Mirage Speakers - Page 231 - AVS | Home Theater Discussions And Reviews
 22Likes
post #6901 of 6916 Old 02-02-2015, 12:18 PM
Banner23's Avatar
Hi, I would like some advice on which speakers to use for my surrounds. I have 2 OMD-5 and was planning on using them for my surrounds but my concern is the positioning. The rear walls are not close to the side walls that the speakers will be mounted to. Plus, one of the walls has a hallway that is about a foot from the speakers. I am wondering how bad this will affect them in trying to deflect the sound.
An alternative speaker I was looking at are the Svsound Prime satellite speaker. This is a direct radiating speaker. It has a 41/2 woofer compared to the OMD-5 51/2.
Do you think I should stick with the OMD-5 or try the Svsound. My front speakers are the Def Tech SM55 and the center is the Def Tech CS8040-HD.
Banner23 is offline
post #6902 of 6916 Old 02-02-2015, 03:36 PM
morbidcorpse's Avatar
Quoted: 117 Post(s)
Liked: 89
Hi, this response might get a little long winded, but to answer your question, YOU SHOULD MOST CERTAINLY KEEP AND USE THE OMD-5's! The omnipolar design is going to spread around the rear channel mix of a soundtrack soooooo much better than direct radiating speakers. I've used both direct and omnipolar and I greatly prefer the OMD-5's for surround use. There is no comparison! OMD-5's crush a direct radiator for surrounds, I don't care what brand the speaker is. Also, if you look at my HT gallery, which I will post a link to at the end of this response, you'll see that my surrounds are pretty close to the rear wall, a great deal away from the side walls AND, on one side, I have an opening to another room about 1.5-2 feet away from a surround. The only thing I have to do is, using an SPL meter, bump up that surround speaker near the opening, an extra 1.0-1.5 db and it compensates pretty well for whatever sound I lose being close to an opening. Keep in mind, unless you have a dedicated theater room specifically built for HT, it's unlikely your room is going to be acoustically perfect. I think you'll find any decent AVR with room correction will do a fairly good job of compensating for room imperfections, like the one you describe. Don't overthink it too much. And being far from side walls is fine. Being too close is a much bigger problem when it comes to OMD's, IMO. Here is a link to my gallery so you can see what I'm referring to. Pictures of the surrounds are at the bottom of the gallery. http://www.blu-ray.com/community/gal...r=morbidcorpse
morbidcorpse is online now
post #6903 of 6916 Old 02-03-2015, 03:22 PM
Banner23's Avatar
That's a nice home theater you have. I will go ahead and use the OMD-5.
Banner23 is offline
post #6904 of 6916 Old 02-06-2015, 07:53 PM
Steveham's Avatar
Liked: 0
Hi all, newbie to AVS and this Mirage Thread. I discovered Mirage Speakers back around 2003. They sound so vivid and alive, I've had no desire to replace them with anything else over the past 10+ years. My advice is to use them in a large room well away from walls if possible, and prepare to be amazed. My mains didn't get fully open and holographic until I placed them at least 7 feet from any walls ( Large 22 by 24 foot room here). --- Steve ---
Yamaha RX-V377 AVR
Magnavox DVD/VHS Player
2 Mirage Omni 260 Main Speakers
2 Mirage Omni-FX Surround Speakers
HSU STF-2 Subwoofer
Samsung 25" CRT TV
Steveham is online now
post #6905 of 6916 Old 02-08-2015, 06:23 PM
doublewing11's Avatar
Quoted: 118 Post(s)
Liked: 370
I want four OS3's for Atmos!
