Wharfedale Owners Thread - Page 37 - AVS Forum
post #1081 of 1297 Old 04-27-2011, 08:41 PM
jb1677's Avatar
Does anyone have real life pictures of EVO2-DFS speakers? The specs make them sound GIGANTIC especially depth, sometimes an actual visual will help me see what they really look like.
jb1677 is offline
post #1082 of 1297 Old 05-01-2011, 08:12 PM
geekiegeek's Avatar
Hi all, I'm looking for advise on an upgrade.
I currently have a full set of diamond 9s (9.5 Front, 9.1 Rear and 9CS Center). I am driving them with a Sony STR-DA1200ES 100w\\7ch receiver.
I use this for movies\\TV but also for 2 channel music from a DAC using the anologue direct feature on the receiver.
I would like to get better 2 channel sound so was looking at upgrading the fronts to Opus 2-1s.
I know that a more powerful amp would be better for this but in the meantime (untill I have more $$$) do you think the Sony amp will be ok?
Also what are your thoughts on using the Diamond series rears and center with the Opus fronts?
Thanks in advance.
geekiegeek is offline
post #1083 of 1297 Old 05-02-2011, 04:29 AM
rafparedis's Avatar
I'd consider to also get the Opus center speaker for your front stage. Diamond rears should be okay
rafparedis is offline
post #1084 of 1297 Old 05-02-2011, 10:35 AM
geekiegeek's Avatar
Yeah I'm leaning towards the opus center as I have read that that is pretty much the speaker doing most of the work when watching multi channel movies etc.
Hoping to get a price back from the supplier for the Opus 2-1s today and might ask them to add the center as well.
Another question:
If the supplier cant get me the 2-1s I know that they have the 2-2s in stock. My amp is at the low end to run these (manual states 100-500w) but would this be helped if I use my amps bi-amp setup?
post #1085 of 1297 Old 05-06-2011, 01:06 AM
rafparedis's Avatar
the opus speakers do benefit from more amp power and as bi-amping them gives them more power it should help. (I noticed a difference going from the internal amps in the yamaha rx-v3900 to the rotel rmb-1095). The opus 2-2 have a slightly higher sensitivity (Db/w) than the 2-1
post #1086 of 1297 Old 05-26-2011, 09:28 AM
harshw's Avatar
Hi guys
I recently purchased a Wharfedale WA-12SB sub. The moment I turned it on, I noticed a buzzing sound, even without anything connected. The problem is - my apartment is super quiet and the sub is against a wall, making the buzz resonate. Does anyone here know if their Wharfedale subs buzz like this ?
harshw is offline
post #1087 of 1297 Old 05-27-2011, 02:53 PM
soundseeker's Avatar
My SW150 does not buzz. Try to connect it up and see if the buzzing continues. Maybe its just amplifying noise without any imput.
soundseeker is offline
post #1088 of 1297 Old 05-28-2011, 05:12 AM
harshw's Avatar
Connected it to the amp with a screened cable, the buzzing sound is constant and does not vary when I adjust the level or connect/disconnect the sub. Checked the actual woofer, it's not the one making the sound. So looks to me like a bad quality power supply ...
harshw is offline
post #1089 of 1297 Old 05-31-2011, 07:14 AM
k_fassi's Avatar
hi all
I'm new in the amp world and i like to learn from you.
i bought from 2 days ago Diamond 10.5 and i choice them because they are 3 way speakers not like 10.6. i know 10.6 is more power. the receiver i have is Onkyo 608. i have Diamond CM for center really I'm satisfied when i hear music or watching movies. next month i will upgrade the other speakers what you think for the surrounded speakers and Sub. i like to know are that is will be good when i use THX mode.
thanks
k_fassi is offline
post #1090 of 1297 Old 06-14-2011, 01:45 PM
k_fassi's Avatar
are any one come and visit this forum
k_fassi is offline
post #1091 of 1297 Old 06-14-2011, 02:47 PM
AVS Club Gold
seggers's Avatar
Liked: 24
If you schroll back through the dates, then you'll notice this isn't a hip and happening thread. But it is visited.
