Mirage Speakers - Page 190 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #5671 of 7073 Old 01-21-2012, 05:51 PM
pretsam's Avatar
Liked: 27
Originally Posted by b4z View Post
I've got mine at 100hz because they have already started rolling off at 80 hz.
How or what kinda signs do you look for when they roll off?
pretsam is offline
post #5672 of 7073 Old 01-21-2012, 05:53 PM
pretsam's Avatar
Liked: 27
Are you guys using banana clips in the back of your speakers or bare wire? I've looked all over for like a L shaped banana clip but no success.
pretsam is offline
post #5673 of 7073 Old 01-21-2012, 06:11 PM
afrogt's Avatar
Quoted: 1054 Post(s)
Liked: 756
I've never seen an L shaped banana plug. Maybe bare wire is your best solution if you have the no room for regular banana plugs.
Afro GT
afrogt is online now
post #5674 of 7073 Old 01-21-2012, 06:38 PM
purdyd's Avatar
The mirage speakers have great posts, I wouldn't bother with banana plugs
purdyd is offline
post #5675 of 7073 Old 01-21-2012, 07:38 PM
Bluvette's Avatar
Quoted: 166 Post(s)
Liked: 159
This is the closest that I know of.
Attachment 234946
Bluvette is offline
post #5676 of 7073 Old 01-22-2012, 05:33 AM
buzzy_'s Avatar
Quoted: 66 Post(s)
Liked: 89
Try searching on 90 degree banana plug or angle banana plug
audioholics discussion
audiogon mentions some brand names
parts express side entry
parts express angled
EZ Hook
IXOS angled
flatwire ones are the closest but expensive
Though unless you plan to unplug and replug them regularly, banana plugs don't add any functional benefit. Some like the look. For most of my speakers, they stay wired up for years, so bare wire works for me.
buzzy_ is offline
post #5677 of 7073 Old 01-22-2012, 08:11 AM
b4z
b4z's Avatar
Quoted: 18 Post(s)
There was a test review that said they were rolling off in the '80ish haz range. Even though these are acoustic suspension speakers mirage was a little ambitious with their claims of bass.
b4z is offline
post #5678 of 7073 Old 01-22-2012, 11:59 AM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
Home Theater Mag actually measured them as rolling off higher... -3dB was at 101Hz...
alphaiii is offline
post #5679 of 7073 Old 01-23-2012, 07:25 AM
lightbox's Avatar
Quoted: 24 Post(s)
Liked: 25
If you need to have the wires come in at an angle, why not use spade connectors instead of bananas?
lightbox is offline
post #5680 of 7073 Old 01-23-2012, 02:18 PM
dpc123's Avatar
Would anyone have insight on using the OMD-R as the front channels in addition to surround channels? Just wondering if they would work in that arrangement.
dpc123 is offline
post #5681 of 7073 Old 01-23-2012, 02:25 PM
audioguya440's Avatar
Hey everyone, I've been a long time follower of this thread (at least 2 years) but I have neglected join. I wanted to post a link of the CEDIA Expo brochure that shows an image of the "Mirage" MX-F45. The appearance seems to have changed significantly. Unfortunately, since I am a new member here, I can't display a URL until I have at least 3 posts.
audioguya440 is offline
post #5682 of 7073 Old 01-23-2012, 02:44 PM
In the meantime, I will share with you a little information I discovered regarding the energy/mirage brand. I spoke with an audio dealer near my home who attended CES 2012 in Las Vegas. He confirmed that the Mirage brand is officially dead and that their key technologies (patented omnipolar technology etc) have been relinquished to Jamo (this was mentioned previously but I just wanted to confirm). Unfortunately, he did not know whether the current Mirage speaker line (OMD-5's, OMD-28's etc) would still be made under the Jamo name. Since Jamo manufactures its own speaker drivers, its quite possible that we may never encounter an Omnipolar speaker capable of producing the same quality of sound as the old Mirage OMD line. I'm hoping that the new speakers are actually better, but I remain doubtful.
The dealer I spoke with told me that the Energy speaker line will remain intact and that its sound signature will be kept relatively the same.
post #5683 of 7073 Old 01-23-2012, 02:49 PM
I don't know where Vanns sources their Mirage speakers, but there's a possibility they could continue to sell them as long as there is a strong demand. I sincerely hope this is the case because they are a great bang-for-your-buck speaker line.
post #5684 of 7073 Old 01-23-2012, 02:53 PM
Okay, I should be able to show the link now.
http://e-ditionsbyfry.com/Olive/ODE/...00&view=entity
It seems like the original tweeter omniguide has been replaced in favor of an inverted omniguide that uses the midrange woofer as a reflecting surface.
post #5685 of 7073 Old 01-23-2012, 04:39 PM
dr_gallup's Avatar
Quoted: 29 Post(s)
Good review. Sensitivity was a little lower than Mirage claim too.
dr_gallup is offline
post #5686 of 7073 Old 01-23-2012, 06:43 PM
buzzy_'s Avatar
Quoted: 66 Post(s)
Liked: 89
Thanks. Some interesting stuff in there, although it's from August I guess.
buzzy_ is offline
post #5687 of 7073 Old 01-23-2012, 10:59 PM
dmw5678's Avatar
New owner of a pair of OMD-15s , OMD-5s and a OMD-C1 -- grabbed these from VANNS after reading this forum, Kudos to all on this forum for giving me the push I needed to drop down the cash and piss off the wife. I think I made a great choice, they are simply elegant in black. I can't wait until they are broken in.
