Mirage Speakers - Page 148 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #4411 of 7081 Old 08-19-2010, 05:46 PM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
Originally Posted by grego9198 View Post
Just placed my order through amazon.com for the OMD5's. Luckily they accepted my Canadian credit card as vann's only accepts US cards. Having them shipped to a pickup location in Niagara Falls. Can't wait to pick them up next friday. Will post first impressions when they arrive.
I think you'll be very happy with them. Should be a significant upgrade over the nano's...
And since you've been without a sub for this long, I think you'll be happy with the added bass from just the OMD's.... although in the long run, you'll be even happier once you do get a sub...
alphaiii is offline
post #4412 of 7081 Old 08-20-2010, 08:24 AM
ShapS's Avatar
Quoted: 12 Post(s)
For those who have the OMD line in rosewood... Would you say you find the color contemporary? Modern? Classic? Rich? Do they 'fit' in a more modern setup? Is the piano black much more modern? I have piano black, but adding a C1 and really like the rosewood look for it. Problem is all my other furniture is black so I'm trying to decide if it would blend ok or if I should stick with piano black.
ShapS is offline
post #4413 of 7081 Old 08-20-2010, 10:05 AM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
I have the OMD-5 in rosewood, and would say it looks very modern... I've had other speakers in piano black... and I wouldn't say one or more or less modern looking than the other, just different.
My biggest grip with piano black is that it's a dust/fingerprint magnet... and while any gloss finish will show that, it's less noticeable with the gloss rosewood... And having a grain visible beneath that gloss surface really adds nice depth to the finish, IMO.
It's really up to you when it comes to matching with the furniture. Gloss black will match black (obviously), but rosewood works very well with black, but will stand out more, instead of blending in. It's entirely your call if you want to emphasize the speaker visually or not...
alphaiii is offline
post #4414 of 7081 Old 08-20-2010, 10:45 AM
shodulik's Avatar
I agree with alphiii. The rosewood on the OMD's is much more modern than a traditional real wood veneered speaker. The rosewood itself is subtle but the glossy finish makes them stand out a bit and they aren't like a furniture grade wood veneered speaker where the grain is very easy to distinguish and feel by touch. I think the modern finish matches well with the overall non-traditional looking design of the speaker.
Since your other speakers are gloss black I'd go with the black center as well but that's just my preference. Regardless of room aesthetics I always will choose a wood color speaker over a black one but I prefer to keep the color uniform for all speakers.
shodulik is offline
post #4415 of 7081 Old 08-20-2010, 12:29 PM
ShapS's Avatar
Quoted: 12 Post(s)
alphaiii & shodulik,
Thanks, that is what I was trying to get to, if it looked like traditional/classic wood veneer. The photos do make it look much sleeker due to the high gloss and overall design.
Shodulik, I'm thinking center in rosewood and keeping the other two L&R OMD5's in piano black because long term they will become rears and I'm pretty damn sure based on how much I like the OMD5's that I'll get OMD 15's or higher at some point. I'd rather keep rears more 'hidden' and have the fronts pop out, which seems like the rosewood would do with black furniture. Tough call though!
ShapS is offline
post #4416 of 7081 Old 08-20-2010, 04:09 PM
shodulik's Avatar
Ah ok Shaps that sounds like a good plan!
shodulik is offline
post #4417 of 7081 Old 08-21-2010, 08:03 AM
Spurrier Sucks's Avatar
Quoted: 654 Post(s)
Liked: 474
Do it before they are all gone. Rosewood is nice looking.
Spurrier Sucks is online now
post #4418 of 7081 Old 08-23-2010, 07:48 PM
Bluelude1's Avatar
Does anyone have a picture of how the rubber bumpers are supposed to be positioned on the back of the OMD5s ?
Bluelude1 is offline
post #4419 of 7081 Old 08-24-2010, 04:50 AM
LansdaleHokie's Avatar
Originally Posted by jerkweed View Post
anyone know if the Omnimount 10s will handle the OMD-5's ok for ceiling mount? Just got mine in and I'm trying to figure out the best way to position them.
