Definitive Owners Thread - Page 1178 - AVS Forum | Home Theater Discussions And Reviews
 373Likes
post #35311 of 35336 Old 03-11-2017, 09:17 AM
ALtlOff's Avatar
Quoted: 1072 Post(s)
Liked: 528
Originally Posted by DarkTactics View Post
So after listening to my friends all Goldenear setup, was curious if anyone has tried to upgrade drivers in the BP7002's... Wondering if I can in the least put a ribbon tweeter in.
I considered it a while back, but besides the cabinet modification that would be very difficult to change back if I didn't like the results, you also have to consider that the speakers are designed as a whole, that means taking into consideration everything from the size of the cabinet, to specific specifications of the drivers when designing the crossovers. And this is where it "may" go wrong, you would have to switch to an active crossover or custom design one in order to really get it to work properly, granted you could get lucky, but it would be a long shot.
It could be a good experiment if you had an extra pair of speakers around that you weren't going to rely on.
This would be a real case for bi-amping as well, if you decided to use an active crossover.
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
http://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
post #35312 of 35336 Old 03-11-2017, 10:15 AM
Liked: 0
My banana clips and speaker wire are coming in the mail today looking forward to hooking up my PM100s that I got for $60 for the pair, as surrounds. To finnaly upgrade from 3.1. I've had HTIAB 5.1 set ups but not a real set up like this. Kinda older stuff but still hope I'm happy with it.
Fronts - BP6
Center - PC1000
Surrounds - PM100s
Sub - Polk PSW-10
AVR-Onkyo NR626.
Now gonna start looking for a better sub!
ryan.tollefson is offline
post #35313 of 35336 Old 03-15-2017, 10:43 AM
cu_shane's Avatar
Quoted: 47 Post(s)
new 5.1.2 system
I'm putting together a new setup and think I'd like to go with Def Techs. The front speakers can be bookshelf. Everything else needs to be in-wall or in-ceiling. I'll probably use an SVS SB-1000 for the sub. This will be used almost exclusively for movies. I'll definitely do 5.1 and I'm hoping I'll be able to afford adding in to overhead speakers to make it a 5.1.2 Atmos system.
After looking at all the different DT models, here is what I've come up with:
Center: DI 5.5 LCR mounted in-wall
Fronts: ProMonitor 1000 sitting on top of a counter
Surrounds: DI 5.5S mounted in-wall 90deg from the listener
overhead (Atmos): DI 5.5R mounted in-ceiling
I've attached a drawing of the room that shows anticipated speaker placement.
Does it look like I'm headed in the right direction?
Name:	AV setup.jpg
jchas41 likes this.
cu_shane is offline
post #35314 of 35336 Old 03-15-2017, 08:42 PM
ALtlOff's Avatar
Liked: 528
I'd say that it's pretty good, definitely well balanced as far as tonal quality.
My Build Thread:
ALtlOff is offline
post #35315 of 35336 Old 03-16-2017, 12:36 AM
Quoted: 16 Post(s)
Liked: 1
Originally Posted by ALtlOff View Post
For 7.1, the 350's are more capable than your 800's, so the 350's should be your surrounds.
Rule of thumb, your hearing is more precise in front of you, always put your best gear forward.
Thanks for all the help on my HT. I went ahead and picked up the hsu vtf-3 mk5 today. That thing is huge. I just got some play out of it and you were absolutely right. A good sub changes everything. All I need to do now is get stands for my sm350s. I've been slacking on it.
Wettems is online now
post #35316 of 35336 Old 03-16-2017, 08:58 AM
AlexanderDelarg's Avatar
Quoted: 152 Post(s)
Liked: 173
Fronts - BP6
Center - PC1000
Surrounds - PM100s
Sub - Polk PSW-10
AVR-Onkyo NR626.
Next upgrade - Update the center to the PC2000 as it makes a world of difference between the PC 1000.
pmat123 and ryan.tollefson like this.
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | DirecTv | Roku 2 | Monoprice 12AWG |
AlexanderDelarg is offline
post #35317 of 35336 Old 03-16-2017, 02:01 PM
Quoted: 122 Post(s)
Liked: 37
You can also try grabbing a CLR2002 - they often show up on ebay for ~$120. It will be similar to PC2000 but less expensive and better match for your fronts.
ALtlOff likes this.
Def Tech BP8 Front L/R with Def Tech SM350 Front heights [Dolby Pliiz]
Def Tech CLR2002 Center / Def Tech Pro1000 Surrounds L/R
Hsu VTF3 MK5 Sub
pmat123 is offline
post #35318 of 35336 Old 03-16-2017, 04:33 PM
Quoted: 26 Post(s)
This. I went from a PC1000 to a CLR2002 to match my front upgrade of SM350s from PM800s and it's a huge improvement. The PC1000 is fine but the 2000 or CLR2002 is that much better.
