Definitive Owners Thread - Page 1076 - AVS | Home Theater Discussions And Reviews
post #32251 of 32271 Old 01-22-2015, 07:56 PM
LowellG's Avatar
Quoted: 229 Post(s)
Liked: 129
Originally Posted by jeremyc50 View Post
Hey guys, I finally have my new system as follows and I need a sub to finish it off. I'm not getting the overall base that it need so it looking to add a second sub. Debating the supercube 8000. I use this for a home theatre but mainly listen to music that may range from classic rock, jazz to hiphop. I want a clean hit and some variance without simply a thump. What sub would you guys recommend? Would it even be a deftech sub?
Onkyo tr727
Front l/r: studio 65
Center: mythos 7
Side l/e: dir6.5 (ceiling)
Rear l/r: dir8 (ceiling)
Current sub jbl 10" 150watt.
Room 20x25 10ft ceiling.
Dump the JBL on craigslist and buy the most expensive one you can afford from Rythmic, PSA, SVS or HSU. Any of them will smoke the 8000.
AlexanderDelarg likes this.
Lowell
The MARVELous Home Theater: http://www.avsforum.com/forum/19-ded...e-theater.html
LowellG is offline
post #32252 of 32271 Old 01-22-2015, 08:04 PM
AlexanderDelarg's Avatar
Quoted: 49 Post(s)
Liked: 72
Originally Posted by drummer93 View Post
Hey guys, I need some advice from Def Tech owners. I was recently gifted an CS8040HD center channel and Marantz SR5006 receiver from my parents who upgraded. Now currently I have a old Yamaha receiver and a JBL HTIB set that has done an ok job over the years but I'm glad I'm finally getting to take a step up.
My questions are:
-What books shelf speakers would you recommend for my LR to go with this setup?
-For the rear LR, what in ceiling would I look at?
I have to go bookshelf front because of how are TV wall is setup so I can't even consider towers. I'd also need more compact of a speaker because of the location on the shelfs. In the rear, I could go either in-ceiling or bookshelf with a ceiling mount, because there is no where to put rears besides ceiling.
The room is fairly small 2500 ft2, 10ft ceiling, on about 6ft viewing distance and the rear ceiling mounts are only about 2 feet behind the viewing area. It does open into the kitchen which is another 2500ish ft2 so the total area is on the bigger side.
I think my down the road upgrade will be the subwoofer and I think I will go with a SVS PB1000 as it seems like the best bang for your buck sub.
Thoughts on speakers I might look at?
Best bang for your buck sub IMO - Rythmik LV12R. There are reviews out there that give the head to head nod to the Rythmik as the best sub for under $600.
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | DirecTv | Roku 2 | Monoprice 12AWG |
AlexanderDelarg is offline
post #32253 of 32271 Old 01-23-2015, 05:30 AM
Thunder240's Avatar
Hey guys, over on Emotiva Lounge (and Audiogon) someone is selling a pair of modded BP7002s. In describing the mods, he says that he upgraded the caps and resistors on the crossovers to Mundorf polypropylene (he claims the stocks electronics are all computer grade rather than audio grade). He also says that each if the 4 woofers is placed within a metal "can" whose sole purposes is to provide EM shielding from other devices, and that he removed these cans and added damping material around each driver. And of course he says that taken together the mods offer a noticeable improvement in SQ.
I'm curious as to what you all think about these mods that I've described? The polypropylene electronics seem like they could plausibly offer an improvement. Removing these metal "cans", as he calls them, concerns me. Do they really not serve any function other than reducing EM interference from other devices in a home theater?
Finally, has anyone else out there modded their bipolar towers along the lines of the mods described here, and if so, what was the result?
dabsim likes this.
Thunder240 is offline
post #32254 of 32271 Old 01-23-2015, 07:36 AM
fredxr2d2's Avatar
Quoted: 46 Post(s)
Liked: 44
Originally Posted by LowellG View Post
55s would be way better than 800s, but the 45s are all you need and have the same size driver as the 65s.
Yeah. I considered the 45s, but unfortunately with my room layout at the moment, I'm worried about the rear port having enough room to breathe. The top bass radiator makes more sense for me. I also have a really small room and fairly flat response with my speakers now (a slight dip at the highest end), so I'm not sure if spending the money to upgrade is the best choice. I'm actually really considering getting a minidsp 2x4 for my sub.