I use the omnimount 20 wall mount with mine. Highly recommend them. Not sure if the 10's will be sufficient
Edit -I actually use the 10's
Mancave: UN46D7000, Onkyo 818, Mirage OMD-C1, OMD-5 (2), HSU STF-2, PS3, XBox360, Wii, DirecTV, AppleTV v2
Den: LG 55LX9500, Onkyo 709, Polk RC85i (3), Polk PSW10, DirecTV, AppleTV v3
LansdaleHokie is offline
post #4420 of 7081 Old 08-24-2010, 12:05 PM
RoundRocker's Avatar
Hey ShapS,
I have a OMDC1 in rosewood that I used for all of 1 week before running across an open box OMD-15 to use as my center. My pio sits high enough to allow it so 3 OMD-15's across the front sounded good to me. Let me know if you're interested.
RoundRocker is offline
post #4421 of 7081 Old 08-24-2010, 12:13 PM
Bluelude1's Avatar
Has anyone had any luck with different mount for an OMD5 than an Omnimount. The wall mount that comes with the speaker makes me concerned when I mount it upside down. I just really hate to have to spend $25-30 more per speaker (6x) for an Omnimount.
post #4422 of 7081 Old 08-24-2010, 07:46 PM
ShapS's Avatar
Quoted: 12 Post(s)
Originally Posted by RoundRocker View Post
Hey ShapS,
Appreciate it, but ended up doing piano black instead. Should be here Thurs!
ShapS is offline
post #4423 of 7081 Old 08-24-2010, 08:29 PM
I'm not sure what difference upside down vs. right side up makes with the included mount but for what it's worth I mounted all six of my omd-5s upside down with the included mount and they're all rock solid. Just use a good drywall anchor. Now if you looking to get them further from the wall that's a different story.
post #4424 of 7081 Old 08-27-2010, 08:09 AM
ShapS's Avatar
Quoted: 12 Post(s)
The C1 has arrive, wow this thing is big. Especially with the grill on. It came with a stand for on top of my cabinet, but the stand allows all kinds of angles. How angled upward is this suppose to be?
ShapS is offline
post #4425 of 7081 Old 08-27-2010, 08:15 AM
monkuboy's Avatar
Quoted: 20 Post(s)
Liked: 30
The normal position is for the back side of the speaker to be perpendicular to the base but then you should adjust it to your preferences.
monkuboy is offline
post #4426 of 7081 Old 08-27-2010, 08:52 AM
WhskyTangoFoxtrt's Avatar
Quoted: 76 Post(s)
Liked: 58
Here you go:
http://www.avsforum.com/avs-vb/showp...postcount=3595
A Nice Radio Station with Great Music. For Those That Like That Sort of Thing: RadioParadise.com
WhskyTangoFoxtrt is offline
post #4427 of 7081 Old 08-27-2010, 09:04 PM
grego9198's Avatar
Picked up my OMD5s this afternoon. Just barely fit all 3 boxes into the passenger seat of my Miata.
First Impressions: They are larger than I expected, they look double the size of my nanosats. I was a bit worried that they'd get in the way of my projector's light throw but it didn't turn out to be an issue.
The finish on them looks amazing! The grain in the maple looks really good contrasting all the dark coloured wood furniture I have in my loft.
They're still too new to evaluate the sound, have to work on breaking them in over the next week or two.
One negative though. A positive binding post on one of the speakers was loose when I received it. I can move it in and out a few millimetres. I didn't notice until I got it home. It doesn't seem to affect the speaker's sound though. I'll probably call up Mirage on Monday and see if they can fix it under warranty since they're in my city.
Here's a comparison picture of the nanosat vs the OMD5.
