Calling all Polkies:Official Polk thread - Page 425 - AVS Forum | Home Theater Discussions And Reviews
 1432Likes
post #12721 of 43954 Old 02-20-2012, 11:31 AM
jjlee138's Avatar
If I'm using 4 RC80i 2-Way In-Ceiling Speakers and I need a shallow center channel speaker for my Mantle below the TV (Mantle Depth is 7.5in) what should I do! My max budget for a center channel is $350... My initial thought was the CS2, but it's a beast at just under 12in... Any recommendations would be MORE THAN welcome lol
jjlee138 is offline
post #12722 of 43954 Old 02-20-2012, 12:33 PM
Florida_Gator's Avatar
Quoted: 47 Post(s)
Liked: 50
What should you do?
You should MOVE THE DAMN TV FROM ABOVE THE FIREPLACE. IT'S NOT SUPPOSED TO BE THERE.
I'd like to kill the first feng-shui A$$HAT that did this on whatever HGTV show they got on. There are MANY reasons that's a terrible place to put a TV, and you've just mentioned one of them.
Florida_Gator
Florida_Gator is offline
post #12723 of 43954 Old 02-20-2012, 12:55 PM
Geoff4RFC's Avatar
Quoted: 319 Post(s)
Liked: 1576
Although I agree with FL Gator in that TV's over the fireplace is not the most ideal placement, that doesn't help your current situation.
Maybe consider a soundbar?
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
post #12724 of 43954 Old 02-20-2012, 02:10 PM
Quoted: 47 Post(s)
Liked: 50
Or another ceiling speaker (the kind that angle towards the listener like: http://www.polkaudio.com/customaudio/inceiling.php#rts ).
Florida_Gator
post #12725 of 43954 Old 02-20-2012, 04:00 PM
BOTTLEDZ28's Avatar
Im running Polks in my family room and would like some advice on setup. My two mains are R50s and I have them set to Large. I am also using R15s for surrounds and they are set to small. The center is a CSi30 which I just now switched to large to see how it sounded and I'm not sure if I like it. I am using a PSW250 sub. All my speakers are run through an Onkyo 701 AVR which puts out 100W a channel. My room is 16'x13' longer then wider). My rear speakers are mounted on the ceiling angled down because the couch is directly up against the back wall. Yes, I know this isnt ideal but its all I have right now and I just want the best I can get from what I have to work with.
I have my AVR set to 80hz crossover. Now, if you were running this setup then what configuration would you be running these speakers in? (small or large)
Also, here is a picture of my sub. For some reason, I cant really tell a difference when I move the HZ knob around.
Here is a picture of how my rears are set up. Picture was taken from the couch where I watch TV. Not the ideal speaker placement but I have no other choice.
Here is a picture of the entertainment center I made a few years ago for my rear projection. I just picked up this new Sony LED TV 3 days ago.
BOTTLEDZ28 is offline
post #12726 of 43954 Old 02-20-2012, 04:43 PM
viper186's Avatar
Quoted: 20 Post(s)
Liked: 241
Hey thats a nice tv, what size is it? I'm quite new to home theater but it seems that your room in the same size as mine, about 16l by 13w. Although mine is set up with 7.1 channels I find that having everything set to small an my crossover at 100hz works quite well. Then everything below 100hz is sent to the subwoofer. If I set the fronts and center to large it seems the sound isn't nearly as clean and the subwoofer kind of fights the mains and center. Now I know I can change the phase of the subwoofer but I haven't had my set up that long to mess with it. In any case I think with R50's, which I believe are similar to my Moniter 50's, don't really go all that low. I think the general consensus is to run 80-120hz crossover on your receiver and let your sub handle everything below that. As far as the crossover on your sub, I see it's connected to the line in jack. Is this one of two connections, the other being LFE? I'm not really experienced enough to say if line in is the same as LFE if thats the only connection. In any case if it is then the crossover on your sub should be bypassed and it is using the receivers crossover which I believe is what you want in most cases. Hope this helps and maybe some of the more experienced posters here can elaborate furthur.
