Definitive Owners Thread - Page 1218 - AVS Forum | Home Theater Discussions And Reviews
 735Likes
post #36511 of 37363 Old 08-05-2017, 06:31 PM
Quoted: 17 Post(s)
Liked: 2
Originally Posted by Timothy1180 View Post
Call Chet on Monday. They just fixed a bp3000tl amp for me. It's amazing these speakers last so long. Those speakers could be over 20 years old.
Probably pretty close to 20 years old now that I think about it!, bought them used from a Def Tech dealer owner back in 2004 I think.
Def Tech BP3000's/CLR2500/BP2004's Powered by Marantz SR7009
Chris
lubeman1 is offline
post #36512 of 37363 Old 08-05-2017, 06:36 PM
Quoted: 507 Post(s)
Liked: 277
Originally Posted by lubeman1 View Post
Do you have Chet's number?
I only email him. Very nice guy, will bend over backwards for you.
Sent from my Pixel using Tapatalk
Hetfieldjames is online now
post #36513 of 37363 Old 08-05-2017, 07:21 PM
Timothy1180's Avatar
Quoted: 919 Post(s)
Liked: 275
Have to just call definitive and ask for Chet or use directory. I don't have his number
Timothy1180 is online now
post #36514 of 37363 Old 08-05-2017, 09:54 PM
Quoted: 36 Post(s)
I just recently lost the sub woofer on one on my main towers, nothing really unusual happened, just stopped outputting bass. Check the fuse all good, auto on light works as does the LFE signal in is lite just no bass. Switched towers around and the problem follows the same tower. Did I lose the Amp? I pulled the control panel off the back to check wiring and to see if anything was burnt on the boards, all looks visually good.
Mids and highs work fine BTW
Thoughts?
If indeed is is the amp that is bad you might try getting in touch with Bajawaverunner through EBay store. They are out of San Diego. I bought quit a few DefTec parts from them.
WOKNROX is offline
post #36515 of 37363 Old 08-05-2017, 10:00 PM
Quoted: 36 Post(s)
I think I'm going to use CLR2500's for my Atmos speakers instead of the Mirage omd5's.
I'm running powered FULL range speakers ALL the way around everywhere else and really like the sound.
I already have two so I need to pickup 2 more.
I'm thinking they will take better advantage of the full range signal from Atmos and DTSX...
WOKNROX is offline
post #36516 of 37363 Old 08-05-2017, 10:12 PM
Quoted: 36 Post(s)
Originally Posted by keeper View Post
Glad you were able to find the bpvx-p. Are you the one buying up all the clr 3000s?
If you are still in market for a CLR3000 there's a couple on eBay right now..
WOKNROX is offline
post #36517 of 37363 Old 08-05-2017, 11:30 PM
ALtlOff's Avatar
Quoted: 1218 Post(s)
Liked: 616
If you already have 2, go ahead and mount them as your FH and see what you think, since they get more of a workout than the RH, the only challenge I can see is using a solid enough mount that will still allow the powered woofer to not be constricted, since they are so heavy.
I will say though, I actually do like the CLR2000's better than the SM450's I was using, not a big change, but enough of one, esp since we're dealing with reasonably priced, used speakers, instead of full priced new ones.
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
http://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
post #36518 of 37363 Old 08-06-2017, 09:11 AM
Quoted: 17 Post(s)
Liked: 2
Ah ok thanks, I did already send out an email to Definitive inquiring about replacements.
Chris
lubeman1 is offline
post #36519 of 37363 Old 08-06-2017, 10:38 AM
Quoted: 36 Post(s)
I think I'll do that.
I've already figured out the mount I'll be using. It's a piece of 1" square stock that runs from cap to cap on the back of the speaker and angle iron across each end welded together in an "I" shape. I pulled back the sock on each end then installed two screws on each end to attach it to the speaker.
This is how I mounted my 3 upper front CLR3000's and it works great. I was thinking this time I'd just add a poll and foot to it to mount it to the ceiling. Just need to figure out the angle needed so I can point them at the seating.
