Definitive Owners Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 561Likes
post #61 of 36610 Old 02-10-2006, 01:02 AM
I Superman I's Avatar
I'm actually thinking that the 7002's are pretty drastically better then the 7006's, i'm going to do more listening sessions, but if they really do just keep me there then i'll just wait on the sub, i really don't think i'll have the money, but hey, i'm doing this through a Best Buy credit card with monthly payments, so I guess it's just how much it will add to that bill. Or I'll just get the sub and be spioled and owe them a rediculous amount of money
CTS - Certified Technology Specialist
EAVA - Extron Certified AV Associate
I Superman I is offline
post #62 of 36610 Old 02-10-2006, 02:28 AM
Adz523's Avatar
Originally Posted by scofow View Post
What is the best processor setup for the BP7002 with a sub?
Speakers set to small or large?
What do you guys set the processor crossover around?
Is it best to use the LFE connection for the BP7002?
Thanks for you time!
Speakers definitely set to Large or you are losing the benefits of the Supercube being in there. Once set to Large, that overrides your processor's crossover (for any speakers set to Large). As to LFE, its trial and error. I prefer the overall sound not running the LFE to my 7000s but just to my dedicated sub. But others will run to all three or four (2 in the towers and 1 or 2 dedicated subs) with awesome results. It also depends on your processor's # of sub outputs and how many Y-connectors you want to run to split the signal.
Adz
Adz523 is offline
post #63 of 36610 Old 02-10-2006, 03:11 AM
J.H.'s Avatar
Superman thats what I have for mains 7002's and they are considerably better than the 7006's. They flat out rock believe me! J.H.
J.H. is offline
post #64 of 36610 Old 02-10-2006, 06:02 AM
jocnat's Avatar
Hi All,
Just ordered deftech system and was stopping in to say hi. ordered pair 7004s, 2500 center, and bpvx/p.
I guess I'm second guessing myself, After alot of reading I am thinking of the 7002 fronts over the 7004's. The 7002's larger and more midranges better match for the rears. Or the 7004's better match for the room size ( 16 X 16). the speakers should be here in a week. I would really like to here some opinions. Decisions! Isn"t this a great hobby.
jocnat is offline
post #65 of 36610 Old 02-10-2006, 10:03 AM
J.H.'s Avatar
Congrats you'll love the system. J.H.
J.H. is offline
post #66 of 36610 Old 02-10-2006, 11:02 AM
Half Fast's Avatar
I would like to hear opinions from you guys with experience with the BPXV/P's for surrounds. I am currently running the following Def Tech 5.1 configuration; BP2000TL front, CLR 3000 center, BPVX side surrounds. Temporarily the system is powered by a Pioneer 1014 that will be upgraded to (?) within the next few months. I have had these speakers for a few years and really like the DT's for both movies and music. My room is very large volume wise and these speakers do a great job of filling it up with sound. The Pio 1014 is a nice unit but I bought it just as an interim step. I will upgrade the DVD player next month and then I will start looking seriously for a receiver upgrade.
I am currently in the process of installing permanent wiring for the system and placement of the side surrounds. I am going to include wiring for the 7.1 surround rears although I don't have any speakers at this time. My question is whether the BPVX/P is enough of an upgrade over the BPXV that I should consider them for my next purchase. If I go that route I will put the /P's on the sides and use the BPXV's for rears.
Unfortunately the rears will have to be mounted quite high, about 5 feet above the seated listening position and only about 3 feet behind. The rears can either be hung flat against the wall or angled downward with a bracket. There is no power outlets available where the rears will hang so for sure they will be the BPXV's when the 7.1 layout is completed. Would you recommend /P's for the sides or just stick with the standard version and get another set for the rears?
Half Fast is offline
post #67 of 36610 Old 02-10-2006, 11:25 AM
J.H.'s Avatar
I don't know how much of an upgrade it would be because I am using BPVX's for surround speakers but I suspect its a really nice upgrade. I sure wish I would have went for BPVX/P's now. With that being said you would place the BPVX/P's in the surround position and the BPVX in the back surround or Dolby EX/DTS-ES position. That would sound absolutely incredible. Also when you go to upgrade the receiver I would go with separates if you have the money. I have Parasound separates and will never look back. Its the best way to get the most of your speakers. J.H.
J.H. is offline
post #68 of 36610 Old 02-10-2006, 12:18 PM - Thread Starter
khellandros66's Avatar
New pics of the 7006's in place.