KSpan is offline
post #35319 of 35336 Old 03-16-2017, 05:36 PM
cmeinck's Avatar
Quoted: 37 Post(s)
Is it realistic that a ProCenter 1000 would sound better than a Klispch R-5502? I had in-wall speakers installed when I re-did my home, but I've never been particularly happy with the sound. This particular speaker is mounted in fireplace mantel. The whole is big enough to fit the ProCenter 1000. In looking at what I paid for the Klipsch, I'm wondering if there's something I can do to either improve that or maybe the best move is to shift to the Def Techs. I have a ProCenter 2000. If I swap that in, would that provide me with a good idea of what I might expect?
cmeinck is offline
post #35320 of 35336 Old 03-16-2017, 05:55 PM
Liked: 0
I can find one locally for 120 on Craigslist, looks like it's in great condition. How big is compared to the PC1000? It's on a floating shelf above the tv now, just wondering how much heavier it is. Idk if the shelf could take much more weight.
post #35321 of 35336 Old 03-16-2017, 06:53 PM
Quoted: 122 Post(s)
Liked: 37
It is a big/heavy speaker - weighs about 30lbs. Audyssey sets the crossover for mine to 60Hz (I raise it to 80Hz afterwards).
Here are the specifications:
  • frequency response 30-30,000 Hz
  • sensitivity 91 dB
  • 8-ohm impedance
  • handles up to 250 watts
  • one 1" pure aluminum dome tweeter
  • two 5-1/4" bass/midrange drivers
  • two sets of 5-way binding posts (biwireable)
  • piano-gloss black finish
  • 21-3/4" W x 6-7/8"H x 12-1/8"D
https://www.crutchfield.com/S-O6Xfk0...C-L-R2002.html
ryan.tollefson likes this.
Hsu VTF3 MK5 Sub
pmat123 is offline
post #35322 of 35336 Old 03-16-2017, 07:53 PM
Liked: 0
  • sensitivity 91 dB
  • 8-ohm impedance
Wow, that is heavy. It is real pretty and would match my BP towers great! Might just grab it and hold on to it until I get a new tv, and gets tv stand that could accommodate it.
post #35323 of 35336 Old 03-16-2017, 08:58 PM
ALtlOff's Avatar
Liked: 528
FYI, at that price, you could resell it with a minimal or no loss at all, if it doesn't work out.
My Build Thread:
ALtlOff is offline
post #35324 of 35336 Old 03-20-2017, 09:42 PM
bowlingbeeg's Avatar
Quoted: 23 Post(s)
Originally Posted by bowlingbeeg View Post
I have a CLR2002 that I've been using for years as a center channel speaker and the other day I was watching the movie Arrival at a fairly loud level(not reference level but since I have little kids it's been years since I listened to anything that loud) and I noticed what I thought was a rattle somewhere in my front sound stage. So I got closer and it seemed to be coming from the port on my CLR2002 speaker. From up close it definitely wasn't a rattle but I'm not sure what to call it. Does anyone know what that might be? I thought maybe my denon x4300 was being pushed to hard(I've got all 9 channels in use) so I brought out my old denon 3803 and just ran the CLR2002 off that and it had the same problem. So I don't think it's lack of power(but it could be since I don't know what lack of power actually sounds like). Is the speaker going out or just reaching it's limits? Any help would be greatly appreciated.
Thanks littlefoott, I can take a look at that this weekend but it really sounded more like a noise from the air coming out of the port(not sure what to call that). I did some testing yesterday and if I change the crossover on my receiver from 60Hz to 120Hz the noise is substantially less so at least for now I'll run it that way.
So I finally got annoyed enough at this issue that I ordered a new CLR2002 on a whim. Well it has the same problem, so now I'm trying to decide what my next move is. I think my only option is to purchase a new center channel. One that can handle more bass since changing the crossover lessens the noise. But will the current lineup match my bp2002 tower speakers, or do I have to try and buy a used CLR2500 or CLR3000? Anybody have any experience with the current center channel speakers(CS940/960/980) or even the SM65 and the older bp2002 towers?
bowlingbeeg is offline
post #35325 of 35336 Old 03-20-2017, 09:45 PM
badgerpilot's Avatar
Quoted: 75 Post(s)
Liked: 44
I have not listened to the newer Centers, but I can say this, find a good CLR3000 and you will be done. It is an awesome center channel.
badgerpilot is online now
post #35326 of 35336 Old 03-21-2017, 03:53 AM
Gonzilla13's Avatar
Quoted: 48 Post(s)
Liked: 4
+1...Go as big as your budget allows for your center channel.
