Calling all Polkies:Official Polk thread - Page 1467 - AVS Forum | Home Theater Discussions And Reviews
 1448Likes
post #43981 of 43989 Old 09-21-2017, 01:53 PM
aarons915's Avatar
Quoted: 56 Post(s)
Liked: 42
Hey all, I'm considering grabbing 3 LSIM 703 for my front channels when they go on sale again and had a question. I see the top is curved but are the sides curved as well or flat? The reason I ask is because I'll have the center on it's side as a center channel until I can swing a setup where the center is vertically oriented as well.
aarons915 is online now
post #43982 of 43989 Old 09-21-2017, 04:01 PM
chi_guy50's Avatar
Quoted: 1599 Post(s)
Liked: 1343
The sides are basically flat but with a curve at the front. You COULD lay the speaker on its side; however, I would advise against using an LSiM703 in that orientation. Unless, that is, you're the type of person who likes to eat his peas with a knife.
If for some reason you can't fit an LSiM704c in your room/budget (or if you are adamant about having identical L/C/R speakers) I would suggest getting another (cheap/used) placeholder center-channel speaker (e.g., you could pick up the compact but timbre-matched TL3 at the Polk Audio eBay Store for under $150 shipped) or do without one for the time being.
Living Room: Sony XBR-65Z9D UHD LCD TV w/FALD; Oppo UDP-203; Sony BDP-S5200 (multi-region); Denon AVR-X5200W (Video: Dolby Atmos/DSU 7.1.4; Music: DTS Neo:X 11.1); Dayton Audio MA1260 12-Channel Amplifier (60wpc); Polk Audio RTiA7 (F/LR), CSiA6 (C), RTiA5 (FW), OWM5 (Sr, SB), 80F/X-RT (FH, TR); SVS SB-2000 (SW)
Bedroom: Sony XBR-55HX929 LCD HDTV w/FALD, DarbeeVision DVP 5000S, Yamaha R-N402 Network Receiver, Polk Audio LSiM703
chi_guy50 is offline
post #43983 of 43989 Old 09-21-2017, 04:25 PM
Quoted: 865 Post(s)
Liked: 532
703s are VG speaker at 40-50% off; love them + have 704c center and it's as good as my more expensive Revel C205.
I would NOT lay a 703 on it side
Good luck
Primary set-up 5.1.4; Yamaha A2050, Paired w/Parsound P5 Preamp & A21 amp
Revel F206 fronts & Revel M16 rears; Outlaw X12 Sub & 4 RSL C34e in-ceilings
Secondary 5.1: Denon S900W, Polks LSiM703/704C, Polk RC80i in-ceiling rears, RSL Speedwoofer 10s
yanks1 is offline
post #43984 of 43989 Old 09-21-2017, 06:50 PM
aarons915's Avatar
Quoted: 56 Post(s)
Liked: 42
Are you guys saying you wouldn't lay an lsim 703 on it's side for aesthetic reasons or you don't think it will sound as good? As good as the 704 and 706 center channels are I would think an identical center would be best for the front soundstage even if it wasn't in it's ideal vertical orientation.
post #43985 of 43989 Old 09-21-2017, 07:27 PM
PretzelFisch's Avatar
Quoted: 406 Post(s)
Liked: 264
three of a kind is better they all need to be in the proper orientation. the center is a nice compromise when you can have your center take up a lot of vertical space.
PretzelFisch is online now
post #43986 of 43989 Old 09-22-2017, 04:44 AM
chi_guy50's Avatar
Liked: 1343
Yes.
In what world would anyone label the LSiM706c a compromise? That thing is a monster!
post #43987 of 43989 Old 09-22-2017, 06:49 AM
B T C's Avatar
Location: Lansing, MI via Kentucky, Georgia & Tennessee
Quoted: 479 Post(s)
Liked: 159
Originally Posted by mknecht01 View Post
So the LSiM line goes on sale at least once a year. I've been considering a further upgrade to those because they make a size HUGE center channel in that line in the 706C, which I expect will solve the only issue I have with my older LSi's. But I'm wondering if it's worth the money even at 50% off.
Anybody out there have experience with *both* the LSi and the LSiM lines? Care to weigh in?
I'm kinda surprised nobody has responded. Maybe you should try the Polk Audio forum.
I have four LSiM703s and the 706c. The setup sounds pretty good to me, but I have no experience with the prior LSi line.
The LSiM line is available quite often at 50+% off at Adorama. If you're interested, keep an eye on Slickdeals.
B T C is offline
post #43988 of 43989 Old 09-22-2017, 06:58 AM
aarons915's Avatar
Quoted: 56 Post(s)
Liked: 42
Originally Posted by chi_guy50 View Post
Yes.
It has nothing to do with size, but I thought it was pretty much accepted that 3 identical speakers for your LCR all vertically oriented is going to be the best sound possible. I've been using 3 identical 2 way bookshelf speakers as my LCR for the past few years and I would never go back, the 3 identical speakers create a much more seamless soundstage.
post #43989 of 43989 Old 09-22-2017, 07:52 AM
climber07's Avatar
Quoted: 602 Post(s)
Liked: 1944
Three identical speakers work fine for a LCR setup, however, center channel speakers are designed so that their sound field emanates properly. That is why they have a symmetrical driver compliment with an equal number of mid drivers on each side and tweeters in the middle. You can't go wrong with a center channel from the same series. Go with the biggest center channel you can. 75 percent of a movie comes through that speaker.
chi_guy50 likes this.
Power Sound Audio S7201 Quad 18" 4000W Sealed Subwoofer - Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Epson 5030UB Projector - Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - - XBox One S - Logitech Harmony One, and custom DIY media console...
climber07 is online now
Reply Speakers
Polk Audio , Polk Audio Csi5 High Performance Center Channel Speaker , Polk Audio Monitor 30 Bookshelf Speakers Cherry , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Cherry , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio R50 Floorstanding Speakers Each , Polk Audio Rti4 High Performance Bookshelf On Wall Speakers , Polk Audio Rti6 High Performance Bookshelf Speakers Pair Black , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Polk Audio Surroundbar 4000 Iht Virtual Surround Speaker Bar With Wireless Su , Polk Audio Three Way Vanishing Rt Series In Ceiling Speaker 70 Rt , Polk Psw108 10 100w Psw Series Powered Subwoofer
