Mirage Speakers - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #721 of 7081 Old 05-01-2008, 02:03 PM
1080pixel's Avatar
A reputable electronics dealer has the silver Uni-theater for $300 and the black one for $600. I am thinking getting a silver one and spray paint it black (or dark gray like its cousin).
Has anyone tried that? Problems? Void warranty? Looks tacky/cheap?
Obviously you can't return it once painted.
1080pixel is offline
post #722 of 7081 Old 05-01-2008, 02:18 PM
LushMojo's Avatar
Was thinking of picking up some Mirage Omnisat V2FS fronts to replace my Polk Surroundbar (which I don't really like). However, I'm wondering what might be a good center channel with the V2FS fronts? I don't like the look of the V2CC AT ALL. I know it's best to get something matched, but that thing is pure ugly to me (your mileage may vary). Anyone have the V2FS fronts successfully matched with another center? I really like something sleek like the Polk VM20.
I'm using a Denon AVR3080CI and Infinity sub, by the way.
LushMojo is offline
post #723 of 7081 Old 05-01-2008, 04:24 PM
TDI Driver's Avatar
Never tried it or known anyone who has. Probably won't void the warranty since it is not a modification of any of the parts that matter in such instances. Just make sure that you don't paint any of the drivers in the process. Also, painting the grille could prove to be tricky which could result in the undesired tacky/cheap appearance you most likely are trying to avoid. Best of luck in your endeavor.
"What's better? A great 2D movie or the worst 3D movie?" - Stephen Colbert
TDI Driver is offline
post #724 of 7081 Old 05-01-2008, 04:31 PM
TDI Driver's Avatar
Aside from the V2-CC, the only other Mirage products that use the same composite drivers are the Nanocenter, Nanosat, Nanosat Prestige, and Omnisat V2. Any of those would be a theoretical match, but the V2-CC is the best overall option with the V2-FS. Mirage, unfortunately, has never really had a sleek center channel option. BTW, I have a demo V2-CC I'd let go for an attractive price. Wish I could be of more help. Perhaps someone who has successfully mixed-and-matched will enter with some suggestions.
post #725 of 7081 Old 05-07-2008, 01:00 PM
RWALKER44's Avatar
I'm on the fence between the Uni-theater ($500) or two Nanosat with a cc ($500)...I have heard the Nanosat but not the Uni-theater..Should they both sound the same? Can I get good seperation with the Uni in a small room?
I will pair it up with a sub. Do you suggest the Omni S8 or the Omni S10? I was also looking at the Velodyne subs, but thought it would better better to stay within the brand
I am planning on getting rear speakers later
RWALKER44 is offline
post #726 of 7081 Old 05-07-2008, 01:09 PM
pbc
pbc's Avatar
Quoted: 373 Post(s)
Liked: 208
While I've read good things about the Unitheater, it will never give you the same separation and spacial feeling as seperate speakers.
As for the sub, bigger is always better if you can fit it (goes lower, more headroom etc). Keeping the "brand" consistent should be the last thing on your priority list for subs, it really doesn't matter as you're not looking to "timbre" match or voice match the sub to your speakers.
Regards.
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #727 of 7081 Old 05-07-2008, 01:38 PM
1080pixel's Avatar
Here are two reviews on Uni-Theater:
http://www.soundstageav.com/audiovid...s/20050901.htm
http://www.soundandvisionmag.com/art...&page_number=1
The Uni_theater speaker is not for everyone. It's main niche is simplification, elegance, minimalism.
post #728 of 7081 Old 05-07-2008, 01:40 PM
1080pixel's Avatar
By the way, the SILVER Uni-Theater is on clearance at Vanns for half the price of the black color.
post #729 of 7081 Old 05-09-2008, 01:48 PM
RWALKER44's Avatar
Thanks for the heads up, I just purchased at Vanns. Although it would be nice to get the seperation. $300 for the Uni-Theater is hard to pass up. Its twice the speakers for half the price. The Uni is also much cleaner looking.
I also just purchased a HSU Sub to go with it. My wife wants the Mirage Omnican for the L,R & rear, but I have not made up my mind.
post #730 of 7081 Old 05-09-2008, 01:59 PM
Venomous's Avatar
i picked mine up last week. I was thinking of grabbing one more. I really want a pair of V2s though and i keep getting screwed on some Ebay auctions. I almost had a pair of V2 floorstanders for $425 shipped.