You have any further advice on that?
Tim S.
Former 35mm and Digital Projectionist @ Regal Cinemas
Currently watching on: BenQ W1070, 82" 1.0 Gain Screen, Darbee Darblet, PS3, with Yamaha RX-V473, SVS PB-1000, a Def Tech CS-8040HD, 2 SM65 for L/R, and 2 PM 800s for surrounds.
fredxr2d2 is online now
post #32255 of 32271 Old 01-23-2015, 08:28 AM
drummer93's Avatar
Liked: 0
I'll definitely take a look at that but my question really was on recommended bookshelf and rear LR speakers.
What are the differences between the SM45, ProMonitor 1000 and the Mythos Gem? Would one of those match up better with the cs8040hd? I think I'm going with the ProMonitor 800 for rear LR since I'm mounting them to the ceiling, so should I go with Pro Monitor 1000 for the front or would the SM45 work well also?
"If you have to ask big man, you can't afford it"
drummer93 is offline
post #32256 of 32271 Old 01-23-2015, 11:52 AM
Quoted: 49 Post(s)
Liked: 72
I have the PM 1000's as my front L/R. The SM45's would be a little bit better overall speaker for not much more $. You can't go wrong either way.
post #32257 of 32271 Old 01-24-2015, 06:01 PM
Liked: 0
Best match with 8040 center
The 8040 center has DefTech's second generation drivers with a bass radiator. It is important that your front speakers match so you have fluid movement of sound artifacts across the stage. The best match would be from the studio monitor line which uses the same technology. The 45, or 55 would be a great choice. The other choices would not be as cohesive.... for you rear surrounds?,, not sure of your options but you might be better to place them a foot or two above ear level .
Richard
RichardGS is online now
post #32258 of 32271 Old 01-24-2015, 09:59 PM
Liked: 0
Hi guys,
Im looking for a sub to add my current q acoustics speakers 2050i floorstandings, 2000ci centre and 2020 bookshelf speakers as rears.
Definitive Technology SuperCube 3 is one of the speakers on my list. Would SC3 support my speakers sufficiently? I have some concerns as the size of the sub is small, even it has a 650w amp attached to it.
The room size is 35sqm2 and the system will be used for 60% movies and 40% music.
These are the other subs on my list:
Revel Concerta B120
Quadral QUBE 10"
Sunfire SDS10
Svs pb-1000
Im from Australia and prices for these subs are similar, therefore, the cost is not a decision factor. I just like to get the one the most suitable and the best from the list.
Al_kata is offline
post #32259 of 32271 Old 01-25-2015, 08:29 AM
dabsim's Avatar
Quoted: 30 Post(s)
Yeah Thunder, I rewired a pair of Def Tech BP-2000 With silver coated 14 awg 19 strand Teflon coated. It's made a great improvement in the puppet and lower Sonics!
Now I know this isn't exactly in ref to your question? But yes I do believe new propylene pieces could and would make a diff? I bet they sound really good? Especially if he changed out the 18 awg aluminum ,tin wire I found in my DEF TECH speakers? I even called Def Tech and inquired? I even emailed Sandy Gross on this issue? He did tell me where to find his new Line Goldenear? Nothing about the cheap wire? Send me a link to the Def Tech You are talking about here? I'm a member of Audition ,so?
dabsim is offline
post #32260 of 32271 Old 01-25-2015, 10:11 AM
Quoted: 49 Post(s)
Liked: 72
Originally Posted by Al_kata View Post
Hi guys,
Revel Concerta B120
Quadral QUBE 10"
Sunfire SDS10
Svs pb-1000
I would add the Rythmik LV12R to that list as it is the best sub for under $600 IMO (and many, many others).
post #32261 of 32271 Old 01-25-2015, 12:10 PM
Liked: 1
Audyssey MultiEQ
Hi,
I always feel under Audyssey setup my CS-8040 center channel volume is too low so I manually adjust center volume up from Denon manual setup while keeping everything constant. But I heard as soon as I go into manual setup, my MultiEQ will be disabled forever unless I re-run the Audyssey setup. Is that true?
Larry Chen is offline
post #32262 of 32271 Old 01-25-2015, 07:05 PM
LowellG's Avatar
Quoted: 229 Post(s)
Liked: 129
Originally Posted by Larry Chen View Post
Hi,
I don't know what model you have, but most likely no. You can adjust the level of any speaker after Audyssey runs. I can do it on my Denon from 2 different menus.
