Definitive Owners Thread - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 745Likes
post #811 of 37383 Old 10-18-2006, 07:53 AM
DMZIGON's Avatar
Originally Posted by marengo123 View Post
Hi everyone,
I currently have a set of the 7004's as front R/L. I am in process of getting a set of 7006's for the rear surrounds and a CLR 2300 center.
A couple of questions.
1) does anyone know a reason why towers will not be a good choice for rear surrounds (as opposed to say BPVX/P's)?
2) I have a stand that sits on top of my Tosh 62hm84 where i keep the cc. Does anyone know how much the 2300 weighs? Is it true that if your cc weighs too much, it can damage the tv set?
TIA
Matt
Matt,
Room size, and equiptment have to be taken into account(dedicated ht room, seating area etc.) The BPX bi pole surrounds match up very well with the 7004's. The design gives you a much larger sound field. Proper speaker placement is also easier with the BPX's. Also, for the amount of information you actually get from the back surrounds it really isnt cost effective...
I am currently running 7004's with 2 sets of BP2Xs and a clr 2300. Room is 27 x 16.
DMZIGON is offline
post #812 of 37383 Old 10-18-2006, 12:13 PM
IlEagle's Avatar
Hey ya'll -
I am the new proud owner of a Definitive setup... My first true home theater.
Here's a quick list (Any and all input, good or bad, is encouraged!)
-7002's Up front
-CLR2300 Center
-BP2X's Out back
-Supercube II
I should have everything delivered and ready to go by early next week. I couldn't be more anxious Only thing left to purchase is the Elite VSX-84 Receiver I hope it knocks my socks off.
And btw, I currently am running a Samsung S4253 42" Plasma.. After the Def Tech's are done, I'm going to move this TV to the bedroom and look at the Sammy 71" DLP
IlEagle is offline
post #813 of 37383 Old 10-18-2006, 12:43 PM
schroedk's Avatar
Congratulations, ILEagle! I must say, that if this is your first home theater, you got some good advice, or you did a very admirable job shopping around. I think you'll be very happy for a long time. Enjoy!
Two things are infinite: the universe and human stupidity. And I'm not sure about the universe. -- Albert Einstein
schroedk is offline
post #814 of 37383 Old 10-18-2006, 03:56 PM
hi im drummer03's Avatar
Thanks for the reply. I'm not worried about the room in the back. My couch is in the middle of the room and there is plenty of space. I actually have a pair of bookshelf speakers on stands in the back so the 7006's will clean things up a bit.
I'm not sure I understand what you meen by "your going to be spending some back in the wrong area"? Can you explain in more detail?
Matt
Sounded like you were going to put Towers in the rear?
PN58B860
TCP50GT50
hi im drummer03 is offline
post #815 of 37383 Old 10-18-2006, 04:00 PM
Originally Posted by Neo-Geo View Post
That's exactly how I have my setup.
Front, Center, Surround, Surround Back = SMALL
Subwoofer = YES
Crossover frequency = 80hz
I do have the option to set the Fronts to LARGE and Subwoofer to PLUS. I just tried that and it sounded the same to me. Seems that even when fronts are set to SMALL they still receive a bass signal since the subs are vibrating and outputting sound. There's just no comparison with the subs from the 7006 with the ML Descent. I figure I'd try to milk the 7006's for fuller midrange sound instead of using the 8 subs for bass production since they are vastly outperformed by the Descent.
May not have heard a diffference on few songs you listen to.When its emphasized you will know.So put all the DefTechs to LARGE.Music will have better mid rang.Also plays more detail and will in return give you a more crisp,dynamic sound.On movies the subs wont whine when there getting a small amount of signal.
PN58B860
TCP50GT50
post #816 of 37383 Old 10-18-2006, 04:07 PM
rlhjr34's Avatar
I'm also looking to do something similar in my room. I'm considering moving my 2006's to my surrounds and upgrading the 2006's to either the 7002's or 7001's. I also have the 2300 center channel. Wouldn't adding these to the rear be the rough equivelant to getting the powered surrounds they sell? Space won't be a factor for me and I only have one row of seating anyhow.
rlhjr34 is offline
post #817 of 37383 Old 10-18-2006, 04:39 PM
marengo123's Avatar
drummer,
I am going to put the towers in the rear. i just didn't understand what you meant by "your going to be spending some back in the wrong area". Are you referring to a monetary amount?
Sorry for the confusion.
marengo123 is offline
post #818 of 37383 Old 10-18-2006, 08:53 PM
IlEagle's Avatar
Thank you, sir!
With my hobbies, I tend to get in over my head, but I think I made the right choice diving right in to a system of this caliber. I made a point to keep an open mind and open ears while researching AVS and speaking with enthusiasts, so absolutely! It's the most any of us can do, I suppose
IlEagle is offline
post #819 of 37383 Old 10-19-2006, 04:02 AM
Adz523's Avatar
I have stated this countless times - Using towers in the back are fine but really not even close to the optimal set-up. A much better surround sound immersive experience can be attained by placing 4 of the BPX line (BPX, BPVX, BPVX/P, etc.) around the listening position and about two feet above the listener. As a custom dealer for Def, I have had the oppt'y to try virtually every kind of set-up in my showroom including using towers as surrounds (side and/or back), and at the end of the day, nothing came close to mounting those bi-polar surrounds all around the listening position which added a much bigger sense of spaciousness.
