Definitive Owners Thread - Page 873 - AVS Forum | Home Theater Discussions And Reviews
 368Likes
post #26161 of 35304 Old 03-18-2012, 08:50 PM
LowTech1's Avatar
Quoted: 1144 Post(s)
Liked: 269
Thanks for the tip josh What about speaker calibration and crossovers?
LowTech1 is offline
post #26162 of 35304 Old 03-18-2012, 09:02 PM
laeriq's Avatar
Quoted: 64 Post(s)
Liked: 90
What receiver are you using?
laeriq is online now
post #26163 of 35304 Old 03-18-2012, 09:06 PM
LowTech1's Avatar
Liked: 269
Onkyo 805
LowTech1 is offline
post #26164 of 35304 Old 03-18-2012, 09:14 PM
laeriq's Avatar
Quoted: 64 Post(s)
Liked: 90
Onkyo 805
Have you looked at the Audyssey thread? Off the top of my head first thing I would do is set the front three back to small with an 80 crossover. Audyssey works fine with my bipolars so it's probably a setup issue.
post #26165 of 35304 Old 03-18-2012, 09:16 PM
LowTech1's Avatar
Liked: 269
audyssey set them up all large..
LowTech1 is offline
post #26166 of 35304 Old 03-18-2012, 09:23 PM
laeriq's Avatar
Quoted: 64 Post(s)
Liked: 90
Yeah it does that with most badass def techs. Look at the Audyssey thread or even google ask Audyssey...9 times out of 10 they recommend all speakers set to small regardless of what the calibration says. You're using an outboard sub right? If so definitely try the fronts as small.
post #26167 of 35304 Old 03-18-2012, 09:27 PM
LowTech1's Avatar
Liked: 269
Yes I have a Klipsch 12" down firing sub.. My onkyo doesn't have settings for small per se'.. Just hz.. Why set them to small?
LowTech1 is offline
post #26168 of 35304 Old 03-18-2012, 09:32 PM
josh6113's Avatar
Quoted: 16 Post(s)
Liked: 25
don't set them small...otherwise the subs in your towers are wasted in my opinion....leave them large and let them do there thing...
Doing what I do best...LIVIN!
josh6113 is offline
post #26169 of 35304 Old 03-18-2012, 09:40 PM
LowTech1's Avatar
Liked: 269
I agree with that Josh. It doesn't make sense to neuter the subs.. Unless that doesn't affect them.
LowTech1 is offline
post #26170 of 35304 Old 03-18-2012, 09:40 PM
laeriq's Avatar
Quoted: 64 Post(s)
Liked: 90
https://audyssey.zendesk.com/entries...udyssey-set-up
Straight from the horses mouth. Check the Audyssey thread out and you'll find lots of knowledgeable, helpful folks over there. I'm also going to guess the onkyo will let you adjust speaker size....apparently you have to choose a certain crossover for the onkyo to consider a speaker large or small. Weird...
post #26171 of 35304 Old 03-18-2012, 09:46 PM
laeriq's Avatar
Quoted: 64 Post(s)
Liked: 90
check out the bass management link on the ask audyssey site. I think it will clear some things up for you guys
post #26172 of 35304 Old 03-18-2012, 10:16 PM
LowTech1's Avatar
Liked: 269
So what would be considered small on my onkyo.. There is no small setting,just 40hz and up..
LowTech1 is offline
post #26173 of 35304 Old 03-18-2012, 10:19 PM
laeriq's Avatar
Quoted: 64 Post(s)
Liked: 90
Got me there. Im a denon owner. Might head to the 805 thread and ask.
post #26174 of 35304 Old 03-18-2012, 10:27 PM
KJSmitty's Avatar
Liked: 34
40hz is actually a great setting for the powered DT towers. Everything below 40hz would then be directed to your sub(s). Set at 40hz you're not neutering your towers. Rather just running them where they really shine - the rest/lower goes to your sub where hopefully it really shines.... :-)
Cheers.
Love DIY
KJSmitty is offline
post #26175 of 35304 Old 03-18-2012, 10:35 PM
LowTech1's Avatar
Liked: 269
Now that makes sense Smitty..
LowTech1 is offline
post #26176 of 35304 Old 03-19-2012, 07:16 AM
Joe@Definitive's Avatar
Originally Posted by otk View Post
of course and an acoustically transparent screen to put the 3 main bp7000s behind and a nice 4K projector
Don't forget to inlcude a nice home in the hills, with a great view, to enhance the listening experience...plus a fully stocked refrigerator.