WOKNROX is offline
post #36520 of 37363 Old 08-06-2017, 11:07 AM
Quoted: 36 Post(s)
Yesterday I was able to get the 4 BPVXP's mounted and cal'd in time for Jerry Garcia's special tribute concert at Red Rocks!
It sounds fantastic.
After that I checked out Billy Lynn's long halftime walk in 4k at 60 frames per second.
WoW! That really took a minute to get used to but it was definitely smooth.
The new addition of the upper surrounds really pushed the ceiling up and added a whole new level of dimensions to the sound.
Can't wait to get the atmos/DTS-X ceiling speakers installed.
Cnguyen1127 likes this.
WOKNROX is offline
post #36521 of 37363 Old 08-06-2017, 11:09 AM
Quoted: 507 Post(s)
Liked: 277
4 BPVX/Ps! Wow that's crazy stuff. Those old Def Tech wedge bipolar speakers were awesome.
post #36522 of 37363 Old 08-06-2017, 11:25 AM
Quoted: 36 Post(s)
Yeah I know a lot of people prefer the non-powed version of these but I really love the fullness and with their powered bottom end you can adjust them up to really kick at lower volumes.
Wish they still made them
WOKNROX is offline
post #36523 of 37363 Old 08-06-2017, 11:29 AM
Quoted: 507 Post(s)
Liked: 277
Funny thing is I could have sworn I had a pair but I found a pair of BPVX non powered ones that I sold on here.
post #36524 of 37363 Old 08-06-2017, 11:47 AM
Quoted: 36 Post(s)
What are you using for surrounds now?
WOKNROX is offline
post #36525 of 37363 Old 08-06-2017, 11:49 AM
Quoted: 507 Post(s)
Liked: 277
I have SM 65 mains and center and SM 55 surrounds. That's my whole system except for the PB-1000 which I really like.
post #36526 of 37363 Old 08-06-2017, 11:54 AM
Quoted: 36 Post(s)
That's right I read that.
That's a sweet setup.
What made you get away from dipoles?
I've been hearing a lot of really great things about the 65's. They are getting a huge following. It's good to see DT getting some love again.
WOKNROX is offline
post #36527 of 37363 Old 08-06-2017, 11:57 AM
Quoted: 507 Post(s)
Liked: 277
They are just too hard to place and setup right in your room. When they are setup right and you can set them up right it's incredible. Just didn't work for my room at all. I did deliberately move away from bipolar speakers.
The studio monitor line is awesome to be honest. On sale right for a ridiculous price.
post #36528 of 37363 Old 08-06-2017, 12:07 PM
Quoted: 36 Post(s)
Yeah I saw that someone posted the pricing on them at BB... killer deals!
When I was redoing the setup in my Living room I looked at DT's.. I really wanted them but wound up with some wall hangers from HTD. I picked up the Versa 1's and added 2 Martin Logan Dynamo 700w subs. The sound fantastic plus the wife got to do her thing with the caps and socks... they really look good in the room.
WOKNROX is offline
post #36529 of 37363 Old 08-06-2017, 05:40 PM
keeper's Avatar
Quoted: 298 Post(s)
Liked: 114
So it seems your building a really nice 7.4 atmos system. So you have clr3000s up front and then bpvxs in back? What speakers are you using for overhead?
keeper is online now
post #36530 of 37363 Old 08-06-2017, 07:11 PM
Quoted: 36 Post(s)
Well I built this theater 11 years ago when we built our house. A little over a year ago I started gathering equipment for a complete remodel.
I removed the big Klipsch speakers, subs, Carver amps projector... yada yada.
The only thing that stayed was the screen.
So flash forward I just purchased one of the last two Atmos speakers needed to finish my build.
I was going to use OMD5's for the ceiling but I've changed direction and now I'm going with the DT clr2500..
So once this is complete I will have three levels of speakers..
