Definitive Owners Thread - Page 874 - AVS Forum | Home Theater Discussions And Reviews
 352Likes
Old 03-20-2012, 10:26 AM
LowTech1's Avatar
Quoted: 1140 Post(s)
Liked: 269
Originally Posted by Joe@Definitive View Post
Hello Low, we usually recommend 2-3 feet away from the back and side walls for the BP 8000 series products. They have rear-firing drivers, and the sound stage is noticeably better when you pull them out a bit. If you mean the CS 8060 HD center channel (which is not bipolar, but forward-firing), even a conventional speaker may sound a bit better if it isn't butted up against a wall or cabinet. I hope this helps - best, Joe
I kind of thought that,thank you Joe. Do the rear firing drivers really make any difference?
LowTech1 is online now
Old 03-20-2012, 11:21 AM
logicators's Avatar
Liked: 26
No, definitive just felt like adding them
In seriousness, the rear drivers make a significant difference in quality, but at the same time, they make placement / distance from the wall more critical to tune. That seems to be the reason why definitive moved from a full set of drivers on the rear to the half set (essentially making bipolar speakers sound somewhat closer to the Mythos line, while still keeping some bipolar advantage).
logicators is offline
Old 03-20-2012, 12:00 PM
LowTech1's Avatar
Liked: 269
How do you guys have them positioned? Toed in? Not toed in? I have the left one about a foot from the side wall.. The right speaker has no side wall..
Old 03-20-2012, 02:23 PM
thebriman's Avatar
I have mine toed in slightly.
thebriman is offline
Old 03-20-2012, 05:50 PM
LowTech1's Avatar
Liked: 269
That's how I have mine.. But if they are toed in,how is the rear supposed to bounce off the walls at you or around you?
Old 03-20-2012, 07:18 PM
KJSmitty's Avatar
Liked: 34
Only Definitive knows that,,,, and it's a secret.. :-)
Perpendicular may be best in regards to the overall bipolar action yet toeing them in helps with localization. That way you get the direct radiating benefits as well as a dispersed front sound stage.
Try them both ways and see what you think. Depending on the room/surroundings it's just another way of tweaking your preferences etc.
Cheers
Love DIY
KJSmitty is offline
Old 03-21-2012, 09:23 AM
LowTech1's Avatar
Liked: 269
I moved the speakers forward a little and toed them in just a touch and WOW! I was watching Hawaii five O last night and the sound stage was incredible. It sounded like one large sound stage. My girl even commented on it.. Watched a little Tron Legacy.. Had the buttkicker hooked up to the couch also..WOW again! Just sounded and felt crazy..
Old 03-21-2012, 09:46 AM
KJSmitty's Avatar
Liked: 34
Awesome!
Nothing better than when you make a tweak and you get immediate noticeable/positive changes! I've never experienced the buttkickers but I bet that's quite the effects/enhancer.
Cheers
Love DIY
KJSmitty is offline
Old 03-21-2012, 10:05 AM
LowTech1's Avatar
Liked: 269
Smitty,don't even hesitate and get one.. I'd get the blue one tho.. I have the advance. The LFE one is more heavy duty.. I just couldn't believe there was no gap in the sound stage up front..It was cool..
Old 03-21-2012, 10:47 AM
badgerpilot's Avatar
Quoted: 73 Post(s)
Liked: 43
Another happy DEF TECH owner Sound stage is definitely a Def Tech strength! Glad you are enjoying them.
badgerpilot is offline
Old 03-21-2012, 12:20 PM
Shadow Jack's Avatar
Yeah, I don't even watch Hawaii 5-0 but I'll record it every once in a while just to enjoy the sound. One of the best sound designs and mixes on television.
Shadow Jack is offline
Old 03-21-2012, 12:23 PM
LowTech1's Avatar
Liked: 269
That and believe it or not Chuck.. I have the last one tapped just so I can hear the sound track. Why don't all stations sound like that?
Old 03-21-2012, 01:28 PM
Drivingrain's Avatar
Im considering the following setup to go with a Marantz SR5006 AVR and could use some feedback.
I'll be going to 7.1 with:
ProCinema 600 5.1 Speaker System
plus
2x Studio Monitor 45 Bookshelfs to use as L and R fronts
It's a small room which drove the need for a smaller setup. It was built in 1850 with thick walls that can break your hand if you punch them.
Is the pairing of the 45s with the 600s ok? Does the setup of the Marantz SR5006 and these speakers make sense? Meaning....will the setup allow both AVR and speakers to reach enough of their respective potentials to make sense?
Drivingrain is offline
Old 03-22-2012, 07:00 AM
logicators's Avatar
Liked: 26
plus
I don't think that anyone here have tried that combination but in general it's not advisable to mix speakers from different generations. You might be ok with using promonitors as surrounds but the center channel may not blend well with the new studio monitors. Perhaps you should consider getting a matching center?
Marantz SR5006 is a pretty good receiver and it can handle much bigger speakers with ease so you should be ok.
Let us know your impression of the new SMs!
Old 03-22-2012, 07:49 AM
LowTech1's Avatar
Liked: 269
Has anyone had Mirage speakers and switched to def tech? And if you did,why? I'm just curious..Or what made you switch from your other speakers you had previously?
Old 03-22-2012, 08:08 AM
Thanks, will do.
What center speaker would be the best match? I dont see one in the Definitive lineup that matches the SM by name.
http://www.definitivetech.com/produc...torSeries.aspx
Given that I wanted real fronts and real center, given my space constraints, this seemed to be the best-non-matched solution. But maybe I missed a different small-form-factor bookshelf and/or center combo that would be a better match?
