Definitive Owners Thread - Page 352 - AVS Forum | Home Theater Discussions And Reviews
 368Likes
Old 01-27-2009, 11:47 AM
webcrawlr's Avatar
Originally Posted by otk View Post
where do you keep your crossover setting ?
120hz is the upper limit of the LFE channel which is a digital brick-wall
by spec, the LFE channel also goes down to 3hz and the only way to do that is with a massive array of sealed subs or an IB (which is also a sealed alignment) or a rotary sub
Knowing that there's the possibility that content can go up to 120hz on the LFE channel I keep my low pass filter set to 120hz.
webcrawlr is offline
Old 01-27-2009, 11:50 AM
cliff257's Avatar
NO more reading just give an answer. You have thrown a new sub into the mix the av123 mfw-15. I guess i have all the info I just need to make a decision. More opinions would be good too.
Been reading about the things I need to integrate this sub into my system(something I've never done). Umm Behringer, Mic, REW, ect. Can someone give me a list of the things I need. Thanks
Cliff
cliff257 is offline
Old 01-27-2009, 12:37 PM
g_bartman's Avatar
Quoted: 145 Post(s)
Liked: 122
[quote=cliff257;15665617]NO more reading just give an answer. You have thrown a new sub into the mix the av123 mfw-15. I guess i have all the info I just need to make a decision. More opinions would be good too.
I have the same speakers as you with 2 bp20's for rears. My ht is in a medium size basement, not sure of the exact sf. The theater area is 14.5 x 28with 7.5' ceiling. It is open to aditional sf. I have a earthquake supernova mkIV-10 up front and an svs 25-31pci 3' behind the main listening seats. For my expectations, I have more then enough lf output in the room. I am not currently looking to upgrade my lf. That may change some day. If I could get a trinity for 1700, I would have to consider it. The mfw-15 are very tempting but have had some qc issues with the amps. svs makes many good subs, i would not hesitate to go with them. The epik knights look good too. If I had no subs and were in the same boat as you, I don't know what I'd get. Probably would try the knights if they had a good return policy.
Here is a link if you are curious....
http://s231.photobucket.com/albums/ee316/speakerman_ht/
g_bartman is offline
Old 01-27-2009, 12:41 PM
mrted46's Avatar
Quoted: 30 Post(s)
[quote=g_bartman;15666134]
I have the same speakers as you with 2 bp20's for rears. My ht is in a medium size basement, not sure of the exact sf. The theater area is 14.5 x 28with 7.5' ceiling. It is open to aditional sf. I have a earthquake supernova mkIV-10 up front and an svs 25-31pci 3' behind the main listening seats. For my expectations, I have more then enough lf output in the room. I am not currently looking to upgrade my lf for now. That may change some day. If I could get a trinity for 1700, I would have to consider it. The mfw-15 are very tempting but have had some qc issues with the amps. svs makes many good subs, i would not hesitate to go with them. The epik knights look good too. If I had no subs and were in the same boat as you, I don't know what I'd get. Probably would try the knights if they had a good return policy.
I hear Epik conquest is the way to go. After reading some posts in the subwoofer forum, I am saving up to buy one of those. I believe it is cheaper than the trinity (after discount) and can hit low frequencies with ease.
mrted46 is offline
Old 01-27-2009, 12:46 PM
g_bartman's Avatar
Quoted: 145 Post(s)
Liked: 122
[quote=mrted46;15666186]
Yeah, they are suposed to be unbelieveable. I suggested the knights (a pair) because he said the conquest is too big in a earlier post.
Old 01-27-2009, 01:10 PM
otk
otk's Avatar
i heard Epik isn't currently taking any orders but you should check with them directly if you can
i also hear the av-123 sub has a lot of issues and some very unhappy customers (to be fair, they also have a lot of happy customers as well)
All this noise about noise.
