Definitive Owners Thread - Page 1184 - AVS Forum | Home Theater Discussions And Reviews
 392Likes
post #35491 of 35503 Old Yesterday, 08:55 AM
Sharp1080's Avatar
Quoted: 690 Post(s)
Liked: 429
Originally Posted by grandmaison View Post
My room isn't huge, it's about 12'-6"x18'-0"...and my media center is on a wall that also has a door on the far left side of that wall. So, I'm planning on raising my 70" SonyXBR and mounting it to the wall (it currently uses the factory legs to sit atop the media cabinet). I need to raise it for the new center speaker to sit below the tv and on the media center. I'm hoping to place each of the towers on each side of the media cabinet, and as far forward as practical. Since they're 16" deep and the front of my cabinet is 26" from the wall, I'm hoping 10" to the back wall will work well enough for the bipolar elements. The media cabinet is 25" high and my CS9060 will sit centered on it. The cabinet is 6'-8" long- so that means my towers will end up being placed about 7' apart...not much, but I think it will work out for me.
Still not sure what to do about the surrounds and rear heights....money's not there to do it all at once anyway.
I am doing the same thing as you! I just had my Sony mounted last Friday and also raised it 8 inches higher to accomodate the CS9080 center channel. Having owned bipolar speakers in the past I know that the further out they are placed the better the soundstage imaging.
Sharp1080 is offline
post #35492 of 35503 Old Yesterday, 08:59 AM
Quoted: 67 Post(s)
That's the thing with bipolar speakers, if you have the right space, the right room for them and place them right there is no better soundstage around. It's quite incredible, the parameters have to be right though and that's tough for a lot of people. Awesome if you do though.
Sent from my Pixel using Tapatalk
Hetfieldjames is online now
post #35493 of 35503 Old Yesterday, 09:06 AM
Sharp1080's Avatar
Quoted: 690 Post(s)
Liked: 429
I have no more WAF to deal with so I am okay with placement wherever needed.
post #35494 of 35503 Old Yesterday, 09:17 AM
Quoted: 67 Post(s)
I have a wife, I just don't care when it comes to the home theater. She can do what she wants with every other room, but I do what I want when it comes to the home theater. I don't have bipolar speakers and I don't miss them. I have an all Def Tech non-bipolar system, other than the sub which is SVS.
post #35495 of 35503 Old Yesterday, 10:05 AM
grandmaison's Avatar
Quoted: 61 Post(s)
I'd like to try going without a sub and using the BP9060's 10" subs as a separate LFE input. But, that doesn't seem to be the "preferred" method according to the manual.
Does anyone forgo the use of a separate sub and only use the two towers?
(Haven't yet received any kind of email from DT as regards my order placed yesterday. Hopefully I will get some kind of receipt tomorrow and some idea of shipping/arrival dates.)
grandmaison is offline
post #35496 of 35503 Old Yesterday, 10:14 AM
Quoted: 67 Post(s)
I did just that for years and it was ok but nothing like having a real sub. I wish it would have been but it's not enough. Then I was dumb enough to buy a DT sub which is overpriced for the performance. Years down the road I smartened up and have an SVS PB-1000 and this how a sub should sound and perform.
post #35497 of 35503 Old Yesterday, 11:24 AM
nativecodder's Avatar
Quoted: 62 Post(s)
I have a pair of BP-8060's and have been using the LFE RCA cable on them for the past 15 months. I'm considering getting a SVS PB2000 if not 2 of them. Still looking at HSU or Rythmik but leaning more towards the SVS. I know one will fit in front where my mains are, I don't know if I can squeeze a second upfront due to the placement/area restriction that I have now.
Just biding my time till I round up enough cash to buy one (or two).
nativecodder is offline
post #35498 of 35503 Old Yesterday, 11:42 AM
pmeintel's Avatar
Quoted: 77 Post(s)
Liked: 26
Question for all those in the "know", I currently utilize a DT Supercube 2000 as my one and only sub (the rest of my system is noted in my signature as well). I would really like to add an additional sub to lessen the load and to smooth the response in my room. My room is approximately 16'W x 22'L x 8'H and is partially open (8' open doorway) to another room. I know for the most part the def tech subs are considered over priced for their performance yet If I had the opportunity to add a 2nd def tech SC2000 for a pretty reasonable price (say around $300) do you all think that this would be a sensible route to take? Also not sure if this is the best place to post this question yet I haven't been steered wrong by you all yet . Thanks ahead of time for your opinions and experiences.