The ground level has
OM5's x6 ft L/R, SS, BS
clr3000 x1 center
The mid level has
clr3000 x3 ft L/C/R
BPXV/P x4 SS, BS
The ceiling level has
clr2500 x4
I'm running a clr3000 above and below the PJ screen..for my center channel.
WOKNROX is offline
post #36531 of 37363 Old 08-06-2017, 07:55 PM
weekendtoy's Avatar
Quoted: 335 Post(s)
Liked: 339
Originally Posted by Gonzilla13 View Post
Hey fella...North metro area here...Where in MN are ya?
Hermantown, just outside of Duluth.
I reject your reality and substitute my own.
weekendtoy is offline
post #36532 of 37363 Old 08-07-2017, 02:09 AM
keeper's Avatar
Quoted: 298 Post(s)
Liked: 114
clr3000 x1 center
The mid level has
clr3000 x3 ft L/C/R
BPXV/P x4 SS, BS
clr2500 x4
Very nice must sound awesome. Prior to installing my di6.5 for atmos I was researching if it was possible to mount the bpx or bpvx to the ceiling. I couldn't find anyone who did that. I still think they would sound great directly above you for atmos. Much better than in ceiling.
post #36533 of 37363 Old 08-07-2017, 10:17 AM
Gonzilla13's Avatar
Quoted: 198 Post(s)
Liked: 58
DI 6.5 str is a dual tweeter in wall speaker.
I've been waiting for months and months to see if anyone has used these and what their thoughts were.
Not the same as a BPVX at all, but it's gotta be a bit better than the standard 6.5...Right?
I've heard of people mounting the BPX/BPVX sideways for height speakers.
Gonzilla13 is offline
post #36534 of 37363 Old 08-07-2017, 10:26 AM
keeper's Avatar
Quoted: 298 Post(s)
Liked: 114
Yeah in all honesty the di 6.5 blends in very well with the other 6.5 drivers I have. I can't tell a difference.
post #36535 of 37363 Old 08-07-2017, 11:47 AM
pbz06's Avatar
Quoted: 314 Post(s)
Liked: 262
I have those in my ceiling, 5.1.2 Atmos, configuration as "top middle". I love them and they look nice. I haven't tested them in isolation, and it's difficult to compare with my older speakers since it's only atmospheric effects, but I do feel they fill the room a lot better (older ones were polk audio rc60i).
Sony XBR-65Z9D / Oppo UDP-203 / Marantz SR7011 / Def Tech 9060 Series
pbz06 is offline
post #36536 of 37363 Old 08-07-2017, 11:48 AM
Quoted: 36 Post(s)
I've mounted 4 BPVXP's vertically and high on the side walls for my "upper" surrounds.
I'm running 4 Mirage om5's at ear level for my lower surrounds.
I'm using 4 clr2500 mounted to the ceiling for my Atmos heights speakers
WOKNROX is offline
post #36537 of 37363 Old 08-07-2017, 12:34 PM
ALtlOff's Avatar
Liked: 616
While I've heard the BPVX's before as surrounds, I'd be curious to hear the difference between the wedge design of the BPVX/P vs the 180° of the towers, when using them as surrounds and rears. Very nice.
My Build Thread:
ALtlOff is offline
post #36538 of 37363 Old 08-07-2017, 08:21 PM
Gonzilla13's Avatar
Quoted: 198 Post(s)
Liked: 58
That's all I needed to hear. When I have the time and $ for an amp and speaker install those are going to be my RH choice.
post #36539 of 37363 Old 08-10-2017, 10:00 AM
chas_w's Avatar
Any ideas on which in-ceiling speakers to use as surrounds in a 5.2 system that would match well with Studio Monitor 55 fronts?
chas_w is offline
post #36540 of 37363 Old 08-10-2017, 12:34 PM
ALtlOff's Avatar
Liked: 616
Depends on your space....
For an enclosed space, where the surrounds would be within a few feet of the rear wall, I'd look at the Di-6.5 (now called DT-6.5)
But in a large space or great room, I'd consider the UIW RCS II.
My Build Thread:
ALtlOff is offline
Reply Speakers
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
