Wharfedale Owners Thread - Page 55 - AVS Forum | Home Theater Discussions And Reviews
 63Likes
post #1621 of 1630 Old 12-29-2016, 01:35 PM
JohnFR's Avatar
Quoted: 16 Post(s)
Originally Posted by Zorba922 View Post
If they are these speakers and in reasonable condition, then yes you'd be getting them for 1/10th of regular price.
https://www.musicdirect.com/speakers...pr-awfjade3blk
Oops I meant they are sale (new) for $999.00 a pair, same as at Music Direct. Thanks for the link. I hope to go listen to these next week.
JohnFR is offline
post #1622 of 1630 Old 12-29-2016, 01:51 PM
aarons915's Avatar
Quoted: 38 Post(s)
Liked: 33
Huh, listening fatigue is usually caused by excessive treble; I've never heard of anyone getting it from too much midrange.
Unless you're listening to Celine Dion wailing at the top of her lungs for hours on end, of course.
(Personally that would give me nausea much faster than listening fatigue, lol.)
I always figured fatigue was caused by high treble as well like above 10k but actually I think I read somewhere that 99% of musical frequencies are below 6k Hz. If you do a sweep in REW or some other means and just go up to 4k you'll hear how high pitched it sounds there. From 2k-4k is where our ears are very sensitive and this is generally the range that gives fatigue after long listening sessions. Every speaker that I like and have measured and consider "laid back" has about a 5 decibel drop around 1k to at least 5k.
Zorba922 likes this.
aarons915 is online now
post #1623 of 1630 Old 12-29-2016, 02:14 PM
ereed's Avatar
Quoted: 795 Post(s)
Liked: 367
I was about to ask where you saw the $99 price for Jades and buy them before you did. LOL
Main theater: Sony 45es, 120 inch ST screen, Panny BDT500, Rotel RMB-1075, Rotel RSP-1068, Klipsch RP-280F, RP-450C, RP-160M, SVS PB13-Ultra x 2
Loft theater: Panasonic 60" plasma, Integra DTR-30.3, Axiom Audio M60, VP150, QS8, EP500
ereed is online now
post #1624 of 1630 Old 12-29-2016, 02:16 PM
Zorba922's Avatar
Quoted: 2312 Post(s)
Liked: 1630
Me too...had a feeling that was probably a typo.
ereed likes this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is online now
post #1625 of 1630 Old 01-03-2017, 11:14 AM
JohnFR's Avatar
Quoted: 16 Post(s)
I noticed on this company's website today that they have an open box pair of rosewood Jade 3s for $799.00.
Any owners of these speakers care to offer an opinion? My fronts are Dali Helicons. I intend to use them as surrounds at present but have plans to set up a 2.1 system with bookshelfs/sub for music.
JohnFR is offline
post #1626 of 1630 Old 01-05-2017, 10:01 PM
aarons915's Avatar
Quoted: 38 Post(s)
Liked: 33
I've decided to go with 3 220's across the front instead of using Diamond 10 CS, my 2nd set of 220's will be here tomorrow, if anyone else wants to use a 220 as a center channel let me know as I'll have a brand new one in the box that I could ship out. They are walnut by the way. Anyone wanting to use the 10 CS as MTM fronts should take advantage of how cheap they are on music direct by the way, they really are very solid speakers and I almost don't want to let them go but they just don't quite work in my setup and for some reason there is just something special about a good 2 way Bookshelf speaker when it comes to music for me. Oh and the little rubber pieces used to allow it to sit flat for center channel use are just held on by an adhesive that feels like they would just pull right off without hurting the finish so they'd be great for anyone looking at them for fronts. Just make sure you have the room they are pretty big.
post #1627 of 1630 Old 01-05-2017, 10:24 PM
Zorba922's Avatar
Liked: 1630
I'd be curious to hear how you find the extra 220 as a center vs the 10.CS, in a direct switch comparison.
Will you have the center 220 on its side or vertical?
post #1628 of 1630 Old 01-05-2017, 10:46 PM
aarons915's Avatar
Quoted: 38 Post(s)
Liked: 33
I've used a 220 as center with the 10 CS as mains and the 220's as mains with a 10 CS as the center, it's pretty much the same story, the 10 CS is a fuller sounding speaker and probably better for home theater but for my purpose the 220 does fine. Of course the 10 CS suffers the normal problems of an MTM speaker laying on it's side so if that's a concern you might go with the 220 but I'm always directly in front of it so it's no big deal to me.
post #1629 of 1630 Old 01-16-2017, 01:14 AM
Liked: 6
Wharfedale Diamond 10.5
MarlinFan, ereed, seggers and 1 others like this.
Brettinlux is offline
post #1630 of 1630 Unread Today, 04:44 PM
seggers's Avatar
Quoted: 102 Post(s)
Liked: 52
So I think I just talked myself back from buying a set of used J7s, CS2 and DFSs. Not sure if they were a good price or not.
Anyways, my Evo 40's suffer from the usual for these models. The speaker grill tabs break off. I've managed to save a couple of broken ones. Has anyone got and useful ideas on how to reattach the posts back to the grills? Hoping it doesn't involve industrial strength glue and 6 inch nails...
Seggers
Vizio M80-C3, Denon X6300H, Emotiva UPA5 (triggered), Wharfedale Pacific Evo 40s, CS, 10s, PC DX12 sub, Def Tech A60 Atmos tops, the internet, an ASUS ChromeBox running Kodi, a TiVo Series 3 and a Philips BDP7501 UHD . There's also a Wii, but we don't talk about that...
seggers is online now
Reply Speakers
Sp870 Sp870 , Wharfedale Opus 2 3 Speaker Pair Piano Finish