"These go to eleven."
Great words from Nigel Tufnel.
Gear:
Sony KDL55W800C, LG BD570, Pioneer SC-95, FL/FR - DefTech SM65, C- DefTech PC2000,
FLH/FRH - DefTech PM1000, SL/SR - DefTech SR8040BP, Sub - DefTech Supercube 2000
pmeintel is offline
post #35499 of 35503 Old Yesterday, 11:46 AM
Quoted: 67 Post(s)
Personally I think you'd be better off with one SVS PB-1000 and forgetting about the SC 2000. That's just my opinion. You could try a second SC 2000 and see.
post #35500 of 35503 Old Yesterday, 12:47 PM
ALtlOff's Avatar
Quoted: 1089 Post(s)
Liked: 536
If you can get a used SC2000 for $200-$250 then your dollar -per- performance ratio will be in line, but....
The real question is "how big is your space" this will tell you if it's even worth doubling up on such small subs, and with the size of your room + the extra room, I'm thinking you really need something more than a pair of SC2000's to really make a purchase worth it, while smoothing out your frequency response for more than one or two seats is a good idea, if your going to spend money to achieve this, might as well throw having Subs capable of pressurizing your space and dipping into those really low frequencies, into the mix, even if it means mis-matching them for a while.
pmeintel likes this.
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
http://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
post #35501 of 35503 Old Yesterday, 08:34 PM
littlefoott's Avatar
Quoted: 278 Post(s)
Liked: 155
adding a second identical sub will smooth out the bass response in the room and seating positions but make no difference in frequency range.
Audyssey is a great start, but not always a great finish.
Receiver:Marantz SR-5010, Speakers:Def Tech ST-8060 towers, CS-8040 center, SR-8040 surrounds, Pro Monitor 1000 heights
Subwoofer: SVS PB-2000
TV: 65" LG UG8700 remote: Harmony 1000
littlefoott is offline
post #35502 of 35503 Unread Today, 12:03 PM
Liked: 0
I just installed a Hsu VTF2-MK5 to supplement my Def 8040's. What a nice difference, especially with a 1/3 octave 31-band equalizer with a sub output so I can tweak the lower 5, 1/3 octaves: 20, 25, 31.5, 40 and 60 Hz.
Outlaw Audio RR2150 integrated amp; Definitive BP 8040 (2), Hsu VTF2-MK5 sub, Rockville 31 band equalizer w/sub out. Sources: Nvidia Shield tablet with USB out to amp; Logitech Squeezebox; Amazon Echo "Dot"; CD player.
gfmucci is online now
post #35503 of 35503 Unread Today, 12:28 PM
Falconsfan71's Avatar
Quoted: 241 Post(s)
Liked: 97
SO.. where can I find a ProCenter 2000 for a good deal??? There's no reburbished (which I've never bought) on eBay bahawaverunner's site so they must be out of stock. A Magnolia Design Center in Best Buy that's over an hour away from me wants $300 for a new one. It's $314 new currently on DT's website. I see a couple of "like new" on Amazon for around $235-$259 but without knowing the history or without actual pics I'm a little skeptical. I have the PC1000 now but have been thinking about going bigger since I just got some new Studio Monitor 45's and dual PB-1000's.
Pioneer Elite VSX-90 7.2 AVR * Def Tech Studio Monitor 45 front L/R * Def Tech ProCenter 1000 * Def Tech ProMonitor 800 surrounds (sides & rears) * dual SVS PB-1000 subs * VTI RF Series 29" speaker stands * Def Tech ProMount 90 wall mounts * OSD Audio WSK-100 wireless sub kit *
Falconsfan71 is online now
Reply Speakers
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