I have a matching set of Evo 1s (2x40s, CS and 4x10s), running from an Emotiva UPA-5 (5 channel amp) - the 40s have 4 chanels and the CS the remaining - hooked to an Onkyo 805 7.1 THX AVR.
I previously had Raidiance speakers, small at that.
My advice, go for the biggest speakers you can afford and make sure that they match. Then get an amp to run the mains.
Seggers
Mits 73835, Denon X4000, Emotiva UPA5 (triggered), Wharfedale Pacific Evo 40s, CS, 10s, the internet, a NAS drive, a TiVo Series 3 and an Oppo 103 (bye bye PS3). There's also a Wii, but we don't talk about that...
seggers is offline
post #1092 of 1297 Old 06-14-2011, 05:43 PM - Thread Starter
gmoney80's Avatar
I agree with above statement
HD-DVD COUNT:141
BLU-RAY:192
X360 GAMERTAG:trickygmoney80
gmoney80 is offline
post #1093 of 1297 Old 06-15-2011, 01:32 PM
k_fassi's Avatar
what is the different between Diamond 10 and Evo 2
k_fassi is offline
post #1094 of 1297 Old 06-16-2011, 08:38 AM
IceTBC's Avatar
Both products are on Wharfedale's web site. http://www.wharfedale.co.uk/Home/tabid/37/Default.aspx
IceTBC is offline
post #1095 of 1297 Old 06-18-2011, 04:34 AM
k_fassi's Avatar
thanks so much
k_fassi is offline
post #1096 of 1297 Old 06-19-2011, 05:45 AM
ausmariner's Avatar
What are the differences between the Diamond 9.6 and 10.6?
At my local retailer, the 9.6 is $50 extra per pair.
Which one is the better speaker? I would've thought the 10.6, but the 9.6 is more expensive??
ausmariner is offline
post #1097 of 1297 Old 06-21-2011, 05:51 AM
k_fassi's Avatar
Diamond 9.6 is equal diamond 10.7 . the 10.6 is equal 9.5. for that you found the 9.6 is expensive than 10.6.
you must compare between Diamond 9.6 and 10.7
Diamond 10 is look more nice than diamond 9.
i have Diamond 10.5. I choice it because it is 3 way speakers. and the sound is very great.
10.6 is a 2.5 way speakers
you can go to the next web site and you will find a full information
k_fassi is offline
post #1098 of 1297 Old 06-25-2011, 10:38 AM
iflytwo's Avatar
During my search for speakers the term "Reference" came up quite often. I have not been able to determine what that really refers to, other than to notice reference speakers are usually on the larger size. Does it relate only to size? My Diamond 10.5's are floor standing cabinets with drivers = 6.5", 3", and tweet, would they be considered reference speakers?
Any explanation of this term would be appreciated.
Thanks for helping with my education.
iflytwo is offline
post #1099 of 1297 Old 07-01-2011, 12:36 PM
iflytwo's Avatar
I asked the question on another forum and got some answers. Calling a speaker a reference speaker is just marketing fluff that manufactures use to imply the speaker is capable of a higher level of sound reproduction than other speakers. A manufacturer usually reserves the REFERENCE label for their high end product. There is no defined performance capability that a speaker must have in order to be called a reference speaker. One of the responders to my question pointed out that the term Reference, when used to discuss the quality of sound heard in for instance a theatre, does impose certain measurable sound characteristics that must be met. The THX standard is an example. The "Reference" label can be put on any speaker without it being required to meet any performance standards.
