Definitive Owners Thread - Page 1042 - AVS Forum | Home Theater Discussions And Reviews
 304Likes
post #31231 of 35028 Old 06-21-2014, 12:52 AM
jlpowell84's Avatar
Quoted: 1539 Post(s)
Liked: 684
I got a local shop to do 500 for the Pro cinema 600 set. I will sell the Pro sub and center unless I find a performance improvement by integrating the pro sub next to my seat and I am going to run a HPF and LPF via a channel on my mini dsp. Prob like 40hz to whatever I think is good. I already get ridiculous bass performance with dual Seaton Submersives. My thinking was to try and use it like the HSU MBM is used for. Anyway the key is the 4 Pro Monitor 600's. I have owned the 1000's and they were great big little satellites. The 600's will be very small and discrete but yet offer the surround effects to pan out to the wide positions and the height positions. I will then get either 800's or 1000's to run as back surrounds down the road. My Denon 4520 only amplifies 9 channels so I will need a 2 channel amp with those.
jlpowell84 is online now
post #31232 of 35028 Old 06-24-2014, 06:16 AM
ALtlOff's Avatar
Quoted: 990 Post(s)
Liked: 477
Originally Posted by ALtlOff View Post
Ya, the whole "how important are heightpspeakers" are what raised the question in my mind in the first place, so I may just have to experiment after all, hell I just moved, not like I don't have a few spare boxes lying around...lol.
As far as the Bi-Amping is concerned I've done some reading and understand the crossover thinking and am pretty comfortable with the factory tech, that was why I posed the question in this thread instead of somewhere else, (prob. should have explained things a little better) I should have said I was more over looking for other 2000 users impressions of the difference in putting the extra power to the separate drivers, highs/mids, since the original 2000's are notoriously power hungry and supposedly fuller and richer when fed that way, and if they thought that difference may add extra depth there instead of just adding extra sound up higher in the soundstage.
As far as the front 3, I'm running the full range pre-amp outs to the low level input for the 3 powered subs, not LFE, I'm letting the 1500's do that lifting.
Thanks for the reply
So, I did some experimenting over the weekend and heights it is, but I'm not going to use the SR8080bp's (prob. gonna just sell them) as I was putting things away I found my original surrounds from about twenty years ago, some BP-2's, (my first Def's were my BP-10's the BP-2's and my Powerfield 1500) I swapped them around for my center over the weekend just to put them through their paces and they're working perfectly, plus I like the idea of the 5 1/4" drivers more than the 4 1/2's in the 8080's, so those are my heights, and I won't need wides with the 2000's up front and the way their positioned. (Final positioning for most pleasing sound ended up being, subs in the rear, 180° out of phase, fronts 48° of center, aimed at the listeners, with the subs facing out and about 42"of the side walls) Now I absolutely don't regret going overboard early on when I really didn't have the room for everything, because now, even in a room this size the sound isn't only enveloping, it's extremely visceral.
Now, new question, new room, strictly music, 14 x 16 room with 2 large, open, doorways.
I'm using a 35w tube amp, (yaqin, nothing fancy) and CD's, as much as I would like to go big I just can't work it into the budget right now, so... no sub, just two speakers in stereo, I have the option of another pair of original BP-10's (not b's) or a pair of StudioMonitor 65's, what do you guys think? Or maybe something else, as long as it's D.T. and under our near the $800.00 mark.
ALtlOff is online now
post #31233 of 35028 Old 06-24-2014, 12:48 PM
jlpowell84's Avatar
Liked: 684
So gentlemen I am officially back to being a DT owner. I had sold my first system of 8060 LR, 8040 center, 8040 surrounds, and PM 1000's. I picked up a pro cinema 600 set and have installed the monitors at the height and wide positions. I have a couple side surrounds I built from the DIY sound group. Volt 10's and great speakers. Anyway I am going to install the Pro cinema 600 center as a single rear surround. I could do two speakers back there but only like 1.5 ft apart. So the one.
Anyway I have the Pro sub I am going to sell. What is a good price for the sub from the pro sub 600 set? I also ended up with a bunch of little swivel mounts for tiny speakers too if needed.
post #31234 of 35028 Old 06-24-2014, 04:45 PM
bradthebold88's Avatar
Quoted: 16 Post(s)
Liked: 31
If you want bipolar, you can get BP30s or BP2000s for that price. If you already have the BP10s or SM65s, I'd probably just use those, or at least try them.