Venomous is offline
post #731 of 7081 Old 05-09-2008, 10:03 PM
1080pixel's Avatar
My silver Uni coming Monday 5/12. Got my matte black spray can ready! Hope to post some before and after pix.
post #732 of 7081 Old 05-09-2008, 10:07 PM
Venomous's Avatar
Are you going to disassemble the unit or just tape it up?
Venomous is offline
post #733 of 7081 Old 05-10-2008, 07:48 AM
GioGambino's Avatar
Go with the Nanosats. I haggled with a Best Buy associate for an open box item. I ended up getting the Prestige 5 set, which consists of 4 Mirage Nanosat Prestige and 1 Nanosat CC. I got that for $500.
Try a Best Buy to see if they have that set as an open box item. The ones I got were essentially brand new, I kid you not. I honestly don't think they were ever used. I could live without the box.
GioGambino is offline
post #734 of 7081 Old 05-10-2008, 10:00 AM
1080pixel's Avatar
Definitely remove the grill and spray paint both outside and inside. I might need to spray at an angle and not straight on so "sides" of the perforations get coverage too.
I am thinking of cutting cardboard template for the speakers to cover up them up during spraying. I am not sure about those tiny tweeters yet.
As for the case, I won't install the glass base until the case is painted.
I think it's best to keep the spray paint at least about a foot or foot/half away from the painting surface.
THIS IS NOT INSTRUCTION FOR YOU TO DO IT. IT'S SIMPLY HOW i PLAN TO DO IT.
post #735 of 7081 Old 05-10-2008, 12:46 PM
RWALKER44's Avatar
Look into powdercoating. Not too expensive for an item that small and it will give a nice gloss finish (any color). You will need to remove the speakers though.
You can also go to an auto painter and get a price, may be worth the extra cash. I think the DIY spray paint is a bad idea
post #736 of 7081 Old 05-16-2008, 07:19 AM
tomwil's Avatar
Liked: 26
Stopped in BB/Magnolia and decided to get the Mirage Omni S8 Subwoofer. When they brought out the box, I noticed that on the box it said it was made in China.
I looked at their floor demonstration model, and it was made in Canada. They would not sell me the floor model, so I left empty-handed.
How reliable is Mirage "made in China" electronics? My KLH subwoofer that was made in China died in only a couple of years. I don't want the same thing happening with the Mirage.
The Mirage seems to have a circuit board and transformer, as shown.
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
post #737 of 7081 Old 05-16-2008, 11:20 AM
PULLIAMM's Avatar
My Mirage Omni 350s are for sale. PM me if interested.
PULLIAMM is offline
post #738 of 7081 Old 05-19-2008, 10:44 AM
1080pixel's Avatar
Paid 300 for the silver instead of 600 for the black, then painted black myself.
Here are the before and after pix. The 'metallic' in the paint shows up as tiny 'sparkles' because of the camera's flash but I barely see them.
Not as good as the orig black but I think it's worth $300 saved.
post #739 of 7081 Old 05-19-2008, 12:10 PM
TDI Driver's Avatar
I've sold Mirage before and after the manufacturing shift from Canada to China and I've had the same amount of failures with both countries of origin - 2 each (all but one within warranty and the warranty ones were replaced free of charge).
post #740 of 7081 Old 05-19-2008, 12:10 PM
TDI Driver's Avatar
1080p, very nice job!! Congratulations on the success of your project and happy listening
post #741 of 7081 Old 05-25-2008, 12:10 AM
ultimaterowdy's Avatar
I've got OMD-5 as satellite "mains" & some omnican6's coming as surround. I'm going to splurge on the OMD-C1 to round out the system (oh along w/ a Hsu sub I've had for 10 yrs).
but the question is... can the omd-c1 center sit above the TV? THis would put it at 6' off the ground, and so 2-3' above the ear when seated. Also wondering if you're supposed to turn it upside-down if you do mount it high like that.
Let me know if you have some thoughts or experiences for me. much appreciated!!
ultimaterowdy is offline
post #742 of 7081 Old 05-25-2008, 01:37 AM
EJ
EJ's Avatar
I bought my in-laws 5 omnisats with a small HSU sub. Not a very accurate sound stage, but sound very open. perfect for my in-laws, who wanted them to be as invisible as possible, and a much better option than the bose system i talked them out of.
