Definitive Owners Thread - Page 1176 - AVS Forum | Home Theater Discussions And Reviews
 352Likes
post #35251 of 35258 Old 02-21-2017, 10:32 AM
Onedark1's Avatar
Originally Posted by pmeintel View Post
The BP8040SR's have a keyhole slot located on the back for mounting on the wall. Very easy and simple. Just use a quality wall anchor if mounting on sheet rock.
@pmeintel ~ Thanks for the response.
Was just wondering since I already had BP 90's in place, would these be able to use those, or will I have to remove and replace.
Thanks again!
Onedark1 is offline
post #35252 of 35258 Old 02-21-2017, 12:24 PM
littlefoott's Avatar
Quoted: 192 Post(s)
Liked: 82
Originally Posted by Whitecivicex1 View Post
Hello All,
Long time Lurker, first time poster. Let me start out with my setup
Def Tech BP8040st towers
Def Tech ProCenter 1000
Def Tech Supercube I
Def Tech Promonitor 800s (surrounds)
Sony STRDN1030 AVR
I recently put together this system, upgrading from my old school Bose Acoustimass 10 setup (I know it sucked compared to this. For some reason, it seems that the Procenter 1000 cant keep up with the rest of the speakers. It sounds low compared to the rest. I played with the adjustments for the Center on the AVR and it still is low. Would the CS-8040HD be worth buying to replace this? Is it any better?? Thanks in advance.
double check the center placement,and wiring connections, if it isn't pointed directly at the listener ear height it can sound off
you have 16 or 14 gauge wire, 18 gauge or thinner is not recommended
no stray wire strands touching each other
your center should have no issues keeping up
what are you testing with?
Audyssey is a great start, but not always a great finish.
Marantz SR-5010
Def Tech ST-8060 towers, CS-8040 center, SR-8040 surrounds, Pro Monitor 1000 heights
SVS PB-2000
65" LG UG8700
Harmony 1000
littlefoott is offline
post #35253 of 35258 Old 02-21-2017, 04:24 PM
Whitecivicex1's Avatar
Liked: 0
im running 12AWG Sewell 259 Strand 6 ft. cables with banana plugs for the L/C/R
14 AWG wire for the rear 4 promonitor 800s
I just used the standard Sony AutoCal to set up the speakers. Maybe I need to fine tune them.
Whitecivicex1 is online now
post #35254 of 35258 Old Today, 08:33 AM
yosh7's Avatar
Quoted: 131 Post(s)
Liked: 161
Hi everyone on the Definitive Thread. Updating my theater with an AT screen and looking to potentially part with my beloved BP7000 setup. Hope these can find a loving home!
FS: Definitive Technology BP7000 SC speaker package
yosh7 is offline
post #35255 of 35258 Old Today, 02:57 PM
pmeintel's Avatar
Quoted: 62 Post(s)
Well finally pulled the trigger and should be receiving a CS9060 sometime next weekend (A pair of SM65's arrive tomorrow ) . My initial intent is to try the CS9060 set to small with the cross over set to 80. Also will try the CS9060 set to large and see how this sounds. Just thought I ask everyone eases thoughts and or imprecations and perhaps what has worked well for them. I understand that every ones ear's are different yet I'm under the mind set of there is no such thing as to much data.
P.S. If I don't reply it's because the purchase of the center speaker has pushed my wife over the edge......
"These go to eleven."
Great words from Nigel Tufnel.
Gear:
Sony KDL55, LG BD570, Pioneer SC-95, FL/FR - DefTech SM65, C- DefTech PC1000,
FLH/FRH - DefTech PM1000, SL/SR - DefTech SR8040BP, Sub - DefTech Supercube 2000
pmeintel is offline
post #35256 of 35258 Old Today, 06:34 PM
Liked: 0
Those with ProMonitor 800/1000s in the rear What do you guys normally have the rears set to? Small or Large?
Gear: Sony STR-DN1030 (AVR); Def Tech Super Cube I; Def Tech BP-8040st (Fronts) ; Def Tech Procenter 1000 (Center); Def Tech Promonitor 800 (SL, SR, SBL, SBR)
post #35257 of 35258 Old Today, 06:41 PM
Quoted: 66 Post(s)
Liked: 31
100% small.
weboperations is online now
post #35258 of 35258 Old Today, 07:11 PM
RKSKYDANCER's Avatar
Quoted: 92 Post(s)
Liked: 73
I have no problem with my Procenter 1000, but just for kicks bought a new CS-8040HD to see if it would improve anything for my 5.1 system and it did not. No difference between the PC1000 and CS-8040HD. Both have the same drivers in them. Personally i think they make the CS-8040 to match the towers and the PC1000 to match the pro cinema series speakers. You might want to get it just so it matches your BP8040 towers.
Living room; Samsung PN60F5300B Plasma TV, Marantz SR5008 AVR, Sony UHP-H1 UHD Blu-ray, Definitive Mytho 2's fronts-wall mounted, Definitive Pro Center 1000 speaker, Definitive Di 5.5R in ceiling for surrounds, RSL speedwoofer 10s , Comcast Xfinity HD DVR box.
Garage; Sherwood RX-4105 2 channel stereo receiver, Samsung DVD-C500 CD player, Klipsch KG 2.5 med Oak speakers
RKSKYDANCER is online now
Reply Speakers
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
