Definitive Owners Thread - Page 1179 - AVS Forum | Home Theater Discussions And Reviews
 374Likes
post #35341 of 35356 Old 03-23-2017, 01:53 PM
ALtlOff's Avatar
Quoted: 1077 Post(s)
Liked: 529
Originally Posted by jchas41 View Post
Anyone know where I can find the pre-construction brackets for the UIW RLS II and the UIW RSS II? Having a hard time finding them from a reputable site. Thanks!!
Have you e-mailed DefTech yet?
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
http://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
post #35342 of 35356 Old 03-23-2017, 02:15 PM
jchas41's Avatar
I wasn't aware they could supply them direct, I will email them now! Ty!
jchas41 is online now
post #35343 of 35356 Old 03-24-2017, 03:31 AM
Liked: 0
Originally Posted by Gonzilla13 View Post
Nice. I have the same arrangement. One of the perks of a split level. I haven't heard a lot of in wall speakers, but Im yet to be impressed by them...
If you wanted a timbre match you could set up some SM65s back there on stands. Are another set of ST-L towers an option?
Are you going to do surrounds AND rear surrounds?
I'm not sure another set of ST-L would sit very well with my fiancee LOL. Yes I plan on doing surrounds and rear surrounds. I have been thinking about getting 2 BP9020 and 2 SR9080. Not sure if those would complement the fronts well though
Housemuzik52 is offline
post #35344 of 35356 Old 03-24-2017, 04:23 AM
Gonzilla13's Avatar
Quoted: 54 Post(s)
Liked: 4
From the looks of your layout you may have outlets near where your rear speakers would be. Timbre matched, powered loud speakers for rears are a real kick in the pants.
The guy I bought my 2006's from was running a 5.0 set up with 4 2006's. He let me test drive them prior to buying and it was a very enjoyable experience.
I definitely wouldn't skimp on your rear channels if youre running ST-Ls up front. Just my 2 cents.
Gonzilla13 is offline
post #35345 of 35356 Old 03-24-2017, 04:47 AM
pmeintel's Avatar
Quoted: 71 Post(s)
Well I have a Procenter2000 on its way from Bajawaverunner, can't wait test drive it. Hoping it lives up to everyone's comments. Although just looking at the specs compared to my current Procenter1000 it should be an improvement (fingers crossed)
"These go to eleven."
Great words from Nigel Tufnel.
Gear:
Sony KDL55, LG BD570, Pioneer SC-95, FL/FR - DefTech SM65, C- DefTech PC1000,
FLH/FRH - DefTech PM1000, SL/SR - DefTech SR8040BP, Sub - DefTech Supercube 2000
pmeintel is online now
post #35346 of 35356 Old 03-24-2017, 05:06 AM
Quoted: 28 Post(s)
I was looking at making the same change and ended up with a CLR2002 instead of a PC2000. For me it was a massive improvement and no reason to think you won't experience the same. The PC1000 is fine but I always felt like it was a bit congested and boxy, particularly with male voices, and switching it out took care of that.
KSpan is online now
post #35347 of 35356 Old 03-24-2017, 05:34 AM
pmeintel's Avatar
Quoted: 71 Post(s)
I hope you are right. I originally went with the C9060HD but it did not pass the WAF and to be honest it truly didn't fit my space. The PC2000 will fit like a glove and should tide me over until we get my last little sponge out of college and then I can go really crazy ( 9 BP 8080ST for the bed layer sounds like it should do nicely.... )
Gear:
post #35348 of 35356 Old 03-24-2017, 06:31 AM
jchas41's Avatar
Hey guys, was just curious, if I go ahead with the UIW RLS II for LCR. Would I be better off using the RSS II or the RCS II as my surrounds, since they will be installed in the rear wall at either end of the couch? Since I don't have side walls not sure if it would be helpful to "aim in" the RCS from the couch edge rather than have the RSS pointed straight.
I attached a pic to illustrate. Def tech's are marked as blue dots. The Red dots would be for the RSL C34E's I'm planning to use for a future 5.1.2 atmos set up. Thanks for any help!
post #35349 of 35356 Old 03-24-2017, 09:33 AM
AlexanderDelarg's Avatar
Quoted: 152 Post(s)
Liked: 174
Huge improvement.
pmeintel likes this.
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | DirecTv | Roku 2 | Monoprice 12AWG |
AlexanderDelarg is offline
post #35350 of 35356 Old 03-24-2017, 08:42 PM
Quoted: 390 Post(s)
Liked: 240
Hello all,
Sorry if this question has been asked, but the search function is not helping me to search for this question.
I'm strongly considering getting a 7 speaker set of the 9000 series lineup.
