Calling all Polkies:Official Polk thread - Page 1460 - AVS Forum | Home Theater Discussions And Reviews
 1387Likes
post #43771 of 43778 Old 06-15-2017, 02:49 PM
Titan319's Avatar
Quoted: 348 Post(s)
Liked: 149
[QUOTE=UncleSpud;53663345]I’m trying to decide between an RTI A7 or A9. I live in a rural area so I can't audition either of them. My current amp (Outlaw 5000) doesn't have enough power to do the A9's justice, so I'll need a new amp (I'm thinking of two Outlaw monoblocks at 200wpc). I currently have RTI A5's as my front speakers, and I'm disappointed with them (muddy midrange).
Any thoughts on the 7’s versus the 9’s? Is 200 WPC enough to drive the 9’s? The wife is concerned that the 9’s are too big for our living space (they are), but I’m concerned that there’s not enough difference between the 5’s and the 7’s, so I’m tempted by the A9’s.
I would step up to the LSIM 703 or 705 much better midrange if that is out of your budget get the A7. Overloading your living room with big speakers (A9) that don't have room to breath can cause all kinds of issues. It is better to get the best speakers you can afford first and then add a amp later when funds permit if you feel they need more power.
Titan319 is offline
post #43772 of 43778 Old 06-16-2017, 06:39 AM
Methodical_1's Avatar
Quoted: 379 Post(s)
Liked: 193
TIA
I will use the analogy I use for my photography hobby. Glass (lens) first, camera body second. Glass in your case are the speakers and camera body is the amp. In photography, glass changes every 10+ years, similar to speakers. You can get great results more so with better glass on an average camera than vice versa. Camera bodies come and go, they change very often, they come out with something new very often and whole bunch of companies make them. Basically what I am saying is I'd get the best speaker (glass) now and worry about the amp (camera body) later. You may find yourself changing amps (camera body) more so because they make changes, they come out with something new or you can just want more power, rather than speakers (glass) because you have a great set.
Just One Man's Opinion.
Titan319 and Frostyboy115 like this.
HT Configuration: 7.2.4 l Panasonic Plasma (65") l Denon X4300H l Polk LSiM 707s l Polk LSiM 706c l Polk FXi-30 (x4) l Infinity ERS-610 (x4)-Atmos l SVS PB-2000 l Polk PSW 505 (temp) l Monolith 7 amp l Behringer A500 (2x) l Behringer FBQ3102 EQ l Oppo BD-93 l Music Hall MMF-9.3 TT l Denon DP-300F TT l Denon CD player l Cassette Deck.
Subwoofer Trim and Audyssey EQ setup guide
Methodical_1 is offline
post #43773 of 43778 Old 06-16-2017, 08:39 AM
climber07's Avatar
Quoted: 343 Post(s)
Liked: 1356
There are so many variables when dealing with speakers, subwoofers, AVRs, and amplifiers. The RTiA9 speakers are particularly problematic when trying to make a single capability statement for every receiver, room, and crossover point. You can easily run the RTiA9 speakers with 30 - 50 watts. Now that I've said that, I have to caveat the statement with a dozen other qualifying comments. You will need to listen at lower volume levels, you will need to be crossed over at around 80 Hz, and you will need a quality dedicated subwoofer. PHEW, that's a lot of "needs".
Now let's talk about the average setup. RTiA9s are generally purchased due to their power handling capability and frequency response (even though they only dig down into the bass a little). If you run the RTiA9s at full range, with an AVR rated at 140W, with five channels driven with the AVR, and are watching an intense bass scene on a Blue-ray at near reference levels, you're going to clip the AVR amp and have massive distortion. Why, because the AVR will see dips in it's power output down into the 60W - 80W range depending on the scene, the reactive impedance of the speakers (the natural increases and decreases in speaker impedance through the frequency spectrum). I think we can all agree that 80W is not enough power to drive the RTiA9 in full range at reference volume levels. I don't know too many people that buy speakers with the intention of listening at low SPLs either.
The ideal setup for the RTiA9 would look something like this. First we have the RTiA9s crossed over at 80 Hz driven by a dedicated amp of around 200W - 300W. Even though the speakers can require massive amounts of power, they will generally only use around 30W for average movie watching and music listening. The more powerful amps are for those immediate peaks in power draw due to intense audio tracks. Headroom on the amp is key to a distortion free listening experience at high SPLs. Second we will need to have a dedicated subwoofer to take care of the low end business. Sure the RTiA9s work the low end pretty good, but they cannot produce clean SPL below around 40Hz. We will need to let a good quality powered subwoofer to manage the chest thumping, thus the 80Hz crossover for the A9s (and every other speaker too). This setup should provide hard hitting audio for even the most intensive movie sound tracks.
The budget setup isn't really a factor with A9s. If you have a budget that doesn't allow for a dedicated amp, I'd stay away from the A9s and go with A7s or bookies. You need a subwoofer for any setup to sound GOOD so the smaller speakers can do the same duties as the A9s with an 80Hz crossover. We all know that 75 percent or more of our listening is at -40 main volume and that is perfect for two A9s on an AVR with 100WPC or more. With that being said, the AVR neuters the A9s in the higher volume levels and you will inevitably be dissatisfied with the performance, always wanting to go higher and have more impact. The bottom line is that most AVRs will drive the A9s in moderate SPL at lower volume levels for most applications. We don't want moderate though. That's why I recommend a 200W - 300W dedicated amp for the A9s for any setup along with a good quality powered subwoofer. You'll be glad you made the jump to an amp and subwoofer early on. I am. Good luck and good listening.
chi_guy50 and shyyour like this.