~Bob
khellandros66 is offline
post #69 of 36610 Old 02-11-2006, 07:10 AM
Gators2001's Avatar
Can I get some feedback from ppl w/ Mythos ONEs. Do you have them set to LARGE or SMALL???
I have the ELITE 74 so I am able to PUSH the sub even if they are set to large.
Gators2001 is offline
post #70 of 36610 Old 02-11-2006, 10:37 AM
Kaptain Karl's Avatar
I'm going to chime in about the Def techs. I recently made a change from all KEF
speakers to deftechs. I got a killer deal from my brother in-law that just got remarried and moved into a small house. He had to unload most of them but kept
his bp3000 towers. Here what I bought. 3- CLR2000, 2- BPVX, 2-BP-2006TL all for a grand! While I loved my KEFs they just dont have the dynamics for movie soundtracks. And whats nice is I can run all 3 CLR2000's for movies and then switch out the 2 left and right for the 2006's for music and multichannel music. I find that I much prefer the 2006's for music.
Ive been enjoying the new setup so much that I felt compelled to comment here.
P.S. - Gotta give a nod to my wife for putting up with 2 sets of left and right speakers at the front of the family room.
Kaptain Karl is offline
post #71 of 36610 Old 02-12-2006, 05:40 PM - Thread Starter
Gators2001,
I would set the Mythos ones to small, then listen to a 20Hz to 200Hz sweep, and if you are set to small and cut em off at 60Hz and hear a dip in the voume try setting them to 80Hz.
20Hz to 200Hz sweep can be found on the THX Optomizer discs (Star Wars I, II, III, or T2 Dual Disc Set)
~Bob
post #72 of 36610 Old 02-13-2006, 01:15 AM
What i was wondering is how the subwoofers in the 7002's work alongside the standalone sub. I'm gonna be using the subwoofers in the Front and Center speakers along with the SuperCube II, so how does all that sub stuff get dispersed? I mean there is obviously the channel off for the sub, but how do you wire or set the 02's to get that sub channel as well? lol i'm pretty clueless on this. I'll be pairing it with a Yamaha 5990, and have no idea about these settings or issuses, any info could help
post #73 of 36610 Old 02-13-2006, 05:00 AM
J.H.'s Avatar
Thats the setup I have 7002's mains and SCII and it sounds great. The low end bass fills the entire room. It covers the entire room with low end. I like having the room filled with bass. J.H.
J.H. is offline
post #74 of 36610 Old 02-13-2006, 10:36 AM
SJac's Avatar
Originally Posted by Scott Tucker View Post
BP7000sc mains
CLR3000 center
4 BPVX surrounds
Love the set up for movies and concert DVD's.
Scott
Scott,
What kind of Reciever you use with this? HOw long have you been using this? I was considering the same combinaton with Yamaha RXV 2600. Thansk in advance.
SJac is offline
post #75 of 36610 Old 02-13-2006, 10:47 AM
g_bartman's Avatar
Quoted: 158 Post(s)
Liked: 132
I have 2002tl's which is an older version of the 7002. I have a c/l/r 2300 and an svs 25-31 pci sub. I have z series monster wire to the mains, no lfe. I have my yamaha receiver set to large for the mains, volume for the built in subs at 12 o'clock. I have the clr 2300 set up the same. lfe is going to the svs, xover @ 60hz. That is the best set up that I found......
g_bartman is offline
post #76 of 36610 Old 02-14-2006, 02:38 AM
I'll have to try that when i get my setup, but what i'm wondering is how to get those LFE's over to those Front and Center Speakers to use their subwoofer, that is what i'm clueless on, also this "Large" setting, what would this be?
post #77 of 36610 Old 02-14-2006, 06:59 AM
horrorfan2112's Avatar
I have a def tech system, I have bp10b in the front a clr2500 , and bp2x in the back . I am running 300 watts into the center 250 each into the fronts both carver amps . and I am using my yamaha receiver to power the rears. I also am using a SVS pb12+/2 . I love that bipolar sound I have been a fan since the very early 90s when I bought def techs first speaker the bp10 .
horrorfan2112 is offline
post #78 of 36610 Old 02-14-2006, 11:16 AM
Sorny's Avatar
No current pics, but my setup is as follows:
3x CLR2002 (FL, C, FR)
2x BP2x (SL & SR)
2x BP1.2x (SBL & SBR)
2x HSU TN1220HO subs
Powered by a Sunfire Cinema Grand (front 3 and both HSU TN1220HO subs), Pioneer Elite VSX-45tx for the surrounds. I also use a Pioneer Elite DV-45A to feed it DVD-A and SACD...