Finding the acoustic sweet spot.
otk is offline
Old 01-27-2009, 01:11 PM
progprog's Avatar
Cliff
I haven't seen you mention the SC Reference. Any particular reason for excluding it? I have almost exactly the same setup as you, and I added a Ref a few months ago. It made a huge difference and I really love it. (Got it open box for $900.)
progprog is offline
Old 01-27-2009, 01:27 PM
Macfan424's Avatar
...Been reading about the things I need to integrate this sub into my system(something I've never done). Umm Behringer, Mic, REW, ect...
Since you don't seem to be on a tight budget, I'd recommend you consider a Velodyne SMS-1 with whatever sub you choose. It does a wonderful job of easing integration as well as helping alleviate room problems. And it's much easier to use than some of the other solutions mentioned.
Macfan424 is offline
Old 01-27-2009, 02:48 PM
cliff257's Avatar
Not that money is no issue but i dont believe I will spend the money on the sms-1 when I hear avia will do fine or the other I mentioned for only $250 as a kit.
Well when otk says he would get a trinity over 2 ref's I nulled that out. I've heard an f112 but want f113 so I can speak on it. But have only heard good things about the trinity. And dual pb13 for the price of those other two is really nice. Havent looked at epik but dont wont the huge conquest and the others are quite large too. The Knights have the same cab. as the castle so i suppose the castle would be a close comparison.
Bottom line love my def tech would like to buy the trinity even at msrp so thats my budget. If i could get the trinity for 2200 or less that means i would have to buy two. Would that be overkill?
cliff257 is offline
Old 01-27-2009, 03:08 PM
progprog's Avatar
Some people believe there's no such thing as too much bass. I'm not one of them. I've heard setups with big, overblown bass that the owner thought was "awesome" and it just sounds awful to me. I find that ONE Reference can sometimes be almost overwhelming- movies like The Dark Knight and The Hulk can literally pound you in the chest and shake the foundation.
progprog is offline
Old 01-27-2009, 03:30 PM
headedforhighend's Avatar
Buying duals would not be considered overkill with the added benefits they bring to the room, but maybe not necessary with the quality of subs you're considering. If this came down to a two party election, I believe the favorites would have to be the Trinity and the PB13Ultra. Granted, the Fathoms have been the torch bearers in the past, but todays sub manufacturers produce subs quite comparable in performance and let's not forget... you wouldn't want to be missing the lows. An Epik sub woofer would be in consideration due to it's price versus performance, but your ship date would more likely be found in the Book of Revelations. The Trinity and Ultra would give you what I believe you're looking for and whichever one you had, you would never ever consider for a moment if you made the right decision. The added feature of optional tuning including seal mode makes the Ultra very versatile.
'It's not what you don't know that hurts you; It's what you know, that just ain't so.'
headedforhighend is offline
Old 01-27-2009, 04:11 PM
DoingOK's Avatar
It's too bad Epik is so backlogged.........my Epik Castle works very well with my Mythos system. I was lucky that I had the space to build it into the wall under the stairs so it wouldn't impede on our living space. Great thunderous yet articulate sub.
DoingOK is offline
Old 01-27-2009, 05:09 PM
otk
otk's Avatar
i think what people mean when they say you can never have too much sub is headroom and also, the more subs you have in more locations, the smoother the response will be in room
you can have 100 subs, as long as each channel and each frequency is calibrated to the same level, it will sound awesome. another thing is the more subs you have, the less each driver has to work which means less distortion at higher levels
also, with sealed subs, the more you add, the lower you can EQ them
1 or 2 subs is all most people will need in most rooms. i've been watching a lot of movies lately with just my towers and my extra subs turned off and i'm blown away by what two 15 year old towers can do with no extra subs helping out
otk is offline
Old 01-27-2009, 05:44 PM
cliff257's Avatar
Yep all i got are the sc's in the towers and i thought that was what bass was. Did some shopping heard a couple of custom systems, a 600w yamaha and a jl f112. After that I realize I dont know what low bass is for home audio.
