Definitive Owners Thread - Page 1068 - AVS Forum
post #32011 of 32014 Old Today, 10:43 AM
LowellG's Avatar
Quoted: 187 Post(s)
Liked: 119
Originally Posted by JAMES MCHUGHES View Post
Dual psa xv30f
Dual psa xs30
Is that the same house with 4 subs. Holy crap, that's a lot of bass if it is.
Lowell
The MARVELous Home Theater: http://www.avsforum.com/forum/19-ded...e-theater.html
LowellG is online now
post #32012 of 32014 Old Today, 11:47 AM
JAMES MCHUGHES's Avatar
Quoted: 21 Post(s)
[QUOTE=LowellG;30249658]
Dual psa xv30f
Dual psa xs30
Is that the same house with 4 subs. Holy crap, that's a lot of bass if it is. [/QUOTE
Yes the same house lol
JAMES MCHUGHES is offline
post #32013 of 32014 Old Today, 12:48 PM
sm4llz's Avatar
Quoted: 18 Post(s)
Originally Posted by ALtlOff View Post
No, I was talking about connecting the Front Full Range Pre-outs to the RCA inputs on the St's, sometimes this will give you a different sounding bass profile. Also, what are are your receiver settings for your Fronts, Large, Small, and if small, where are the crossovers set at? Technically your still using your woofers in the ST's, just not as Subs, in most cases, the powered woofers really add to the soundstage when set properly. I'm curious about your settings more than running the Full Range signal out too the speakers.
I just changed a few things around, let me know what you think.
On the Yamaha I have 2 subwoofer RCA outs. (front and rear)
I have a splitter goings into the fronts and then splits to the Left Mythos ST. The other Cable goes to the Left SVS sub. From there the Left Mythos is connected to a splitter to connect the LFE on the Left and Right Mythos. Then the RCA to the Left SVS sub is split to connect to the LFE on the Left and Right SVS. I have the Mythos set to large and sub enabled.
I'm not sure if there would be a benefit to removing the splitting going into the yamaha and having the Mythos ST connect into the rear sub input. It sounds pretty good now but i'm sure there are still settings I should adjust.
The mythos ST only has a LFE input and then speaker inputs. The SVS does have additional inputs but I don't think my Yamaha has an output for them.
sm4llz is online now
post #32014 of 32014 Old Today, 01:40 PM
ALtlOff's Avatar
Quoted: 98 Post(s)
Sorry I'm having trouble picturing your connection, sounds like your basically just splitting the the LFE signal into the ST's which of course will work.
Even though the inputs on the speakers say LFE it's actually a low level input to the amp for the woofer, while yes it was designed to be used a Sub/LFE input, it can also be a simple low level connection too, remember LFE isn't simply low frequency sounds, it is it's own discrete Low Frequency Channel, there are still other Low Frequency sounds that are coming from the the front channels.
It will still make a difference with your Large/Small & Crossover settings.
If you run just speaker wire to the ST's the Sub's/Powered Woofers will still work, again just not for LFE content.
Check your settings, I'd start with just running speaker wire to the ST's set your Fronts to Small with a 40hz crossover setting, this will send everything from 40hz and up to your Fronts, and everything below to the Subs.
Set your Subs to whatever best matches their actual location, this setting may effect Sub Phase when using two Subs.
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
http://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
Reply Speakers
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