Old 03-22-2012, 08:29 AM
Quoted: 73 Post(s)
Liked: 43
Thanks, will do.
When you go to your link, select the SM45's, and then scroll down to find the link to the system recommendations. You will see that the CS-8040HD Center is recommended.
Old 03-22-2012, 08:57 AM
Thanks. That's perfect, though a good chunk of change for that center. I might be forced to stick with the Pro Cinema for a while b/c of budget; though would the newer 400 series be a better match to the SM than the older 600?
Old 03-22-2012, 01:54 PM
Joe@Definitive's Avatar
Hello Low, Smitty, Briman, Badger, Logic,
I chuckled a bit when I read these posts. Yes, it is great when you tweak your system a bit and it sounds much better. There's nothing wrong with buying new gear, but when you get a free upgrade - oh, yeah! Logicator talked about the newer bipolars having both the advantage of a big, realistic soundstage, yet having better imaging characteristics. The research pointed us to the 6 dB down point on the rear drivers. It really seems to work well. In my view, with all speaker placement: Experimenting is the key! Your room, how far away your main listening position is from the speakers, how the speakers are positioned vs. the rear and side walls - all influence the sound.
Now go buy UFO's "Strangers in the Night", and crank it as soon as your significant other goes out. Nothing like a little live rock n roll to get the blood flowing. Best, Joe
Joe@Definitive is offline
Old 03-22-2012, 02:08 PM
Quoted: 73 Post(s)
Liked: 43
I would save your money for the matching center or try to find a deal on one. In the long run, you'll save money because I can almost guarantee that you will want to upgrade/wonder what you are missing. You can always set up your system with a "phantom" center for now until you can afford the center. Def Tech's can be pretty good at creating a phantom center. I can't vouch for the SM45's but the BP's are excellent in that respect IMO. One other thing, your center speaker is probably the most important speaker in your system. The majority of a soundtrack comes through the center including nearly all dialog. Don't underestimate the importance of that. This is from someone who tried three Def Tech centers before I followed the advice on this thread and ended up with a very reasonable priced but incredible center, the CLR1000b.
Old 03-22-2012, 02:12 PM
LowTech1's Avatar
Liked: 269
Some dude told me on a different speaker thread that the subs in the Def techs were a gimmick.. What do you have to say about that Joe?
Old 03-22-2012, 02:14 PM
Quoted: 73 Post(s)
Liked: 43
Couldn't agree more! Set up is sooooo important. Experiment and suddenly you will have that silly grin moment!
Old 03-22-2012, 02:17 PM
Hello Driving,
The new SM 45's will make good left and right speakers for your ProCinema 600 system. They will have additional bottom end and a better midrange, but the mids and highs will be close enough that when the actors move from left to right or vice versa, it will transition smoothly. The new ProCinema 400 system is good, but not as good as the 600 system, so I would not suggest that direction. I hope this helps - best, Joe
Old 03-22-2012, 02:23 PM
Hello Low, I am chuckling again! If you read the independent reviews of the Mythos ST and STS, the BP 8000's, or way back to other speakers in our history, it is clear that they are no gimmick. Can adding high quality separate subs to a system that already has good bass from the main speakers make things even better? Sure - but for more money. Our powered Supertowers have a very high value proposition - good bang for the buck - which is why the reviews are so strong. I hope this helps - best, Joe
Old 03-22-2012, 02:30 PM
otk
otk's Avatar
was that dude talking about def tech towers or the long discontinued bpvx/p ?
All this noise about noise.
Finding the acoustic sweet spot.
otk is offline
Old 03-22-2012, 02:37 PM
LowTech1's Avatar
Liked: 269
Def tech towers.. Personally I love the subs. And when I add my 12" sub to the mix its even better.. I mean,seriously,the dude could not have ever heard these speakers or he would have never said that.
Old 03-22-2012, 03:55 PM
logicators's Avatar
Liked: 26
You can also consider a third sm45 as center. I have used three sm 450s in the front for more than a year (all mounted) and found that setup to sound a lot better than using two sm 450s as left / right and a procenter 1000.
Old 03-23-2012, 10:13 AM
LowTech1's Avatar
Liked: 269
I had a friend over to listen to the def techs last night.. He owns a home theater company. He was floored by the def techs.. He just loved them. He said the room sounded a lot bigger than it really was.. He said he runs audyssey and then dials in the speakers.. He's not a real believer in audyssey tho. I threw some music on and he just loved it. Said it puts his James speakers in this theater to shame..lol
Old 03-23-2012, 10:25 AM
Quoted: 73 Post(s)
Liked: 43
Lots of "experts" dismiss Def Tech. The reality is they have never heard them properly set up.
Old 03-23-2012, 10:27 AM
LowTech1's Avatar
Liked: 269
He was ranting and raving about the imaging.. Sounded like you were in a movie theater.. I told him I liked how cinematic they sounded and he agreed..
Definitive Technology , Definitive Technology Supercube Trinity , Definitive Technology Bpx Speaker Single Black , Definitive Technology Bpvx Speaker Single Black , Definitive Technology Supercube 2000 Subwoofer , Definitive Technology Super Cube 4000 Subwoofer , Definitive Technology Studiomonitor 350 Speakers , Definitive Technology Bp2x Speakers , Definitive Technology Mythos 6 Aluminum Stand , Marantz Sr7002 Surround Receiver , Receivers Amplifiers , Parasound , Definitive Technology Bp7004 , Speaker Systems