Specifically I'm looking at two BP-9040's for Front L and R with the A90 atmos modules. The CS-9040 for center, and two SR-9040's for side surrounds.
My primary question is in regards to matching a receiver to this set up. But I'd also really appreciate any thoughts, suggestions or feedback.
For my receiver, I'm looking at the Denon AVR-X4300H IN-Command because it supports 9.2 channels with HDCP2.2, HDMI 2.0a and Atmos, and I like its bluetooth and spotify features. The main reason why I was looking at this particular receiver, beyond being a fan of and used to Denon products, is because it supports a 5.2.2 setup, whereas other atmos enabled 7.2 channel receivers that I've seen do not allow 5.2.2.
BUT - now that I've done some more reading, it appears that if I were to use the integrated subs in these speakers (BP-9040), and set the speakers to Large with no LFE connected, then I would be running 5.0.2 and would not need to spend another $500+ on an extra 2 channels I do not plan to use. Is this assumption correct, does anyone else run a set-up like the one I'm looking at?
Edit: for example, maybe the Denon AVR-X3300W 7.2 Channel would be just as appropriate for my setup.
For some background if interested:
I'm moving to a new home and have a preferable max $4,500 budget, before the wife kills me (keeping it towards 3,500 is preferable). I'm coming from a 5.1 setup with some old Infinity speakers with ribbon tweeters that I've repaired and refoamed. Front L&R are Reference Five series, side LR are similar era bookshelves (no ribbon tweeter), center is an Infinity PC351, sub is some random front firing hand-me down. Been happy with these speakers as a hand me down from my father for a long time, but they are bulky and will look ugly in our new home. I know I can do better now and want atmos.
Current: LG 55E6P OLED (Self calibrated with Colormunki Display and HCFR)
Previous: LG 55" EF9500 OLED (Self calibrated with Colormunki Display and HCFR)
Tomcup is offline
post #35351 of 35356 Old Yesterday, 03:45 AM
Gonzilla13's Avatar
Quoted: 54 Post(s)
Liked: 4
Tomcup,
It all depends on how much you want to spend in the end. I believe the 2300 and 3300 would support your 7 channel needs, the 4300 just has more power and more options.
post #35352 of 35356 Old Yesterday, 08:39 AM
Quoted: 390 Post(s)
Liked: 240
Tomcup,
Yeah I meant to link the 3300w as what I would chose.
It makes sense if setting the speaker to large, that I would have no problems with a 7.2 channel receiver (that is only capable of 5.1.2). Could probably still even split the LFE line to the two if I preferred to go both fronts as Small and LFE enabled. But I think I'd just wire 'em in as large mains and allow the internal crossovers to do their things.
Appreciate the input.
Tomcup is offline
post #35353 of 35356 Old Yesterday, 11:57 AM
Gonzilla13's Avatar
Quoted: 54 Post(s)
Liked: 4
There is a huge Denon owners thread on this website too. I learned a lot reading through there.
The 3300 is a nice piece for sure though. If I wasn't going for a 9.x + set up I would grab one.
post #35354 of 35356 Old Yesterday, 03:40 PM
Quoted: 12 Post(s)
Liked: 5
Def Tech owners let me know if this would power or drive my speakers or I would end up wanting more power. I'm thinking of replacing my older Yamaha RX-V663 receiver with the Marantz NR-1506 slimline receiver. Its only 50 watts per channel but I was told Marantz is super conservative with their amp power ratings and probably puts out a bit more than what is stated. I have for speakers SM65 mains, SM55 surrounds, CLR2000 center that in time will be replaced with a 3rd SM65 for a center channel. I also have a SVS PB-1000 sub. Anyway do you think the Marantz NR-1506 will power and drive these speakers or will I end up wanting more power? I do not listen at ridiculous volume levels so I'm thinking it might be OK, but would like to see what Def Tech fans will say. Thanks in advance.
Hetfieldjames is online now
post #35355 of 35356 Old Today, 03:57 AM
Gonzilla13's Avatar
Quoted: 54 Post(s)
Liked: 4
IMO you should always go with as much as you can afford...SM65s + SM55s would benefit from an ample power supply.
You should be able to move that CLR2000 pretty quick here once you get your third SM65.
post #35356 of 35356 Old Today, 06:54 AM
Quoted: 12 Post(s)
Liked: 5
Thanks for the advice. Maybe I'll just get another Yamaha receiver, they do build great receivers. I have been reading though they are skimping on the amp section, all the receiver company's are so I keep reading. I might go with a 5 channel amp from Outlaw and one of their new HT processors coming out.
When you say move the CLR2000, you mean sell it here? I have a pair of Mythos ones also. I didn't even know you could sell old equipment on here. Thanks for the post.
Reply Speakers
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
