Definitive Owners Thread - Page 1158 - AVS Forum | Home Theater Discussions And Reviews
 282Likes
post #34711 of 34712 Old Today, 01:05 PM
hearrean's Avatar
Quoted: 114 Post(s)
Question CLR 2500 instead of CLR 2002?
I made an obvious mis-type in an earlier post & need to re-phrase my question so I'm giving accurate info. I have a simple 5.1.2 system w/BP-2002 towers/mains with BPX surrounds. I used to have the CLR 2002 center channel, but not too long ago, as I had posted, I was forced to sell that CLR 2002 because of having to down-size my a/v cabinet. Well, now that issue is resolved & I can go back to a larger cabinet. So my question now is this; since the CLR 2500 is the same center as the CLR 2002 (except the 2500 is powered), should I go to the 2500 or go back to the 2002? I can get a great deal on the 2500 & even lower than I've found for a good used 2002. So if the 2500 is the same center except powered sub (like my BP 2002 towers), it seems that would that be a better speaker? I gave my room size in an earlier post but again it's about 20' X 16' & we sit about 7' away from our LG OLED 4K display. Suggestions!
Ken
The optimist claims the glass is half full; the pessimist claims it is half empty. An engineer observes that the glass is twice as big as it needs to be.
hearrean is online now
post #34712 of 34712 Old Today, 01:28 PM
fredxr2d2's Avatar
Quoted: 159 Post(s)
Liked: 83
Ken
If you can get it for cheaper than a 2002, then I say you might as well. Also realizing that it takes power (like your towers) and that you may need to adjust the powered woofer to get the best balance (not everyone is Darth Vader). That said, I don't have any experience with the powered towers/speakers from def tech in comparison to the speakers with just the passive radiators.
Tim S.
Former 35mm and Digital Projectionist @ Regal Cinemas
Currently watching on: BenQ W1070, 106" 0.8 Gain Monoprice Multi-format Screen, Darbee, PS4, w/ Yamaha Aventage RX-A1030, NAD C370 (for Front L/R), SVS PB-2000, SVS PC-2000, a Def Tech CS-8040HD, 2 SM65 for L/R, 2 SM55 for sides, and 2 PM1000 for rears.
fredxr2d2 is offline
Reply Speakers
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
