Wharfedale Owners Thread - Page 50 - AVS Forum | Home Theater Discussions And Reviews
 25Likes
post #1471 of 1497 Old 02-03-2016, 01:51 PM
bgtighe23's Avatar
Quoted: 893 Post(s)
Liked: 404
Originally Posted by Zorba922 View Post
I've always been skeptical of audiophile esoterica like bi-amping, but recently I discovered that I had some extra banana plugs and speaker wire lying around, so I decided, oh what the hell, why not.
Wasn't expecting anything dramatic, but I could swear that my Diamond 10.1s are now a good bit livelier, the highs especially but also the mid-bass seems more solid...I use them for music usually without a subwoofer, playing full range, not at reference levels or anything, but sometimes I do like to turn up for some of my favorite tunes.
Anyway, I should add that my receiver is a 10 year old digital switching Panasonic SA-XR55, which in bi-amp mode actually uses 2 amps per woofer and 1 per tweeter. It also has digital phase correction controls as well as allowing you to adjust how much power you want to go into the tweeters vs the woofers; have yet to really play around with this yet but am planning to do so this weekend.
When I previously owned the Ascend 340s with this receiver, I also bi-amped them but didn't notice more than minor differences. Was wondering if the Wharfedales being 6 ohm speakers and with their warm, laid back characteristics (the Ascends were much more neutral, bordering on clinical, 8 ohms and at least 4-5db higher in sensitivity) benefit more from the extra power?
There is passive bi-amping and active bi-amping. Your 10 year old receiver has an active bi-amp feature. That means, as you said, it has another or additional amp powering the woofer. This is no gimmick and is very much so used in powered speakers and in your case, a receiver.
The Seaton Catalyst is a Internally powered, tri-amplified design.
Three (3) ICEpower channels of amplification with 24-bit/96kHz DSP executing the crossover design and response contouring.
300W powering the coaxial 1" Neodymium compression tweeter
700W powering the 8" midrange (coaxial with tweeter)
1000W powering the pair of 12" sealed woofers.
Passive bi-amping is the "skeptical of audiophile esoterica" as you described.
_____ _____ _____ _____ _____ _____ _____ _____ _____ _____ _____
HTD Level 3 Review
Receiver : Denon x4100
Speakers : Martin Logan Motion 40s/P363 center/HTD Level 2 Tower surrounds
Subwoofer : Dual UM-18s
Born in 1995 and still continuing my HT journey
bgtighe23 is offline
post #1472 of 1497 Old 02-03-2016, 02:26 PM
ereed's Avatar
Quoted: 134 Post(s)
Liked: 54
If you're happy with the voice clarity of your current Axiom center, I'd recommend hanging on to it. Especially since you already use 2.0/2.1 for music anyhow...Wharfedale tweeters are great for music, but you may find them not as forward or lively for HT.
Wharfedales will generally benefit from good quality power, so your Rotel amp should work very well with them.
If you were planning on upgrading your Axiom sub eventually, I would get the smaller less expensive Wharfedale tower and put the savings into that subwoofer budget.
Yes, I noticed they are 4 ohms and go down to 3 ohm minimum so my rotel 1075 should do fine (at least better than most avrs). I was planninng on keeping the axioms anyway but if the 220c or 240c center channel is better than my vp150s (bad horizontal axis off center) then I may change it out. And I would change the center only if I decide to sell my axioms and I'm sure someone would want the axiom center as a set with the towers for timbre matching (you know how people with OCD are). I'm quite happy with my EP500 subwoofer and it does the job wonderfully for movies and its very articulate with music which I'm very surprised cause of my huge floor plan. I would say the ep500 is the better speaker out of my whole axiom 3.1 setup in my room. I could probably find another ep500 used for sale to improve the HT experience which would be cheaper than buying new subs. Mainly just looking for better 2.0 experience. Don't get me wrong I love my axioms and everyone who hears it think my system is better than what they have heard. But sometimes I just feel like I'm not emotional into the music and I want to be drawn into the music rather than having it thrown out at me.
I thought about cheaper 230 series but since I'm used to having 4 drivers in my axiom towers I'm afraid I'm going to lose the presence of the larger tower if I do music in 2.0 and not use the sub especially in a large space (18 feet x 22 x 9 feet ceilings (18 feet x 14 feet HT space)) and it opens up to the hall and the loft upstairs. And then I saw the 250. Any idea how the 200 series compares to 10 series in sound? I've only heard the 9 series but that was over 5 years ago. I need to go audition them.
Zorba, have you heard your wharfies compared to emp teks, which is a more forward speaker between the two?