Former USSB uplink operator.
EJ is offline
post #743 of 7081 Old 06-01-2008, 01:37 AM
skf42002's Avatar
First let me disclose that I am pretty much a newbie when it comes to home theaters. I'm looking to purchase a complete home theater and have already decided on the TV (Samsung LN52A650) and the receiver (Denon AVR-2308CI) but am somewhat undecided on the speakers. The manager at Electronics Expo recommended the Mirage Nano Sats 5.1, but I'm a little concerned that the sub won't be strong enough for my room which is approximately 23' x 18'. Also, I read some reviews where some people had problems with the cc where they had trouble clearly hearing dialog, but I think this may be more of a placement issue rather than an issue with the cc. I'm now considering going with the Nano Sat Prestige system and buying the Mirage M10 sub, however that package will cost $1,400 or so vs the $600 for the Nano Sats 5.1 package. Is it worth the difference in the money? I'm also considering getting the KEF KHT3005 speakers since a salesperson at 6th Ave Electronics recommended these and CNET has them rated as their Editors Choice. The KEF's are on sale at Circuit City for $900 after their 10% online coupon. I appreciate anyone giving me some input. BTW, I anticipate using the speakers as follows: 50% watching TV, 20% gaming, 20% movies & 10% listening to music. Thanks in advance.
skf42002 is offline
post #744 of 7081 Old 06-03-2008, 09:22 AM
iMbEst's Avatar
why didn't you pay $300 for the black B-stocks? I got mine from ebay for < $300......
But I really admire your painting/spraying skill! It really look like an original black lol!
by the way, may I know what kind of terminal you use for your Uni-Theater? I am forced to use bare cable I'm using Belden 1311A (12AWG) and I almost bought 1313A (10AWG) and I doubt it can fit in the hole in the spring terminal.
iMbEst is offline
post #745 of 7081 Old 06-26-2008, 04:33 PM
1080pixel's Avatar
I am not comfortable about purchasing stuffs from ebay especially electronics.
Bare cable. I heat it up with solder and flux so it won't fray or broken from connect/disconnect.
post #746 of 7081 Old 07-19-2008, 11:53 AM
buzzy_'s Avatar
Quoted: 76 Post(s)
Liked: 96
FWIW the Mirage Omnisat V2s seem to be on sale now ... for example, Vanns.com
buzzy_ is offline
post #747 of 7081 Old 07-19-2008, 12:40 PM
dftkell's Avatar
Quoted: 76 Post(s)
Liked: 68
Do you know if that's because they're being discontinued? When the V1's were discontinued, they ended up selling for about $80 a piece.
dftkell is offline
post #748 of 7081 Old 07-19-2008, 01:15 PM
TDI Driver's Avatar
New Omnisat (OS3) product is said to be coming in September. The changes include MDF baffles and OMD series-inspired ribbed elliptical surrounds. Prices will remain the same on the OS3-Sat and OS3-CC while the OS3-FS will increase by $200 MSRP per pair.
No new traditional Omni series box product is slated. The only other new product introductions are a satellite smaller than the Nano, called the Pico, and a couple of new small, high power subwoofers that will be crossed over between the Mirage and Energy lines.
post #749 of 7081 Old 07-24-2008, 08:57 AM
knmlee's Avatar
Hi,
I'm moving to a new house that has a 5.1 speaker setup already installed.
The center channel speaker is a cheap one though.
I have a Uni-Theater from my old house. Has anyone tried using the Uni-Theater as a center channel speaker? Is there anyway to utilize all of the drivers from just one speaker cable?
knmlee is offline
post #750 of 7081 Old 07-28-2008, 01:20 PM
Robonaut's Avatar
I'm currently putting together a 5.1 home theater system. My budget is $2,500 for speakers. I already have a subwoofer, so I will just be purchasing the fronts, the satellites, and a center channel.
I've auditioned Mirage speakers in the past, and I've been impressed by their ability to make just about every seat a good one.
I'm trying to decide if I should get four Omnisat V2 FS floorstanders and their matching center channel, or go for four OMD-5 bookshelves with their matching center.
If it helps, the room I will be using is 14' 9" wide and 23' 8" long with 6' 6" ceilings (it is a finished basement, hence the low ceiling height). The last 5' 5" of the left wall is a doorway into another room.
Robonaut is offline
Reply Speakers