Joe@Definitive is offline
post #26177 of 35304 Old 03-19-2012, 07:21 AM
The bipolar speakers bounce off the wall behind the speakers right? How far from the wall behind the speaker should the speaker be?
Hello Low,
We usually suggest 2-3 feet from the rear wall, and 2-3 feet from the side walls. But again, as per the discussion before, this is room dependent. They sound good closer to the walls too, but not all rooms (and significant others) can accomodate much distance from the walls. So the best suggestion is to experiment, and see what works in your room.
One of the benefits of the BP 8000 Series design is that they are a bit more "room friendly". The rear firing output is down by 6 db compared to the fronts, which makes them easier to place. I hope this helps - best, Joe
post #26178 of 35304 Old 03-19-2012, 08:45 AM
joepags's Avatar
Cheers.
+1. You beat me to it.
You need to look at the frequency response of the speakers and the sub. The crossover determines what frequency goes to the speaker vs the sub.
joepags is offline
post #26179 of 35304 Old 03-19-2012, 09:02 AM
badgerpilot's Avatar
Quoted: 73 Post(s)
Liked: 43
I generally run my towers(7001) at 40hz with my center(CLR1000b) and BPX's at 60hz. Small on an Onkyo is any crossover 40hz and up.
badgerpilot is offline
post #26180 of 35304 Old 03-19-2012, 12:23 PM
LowTech1's Avatar
Liked: 269
Thanks guys. What about my 8060HD center.. It has an 8" powered sub in it..
LowTech1 is offline
post #26181 of 35304 Old 03-19-2012, 12:38 PM
logicators's Avatar
Liked: 26
I have my CLR-3000 (with 10" sub) crossed at 60 Hz. KJSmitty and others have done the same.
logicators is offline
post #26182 of 35304 Old 03-19-2012, 12:44 PM
LowTech1's Avatar
Liked: 269
Cool ty,I'll try that..
LowTech1 is offline
post #26183 of 35304 Old 03-19-2012, 02:10 PM
thebriman's Avatar
Because my pioneer reciever only supports a single global crossover setting I use 50hz for all channels. If I could cross each channel individually I would also run my 8060hd at 60hz and the towers at 40hz.
thebriman is offline
post #26184 of 35304 Old 03-19-2012, 02:39 PM
g_bartman's Avatar
Quoted: 145 Post(s)
Liked: 122
I used to hve an Onkyo 805 driving my 7001's, clr 3000's bp20's and bpvx's. I also had three subs at the time. Audyssey set my 01's to large, I changed that to 40hz. It set my 3k to large, I changed it to 60 hz. It set the bpvx's to 60, I left that, set my 20's to 40, left that.
g_bartman is offline
post #26185 of 35304 Old 03-19-2012, 02:39 PM
LowTech1's Avatar
Liked: 269
Wouldn't it make sense to put the rear of the 8060st's right in front of the wall ,wouldn't that disperse the sound better?
LowTech1 is offline
post #26186 of 35304 Old 03-19-2012, 06:57 PM
destiny 21's Avatar
Quoted: 12 Post(s)
which do you think are better tower speakers def tech bp 10s or energy rc 50
destiny 21 is offline
post #26187 of 35304 Old 03-20-2012, 04:55 AM
MacdaddyPS's Avatar
No one has bought the new bookshelf speakers?
No reviews yet?
MacdaddyPS is offline
post #26188 of 35304 Old 03-20-2012, 07:46 AM
No reviews yet?
Hi Mac Daddy, we have already sold out of the first production run. We are trying like mad to build more, as we have plenty of orders. I will post the reviews next (although you are looking for AVS reviewers, I'd guess). Best, Joe
post #26189 of 35304 Old 03-20-2012, 07:50 AM
Hello Low, we usually recommend 2-3 feet away from the back and side walls for the BP 8000 series products. They have rear-firing drivers, and the sound stage is noticeably better when you pull them out a bit. If you mean the CS 8060 HD center channel (which is not bipolar, but forward-firing), even a conventional speaker may sound a bit better if it isn't butted up against a wall or cabinet. I hope this helps - best, Joe
post #26190 of 35304 Old 03-20-2012, 09:56 AM
Quoted: 73 Post(s)
Liked: 43
If anybody is looking for SM350's, NEWEGG has them half price for a pair with code EMCNGHN32.
Reply Speakers
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