Axiom M60, VP150, EP500
Panasonic 60-S60 Plasma
Panasonic BDT 500
Rotel 1075 Amp & Rotel 1068 Processor
Monster power conditioner
ereed is online now
post #1473 of 1497 Old 02-03-2016, 02:31 PM
Zorba922's Avatar
Quoted: 921 Post(s)
Liked: 602
Huh, I thought I read somewhere that you have to remove the speaker's internal crossover in order to have "active" bi-amping...or something like that? It sounded awfully complicated.
Zorba922 is offline
post #1474 of 1497 Old 02-03-2016, 02:42 PM
ereed's Avatar
Quoted: 134 Post(s)
Liked: 54
It does sound complicated....that's why I stick with bi-wiring instead. lol
Zorba922 likes this.
Panasonic BDT 500
ereed is online now
post #1475 of 1497 Old 02-03-2016, 03:44 PM
ereed's Avatar
Quoted: 134 Post(s)
Liked: 54
I just happened to be at best buy's website browsing around and I see they have wharfedale speakers at magnolia store! Is this new? I swear I've never seen wharfedale at my best buy magnolia store. Gonna check it out this weekend!
Panasonic BDT 500
ereed is online now
post #1476 of 1497 Old 02-03-2016, 04:07 PM
ereed's Avatar
Quoted: 134 Post(s)
Liked: 54
New update! I got too excited and actually drove to best buy which is 5 min from my house. They don't have the wharfedales in the stores yet but they will in 2 weeks according to the magnolia store employee. I can not wait to audition these speakers! Does anyone on here have the 230, 240, or 250 towers? Would love to see pictures instead of online pictures.
Panasonic BDT 500
ereed is online now
post #1477 of 1497 Old 02-03-2016, 11:01 PM
Zorba922's Avatar
Quoted: 921 Post(s)
Liked: 602
What??? I thought the Wharfies are 6 ohms, probably with dips down into 4?
WhatHiFi? gave the 220 a perfect 5 star rating vs the 3 or 3.5 star rating they'd given to the 10.1 previously, but I find that magazine quite unreliable...a couple years ago they claimed that the iPod Touch has "authoritative bass" and rated it the best SOUNDING (best GUI, that I could understand) player around, which is absolutely hilarious.
On the other hand, Steve G from CNET wrote that he didn't think the new ones were any big improvement over the 10.1 which he had previously raved about and recommended getting the 10.1 due to their spectacular closeout pricing.
Me, I ruled out the new series due to the hideous blingy metal rings that surround the drivers...ugh, pure teenager-pandering aesthetic! But I have to say, if you don't have a good foot of rear clearance for the old rear-ported models, then the downfiring new models might be worth that ease of placement.
From what I've read, the EMPTek R55ti is slightly warm (possibly due to the MTM design up top) while the R5Bi bookshelf is apparently very neutral. So generally I would still expect the Wharfies to be warmer and more laid back.
Your experience with your Axioms parallels mine with the Ascends I used to own...they were great for HT and certainly no slouch for music, but once I heard my favorite tunes play on a couple of "warm" speakers, I knew that change was in the air!
Didn't know that about the Wharfedales getting picked up by Magnolia/BB ... will have to go visit one in the next few weeks, then! Just checked their website and they're listing Feb. 12 as the availability date.
Zorba922 is offline
post #1478 of 1497 Old 02-04-2016, 09:28 AM
bgtighe23's Avatar
Quoted: 893 Post(s)
Liked: 404
To bi-wire, you simply remove the jumpers.
If the crossover is poop, then there isn't a point to active bi-wire. Either way, most of us use subs and the price to have a noticeable difference isn't something that makes bi-wiring any interesting.
HTD Level 3 Review
post #1479 of 1497 Old 02-04-2016, 03:46 PM
ereed's Avatar
Quoted: 134 Post(s)
Liked: 54
Yes, the 240 model I was most interested in is 4 ohms nominal and 3 ohm minimal and the 230 model is 8 ohms nom and 3.7 min and the 250 is 6 ohm nom and 3 ohm min. (all this according to music direct website) I hear from reviews that its easy to drive and has 89-90db sensitivity. My rotel 1075 should be just fine.
Was gonna order from music direct but I'm gonna wait 10 days to check it out at best buy (feb. 14th) and do a week trial at home to see if I like it. If it turns out I don't like it then I have some other speaker options in mind.
I understand the metal rings looking weird but I believe they have it on 10 series as well (at least you can cover it with the grill). The white gloss metal grills doesn't stand out like black does and it will go well with my modern decor (and the wife thinks upgrading to another black speakers is nothing more than keeping same speakers I have now. LOL) I watch my movies in the dark and I'm hoping the white gloss doesn't reflect much light from my plasma or anything.
