Definitive Owners Thread - Page 1094 - AVS | Home Theater Discussions And Reviews
Old Today, 02:26 PM
WarmongerX's Avatar
Quoted: 25 Post(s)
Update - Got the new Entertainment Center last week and I'll be sticking with the ProCenter 2000. I haven't had time to sit and listen to see if there is any difference in sound with the larger cabinet area yet. I think I just wanted to continue the upgrade path for no real reason other than to buy something new and play with it
Some before and after shots. The new Entertainment Center makes things look cleaner and makes it so the sub doesn't look so huge. I put the HTPC into an actual HTPC case and put it in the cabinet instead of on the side. I also bought an Antec IR receiver to put in it and use with my Logitech Harmony remote. So I can now turn on and off the PC as well as launch and control Plex with the Harmony
Originally Posted by WarmongerX View Post
Yeah I noticed they did very well in phantom mode while in the store, however like Lowell said, in any other position besides the MLP, it wouldn't work.
Good point though on playing with the PC2000 and the new Entertainment Center with wider space, it might actually sound a bit better with more room. It doesn't sound bad now, I just wonder if I'm missing anything by not moving to something like the 8040 or another SM65 and my only concern with moving away from the PC2000 to something like the CS8040 is driver size...5.25 down to 4.5.
ID:	736498   Click image for larger version
ID:	736506   Click image for larger version
Samsung 65" UN65ES8000FXZA
Pioneer Elite VSX23-TXH
Def Tech StudioMonitor 65 L/R - Def Tech ProCenter 2000 - Def Tech ProMonitor 1000 x 4 Surround
SVS PB12+ Subwoofer
18TB Plex Media Server
WarmongerX is online now
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