CLR2300 or 2500s can be found for pretty good prices on CL. There should even be a fair number of DT center channels for sale here depending on what youre looking for.
CLR3000 is where its at though.
Gonzilla13 is online now
post #35327 of 35336 Old 03-21-2017, 10:41 AM
Quoted: 23 Post(s)
Thanks Baderpilot and Gonzilla13. I guess my main hesitation with going the used route is if it ends up not being a speaker issue and something else then I don't have any way to return the speaker and I'm left reselling it.
post #35328 of 35336 Old 03-21-2017, 11:25 AM
Quoted: 75 Post(s)
Liked: 44
If you buy a nice used CLR3000, you won't want to return it. I would stay away from the 2300, I was not happy with it. Also, if you can find a CLR1000b, it is nearly as good as the 3000, it would be my second choice. Make sure it is a "b" though, it has the more recent tweeter. I used to have the 1000b but then I found a deal too good to pass on for a 3000. Honestly though, there is not a huge difference between the two IMO. The 1000b's can be found around $150-$200.
post #35329 of 35336 Old 03-21-2017, 11:26 AM
Gonzilla13's Avatar
Quoted: 48 Post(s)
Liked: 4
Have you changed the speaker wire or hooked the center speaker up to another channel to trouble shoot it? Or maybe hooked up another speaker to the center channel speaker to see if the problem still exists?
post #35330 of 35336 Old 03-21-2017, 12:07 PM
Quoted: 23 Post(s)
I did try hooking up one of my rear BPX speakers to the center channel output on the AMP and it seemed to play fine(although there's no port on that speaker so maybe it's just an issue because the CLR2002 has a port) but I never did try a different wire to see if that makes it any better. Not sure why it would but can't hurt to try.
post #35331 of 35336 Old 03-21-2017, 12:21 PM
Gonzilla13's Avatar
Quoted: 48 Post(s)
Liked: 4
Just a few quick things to narrow down the culprit...Let us know how it goes...
post #35332 of 35336 Old 03-21-2017, 04:27 PM
keeper's Avatar
Quoted: 96 Post(s)
Add the clr2000 into the mix also. I see a few on eBay on occasion for $200 and less.
keeper is online now
post #35333 of 35336 Old Yesterday, 07:09 PM
Quoted: 16 Post(s)
Liked: 1
I currently have three sm65's for my fronts. I know matching all three is recommended, but Im still not entirely happy when it comes to dialogue. I upgraded from a pro center 1000 hoping that it would be much louder or clearer. Would a clr 3000 be an improvement as my center channel with my sm 65s remaining as the front left and right? Or would you guys recommend Messing with then receiver and settings and keeping the sm65
post #35334 of 35336 Old Today, 04:53 AM
Gonzilla13's Avatar
Quoted: 48 Post(s)
Liked: 4
If you have the space and can find a CLR3000 for sale you should absolutely go that route. Use that as your center channel and pick up another sm65 and use those as your surrounds perhaps? I think that would be a pretty nice set up personally.
post #35335 of 35336 Old Today, 06:19 AM
Liked: 0
I posted this in the general speaker second but had no idea there was a dedicated Definitive owners thread which is probably where this belongs instead of in general, I apologize for the double post I'm new around here.
I'm finally moving into a single family house with my Fiancee after living in a townhouse for the last 5 years, with that being said I can finally set up a proper A/V setup without pissing my neighbors off to much. I still relatively new to all of this but have been trying to do a bunch of research and have pieced together part of a system so far. However I'm stuck on what I should do for the 4 rear speakers so was hoping I could get some advice from people that know way more than myself. I'm looking to complete a 7.2 setup.
Currently have:
DefTech ST-L Towers
DefTech CS9080 Center
SVS PB2000 Sub, will be adding a second one as well
Marantz 6011 Receiver
Just have no idea what to run in the rears. Any suggestions anyone has would be greatly appreciated. I have attached a diagram of what the space looks like in the basement.
Name:	Basement Layout.png
Housemuzik52 is online now
post #35336 of 35336 Old Today, 09:44 AM
Gonzilla13's Avatar
Quoted: 48 Post(s)
Liked: 4
Currently have:
DefTech ST-L Towers
You should buy my 8040s!!
Do you want towers? Wall mounts? In wall? Do you need to have WAF?
Reply Speakers
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