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - - XBox One S - Logitech Harmony One, and custom DIY media console...
climber07 is offline
post #43774 of 43778 Old 06-16-2017, 10:24 AM
chi_guy50's Avatar
Quoted: 1484 Post(s)
Liked: 1168
^^^^^ That pretty much covers all the bases IMHO.
climber07 likes this.
Living Room: Sony XBR-65Z9D UHD LCD TV w/FALD; Oppo UDP-203; Sony BDP-S5200 (multi-region); Denon AVR-X5200W (Video: Dolby Atmos/DSU 7.1.4; Music: DTS Neo:X 11.1); Dayton Audio MA1260 12-Channel Amplifier (60wpc); Polk Audio RTiA7 (F/LR), CSiA6 (C), RTiA5 (FW), OWM5 (Sr, SB), 80F/X-RT (FH, TR); SVS SB-2000 (SW)
Bedroom: Sony XBR-55HX929 LCD HDTV w/FALD, DarbeeVision DVP 5000S, Yamaha R-N402 Network Receiver, Polk Audio LSiM703
chi_guy50 is online now
post #43775 of 43778 Old 06-16-2017, 01:48 PM
tegage's Avatar
Quoted: 52 Post(s)
+1 I shoot a fuji because of their glass
Sent from my SM-P600 using Tapatalk
LG 65EF9500
Oppo BDP-103
Polk LSiM703, LSiM704C, LSiM 702, LSi 7
Rythmik D15SE sub
Outlaw 975
Outlaw 7125
tegage is online now
post #43776 of 43778 Old 06-18-2017, 09:53 PM
Tesla1856's Avatar
Quoted: 97 Post(s)
Liked: 68
Originally Posted by JayFank View Post
I have the monitor 60s as funny channels. Am I supposed to run speaker wire to all 4 ports on the rear to my receiver?
Not sure what a "funny channel" is, but those are for Bi-Amping. Otherwise, you leave on the 2 shorting bridges.
Living Room Home-Theater:
Epson 8350 Projector (1080p @ 96") / Panasonic 850u 46" 1080p Plasma TV
Onkyo TX-sr607 AVR (7.2ch ~ HDMI ~ wrat-Amp 630 watts )
AppleTV-4 / Panasonic dmp-BD60 Blu-Ray Disc Player / Cisco 8742hdc DVR (TWC)
Harmony 670 Remote / HTPC (Kodi/Win10-64) Media Server PC / Synology 12tb Raid-5 NAS
Polk Audio Monitor Series-II Speakers (Large 6.1 Matched Separates) / psw-505 12-Inch Sub
Tesla1856 is offline
post #43777 of 43778 Old Today, 08:44 AM
Quoted: 231 Post(s)
Liked: 59
I'm thinking of switching my surround RTiA1 for a FXiA4. The A1 has been fantastic the only thing is my room is a bit narrow and i get a bit of hot spotting every now and then from the left surround speaker hence why im thinking of switching to the FXiA4.
Please can anyone enlighten me on the FXiA4 as a surround speaker, as well as in an Atmos setup.
Thank you for taking the time.
Living Room: Pre-Pro- Marantz AV7702, Amps- Crown X1500 & XLS1000(5). Mains- RTi12, Center- CSi5, SR- RTiA1, SRB-RTi8, Atmos- 620RT(4), Sub- RBH I-12 & BIC F12, TV-LG55LB7200, PJ-Benq HT1075, Screen 106", UBD- Samsung K8500, Bluray-LGBP440, Misc- Nvidia Shield, Apple TV, Chromecast, DSTV HD PVR, Wii U, DVP-5000s.
Bedroom:AVR- Marantz SR5009, Mains-Tsx110B, TV-VIZIO E500i-B1, Bluray-LG BP540, Misc- Fire TV, Chromecast Audio, Sennheiser RS170, DSTV HD, QNAP TS-451+.
shyyour is online now
post #43778 of 43778 Old Today, 03:15 PM
Liked: 0
Finally did a little upgrading today So far, sounds leaps and bounds better than my old Def Techs! Excited to break these bad boys in
Trollbiscuits is online now
Reply Speakers
Polk Audio , Polk Audio Csi5 High Performance Center Channel Speaker , Polk Audio Monitor 30 Bookshelf Speakers Cherry , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Cherry , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio R50 Floorstanding Speakers Each , Polk Audio Rti4 High Performance Bookshelf On Wall Speakers , Polk Audio Rti6 High Performance Bookshelf Speakers Pair Black , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Polk Audio Surroundbar 4000 Iht Virtual Surround Speaker Bar With Wireless Su , Polk Audio Three Way Vanishing Rt Series In Ceiling Speaker 70 Rt , Polk Psw108 10 100w Psw Series Powered Subwoofer