Living room: Definitive BP2000TL, CLR3000, BPVX, Quad SI 18" subs
Bedroom: Definitive BP30, CLR2000 Also have had: BP7000SC, BP8B, BP10B, BPX, Dayton 15" HF subs, Rythmik F15
bradthebold88 is offline
post #31235 of 35028 Old 06-24-2014, 11:51 PM
ALtlOff's Avatar
Quoted: 990 Post(s)
Liked: 477
I thought about another pair of 2000's but didn't know if this amp (Yaqin MC-100B) would be the best fit for them musically, as far as bi-polar or not, i really hadn't considered it to be a determining factor, the only reason I was interested in opinions between the SM-65's and the BP-10's is because I have the opportunity to pick up either/or used, both at a decent price (about + $200 on the 65's) and was hoping I could get some input on the difference in musicality between the two. But also wanted to stay open to other options since whatever I choose would be an addition, not a swap.
post #31236 of 35028 Old 06-25-2014, 06:56 AM
truwarrior22's Avatar
Quoted: 326 Post(s)
Liked: 71
What are you using for mains? Volt 10? 600 seems like a big downgrade.
truwarrior22 is offline
post #31237 of 35028 Old 06-27-2014, 12:22 PM
jlpowell84's Avatar
Liked: 684
I have Left/Right JTR Triple 8 HT, Center is JTR Triple 8 LP, two main side surrounds are DIY Sound Groups Volt 10's. So I added these little guys in at the wide and height positions so far. Certainly adds a bitt. Perhaps better if better speaker but then again this is the only way I can have them there. That is small and stealth like
post #31238 of 35028 Old 06-27-2014, 08:44 PM
AlphaPie's Avatar
Quoted: 144 Post(s)
Liked: 371
How many of you guys are running the studiomonitor series in a HT application? I'm trying to compare these directly to the Emptek speakers..
7.2 w/front wides - Pioneer Elite SC-85 - Polk Audio RTi12/CSi3/RT25i - DIY Dual 12" subs/Behringer Inuke3000 - Monster Power 2500
Sharp Aquos 60" - Xbox One - Sony BRP - Plex Server
AlphaPie is offline
post #31239 of 35028 Old 06-27-2014, 09:30 PM
Kriszilla's Avatar
*raises hand* I'm using the SM65's in the front and the SM55's in the rear. My center is the Mythos 8. My wife and I watch 3-6 movies a week and lots of HD 5.1 TV (Game of Thrones, True Blood, etc...), and I also use them to play concert bluray's and FLAC music files. They sound fantastic doing it all.
My previous speaker experience includes Magnaplanar, Martin Logan, Andy Jones Pioneer's, and B&W. I'd take these over any of them. The only thing I have that sounds better are my Morel / Dynaudio components in my car.
Baja on ebay currently has the the SM 65's, 55's, and 45's in stock. I got a killer deal on my 55's from him. They still had the cling-plastic on them when I received them.
Kriszilla is offline
post #31240 of 35028 Old 06-28-2014, 01:18 AM
Shpongle DMT's Avatar
Quoted: 26 Post(s)
Liked: 31
My set up has the SM65s for L/R with an 8040HD center. Its a perfect combination IMO. The SM65s sound amazing and work really well for movies. I also use the set up to listen to music. The SM65s produce the most pristine and pure sound I have ever heard from a speaker. I got mine from bajawaverunner and they work perfectly. Saved me almost 50% off msrp.
Shpongle DMT is offline
post #31241 of 35028 Old 06-28-2014, 01:31 AM
ALtlOff's Avatar
Quoted: 990 Post(s)
Liked: 477
Ditto on both the above, if I didn't have what I do the SM65's would be my absolute first choice for fronts, plus great for stereo when you just want to listen that way, I've basically decided to go with them for my living room over another pair of bp-10's.
And also as mentioned above, the baja referbs have a really good track record, esp. for the price.
(ended up picking up a pair of SM45's from an individual that ended up costing me $50.00 more when it was all said and done, than what baja has then for....da**it, timing is everything...lol)
post #31242 of 35028 Old 06-28-2014, 08:47 AM
AlphaPie's Avatar
Quoted: 144 Post(s)
Liked: 371
Can you link to Baja eBay page?