I'm in search for that low bass and have done a lot of reading and see that multiple subs in multiple location is best. 2 now for HT and 2 later for stereo, I believe that will do it. The 2 for stereo will be the JL's. So now I'm thinking 2 ref's or 2 pb13? I believe 2 trinity's will be overkill? Thanks for all the feedback, keep going!
cliff257 is offline
Old 01-27-2009, 05:59 PM
otk
otk's Avatar
i was thinking of that also, dual trinitys for HT and dual JL's for music
or just do this. go to your JL dealer and see what kind of deal you can get on dual JL F212's and just be done with it
otk is offline
Old 01-27-2009, 06:22 PM
lefthandluke's Avatar
Quoted: 137 Post(s)
Liked: 266
cliff, believe me brother, i feel your pain...
first tho, i've never heard either fathom sub or the pb13, but geez, i have read nothing but praise, HIGH praise for any of those three subs...i don't think the word "unhappy" would come into play with picking any of those...
i do, however, own two trinity subs, and i can't give a higher recommendation than i would give the trinity. it goes deep, it hits hard and has unbelievable output.
otk has assembled craigsubs thoughts on the trinity, i suggest you give that a read, as well as his comments on the other subs you're considering...
as for two being overkill...well, it may be, it just depends what you're after. like otk said, adding another gives you more headroom (less distortion) and the ability to smooth your room response (altho i do use an sms-1 to help me, fantastic tool)...tho adding a second is not as dramatic as adding the first, i think, as with any sub, once you experience two, it's tough to go back to one...
at the zenith of his nadir...
lefthandluke is offline
Old 01-27-2009, 06:26 PM
cliff257's Avatar
Ha on the same page!!! Really I would like 4 f113 but im gonna go with def tech for the HT, cant go wrong with that I believe so I guess the question is 2 ref's or 2 trinity's.
I can get a great deal on the JL's but still not 30% the msrp of the trinity or ref's. I'm considering ref's to save money and get the sms-1 or the a.r.o. any opinions??
Is two trinity's overkill?
cliff257 is offline
Old 01-27-2009, 06:46 PM
otk
otk's Avatar
when you add a 2nd sub and stack them on top of each other or side by side, you gain no more than 6db extra output by adding the 2nd sub
when you add a 2nd sub and place them apart from each other like one on each side of your room, you'll get an average of 3 extra db of output depending on room size and acoustics. sometimes you'll get a little more than 3db sometimes a little less depending on many variables but the important part of adding a 2nd sub is the smoothing of peaks and dips in frequencies response
adding the first trinity will let you know the beast has arrived. adding a 2nd will smooth him out a bit and give him some extra bite when needed
not only does the trinity go louder than the reference but it also goes a tad lower
the trinity is flat to 16hz +/-3db @ 1 meter no wall reflections but mic was on the floor so there were some floor reflections
the reference is close @ 18hz +/-3db @ 1 meter no wall reflections but mic was on the floor so there were some floor reflections
those are def tech measurements from chet at def tech
also cliff, have you considered this system ?
http://www.hsuresearch.com/products/uls15quaddrive.html
$3999 for 4 of HSU brand new sealed 15" subs
i haven't heard them yet but the new owners seem to love them (even the singles and duals)
here's another ID company who sells sealed subs that i hear a lot of good things about
http://www.rythmikaudio.com/products1.html
those are also sold through Ascend Acoustics
http://www.ascendacoustics.com/pages.../subintro.html
lots of choices
otk is offline
Old 01-27-2009, 06:58 PM
Quoted: 137 Post(s)
Liked: 266
...read post above yours about trinity overkill
well, i also have two references, and while a reference on each side of the room is a sweet setup, you will notice the diff with two trinity's...
i think def tech's raising the price of the reference to 1899.00 makes it a little less attractive as an option...