Darn klipsch........
doublewing11 is offline
post #6906 of 6916 Old 02-12-2015, 10:14 PM
sthompson's Avatar
Hi,
If anyone has or knows where I can find a couple of pairs of OC-65 or OC-55's, it would be greatly appreciated.
sthompson is online now
post #6907 of 6916 Old 02-13-2015, 08:43 AM
dr_gallup's Avatar
Quoted: 21 Post(s)
Originally Posted by sthompson View Post
Hi,
Try http://www.hifishark.com/
dr_gallup is offline
post #6908 of 6916 Old 02-13-2015, 08:47 AM
sthompson's Avatar
Originally Posted by dr_gallup View Post
No dice but thanks for the site, have never heard of it. I'll keep an eye out there.
post #6909 of 6916 Old 02-13-2015, 09:31 AM
WhskyTangoFoxtrt's Avatar
Quoted: 40 Post(s)
Liked: 45
The OMD-5s are better speakers and can be had for a song on the Woot!
Klipsch (and its companies) were purchased by Audiovox, which became Voxx International:
http://www.voxxintl.com/brands/.
Just in case you're interested.
A Nice Radio Station with Great Music. For Those That Like That Sort of Thing: RadioParadise.com
WhskyTangoFoxtrt is offline
post #6910 of 6916 Old Today, 11:52 AM
Liked: 0
Mirage OS3 Surround Mounting Height
A friend recently let me borrow some mirage Nanosats to try as surrounds. Very interesting. If I go this route, I'll get the OS3s to XO a bit lower.
It seems to me that in a big open space where direct sound can be diffused, a direct radiating speaker will be perceived as diffuse by the time it hits the listener. In a smaller space, an Omnipolar speaker may create this effect since the direct radiator will be perceived as beaming. Is this a reasonable assessment?
Direct radiating surrounds are supposed to be 1-2' above ear level when seated. Does the same hold true for Mirage omni speakers? Or are they supposed to be mounted closer to ear level when seated if used for surrounds?
JonnyFive54950 is offline
post #6911 of 6916 Old Today, 01:02 PM
buzzy_'s Avatar
Quoted: 43 Post(s)
Liked: 65
IMO the best position is upside down, 8-10 feet high. With their design, they fire forward and upward. So upside down, they fire forward and downward.
Mounting them high also reduces the problem of having people or furniture between listeners and the surrounds.
If you have to mount them near or above ear level, best to tilt them forward so they fire at the listeners, instead of above their heads.
buzzy_ is offline
post #6912 of 6916 Unread Today, 02:57 PM
Liked: 0
Thanks for the input. Assuming mounting into a ceiling or wall is not possible, what height would they want to be on a stand?
post #6913 of 6916 Unread Today, 06:01 PM
Leon O's Avatar
I think the recommendation was to mount upside down when higher than 6 feet. I would keep them high enough so that there is nothing interfering with the path to the listener's ear. They tend to direct sound upwards.
BTW Although my nanosats created a wall of sound around me, it was harder to pin point the surround effects. It depends on your tastes.
Leon O is offline
post #6914 of 6916 Unread Today, 06:17 PM
Quoted: 117 Post(s)
Liked: 89
According to the Mirage manual, the height should be, "above ear level, at approximately 2/3 the height of the wall." However, if they're going to sit more than 6 feet above the floor, they need to be mounted upside down. My OMD-5's sit on stands that are 37 inches tall. This height is perfect for me, as when seated, they sit above hear level and spread the sound around well.
post #6915 of 6916 Unread Today, 09:10 PM
LowTech1's Avatar
Quoted: 91 Post(s)
Liked: 73
Morbid, nice setup. Love the look of mirage speakers. Wish I could hear the 28's. I went with all Martin Logan's. I used to have the 15's, C2, OMDR's. Sold them. I'm using motion 4's for height speakers. You should paint the plastic covers the same color as your wall.
LowTech1 is online now
post #6916 of 6916 Unread Today, 10:45 PM
Quoted: 117 Post(s)
Liked: 89
Thanks for those very kind words. It's a work in progress. I actually just moved the height speakers further out about a foot on each side so they sit at a 45 degree angle from the listening position, as suggested by audyssey for DSX. I've been meaning to paint the covers, just have other projects that have kept me busy. Also trying to resist the urge to go Atmos before all the dust has settled on specifications.
Reply Speakers