viper186 is offline
post #12727 of 43954 Old 02-20-2012, 05:03 PM
BOTTLEDZ28's Avatar
The L and R line in are the only input connections on the sub
post #12728 of 43954 Old 02-20-2012, 05:18 PM
viper186's Avatar
Quoted: 20 Post(s)
Liked: 241
Yeah I see that now lol. So it's only one cable coming out of the "LFE" or "subwoofer out" on the receiver correct? If soo then your subwoofer is only getting a LFE (Low Frequency Effects signal). So the subwoofer crossover is not used in this configuration.
viper186 is offline
post #12729 of 43954 Old 02-20-2012, 07:16 PM
BOTTLEDZ28's Avatar
Sony 55" LED. It replaces a big Sony 50" rear projection. Hence the now big gap I have on the top. I will be modifying the cabinet this spring.
post #12730 of 43954 Old 02-20-2012, 08:20 PM
viper186's Avatar
Quoted: 20 Post(s)
Liked: 241
Thats what I thought. I have a 46 at the moment. Quite happy with it but if I ever move up it's going to be a 55 or 60. Any bigger would be way too much for my setup. I just bought a floating tv stand that only goes up to 46 inches soo I guess I'd have to get a new stand too lol.
viper186 is offline
post #12731 of 43954 Old 02-20-2012, 09:00 PM
Quoted: 47 Post(s)
Liked: 50
I used R50s for front L & R for years, using R150 surrounds (very similar as your R15s). Best setup for what you have is all "small", with an 80 hz crossover. Set your sub's Hz knob into the white area.
You may find that you need to bump up the center level a tad, to hear dialog over the front L & R. Adjust sub and surrounds to taste.
Florida_Gator
post #12732 of 43954 Old 02-22-2012, 07:03 AM
tatumguy's Avatar
Hey, quick question for you Polk owners out there. I have a wierd problem that Im hoping some of you can help me with.
Setup:
Polk Monitor 60 ii - L + R
Polk Monitor CS1
Polk Monitor 40s - Surround
Outlaw LFM-Plus
Onkyo 809
OK so here is the problem. Every thing sounds great except for some circumstances when I am watching my Verizon Fios on HBO and Encore. When I am listening at low to moderate volumes, I get what sounds like clipping from my Left, Right and Center. When there are explosions or heavy noise, it sounds like there is a static that increases with the intensity of the explosion. The funny thing is, its really not on very loud at all, and seems to only happen on HBO and Epix channels. When I flip to another station, like Starz and leaving it at the same volume, I get no clipping sounds. Even increasing the volume, and watching an intense scene like Two Towers - Helm's Deep battle, I get no clipping or static sounds whatsoever.
I flip back to HBO or Epix, and once it gets to a louder scene, I get that static again. I should note that it seems the intensity and frequency of the static sound increase and decreases both with the my changing of the gain on my reciever as well as volume peaks through out the movie im watching.
So, am I clipping my Polks? If so, why is this clipping specific to HBO or Epix channels and not happening when I change to another station and increase the volume.
I appreaciate any help and insight you all may have. Thanks.
tatumguy is offline
post #12733 of 43954 Old 02-22-2012, 08:40 AM
RobLee's Avatar
Quoted: 283 Post(s)
Liked: 287
Your CS1 might be clipping, but unless you have it very loud, it's unlikely the 60's would... especially since it does not occur on other channels. You might try different surround decoder settings on your AVR. If the problem persists, it's more likely you'd get a better answer posting in an Onkyo thread.
Denon AVR-4520ci, Polk LsiM703's, 704c, Rti4 surrounds, some Klipsch subs. Bedroom: Lsi9's, Onkyo TX-8050
RobLee is offline
post #12734 of 43954 Old 02-22-2012, 08:52 AM
runrabbitrun79's Avatar
Hi,
I was thinking of upgrading this. What would sound better: to match the R150 L/R with a CSR for center and have RM8 for surrounds or keep my RM8 center and R150 L/R and add RM8 surrounds?