Old 01-27-2009, 07:16 PM
otk
otk's Avatar
lefthandluke, your system must rock
otk is offline
Old 01-27-2009, 07:35 PM
Quoted: 137 Post(s)
Liked: 266
always tweaking otk, always tweaking...
just ordered a hsu mbm-12...can't wait to play around with that!!
got 30 days to see if i can reach nirvana...
Old 01-27-2009, 07:51 PM
otk
otk's Avatar
just when i thought i couldn't get even more jealous
otk is offline
Old 01-27-2009, 08:33 PM
Quoted: 137 Post(s)
Liked: 266
um, wait a minute here...
you've got eleven 15" sealed subs
whose the jealous one...?
Old 01-27-2009, 09:01 PM
inhertenderlips's Avatar
just because we are on the topic of ridiculous sub setups, I thought I'd link this one for you all to drool over. http://www.wilsonaudio.com/product/thor/ It's over 400 pounds!!
otk, and lefthandluke, question for you. Do you guys ever just crank some death metal up to eleven and see how long you can keep air in your lungs?
Have you found the brown note?
inhertenderlips is offline
Old 01-27-2009, 09:21 PM
Quoted: 137 Post(s)
Liked: 266
59" x 25" x 20", 412 lbs...relatively compact?...that thing sounds like a monster!
not a big death metal fan...sepultura...six feet under...pantera, my son luv's 'em
ac/dc...metallica...kid rock...green day...pixies, oh yeah, i've been known to crank those on occasion
Old 01-27-2009, 09:33 PM
lightguy's Avatar
Just some thoughts on my decision making process;
Subs considered; Started off at the SVS PC12 NSD at $550 on sale.
I think that sub would have been just fine. But....
The mind started going; "If your going to do this and never ask what if... Then get a Big Boy and be done with it".
Enter the realm of Super Subs;
Epik Conquest
SVS PBandC 13 Ultras
Def Tech Trinity
HSU 15
and others.
After researching and agonizing over this I ended up with the Trinity for these reasons;
1. I actually could audition it, and it sounded killer. There is something to be said about brick and mortar stores. Your going to pay a bit more but the product is a given. And if there are problems you know where to go.
2. I got it for a very good price. An ID comparable price. Look around, call dealers, some are hungry, some arent. You never know till you ask.
3. The craigsub reviews, otk and others here at AVS advice, and other professionals reviews such as this;
http://www.avrev.com/home-theater-lo...subwoofer.html
all said the Trinity is a very special speaker.
4. Resale. If I ever completely loose my mind and want to upgrade, Def Tech has a well earned and respected brand name which translates into holding its value. I love my new hobby but it has to make financial sense. Yeah... right...
In all honesty I've never heard the rest, just read the specs and I'm sure they are all great. Its just that the Trinity made the most sense to me.
lightguy is offline
Old 01-27-2009, 09:44 PM
lightguy's Avatar
And if you do get a Trinity please post a note here;
http://www.avsforum.com/avs-vb/showthread.php?t=1113395
Other subs have their own threads like the SVS 13's and Epik ( the only one available these days is the Conquest, if that.)
This very special sub deserves some praise. Hope you feel the same way.
lightguy is offline
Old 01-27-2009, 09:47 PM
Quoted: 137 Post(s)
Liked: 266
lightguy...
we've all been there...after agonizing over countless details, you finally pulled the trigger
now you've got the need to validate your purchase...
trust me when i say "you done good"
Old 01-27-2009, 09:55 PM
lightguy's Avatar
lightguy...
You have no idea what my AVS receiver purchasing process was like. Sub was a piece of cake
lightguy is offline
Old 01-27-2009, 10:20 PM
cliff257's Avatar
AVR was easy for me cause i always had a dream since the first day I bought my def tech in the 90's. My dealer had them powering my old setup and i knew I had to have it. I finally got it now I inspire to hear some low low bass!! You guys have helped so much but will damage the wallet!!
Gimme the low down on the trinity versus the ref's if you guys could. Going to demo a pair this weekend.
cliff257 is offline
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