Lowell
LowellG is offline
post #32263 of 32271 Old 01-25-2015, 07:08 PM
Liked: 1
Thanks Lowell
post #32264 of 32271 Old Yesterday, 10:21 AM
WarmongerX's Avatar
I'm in a similar situation, however it's somewhat reversed. I have the PM1000's as L/R and a PC1000 for center. I was looking at PC2000 for center and SM65 for L/R. Would that be in error? I cannot merge one of the HD Centers into my configuration due to measurement limitations, I have 20.75" available and the 8040HD requires 21 1/8" inches, unless there measurements are in error.
Was going to move the PM1000's to surround duty and pick up another pair to match for the SB's, then match it all to a SVS PB 2000.
Samsung 65" UN65ES8000FXZA - Pioneer Elite VSX23-TXH - 7.1 Definitive speakers - PM 1000 L/R - PC 1000 - ProSub 800 - PM 800's Surround & Surround Back
WarmongerX is offline
post #32265 of 32271 Old Yesterday, 10:51 AM
Liked: 0
I also upgraded from a pro 1000 system with a center 2000. A DeFTech representative told me I would be ok using the 2000 with my 65's, and that the 2000 could hold its own with the 8040. I ran my 65's with with the 2000 until I got the 8060.
( shameless plug -upgraded to 8080, 8060 is listed in classified with towers and a Marantz 7009... all priced to sell)
The 2000 worked ok with the 65's (calibrated up a couple decibels)... the 8060 had a fuller sound with the powered subwoofer and the 8080 is pure heaven.
Can you pull your wall unit out and hold off to buy a 8060?
Richard
post #32266 of 32271 Old Yesterday, 01:21 PM
llkindt's Avatar
Hello guys. Finally finished the new space for my Definitive Technology setup. Thought I would share a couple pics.
ID:	504097   Click image for larger version
llkindt is online now
post #32267 of 32271 Old Yesterday, 01:28 PM
llkindt's Avatar
Almost forgot the most important part.
ID:	504137   Click image for larger version
ID:	504145   Click image for larger version
ID:	504153   Click image for larger version
post #32268 of 32271 Old Yesterday, 01:33 PM
Thunder240's Avatar
Hey dabsim, thanks for describing your mod. Did you ever get a reply from Sandy Gross, and if so, what did you learn?
Here is the thread I referred to on Emotivalounge.
http://emotivalounge.proboards.com/t...8060hd-monitor
If you want to see the Audiogon just google Audiogon bp7002 and it will pop right up.
I'm very tempted to try something like this. However, it'd be my first project of this kind, and it's been years since I've soldered anything.
Edit: I realize you wrote that Sandy steered you to his new Goldenear line of speakers, but nothing regarding choice wire or electronics. Too bad.
post #32269 of 32271 Unread Yesterday, 07:45 PM
Quoted: 49 Post(s)
Liked: 72
Nice room.
post #32270 of 32271 Unread Yesterday, 07:57 PM
Kavan Sidhu's Avatar
I have a cube woofer by them.
http://mvvg.blogspot.com/2015/01/denon-avr-3600.html
3rd pic from bottom.
But doesn't work so good. Probably not doing something right.
Kavan Sidhu is offline
post #32271 of 32271 Unread Today, 08:02 AM
JAMES MCHUGHES's Avatar
Quoted: 60 Post(s)
Liked: 29
Originally Posted by yosh7 View Post
Hello to all my fellow Definitive friends! I have made the very tough decision to sell my beloved Seaton Submersive HP's. They blend wonderfully with my BP7000's and would be a worthy upgrade from any Definitive Sub (maybe the Trinity would give them a run for their money in output - maybe - probably not). I upgraded to my dual Submersives from dual Supercube References and it was an amazing upgrade - an entire different world of performance.
I have been lurking a lot in the subwoofer forums and might be switching to giant folded horn loaded subs. And so my Seaton's must be sold. Let me know if any are itnerested!
Dual Seaton Submersive HP Subwoofers
Tosh
Look at PSA great subs I had the Trinity and Psa xv30f will out perform the Trinity. I know I had the trinity
JAMES MCHUGHES is online now
Reply Speakers
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
