Definitive Owners Thread - Page 1165 - AVS Forum | Home Theater Discussions And Reviews
 294Likes
post #34921 of 34924 Old Today, 05:40 PM
bobby_t1's Avatar
Quoted: 35 Post(s)
Liked: 24
Originally Posted by ALtlOff View Post
Can you do stands in the rear corners?
That would probably be your best option, then you can play with orientation and be ready of you decided to swap for a mono-pole speaker later on.
Yep, I think I can do stands. Anyone have recommendations for stands that would work that don't look horrible?
bobby_t1 is offline
post #34922 of 34924 Old Today, 06:37 PM
BiggShooter's Avatar
Quoted: 112 Post(s)
I'm probably going to go with these http://www.sweetwater.com/store/detail/SS42 for my Definitive Technology SR-9080's or these http://www.sweetwater.com/store/detail/SS42
Let me know if you find anything different or maybe better
BiggShooter is online now
post #34923 of 34924 Old Today, 08:12 PM
Liked: 0
Yamaha TSR 7810 with BP9060/CS7060 sounding weak
I brought TSR 7810 from Costco deal and hooked up to bp9060/cs9060. The sub did not kick in till -40db. YPAO didnt help. Yamaha does sound clear for speech however falls too thin on bass.
I switched back to yamaha ht5400 8 year old receiver and at volume lvl 10 def tech started blowing.
So far I have tried
1. Basic setup.
2. Large and small setting for tower speakers.
3. Adding sub from 1 and 2 receiver to tower speakers
4. reducing to 60hz and 100hz output
5. changing the speaker distance and enabling sound enhancer.
6. YPAO setup
7. increasing the db to +4 and played around with it.
Onkyo sound lvl 10 = Yamaha db lvl -32(Max is 16.5 db )
At this point, I am thinking of returning yamaha as it never drives the sub in def tech.
winkidzz is online now
post #34924 of 34924 Old Today, 10:05 PM
ALtlOff's Avatar
Quoted: 969 Post(s)
Liked: 460
So far I have tried
1. Basic setup.
6. YPAO setup
First thing I would try is doing a full manual setup, this will tell you if it's something in the receiver itself or simply in the setup.
-Run speaker wire only to the speakers
-Set the Sub dials on the speakers to 50%
-Turn off YPAO and all enhancements.
-Set your Sub setting to "none" (unless you have a separate discrete sub)
-Fronts and Center to Large
-Physically measure and set your distances
-With the volume dial at 0, run the test tones and calibrate each position to 85db (even a phone app SPL meter will be close enough for this experiment)
-Then listen to some content and adjust the subs on the speakers themselves to taste.
If this doesn't work for you then yes, something is going on with the receiver, if it does, it's simply something in the setup settings.
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
http://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
Reply Speakers
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