Any small sub recommendations or can I get by without one with the OMD-15s?
dmw5678 is offline
post #5688 of 7073 Old 01-24-2012, 04:15 AM
Bluvette's Avatar
Quoted: 166 Post(s)
Liked: 159
Congrats, great setup. As for a sub how big is your room, is it open or sealed floor plan, what is your budget, and what percent movie, music do you watch or listen to??
Bluvette is offline
post #5689 of 7073 Old 01-24-2012, 05:56 AM
dmw5678's Avatar
Small room approx 20 x 30 , open hard tiled floor - looking for something I can hide(small) or high WAF factor, clear precise low end bass, Budget ~1000. I've have a Denon AVR-2112CI to power the system, possible purchase some small amps if necessary.
I tend to not play music loud.
80% music
20% Movies
Just a quick note my last system in this space was a 5.1 system from logitech hooked directly to the TV and PC. OOOOh-Boy was I missing musical clarity in this office. I've been bitten by the bug no turning back now...
dmw5678 is offline
post #5690 of 7073 Old 01-24-2012, 08:33 AM
Bluvette's Avatar
Quoted: 166 Post(s)
Liked: 159
80% music
20% Movies
I would go with dual Epik legends, Call Chad at Epik subwoofers tell him your room size and ask him his opinion. Great guy to deal with. Other subs to consider is HSU and Emotiva. I like Epik myself. http://www.epiksubwoofers.com/
Bluvette is offline
post #5691 of 7073 Old 01-24-2012, 09:11 AM
dr_gallup's Avatar
Quoted: 29 Post(s)
There was a test review that said they were rolling off in the '80ish Hz range. Even though these are acoustic suspension speakers mirage was a little ambitious with their claims of bass.
I don't think it's a problem if the OMD5 surrounds are naturally rolling off a little above the cross over frequency. There really should not be any bass going to the surrounds. I suppose if you have a really powerful amp you could over drive these speakers. Otherwise, what would you accomplish by setting the cross over higher? The main OMD15's are good to below 80 Hz.
post #5692 of 7073 Old 01-26-2012, 11:46 AM
wazzul's Avatar
Anybody ever heard the Mirage in ceiling speakers? I'm contemplating using them instead of the current Polk ceiling speakers for my home theater surrounds.
They look great and would match better with my Mirage fronts and center.
wazzul is offline
post #5693 of 7073 Old 01-26-2012, 02:50 PM
pretsam's Avatar
Liked: 27
EZ Hook
IXOS angled
Thanks. I'll check them out but may just stick with bare wire on the bike of them.
pretsam is offline
post #5694 of 7073 Old 01-26-2012, 02:52 PM
pretsam's Avatar
Liked: 27
Yeah, I kinda heard the same thing from a local audio store down the street. The owner called one of his dealers to try and price me some Mirage speakers a few weeks ago but said only Vann's sells them of course. His dealer also told him come August I think it was there would be absolutely no more Mirage.
pretsam is offline
post #5695 of 7073 Old 01-26-2012, 02:54 PM
pretsam's Avatar
Liked: 27
They have a bunch of their stuff in a big warehouse near me. I believe its all stored in a Amazon warehouse in Hebron, KY. It's like 15min away. Every time I order from them it's on my door step the next day. I just always have to pay tax on it though. Ordered my OMDC1, OMD15s and some stands from them.
pretsam is offline
post #5696 of 7073 Old 01-26-2012, 03:02 PM
pretsam's Avatar
Liked: 27
I just finished my final break in on my OMD15s. I have the same setup in speakers as you. They sound great! I finally cranked it up a tiny bit and they sound amazing. Probably barely even pushing them and they rock.
pretsam is offline
post #5697 of 7073 Old 01-26-2012, 04:36 PM
dr_gallup's Avatar
Quoted: 29 Post(s)
Vanns has the OMD15 in rosewood for $399 right now. I paid $450 five months ago.
post #5698 of 7073 Old 01-26-2012, 04:45 PM
Venomous's Avatar
Thats an impressive price. Is vanns still going to be able to get the omd line made since mirage is going to get the axe?
Venomous is offline
post #5699 of 7073 Old 01-26-2012, 11:15 PM
pretsam's Avatar
Liked: 27
When I bought my OMD15 a week half ago, like 3 days later they put the gloss black on a 1 day sale for $399 and I just happened to notice and and was able to get them to price adjust for me. Though I am still waiting on the credit to show up on my account they said it would take 7-10days. Prolly call them later today if it's not there to check on it.
pretsam is offline
post #5700 of 7073 Old 01-27-2012, 10:20 AM
dr_gallup's Avatar
Quoted: 29 Post(s)
From some of what I've read in the links above it sounds like no. But if they are making money and there is a market maybe they will for awhile longer. Seems like long term they are a gonner.
Reply Speakers