I wonder if the 250 is an imrovement over the 240 model with 8 inch drivers in music? I dont mind paying more if its bigger improvement for 2.0 setup without a sub. Still trying to decide if I want full range in 240/250 compared to 80hz crossover to my subwoofer. By the way I thought about 230 tower to save money like you suggested but I feel maybe the extra midrange driver will be an improvement? I will find out soon.
And I see there is bigger center channel called 240c but its only available in UK. Same speaker as 220c but with 2 extra woofers. I wonder if I could order one from UK and have it delivered here to usa or would that cost way too much? But I will be trying out the 220c from best buy if they have it.
Panasonic BDT 500
ereed is online now
post #1480 of 1497 Old Yesterday, 11:44 AM
jamie ford's Avatar
duplicate, pls. delete
jamie ford is online now
post #1481 of 1497 Old Yesterday, 11:44 AM
jamie ford's Avatar
Hello all.
Proud new owner of a set of Jade 5's that are replacing Salk Songtowers and a Rythmik Sub.
So far very happy.The Jades and the Salks are rated down to the same level but I feel the 5's go lower or at least sound as if they do. I will be getting rid of the sub which was one of my goals in making the switch. The Jades, not being ported, offered better room flexibility for me as well along with higher WAF. The speakers are not yet broken in but have no complaints so far other than a bit of harshness/forwardness of the cymbals (particlulary the high hat) in listening to Donald Fagen's "Karmakind" CD ....loving other stuff such as Terry Bozio, Joni Mitchel "Blue" , Live GD, ect.
My Salks were run through my Pioneer VSX23 AV amp but I have been running the Jades with my Jolida 502BRC tub amp. I have to say that I love the sound but may need to go back to something solid state that go can in my remote AV closet as the Pioneer does.
Wondering what some pairings are here for the 5's. Am looking at the Marantz 6005 integrated or maybe the Rotel RA 12.
Jamie
post #1482 of 1497 Old Yesterday, 12:12 PM
Carbo's Avatar
Quoted: 26 Post(s)
Jamie,
Welcome, I've been using Jades for a couple of months. I went with the Jade 7's, C2, SR for my home theater and I'm loving them. I have them paired up with a Yamaha CXA5100 and they sound great for Music and Movies. The only problem I'm having is finding some in-ceilings to match them with for Atmos.
But, as is they sound great. The details they bring out in everything is awesome.
Carbo is offline
post #1483 of 1497 Old Yesterday, 03:23 PM
jamie ford's Avatar
Originally Posted by Carbo View Post
Jamie,
Ok, I'm derailed already...lol.
Your post had me googling Atmos.......I want it. Just put my 7.1 system together last year when I went back to DLP (from a JVC LCOS), adding 3D along the way, and finally finishing my HT, time to upgrade?
I almost went with the Jade 7's but they were a little too tall for my room.
The entire line 1's through 7's are really good looking and, I thought, a pretty good value.
post #1484 of 1497 Old Yesterday, 03:39 PM
Carbo's Avatar
Quoted: 26 Post(s)
Just received a response back from Wharfedale about Atmos and was told to get their Pacific Series(either C170 or C250) for Atmos at $249 or $299 per pair.
Not sure how good they are, I'm gonna have to do some home work.
Anyone here have any?
Carbo is offline
post #1485 of 1497 Old Yesterday, 07:23 PM
ratherb1's Avatar
So I'm interested in the 10.5 or .7 s and I don't have any room (or very little ) to move from away from wall. And just wondering from y'all what is the recommended distance from the wall of these speakers with rear ports.
ratherb1 is offline
post #1486 of 1497 Old Yesterday, 07:33 PM
Quoted: 271 Post(s)
Liked: 114
Check the Wharfedale site, but I assume at least 1 foot from wall as a starting point. Good luck
MarlinFan likes this.
yanks1 is online now
post #1487 of 1497 Old Yesterday, 07:51 PM
ratherb1's Avatar
I did check, didn't see anything but I may have missed it, but I didn't see anything related to the 10.5 or 7s either ....
ratherb1 is offline
post #1488 of 1497 Old Yesterday, 08:16 PM
ereed's Avatar
Quoted: 134 Post(s)
Liked: 54
The 200 series such as 230, 240, 250 etc all have ports at the bottom of the cabinet downfiring so placement is more flexible and can be placed closer to the walls. But only way to try it is to order 10 series and see if it sounds good close to your wall. If you have it out 4 inches from the wall minimum I think you will be ok, just don't have it actually up against the wall touching.
ratherb1 likes this.
