Definitive Owners Thread - Page 1201 - AVS Forum | Home Theater Discussions And Reviews
 459Likes
post #36001 of 36012 Old Today, 09:45 AM
Gonzilla13's Avatar
Quoted: 136 Post(s)
Liked: 24
Originally Posted by Timothy1180 View Post
Also tried this for fun. Shotgun double run kimber 8vs from adcom 7605 to 7001. So it's 6awg wire now. Lol.
Sounded great but was to much hassle to get adcom 7805 to do this. Also I was wasting about $400 of cables doing this.
Youre doing stuff I haven't even heard of. It sure is pretty though man. I can appreciate good craftsmanship when I see it.
Like I said, Im sure Ill end up down the cable rabbit hole once I get my front channel situation sorted out. Expect a message or 2 from me.
Gonzilla13 is online now
post #36002 of 36012 Old Today, 09:51 AM
Timothy1180's Avatar
Quoted: 452 Post(s)
Liked: 102
Originally Posted by Falconsfan71 View Post
I don't see how some of you can crank it up that loud. When I hit that 85-90db range I can't think it's so loud in here!
85-90db isn't loud at all. Try watching a 10 minute clip at 125-135db. That's a experience!
I think my phone speaker gets to 85db.
I think my conversations are at 85 db. Hmmmmm maybe 85 db isn't loud at al.
115 db is a reference achievement for any home theater. Thx certification use to mean that. It could drive a system at 115db.
Some people think 100 db is loud or fine. I'm not one of the them.
Timothy1180 is online now
post #36003 of 36012 Old Today, 10:19 AM
Gonzilla13's Avatar
Quoted: 136 Post(s)
Liked: 24
+1...I love that "blow your socks off" volume in a good theater.
I had a few friends that didn't understand why I was getting into home audio as a hobby. Then they came over for movie night. Even in my entry level set up it made them understand right away. Immersive sound makes every movie better.
post #36004 of 36012 Old Today, 10:27 AM
Jameshtx's Avatar
Quoted: 44 Post(s)
Liked: 4
Originally Posted by kdjohn3 View Post
You should be able to hear them loud and clear. What level did Audyssey set all your speakers at? Did you have the mic on a tripod in the recommended locations? What receiver/processor are you using?
Perhaps you have a bad Audyssey mic. Try turning off Audyssey and manually setting speaker levels by ear or with an SPL meter using manual test tones. Then put on some 7.1 material to check the results. If you are hearing them clearly then you know something went wrong with your Audyssey calibration.
These are the levels from the audyssey setup. Sub 1 and sub 2 are alot different. If it is, im thinking all other speakers are off too. Would like everyones feedback. Thx
Jameshtx is online now
post #36005 of 36012 Old Today, 10:42 AM
Gonzilla13's Avatar
Quoted: 136 Post(s)
Liked: 24
Can you tune it all by ear and see how it sounds..?
Is there lint or anything blocking the ports of the mic?
Just spit-balling some ideas here.
post #36006 of 36012 Old Today, 10:51 AM
Quoted: 452 Post(s)
Liked: 102
Need to turn subs down. Get closer to 0
Run audyssey like this. All spots within 5" from each other.
post #36007 of 36012 Old Today, 11:11 AM
Jameshtx's Avatar
Quoted: 44 Post(s)
Liked: 4
Ok I'll try that. Those squares in the picture are seat cushions right?
post #36008 of 36012 Old Today, 11:17 AM
Quoted: 452 Post(s)
Liked: 102
Yeah. But all 8 positions should be in a small area. Start with mlp. Than start moving in 3-5" moves. The last 2 can be farther out maybe a foot out left and right. Honestly the last 2 don't have huge affect. Those first 6 a very important to get right. Some people have even used only 3-5 positions in mlp and have had great results.
Even audyssey admits that by using more positions has a minimal effect on sound.
post #36009 of 36012 Old Today, 01:06 PM
Jameshtx's Avatar
Quoted: 44 Post(s)
Liked: 4
Will do. What's mlp stands for?
post #36010 of 36012 Old Today, 01:30 PM
kdjohn3's Avatar
Quoted: 33 Post(s)
Main Listening Position.
Marantz SR7010 AVR (using as pre-amp), Logitech Harmony One Remote
B&K ST1400 Series II 2-ch amp powering fronts, AV6000 Series II 6-ch amp powering center, surrounds and tactile transducer
Def Tech BP2000 fronts, Def Tech CLR2000 center, Def Tech BPX side and rear surrounds
Oppo BDP-93, Apple TV 4th gen, PS4, Rotel RCL-900 Line Conditioner
Adding Atmos in ceiling speakers soon
kdjohn3 is online now
post #36011 of 36012 Old Today, 02:51 PM
Jameshtx's Avatar
Quoted: 44 Post(s)
Liked: 4
One of the tips from audyssey is to turn the sub's frequency to highest level. Do you guys recommend this as well?
post #36012 of 36012 Old Today, 02:56 PM
Quoted: 452 Post(s)
Liked: 102
Yes. Turn it up all th way for audyssey.
After I always cut it at 50-60 hz.
I run my subs hot and don't like 60-100hz being played through my sub.
Reply Speakers
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