Here's the setup:
Sony STR-DH510 receiver.
pair of Polk Audio R150 speakers for my L/R channels
Polk Audio RM8 center channel
runrabbitrun79 is offline
post #12735 of 43954 Old 02-22-2012, 10:25 AM
Quoted: 47 Post(s)
Liked: 50
Originally Posted by runrabbitrun79 View Post
Hi,
Here's the setup:
What's your budget?
Reason I ask is because my advice would be "none of the above".
At a minimum, I'd get a CS1 ($80 on NewEgg) (or better yet, a CS2) for the center, a pair of Monitor II 30's ($80/pair currently on NewEgg) for fronts, and move your R150 to surround duty.
Florida_Gator
post #12736 of 43954 Old 02-22-2012, 11:38 AM
Not sure of my budget for this yet. I'm happy with the way the setup performs so far and I'm happy with these speakers, but I was wondering what to do when I want to go 5.1 or 5.0.
I was also thinking of looking into the Blackstone series or complete the RM8 series. What's your opinion on those?
post #12737 of 43954 Old 02-22-2012, 12:07 PM
tatumguy's Avatar
Thank You. I appreciate the response. Again, this clipping/static sound is happening at low to moderate volumes. I hear it, freak out, flip to a non-HBO Epix channel, and its perfectly fine.
tatumguy is offline
post #12738 of 43954 Old 02-22-2012, 12:21 PM
Quoted: 47 Post(s)
Liked: 50
Blackstones look nice, and specs look good... other than that, I have no feedback (never heard them, sorry).
Bang-for-buck, I'd suggest either CS1 or CS2 for center, Monitor II 30's or 40's for front L&R, your R150s for surrounds, and a Bic F12 sub. That would get you a very nice 5.1 system for about $350-400 (assuming you don't already have a sub). And all your speakers would match/blend much better than using the RM8s for part of your system. If you do this, I'd suggest using a crossover of 80hz.
If you're looking to save money, then just get a CS1 center, Bic F12 sub, keep the R150s for front L&R, and use RM8s for surrounds. Cost there would be about $270. If you do this, I'd suggest using a crossover of 100hz.
Florida_Gator
post #12739 of 43954 Old 02-22-2012, 02:55 PM
upstate-avfan-da's Avatar
Quoted: 83 Post(s)
Liked: 41
If you sit relatively close my budget set up has fared quite well.
M50's for fronts
Blackstone TL2 center
M30's for rears
+ sub (your choice for budget)
I have my crossover set at 60 for left/right and 80 for everything else.. no issues with the TL2 being overpowered as our sitting position is 8-10 ft away and I bumped the channel level by 2db.
Bit by the upgrade bug, limited by the WAF
upstate-avfan-da is offline
post #12740 of 43954 Old 02-24-2012, 08:36 AM
jjlee138's Avatar
Originally Posted by Florida_Gator View Post
What should you do?
Other than having issues with the center channel depth it's actually the perfect location for our TV. Never had an issue with neck pain or discompfort. Never had an issue with the TV due to heat etc (We use the FP maybe once a year), nor any other TV's we've had over other FP's. It's far ad away the best layout for that particular room.
I don't see how a $2,500 speaker comes in under a $350 dollar budget, but ok, thanks for the link.
Anyway, it's not an ideal timber match, but Newegg dropped the price of the Klipsch WC-24 down to $229 and it just barely squeaks into my dimensions.
jjlee138 is offline
post #12741 of 43954 Old 02-24-2012, 11:32 AM
vodan's Avatar
Has anyone here had experience with Polks Lci-RTS speakers, in particular, the Lci-RTS-C and Lci-RTS 105?