AlphaPie is offline
post #31243 of 35028 Old 06-28-2014, 11:21 AM
ALtlOff's Avatar
Quoted: 990 Post(s)
Liked: 477
Just search bajawaverunner, their products will come up in "related items".
post #31244 of 35028 Old 06-28-2014, 11:50 AM
LowellG's Avatar
Quoted: 521 Post(s)
Liked: 203
http://stores.ebay.com/baja-waverunner?_rdc=1
Lowell
The MarvelAtmos Home Theater: http://www.avsforum.com/forum/19-ded...e-theater.html
LowellG is offline
post #31245 of 35028 Old 07-01-2014, 11:43 AM
jevans64's Avatar
Quoted: 183 Post(s)
Liked: 136
Would using DefTech UIW65 ( TM ) or UIW75 ( MTM ) ceiling-mounted for Dolby Atmos be a good idea?
I plan to build a box around these, using the joists for the sides and 3/4" MDF for the rest, in the attic since they are not enclosed. I'll probably use additional sheets of 1/4" MDF to reinforce the back side of the drywall and to adjust the cabinet volume as needed. My ceiling is stepped/vaulted so the joists run in such a way that the ceiling speakers can mirror the front speakers and be parallel to the floor
The existing setup consists of DefTech BP7000SC, C/L/R 3000, JBL L7 powered by Emotiva XPR-5 and DefTech BPZ/A and SM55 powered by the AVR. I also have a pair of EoSone RSR 350 from my old 5.x setup that I never took down and are still wired as Surround B.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is online now
post #31246 of 35028 Old 07-01-2014, 01:05 PM
jlpowell84's Avatar
Liked: 684
What should a sub from the pro cinema 600 set sell for?
post #31247 of 35028 Old 07-01-2014, 05:28 PM
rdclark's Avatar
Quoted: 277 Post(s)
Liked: 531
Well, Monoprice's "Premium Home Theater Subwoofer," which comes from their system that compares favorably to the Take Classic (a system often compared to the ProCinema 600), can b purchased separately, new, for under $140. You can by a refurbed PC600 system from Baja for a price aboyt $100 more than the cost of the Take-clone system from Monoprice.
So I'd suggest the neighborhood of $100 for a used PC600 sub would be a place to start.
Wide Awake
on the Edge
of the World
rdclark is online now
post #31248 of 35028 Old 07-01-2014, 08:39 PM
LowellG's Avatar
Quoted: 521 Post(s)
Liked: 203
Do you need that much for the ATMOS? If I do it, I plan on using the DI.4.5 or 5.5. Also, round speakers make lining them up much easier. I don't know if it will be that much better, it would just give me an excuse to upgrade to the Denon X5200.
Lowell
LowellG is offline
post #31249 of 35028 Old 07-01-2014, 08:42 PM
marjen's Avatar
Quoted: 76 Post(s)
Liked: 46
I just ordered a pair of the Studio Monitor 450s. They should be here next week, looking forward to seeing what they can do.
Mark-
marjen is offline
post #31250 of 35028 Old 07-01-2014, 11:36 PM
jevans64's Avatar
Quoted: 183 Post(s)
Liked: 136
I probably don't need that much speaker, but I was thinking more on the line that the UIW series have the same drivers as my 7000SC and CLR3000. I'd like to stick with all 6.5" mids as well. I'm going to shoot for the X7200 and hope it will be a decent replacement for the Denon 5308ci. Adding another amp won't be a problem since I have 4 dedicated 20 amp circuits and Emotiva is just an hour's drive away. Just wish they'd hurry up with the XPR-7.
post #31251 of 35028 Old 07-02-2014, 12:19 AM
jlpowell84's Avatar
Liked: 684
Okay thats what I figured to do. I guesss technically it is used since I took it out of the box
post #31252 of 35028 Old 07-02-2014, 06:07 PM
LowellG's Avatar
Quoted: 521 Post(s)
Liked: 203
I understand, you still have two other choice for 6.5 drivers
http://www.definitivetech.com/products/uiw-64-a
http://www.definitivetech.com/products/di-6-5r
Lowell
LowellG is offline
post #31253 of 35028 Old 07-03-2014, 02:03 PM
jasammeg's Avatar
Quoted: 40 Post(s)
Hello,
I just got a pair of definitive technology bp8 speakers to use as mains in my home theater.My question to all def tech owners is what def tech centers match well with the bp8. This is my first time having def techs and any insight from experienced owners is much appreciated.