Panasonic BDT 500
ereed is online now
post #1489 of 1497 Old Yesterday, 08:40 PM
ratherb1's Avatar
Thanks for the input, if I could get past the looks of the 230 I would be considering them( still may be ) but guys with the 230 240 250 are the grills on front kid proof? Even a little ? Its really hard to tell from the pics but it looks like the grille is soft, and if it is my kids would push right through into the dust cap.
ratherb1 is offline
post #1490 of 1497 Old Yesterday, 08:41 PM
ratherb1's Avatar
I have I think at the most 8 inches so maybe the 10.5s would work
ratherb1 is offline
post #1491 of 1497 Old Yesterday, 09:07 PM
Zorba922's Avatar
Quoted: 921 Post(s)
Liked: 602
It depends on whether you'll be running them full range vs. "small" and crossed over with a sub. If it's the second, then you won't need so much space. I prefer to listen to my 10.1 Diamonds full range in order to get more midbass presence, so I have them about a foot away from the wall.
Zorba922 is offline
post #1492 of 1497 Old Yesterday, 09:10 PM
Zorba922's Avatar
Quoted: 921 Post(s)
Liked: 602
If you want a kid-proof option, consider the Ascend 340SE with the OEM pedestal stands---you can fill the stands with upwards of 100lbs of sand or metal shot which will make them a lot harder to knock over, and the first 24" is solid MDF, no drivers there that can be damaged. Of course, the Ascends have a completely different sound signature than the Wharfedales, though...neutral and slightly forward, rather than warm and laid back.
Zorba922 is offline
post #1493 of 1497 Old Yesterday, 09:14 PM
ratherb1's Avatar
Well I just bite the bullet ( did I say that right ?) or took the plunge , Hahahaha. Diamond 10.5s ordered. Now I need to find a center cm or cs im thinking, not sure which pair up better with the 10.5s , Any recommendations for a center?
Anyways I'm coming from primus and hopefully this will be a nice upgrade ( fwiw I find the infinty really bright ). I will have my receiver crossed with a sub..... At maybe 80 or 60. Have an sb-1000 and velo minivee. Looking into getting another sub soon looking for more ommph
ratherb1 is offline
post #1494 of 1497 Old Yesterday, 09:19 PM
Rogozhin's Avatar
I'm still running my wharfedales, haven't seen or heard anything that makes me want to change, but the Jades look really nice.
My system is a 7.2
2x Evo 2 30s
2x Evo 2 20s
1x Opus Tri-Center
2x Opus Tri-Surrounds
2x SVS subs
All in maple. When I upgrade to atmos I'm going to add the Pioneer top pods to the front and rears.
GamerTag= Phaleronic
Rogozhin is online now
post #1495 of 1497 Old Today, 02:56 AM
Zorba922's Avatar
Quoted: 921 Post(s)
Liked: 602
If you're looking to avoid brightness, the Wharfedales are an excellent choice...that's one adjective that I've yet to ever see used in the same sentence with them.
If you want a sub with more oomph, stay away from sealed designs. The Rythmik LV12R is a very good choice, just $70 more than the SB1000.
For the center, if you want maximum voice clarity I would actually recommend NOT going with Wharfedale...the same tweeter that has such a beautifully warm and laid back sound for music listening is not ideal for rendering the human voice clearly and easily (i.e. w/o needing to crank up the volume).
The most economical choice would be the BIC FH-6:
http://www.amazon.com/review/R1DYBWM...cm_cr_rdp_perm
http://www.amazon.com/BIC-America-FH.../dp/B0015A8Y3E
A very safe choice, albeit at nearly 3x the price:
http://www.ascendacoustics.com/pages...c/cmt340c.html
I use the BIC with my Diamond 10.1s and it's pretty much the best of both worlds: nice crisp HT dialogue, and nice warm music in 2.0/2.1!
Zorba922 is offline
post #1496 of 1497 Old Today, 05:07 AM
ratherb1's Avatar
Thanks I'll check into it !
ratherb1 is offline
post #1497 of 1497 Old Today, 07:49 AM
ereed's Avatar
Quoted: 134 Post(s)
Liked: 54
You could do what zorba suggested or keep your primus center channel if you don't want to spend money and see how it matches up with your new wharfedale mains. Unless you have OCD and what it all the same and if thats the case get the bigger CM model since it has extra midrange which might be better for dialog in movies. The center channe you really don't want to skimp on if most of your system is used for movies, it just needs to be clear and dynamic for most part. I have the axioms and Zorba has recommended that option for me as well to try out my center and I will be demoing the wharfedale 200 series very soon and see how their center compares with my brighter axioms.
Panasonic BDT 500
ereed is online now
Reply Speakers
Sp870 Sp870 , Wharfedale Opus 2 3 Speaker Pair Piano Finish