To answer my question, I guess my Diamond 10.5 can be reference speakers if I want them to be.
iflytwo is offline
post #1100 of 1297 Old 07-03-2011, 06:09 AM
k_fassi's Avatar
that mean my speakers 10.5 can play THX .
k_fassi is offline
post #1101 of 1297 Old 08-17-2011, 08:58 PM
mtnsound's Avatar
has anyone replace the grills on their Opus speakers? I have the Opus 2's now for last few years and several of the tabs have broken off on the grills so it doesn't take much to knock them off.
mtnsound is offline
post #1102 of 1297 Old 08-18-2011, 09:27 AM
IceTBC's Avatar
A couple of mine have broken off over the years (had mine for about 6 years now I think) and you're right it's a design flaw IMO. What I found to work as a replacement is getting some of the half inch sticky backed black velcro rolls and cutting a small amount and using it at the corners of the grills that have the broken pin. Depending on the grill and the break you might have to double up on one side to get the necessary thickness. Being black tho they are invisible behind the grill corner. That's what has worked for me.
IceTBC is offline
post #1103 of 1297 Old 08-25-2011, 08:42 AM
djhack1639's Avatar
My comparison of the Energy RC-10 vs. Wharefedale EVO2-8 is up in a new thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1356315
Edit: fixed url.
djhack1639 is offline
post #1104 of 1297 Old 08-25-2011, 08:44 AM
AVS Club Gold
seggers's Avatar
Liked: 24
http://www.avsforum.com/avs-vb/showt...4#post20865964
Err, no it's not...:
Sorry but the page you are looking for cannot be found.
Seggers
seggers is offline
post #1105 of 1297 Old 08-25-2011, 09:24 AM
djhack1639's Avatar
Odd, I fixed the url in the above post.
post #1106 of 1297 Old 08-26-2011, 07:43 AM
Narwhaling's Avatar
Hello,
I've been looking into getting some Diamond 10.1s but I had a few questions. I'm on a budget and I've been reading that the 10.1s are some of the best budget speakers out there. Right now I have an HK3490 receiver. Would that be an acceptable amplifer to run the 10.1s? I'm really not looking to change my receiver, would there be a better option for similar money?
Narwhaling is offline
post #1107 of 1297 Old 08-26-2011, 11:25 AM
Originally Posted by Narwhaling View Post
Hello,
I was able to drive my Diamond 9.1s with my Denon 1909 (90W/channel) without any problems. I've heard very good things about the HK3490, should drive the Diamond 10.1s without issue.
post #1108 of 1297 Old 08-28-2011, 05:34 AM
alatham's Avatar
Narwhaling,
Keep an eye on Musicdirect.com as they gave 10.1 demos at time for around 280 vs 350 for new.
alatham is offline
post #1109 of 1297 Old 08-29-2011, 10:10 AM
jodyscott's Avatar
Hi,
I have a pair of Wharfedale W90 speakers (sand-filled model).
I'm desperately looking for someone who has a photograph of the crossover
for these, or some know-how of the configuration.
I've been attempting to repair them for a year and have had some techs playing around with bypassing the crossover (didn't work).
Any help would be greatly appreciated, as I've almost given up. Wharfedale informed me that they lost this information when one of their facilities burnt several years ago.
Finding someone with some know-how is my only hope.
Kind thanks
jodyscott is offline
post #1110 of 1297 Old 09-03-2011, 10:51 PM
michaeljoo's Avatar
Also regarding the Evo2-DFS surrounds, does anybody know if these are bipole/dipoles? It looks like it might be from the pic, but it's hard to tell. It seems to have 2 x 5" drivers and a single 1" tweeter. A lot of the ones I've seen seem to have either 2 tweeters and 1 driver, or 2 tweeters and 2 drivers, not 1 tweeter and 2 drivers.
It's hard to tell from the specs on the Wharfedale site.
Also, does anybody have any experience with how these sound?
michaeljoo is offline
Reply Speakers
Sp870 Sp870 , Wharfedale Opus 2 3 Speaker Pair Piano Finish
Gear in this thread - Sp870 by PriceGrabber.com