jasammeg is offline
post #31254 of 35028 Old 07-03-2014, 02:36 PM
badgerpilot's Avatar
Quoted: 73 Post(s)
Liked: 43
Originally Posted by jasammeg View Post
Hello,
Personally, I would look for a good used CLR2000 or 3000 even though they have the larger drivers. They are excellent centers and will blend nicely with your BP8's. You won't be disappointed!
badgerpilot is offline
post #31255 of 35028 Old 07-03-2014, 02:38 PM
LowellG's Avatar
Quoted: 521 Post(s)
Liked: 203
I agree with that, but if you can't find one and want matching drivers the 2500 will work.
Lowell
LowellG is offline
post #31256 of 35028 Old 07-03-2014, 04:34 PM
jasammeg's Avatar
Quoted: 40 Post(s)
Thanks for all the valuable input.Would a procenter 1000-2000 work with my bp8's.
jasammeg is offline
post #31257 of 35028 Old 07-03-2014, 05:02 PM
LowellG's Avatar
Quoted: 521 Post(s)
Liked: 203
Def Tech will tell you pretty much any of their CCs timber match any of their other speakers. I would completely avoid the 1000, very small and small = small sound. The 2000 would be OK, but unless you have space issues I wouldn't settle for anything less than a used 2002.
http://www.ebay.com/itm/Def-Tech-CLR...item1c423ca814
Lowell
LowellG is offline
post #31258 of 35028 Old 07-03-2014, 07:06 PM
Quoted: 73 Post(s)
Liked: 43
I would also stay away from the smaller pro centers. The center channel is the most important speaker in a Home Theater setup IMO. I have had the CLR2002 and CLR2300 and I can tell you that there is a big step up when you find a CLR2000 and I imagine a CLR3000(have not heard one but if I find a used one at a good price it's mine). You can find them used and yes they are big but they have an incredible richness that the 2002 and 2300 lacked. My 80 year old parents had a pro center for a short time until they heard my center. I found them a used CLR2000 and they love it as well. Just sayin'
post #31259 of 35028 Old 07-04-2014, 12:16 PM
bronxkid's Avatar
Quoted: 61 Post(s)
So I'm new to speaker shopping and I made the mistake of demoing the mythos sts - they are spectacular but well over my budget. So I was planning on buying the Def Tech 8020 or 8040 for my entertainment room which is 13x30ft with two tiers of seating about 12 and 15 ftt back. There's decent echo in the room. It will be for watching movies. Then I came across the BP series and it seems the BP8 is incredibly inexpensive and even cheaper than the BP6. Is there something wrong with it or would it be a good option for a a home movie theater? I do have a velodyne f1500 sub but I was thinking I could still use speakers with build in sub (ie the 8020/40 series). the fronts will be a part of a 7.1 speaker and the others will be purchased once i know which fronts i'm buying. Any thoughts/recommendations? I know this is the Def tech owners thread but I'm also about to demo the martin logan motion 20 and 40's this weekend.
bronxkid is offline
post #31260 of 35028 Old 07-04-2014, 12:23 PM
LowellG's Avatar
Quoted: 521 Post(s)
Liked: 203
Originally Posted by bronxkid View Post
So I'm new to speaker shopping and I made the mistake of demoing the mythos sts - they are spectacular but well over my budget. So I was planning on buying the Def Tech 8020 or 8040 for my entertainment room which is 13x30ft with two tiers of seating about 12 and 15 ftt back. There's a lot of echo in the room. It will be for watching movies. Then I came across the BP series and it seems the BP8 is incredibly inexpensive and even cheaper than the BP6. Is there something wrong with it or would it be a good option for a a home movie theater? I do have a velodyne f1500 sub but I was thinking I could still use speakers with build in sub (ie the 8020/40 series). Any thoughts/recommendations? I know this is the Def tech owners thread but I'm also about to demo the martin logan motion 20 and 40's this weekend.
The older BPs are good and a great bang for the buck. If you are looking at the 20s or 40s I would get the 8s and save the cash for a CLR 2500. Plus if you have echo you need to look at acoustic panels.
Lowell
LowellG is offline
Reply Speakers
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
