 AM
confinoj's Avatar
Quoted: 137 Post(s)
Liked: 79
I posted this in another thread as well but just following up here with what I decided. So the reason I had not entertained putting a larger/heavier center on top of the TV via a TV shelf (like TL3 is in prior post) is that while the shelves support that weight the TV pedestal on this particular TV is rather flimsy. Even with nothing on top it is not very stable. It's a plasma so it's not light. I would worry about putting a 15Lb speaker on it and then killing one of my kids. I think I found a good alternative that will best solve this scenario. Ordering one of these universal TV stands that mounts to VESA mount with adjustable height.
https://www.amazon.com/Universal-Tab...tv+stand&psc=1
TV will be much much sturdier and can actually be a little lower than it is now (1.5-2"). I also would not be moving the TV even farther away by mounting on the wall (which would be about 9-10" back). I should be able to comfortably place CSiA4 on top aimed down where it will be in a better position relative to fronts. If for some reason I didn't like it that way this stand will accommodate placing speaker in front of TV as it has an adjustable height. I ordered this stand and CSiA4 and returned TL3.
post #42767 of 43518 Old 08-30-2016, 11:33 AM
Quoted: 679 Post(s)
Liked: 345
Pix below of our almost 1 year old set-up of LSiM 703s upfront & 704c center. Now complete with 65" Vizio 4K TV and new RSL Speedwoofer 10S sub that replaced my 20 month old Polk PSW125 (sold on Craigslist).
It's a 5.1 set-up on 1st floor at our SC vacation home. System really rocks for both music & action movies. Two in-ceiling Polk RC80i are used for rear surrounds & Denon S900W AVR.
Upstairs totally different, 5.1.4 Atmos set-up with Yammy A2050 & Parasound 2 channel amp & Chane speakers upfront & 4 RSL in-ceilings
Aarghon likes this.
yanks1 is offline
post #42768 of 43518 Old 08-30-2016, 11:39 AM
confinoj's Avatar
Quoted: 137 Post(s)
Liked: 79
How do you like the RSL 10S? That's what I'm likely going to upgrade to. What size is your room?
yanks1 likes this.
post #42769 of 43518 Old 08-30-2016, 12:30 PM
Quoted: 679 Post(s)
Liked: 345
Room is huge; it's an open great room to the kitchen & Dining room. It's plenty of bass, I'm not a bass head & prefer tight & punchy.
That said, I do have an Outlaw Ultra X-12 upstairs that shakes the house during action movies (that's our primary system)
yanks1 is offline
post #42770 of 43518 Old 08-30-2016, 12:58 PM
B T C's Avatar
Location: Lansing, MI via Kentucky, Georgia & Tennessee
Quoted: 367 Post(s)
Liked: 96
Hi yanks, what stands are you using with the 703s? Do you like them? Do they work well? How tall are they? Would you recommend them? Most people seem to recommend filled steel stands, particularly with the 703s due to their size & weight.
B T C is online now
post #42771 of 43518 Old 08-30-2016, 01:05 PM
Quoted: 679 Post(s)
Liked: 345
Hi BTC; Yes most recommend steel stands. I had these for many years and had TSI 200s on them for almost 10 years. This is our main room so wife preferred wood & they are 24" Sanus stands. I think they are a tad under-weighted for 28 lb. speakers but seem solid to me. Perfect height, puts the 703 tweeters at 36" which matches seated ear level
yanks1 is offline
post #42772 of 43518 Old 09-02-2016, 09:59 AM
confinoj's Avatar
Quoted: 137 Post(s)
Liked: 79
So my plan had to be altered. Turned out a stud was in way the for larger cut out of the 65RT and it's possibly a load bearing wall. Didn't want to risk it. So decided to get bookshelfs - RTi A3s as fronts and place on stands flanking TV. Got CSiA4 for center and will raise TV on new stand a bit to fit underneath. Replacing rears with OWM3s in white (white room). Only non-polk item will be sub - getting the RLS Speedwoofer 10s which gets rave reviews yet still rather compact. I will use the current in wall RC55is as front height speakers in a 7.1 setup since they are already fairly high on the wall. Should overall be a substantial step up for me. Everything is on it's way. Can't wait.
yanks1 likes this.
post #42773 of 43518 Old 09-02-2016, 08:11 PM
Quoted: 28 Post(s)
Liked: 0
Can anyone recommend good set of floor standing speakers? i'll mainly be using it for music / movies (70/30). Need very good front speakers.. thinking of 3.0 or 3.1
juveguy is offline
post #42774 of 43518 Old 09-02-2016, 08:58 PM
Aarghon's Avatar
Quoted: 160 Post(s)
Liked: 380
Depends of the budget... For music LSIM705s ... or RTIA9 could be a good bet too as they have a really good bang for the buck... But I'd wait for the new speaker line release and reviews if I were you...
Aarghon is offline
post #42775 of 43518 Old 09-03-2016, 05:38 AM
confinoj's Avatar
Quoted: 137 Post(s)
Liked: 79
When are new speaker lines expected to be announced? I just bought rtia3s, csia4, and owm3s this week.
post #42776 of 43518 Old 09-03-2016, 06:14 AM
Quoted: 679 Post(s)
Liked: 345
Supposedly more news this month
yanks1 is offline
post #42777 of 43518 Old 09-03-2016, 09:51 AM
Quoted: 124 Post(s)
Liked: 109
Shoot me a message if you are looking for FXiA6 or the RTi A3
Yamaha CX-A5100 | 2x Emotiva XPA-5 & XPA-3 | PSA MTM-210T | PSA-MTM210C | PSA-MT110SR | 2x PSA V1800 | AM 8033-SII
Sony 65" 4K| Apple-TV | Network stuff | a lot of wires | Understanding & forgiving GF - priceless!
Kevin Grimm is online now
post #42778 of 43518 Old 09-03-2016, 11:49 AM
laserjock II's Avatar
Quoted: 719 Post(s)
Liked: 391
From S&V ad...
Aarghon likes this.
laserjock II is online now
post #42779 of 43518 Old 09-03-2016, 12:34 PM
Liked: 483
Originally Posted by laserjock II View Post
From S&V ad...
Well, that was certainly... underwhelming...
New24K is offline
post #42780 of 43518 Old 09-03-2016, 01:26 PM
Quoted: 27 Post(s)
Liked: 48
LOL I will just stick with my RtiA 9s and CSiA 6. I thought it might be and RtiA update.
Reply Speakers
Polk Audio , Polk Audio Csi5 High Performance Center Channel Speaker , Polk Audio Monitor 30 Bookshelf Speakers Cherry , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Cherry , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio R50 Floorstanding Speakers Each , Polk Audio Rti4 High Performance Bookshelf On Wall Speakers , Polk Audio Rti6 High Performance Bookshelf Speakers Pair Black , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Polk Audio Surroundbar 4000 Iht Virtual Surround Speaker Bar With Wireless Su , Polk Audio Three Way Vanishing Rt Series In Ceiling Speaker 70 Rt , Polk Psw108 10 100w Psw Series Powered Subwoofer