Adz
Adz523 is offline
post #820 of 37383 Old 10-19-2006, 09:02 AM
marengo123's Avatar
Adz - Thanks for the reply on this subject. I am assuming you are referring to a 7.1 setup as compared to a 5.1. I understand that, given the same speakers, 6 are better than 4 for fully immersive surround sound. I just wanted to see if anyone knew a significant reason for not using towers for surrounds. I got a really good deal on a pair of 7006's and was just wondering if I shouldn't go that way in the end.
I see that you said that rear towers are fine and no one has said anything negative about using them (besides a little overkill).
I really appreciate everyone's input on this forum. its definitely one of the few where you can get relevant information.
matt
post #821 of 37383 Old 10-20-2006, 07:50 PM
Adz523's Avatar
matt
Its a great forum and a lot of Def Tech loyalists on here. While I said they are fine, I do not think they are overkill in a positive way. Using towers for surrounds simply do not sound as good as the bi-polar surrounds (the BPX series) mounted and positioned properly.
By the way, I have a pair of showroom demo BPVX/Ps I am looking to sell if anyone is interested - PM me.
Adz
Adz523 is offline
post #822 of 37383 Old 10-22-2006, 08:27 AM
LowellG's Avatar
Quoted: 523 Post(s)
Liked: 203
IlEagle,
How much do you notice the Super Cube II with the 7002s. I was debating whether to upgrade my 2006s to 7002s, or just add a sub.
Lowell
The MarvelAtmos Home Theater: http://www.avsforum.com/forum/19-ded...e-theater.html
LowellG is offline
post #823 of 37383 Old 10-23-2006, 08:13 AM
jackohu's Avatar
I have the same question about ceiling mounting my newly purchased BP2X. I haven't figure out how to mount them.
Can you post some pictures to illustrate how you did this and how it looks like? Are you ceiling mounting the speakers without the cabinet "naked"?
Thanks in advance.
Originally Posted by videoquest View Post
Here's what I did based on a recommendation from definitive tech support. It sounds scary, but worked out great.
What I did was remove the speakers from the bpx2 cabinet and pre drill a small hole slight of center and in the middle widthwise. I then used a lag bolt and a large metal washer on the inside to screw the speaker directly into the ceiling joist. I then caulked around the washer. By being slightly off center I was able to have the speaker wire come through the drywall and right into the speaker. Basically the speaker is completely flush mounted with no wires showing. I have the ported side aiming at the listening position and the other side aiming at the back wall which is roughly 24" away. I can post a pic if that will help. Good luck!
jackohu is offline
post #824 of 37383 Old 10-23-2006, 09:28 AM
DrJ 1's Avatar
Can anyone comment on Def Tech 7000sc and CRL 3000 center. REX
DrJ 1 is offline
post #825 of 37383 Old 10-23-2006, 11:54 AM
mschiff's Avatar
I don't have the 7000sc, but I do have a CLR3000 center, and it is awesome. It is quite large and heavy though, so make sure you have room for it. I've got mine on a wall TV mount above my projection TV. I have PM900s as fronts and am very happy with them as well, and BPVX/Ps for surrounds. It's really a great system. I get lots of compliments about the sound.
-- Martin
mschiff is offline
post #826 of 37383 Old 10-23-2006, 12:10 PM
stubeeef's Avatar
anyone heard the procinema 1000's yet? or mixed the 800's with mythos? anyone using an AV123 sub (ulw-10) with mythos or procinema?
WAF
stubeeef is offline
post #827 of 37383 Old 10-23-2006, 12:48 PM
IlEagle's Avatar
Originally Posted by LowellG View Post
IlEagle,
The Supercube II is a powerhouse. I was VERY impressed with how such a small package can fill a room with tight, clean bass response.
When I used them supplementally with the 7002's - the result was golden. I auditioned a little of everything that I would put it through, and I couldn't be happier for the price point. I think this combo is going to stay with me for a couple years.
IlEagle is offline
post #828 of 37383 Old 10-25-2006, 06:46 AM
JediMaster109's Avatar
Can the Def Tech 7002's be bi-wired or do they require one cable and connection.
TWC Milwaukee - HTPC with Windows Media Center
JediMaster109 is offline
post #829 of 37383 Old 10-25-2006, 07:12 AM
vinnyvin_m's Avatar
I auditioned the 1000's last week at a Magnolia store. They were powered by the new Pio Elite -84 coupled with a 12" klipsch sub (don't remember the model).
I have never heard the 100's, but the 1000's sound great. The 1000's will definitely go on my recommendation list.
The 800's were not yet on display.
vinnyvin_m is offline
post #830 of 37383 Old 10-25-2006, 06:49 PM
stubeeef's Avatar
thanks vinny, that was good to hear cause I will be most likely using a pion 84!