Uploaded with ImageShack.us
grego9198 is offline
post #4428 of 7081 Old 08-28-2010, 07:38 AM
shodulik's Avatar
Nice Grego! I'm lovin the maple finish...i've been going back and forth on whether to pick up a set of maple's. Don't really have the need for em but i just want a set lol.
shodulik is offline
post #4429 of 7081 Old 08-28-2010, 11:12 AM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
One negative though. A positive binding post on one of the speakers was loose when I received it. I can move it in and out a few millimetres. I didn't notice until I got it home. It doesn't seem to affect the speaker's sound though. I'll probably call up Mirage on Monday and see if they can fix it under warranty since they're in my city.[/url]
I had the same problem with one of my OMD-5's when I bought them. If I tried to loosen the binding post to accept bare wire, it would loosen from the cabinet instead of just the "cap" loosening.
Vann's had no issue with swapping it out for another one.
alphaiii is offline
post #4430 of 7081 Old 08-29-2010, 02:49 PM
ShapS's Avatar
Quoted: 12 Post(s)
WOW Love that color! I'm it adds a nice pop! Any chance you can post a more zoomed out picture? Really want to see how these look against dark furniture.
ShapS is offline
post #4431 of 7081 Old 08-29-2010, 07:20 PM
grego9198's Avatar
Here's a zoomed out picture. The media center is an ikea besta brown/black with the high gloss brown fronts.
post #4432 of 7081 Old 08-30-2010, 04:37 AM
Bluvette's Avatar
Quoted: 170 Post(s)
Liked: 164
Looks good.
Bluvette is online now
post #4433 of 7081 Old 08-30-2010, 02:17 PM
ShapS's Avatar
Quoted: 12 Post(s)
Looks nice! That's funny, something very similar here...
ShapS is offline
post #4434 of 7081 Old 09-03-2010, 05:49 PM
b4z
b4z's Avatar
Quoted: 18 Post(s)
Does anybody have contact info for Mirage Corporate so I can return 2 OMD5s that have blown woofers? Bought them from vanns in '09. Do you think they will replace them for free under warranty?
b4z is offline
post #4435 of 7081 Old 09-03-2010, 08:52 PM
Bluvette's Avatar
Quoted: 170 Post(s)
Liked: 164
Do you have a copy of your bill with the date on it?? They should take care of you. Try this link:
http://www.miragespeakers.com/na-en/support/
post #4436 of 7081 Old 09-04-2010, 05:08 PM
b4z
b4z's Avatar
Quoted: 18 Post(s)
Finding the Invoice from vanns will be interesting. I hope they are in the boxes.
b4z is offline
post #4437 of 7081 Old 09-04-2010, 07:50 PM
Bluvette's Avatar
Quoted: 170 Post(s)
Liked: 164
By the way how did you blow the woofers out??
post #4438 of 7081 Old 09-04-2010, 09:52 PM
drewh01's Avatar
I am new to Mirage but is the om-9 a good speaker? Worth a try for $300?
drewh01 is offline
post #4439 of 7081 Old 09-05-2010, 06:58 AM
tmccombs's Avatar
I am looking for a recommendation for a center channel to replace my larger Mirage. I had to sell it because of size. I have all Mirage speakers, (M7si and OM-R2B for the rears.) and will be placing the new center channel on a fireplace mantel. The new Mirage centers point up in the air (yes, I know they say omnipolar) and from what I read here are not as full sounding.
I have been unable to find some older Mirage centers, so I am looking for another manufacturer that may be a good counterpart to Mirage. I always thought of the Mirage sound as warm, some may say dark, but not crisp or bright. Thanks for your help!
tmccombs is offline
post #4440 of 7081 Old 09-05-2010, 10:51 AM
Nooodle007's Avatar
Quick question for Mirage owners -- will the MX51's be powerful enough to fill my 730 sq. ft. space? I have 13' ceilings and was looking for a set to ceiling-mount in the four corners of my condo. Here's the floorplan if it helps at all...any feedback would be much appreciated - thanks!
Nooodle007 is offline
Reply Speakers