I've got a pair of SM350's in the shop getting new crossovers. Apparently the SM350's don't like playing NIN at reference level when fed with my Sunfire amp... I like using 3 CLR2002's instead of the SM350's and a single CLR2002 as far as sound goes. The CLR2002 is not nearly appreciated as much as it should be, IMHO.
Sorny
Sorny is offline
post #79 of 36610 Old 02-15-2006, 08:12 AM
BashOgreBash's Avatar
i would like to visit your showroom... where in NY are you located?
BashOgreBash is offline
post #80 of 36610 Old 02-15-2006, 06:40 PM
Adz523's Avatar
Sure, I sent you a PM (private message). I am on the Mahwah border in NY.
Adz
Adz523 is offline
post #81 of 36610 Old 02-16-2006, 05:14 AM
PULLIAMM's Avatar
I have been using my BP10's as surround speakers, which is kind of like shooting a butterfly with an elephant gun. Meanwhile, I have been using my Athena F1's in my stereo system (separate room.) I have decided to switch them. Hopefully, the F1's will be sufficient for surround while the BP10's should sound awesome for music.
PULLIAMM is offline
post #82 of 36610 Old 02-16-2006, 01:24 PM
I'm pretty possotive that I have decided on get a pair of 7002's, a C/L/R 2300, and BPX surrounds, paired with a Yamaha 5990 reciever, however i do know it is overkill for my room, but i am wondering how the sound acustics or sound in general will sound in my room. My room is only 12X11 so i know there is alot more sound then is needed, but basically all that is in my room is my bed and my 51inch Toshiba, and my computer, but there is definatly direct places for them,but will it actually sound worse due to the size of the room or should I be fine with that setup. After hearing the 7002's in comparison to the others, it would suck to have to go down to the 06's due to room size
any opinions would be apreciated.
post #83 of 36610 Old 02-16-2006, 02:40 PM
also would a Supercube II be a good decision on a sub, especially if i'm pressed for space?
post #84 of 36610 Old 02-16-2006, 09:59 PM - Thread Starter
ISupermanI for the size room I think that 7002s + 2300 would be more than ample, if HAD to go 7006s Supercube II is suggested to add more power to the sub 30Hz. But with 7002s ina 12x12 room thats more then enough and maybe add a Buttkicker.
~Bob
post #85 of 36610 Old 02-16-2006, 10:09 PM
CraigW's Avatar
My setup consists of the following:
BP10B - mains
CLR2000 - center
BP-2X - surrounds
PM100 - rear surrounds (just added to complete the 7.1 setup)
Only my sub is not a DT which is an OK 10-in Velodyne CT100.
CraigW is offline
post #86 of 36610 Old 02-17-2006, 05:36 AM
PULLIAMM's Avatar
It turns out that the BP8's sound better in my room (18' x 20'). There is such a thing as too much bass, after all.
PULLIAMM is offline
post #87 of 36610 Old 02-20-2006, 02:39 PM
kaosv1's Avatar
BP3000 mains- BPVX rears, BP2x rear center, CLR2000 front center, 15tl sub. Powered by a Sony 3A-es ......ordered the new Denon AVR2807. Room demensions 15x24
Bought my first set in 1990 the same year they opened their doors. I gave my son a set of 100 pro monitors, BP8's and a older model center channel. Still playing solid and clean.....and my old Sony 808ES .....
Next upgrade will be a Trinity Sub and the Butt kicker setup......
kaosv1 is offline
post #88 of 36610 Old 02-23-2006, 10:59 AM
evanhunter's Avatar
I am trying to find the right steup for a room which has vaulted ceiling and is attached to a large dining room.
I am considering this setup below
Definitive Technology Mythos Five FloorStanding Tower Speakers (can't afford the Fours)
Definitive Technology Mythos Three Center Speaker
Definitive Technology Mythos Gem
The system will be run on a Denon 3805 receiver. the listening area is about 15 feet. the listening area is about 10 feet from the tv and mains
evanhunter is offline
post #89 of 36610 Old 02-23-2006, 11:07 AM
J.H.'s Avatar
I think that setup would sound great but you need a sub as the mythos line does not have built in subs. You need low end bass from a dedicated sub. If you can't get a definitive sub I would look at SVS subs HSU subs. Cheap and good bang for the buck. Hope that helps. J.H.
J.H. is offline
post #90 of 36610 Old 02-23-2006, 07:27 PM
~Bob
so i saw it mentioned again up there, but what is/ment by Buttkicker?
Reply Speakers
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