Thanks for any input you can offer,
Daniel
vodan is offline
post #12742 of 43954 Old 02-24-2012, 12:04 PM
Quoted: 47 Post(s)
Liked: 50
That's an understatement!
Might not matter though, given the other compromises you're dealing with.
Florida_Gator
post #12743 of 43954 Old 02-24-2012, 12:24 PM
jjlee138's Avatar
I've been putting up with built in tv speakers for the last decade. If it sounds even slightly better I'll be excited.
jjlee138 is offline
post #12744 of 43954 Old 02-25-2012, 08:21 PM
NewHT's Avatar
Hello All,
I'm new to Polk Audio and I need help with my HT 5.1 setup. Room is 14x10 with open space to kitchen. I do mainly movies and music. I don't need to shake the house but listen to movies dialogs and enjoy the music.
I think there are some promotions on newegg with monitor series. I appreciate the quick response
Which PA series I should look for?
Are polk audio comparable to energy speakers? Which is best PA or energy?
Thanks for the help!!
NewHT is offline
post #12745 of 43954 Old 02-25-2012, 08:39 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Originally Posted by NewHT View Post
Hello All,
Best is subjective.
The monitor series or TSi series are excellent bang for the buck speakers...both are almost identical with the TSi's being newer replacements for the monitors. Sound quality is virtually identical. The RTI A series is lots better. What is your budget?
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #12746 of 43954 Old 02-25-2012, 09:05 PM
NewHT's Avatar
Originally Posted by 67jason View Post
Best is subjective.
Budget is around $400-500.
so which is better in sound, clarity? PA or energy?
NewHT is offline
post #12747 of 43954 Old 02-26-2012, 12:45 AM
NewHT's Avatar
Ordered this on newegg..Feedback on below setup?
Monitor40 series II for front
Monitor30 Series II for Surround
CS2 Series II
PSW10
Total: $429
These will be paired with STR-DN1000 Sony recv. which I already have.
I think I made bad choice on sub. I was looking for PSW12 and it was unavailable on newegg.
NewHT is offline
post #12748 of 43954 Old 02-26-2012, 07:05 AM
RamKat's Avatar
I am interested in getting a set of Polk audio speakers for a 7.1 system. Unfortunately Newegg USA refuses to sell to anyone with a Canadian stamp in his passport, so I have to look at other merchandisers. I have found some on Amazon but the one with the better deals and having everything I want in stock is, according to Polk's website, not an authorized dealer. Are there really Polk Audio knock offs out there and would a company like Amazon be part of a distribution system selling knock off's.
Epson 8500UB (R); Elite Electric100 16:9; Yamaha RX-V671; Polk Monitor 60 x 2, Polk CS2, Polk Monitor 30 x 4
RamKat is offline
post #12749 of 43954 Old 02-26-2012, 07:10 AM
Superman2's Avatar
Quoted: 16 Post(s)
Are you close to a border? Ship to ups stores close by.
Superman2 is offline
post #12750 of 43954 Old 02-26-2012, 07:14 AM
Quoted: 47 Post(s)
Liked: 50
CS2 Series II
PSW10
Total: $429
If you can swing it, consider returning the sub, then order the Bic F12 from Amazon for about $188. One of the best subs until you get up to $300-$350. I have one with my all-Polk speakers, and it's great for home theater and good for music.
Florida_Gator
Reply Speakers
Polk Audio , Polk Audio Csi5 High Performance Center Channel Speaker , Polk Audio Monitor 30 Bookshelf Speakers Cherry , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Cherry , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio R50 Floorstanding Speakers Each , Polk Audio Rti4 High Performance Bookshelf On Wall Speakers , Polk Audio Rti6 High Performance Bookshelf Speakers Pair Black , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Polk Audio Surroundbar 4000 Iht Virtual Surround Speaker Bar With Wireless Su , Polk Audio Three Way Vanishing Rt Series In Ceiling Speaker 70 Rt , Polk Psw108 10 100w Psw Series Powered Subwoofer