What price where they listed for?
WAF
stubeeef is offline
post #831 of 37383 Old 10-25-2006, 09:21 PM
g_bartman's Avatar
Quoted: 170 Post(s)
Liked: 139
They can be bi wired.
g_bartman is offline
post #832 of 37383 Old 10-25-2006, 10:27 PM
Chris72's Avatar
anyone ever notice that there is no gasket around the the edge of the sub on the 7002's?
Chris72 is offline
post #833 of 37383 Old 10-26-2006, 08:12 AM
vinnyvin_m's Avatar
Magnolia has them listed for $199 a piece, which is msrp I believe. I don't remember what they had the center (procenter 1000) listed for.
I do believe Magnolia will give a discount for a package deal.
Good luck and happy listening-vinny
post #834 of 37383 Old 10-26-2006, 06:08 PM
Technically they cant.You can run 2 seperate wires to the speaker and it will be a waste of time....
PN58B860
TCP50GT50
post #835 of 37383 Old 10-27-2006, 05:16 AM
Tarheel72's Avatar
Quoted: 21 Post(s)
what's a resonable price for a pair of used Def Tech BP1X speakers in good shape?
Tarheel72 is offline
post #836 of 37383 Old 10-27-2006, 11:18 AM
schroedk's Avatar
Has anyone used the Omnimount CCH1 shelf to mount their CLR 2300 (or 2500 or 3000) on the top of a DLP monitor? I ask because I'm interested in getting the Toshiba HD-A1, but it won't fit in my cabinet given the components I already have. Right now I have my 2300 on the top shelf (right underneath the TV), angled up towards my listening position. If I were to move the 2300 to the top of the TV (which I would prefer anyway, although where it is now is fine), I could fit the HD-DVD player where the 2300 is now. However, I'm a little nervous about putting the hefty 2300 on the shelf. I can't find the weight of the 2300 online, and my manual is...ummmm....somewhere. Anyway, is this mount sturdy enough for the 2300? I know I could always put the HD-A1 on the omnimount, but for aesthetic and acoustic purposes, I would prefer the 2300 on top. Thanks in advance!
schroedk is offline
post #837 of 37383 Old 10-27-2006, 01:52 PM
billymac's Avatar
Quoted: 25 Post(s)
hi gang. i currently own a pair of BP2002 (the pre 2002TL version) along with BPX surrounds. I have the CLR2002 center, but i'm using it in my other theater because i switched to a front projection setup and just couldn't figure out a WAF way to mount the beast on the wall, ceiling or above the fireplace. i've been dealing with 4.1 just fine for a while now, but would really like to have my center channel back. so, i've been kicking the idea round of adding a mythos 3 center channel because of it's form factor. i could pretty easily run the wiring in my atic and down the two walls i think and mount it above the top of my screen.
two questions
do you think i'll have any problems with mismatch?
does the wall mount for the mythos give you any tilt capability?
mag hi-fi has the mythos 3 on sale for $460 through tuesday and i'm sort of interested in picking one up.
tia
"the one who has the most fun wins."
billymac is offline
post #838 of 37383 Old 10-30-2006, 07:56 AM
mschiff's Avatar
I have a 2300 mounted on the wall in my bedroom, and a 3000 mounted on the wall above my projection TV in the ht. I used wall bracket TV mounts for both, and they work great. No weight on the TV at all.
-- Martin
mschiff is offline
post #839 of 37383 Old 10-30-2006, 10:12 AM
MikeSp's Avatar
Quoted: 33 Post(s)
Liked: 24
Def Tech's top of the line speakers are excellent (and yes I have those), but IMHO, if you have a dedicated subwoofer, you would be just as well off saving some money and purchasing the BP7001SC's. Also IMHO, a dedicated subwoofer is still needed even if you have the 7000's -- I tried them without one for a couple of months and then connected my old PF1800 sub and it made a substantial difference. Therefore, if you do not have a dedicated sub, I would recommend the purchase of one and then purchase the 7001's. YMMV
good luck,
MikeSp
Samsung SUHD UN65JS8500 TV, Marantz MM8077 multi-channel amp, Marantz AV8802a pre-pro; Oppo UDP-203; speakers -- Aerial Acoustics Model 9's for mains and CC5 for center, Def Tech BPVX/P's and BPVX's for surrounds and JL F113's (2) for subs; Roku 3; Tivo Roamio; and Monster HTPS...
MikeSp is offline
post #840 of 37383 Old 10-30-2006, 10:19 AM
J.H.'s Avatar
Hey guys any of you Def Tech fans use pro amps with your setup? I have as most know here BP7002's mains,BPVX's for surround and CLR 2000 for center and SupercubeII. I use a 5 channel parasound amp and a B&K Ref50 S2. I just bought a QSC PLX-1104 two channel pro amp to obviously power the 2 main channels. What do you guys think of this setup being DT fans as I am? what do you think of using pro amps ingeneral for HT use? Thanks guys J.H.
J.H. is offline
Reply Speakers
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
