Ascend SE Owner's Thread - Page 130 - AVS Forum | Home Theater Discussions And Reviews
 99Likes
post #3871 of 4206 Old 02-11-2014, 09:33 PM
Bond 007's Avatar
Quoted: 2594 Post(s)
Liked: 2056
If youre just as interested in music as you are movies and you want the best sound quality you can get I highly suggest the Sierra 1 over the 340. The S1 will provide better sq for music and will have plenty of output in a room that small.
Licence to Kill
Bond 007 is offline
post #3872 of 4206 Old 02-11-2014, 10:44 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4779
Trace79, my opinion is just that, as I haven't used the 340, but do have Sierra-1s (NrT), 170SEs & 200SEs. My general impression is that the 340 should be able to fill a larger room better than a Sierra1 from what I've read. I've been happy now in two fairly large rooms with the Sierra-1s performance, though I rock out occasionally, my higher volumes aren't usually music but is regularly for movies. Previous room (just recently moved) was something like 23 x 19 x 10; (high vaulted ceiling but adjusted) think 4500 cuft plus open to a stairwell/downstairs and often other rooms that had doors. My current living room is 32 x 15 x 8 plus an extra height and depth at one end so figure 4200 cuft, plus a fairly large opening to a good sized dining/kitchen area. I've got the Sierra-1s across the front, 170SEs as surrounds, 200SEs as rear surrounds. I think you'd be happy in your size room with the Sierras easily if you want to spend the coin but might give the edge to the 340 for the use you specify, and either would be a good decision.
lovinthehd is offline
post #3873 of 4206 Old 02-11-2014, 11:01 PM
Trace79's Avatar
Liked: 29
Thanks for the replies. I just checked out Newc33's thread posting the YouTube bids of his CMT-340's with dual RV15HP's and damn! Much bigger room and he was hitting 90dB from his MLP. I know its inaccurate to try and replay the sq so won't go off that. Sure sounded nice even through the recording though.
I'm guessing with the Sierra 1's I can expect a louder soundstage because of my small room. The CMP-340's would destroy though lol. Anyone know how much dB or SPL difference there would be roughly, between these two?
Here's the link just for future ref.http://www.avsforum.com/t/1517338/ascend-plus-rythmik-demo-vids-enjoy#post_24346206
Trace79 is offline
post #3874 of 4206 Old 02-12-2014, 03:42 AM
Bond 007's Avatar
Liked: 2056
Either one will handle more power than your AVR can put out if youre listening in a 5 channel mode. Lots of people use an external amp with them if you want ear bleeding sound levels. Id bet that Newc33 is using one. Your room is so small though that you would have to really want outrageous levels to need an external amp. But keep in mind its just as easy to damage speakers by clipping your amp as it is by giving them too much power.
Both speakers have very good sound quality. If youre looking for the loudest speaker with the best value I would get the 340. If youre really looking for the best sound quality then get the S1.
Licence to Kill
Bond 007 is offline
post #3875 of 4206 Old 02-12-2014, 05:14 AM
Trace79's Avatar
Liked: 29
I'm definitely learning towards the Sierra 1s for Ascend. I was reading in the Sierra thread and discovered the RAAL upgrade that's available. I love that concept as it will probably be used down the road. And right now I have no idea how loud I'll be able to push them stock but there is that 30 day demo to try them out and find out. SQ definitely reigns supreme over SPL so I'll give the 340's a pass I think.
The more I read about these the closer they sound in the reviews as a close comparison to SVS' Ultra bookshelfs which are slightly more expensive. Other factors to consider would be the Sierra 1 center vs the SVS Ultra center too as I'm going for a complete package with the SVS being about $300 more for the center channel.
Regarding the surrounds for Ascend and SVS both, I feel I'd be getting a different brand as SVS surrounds are a crazy $1200 but wall mountable and the Ascend 170's need too much room away from the wall due to the rear port :/.
Lastly, and I don't know how much of a difference this will make, but my sub will be an SVS PC12-Plus so it may integrate with the Ultras slightly better. The only critique I read on the Sierra1 was a slight lack of midrange but great bass. Of course, with a sub, the bass is null regardless of speaker.
I know I still have time to make a decision but these two are the highest contenders right now. When the time comes, and if the funds allow, I may just have to get both and sample them side by side smile.gif.
And then there is the Sierra 2 to think about as well smile.gif. The more I read about Ascend, the more respect I have for them as a company in general...same reasons I'm a fan of SVS. Going to be a tough one.
Trace79 is offline
post #3876 of 4206 Old 02-12-2014, 05:52 AM
lovinthehd's Avatar
Liked: 4779
The 200SE is a good surround and sealed so good with on wall mounting...
Sent from my SCH-I545 using Tapatalk
post #3877 of 4206 Old 02-12-2014, 06:05 AM
Bond 007's Avatar
Liked: 2056
Trace,
3" is too far away from the wall for the 170s? Lots of people have wall mounted them.
Licence to Kill
Bond 007 is offline
post #3878 of 4206 Old 02-12-2014, 08:41 AM
BCRSS's Avatar
Quoted: 250 Post(s)
Liked: 189
I have all my 170's wall mounted and think they look fine.
The Elusive 1099 (L/C/R)---6 DIY Volt 10 (surrounds 9.4)---SVS PB 12 Plus---SVS PC 12 Plus---2 DIY 18's sealed--2 Pico Wreckers (tapped horns)---AVR Denon 4311CI---Emotiva Xpa-3---Behringer Nu6000DSP & Nu3000DSP iNuke---TV Vizio 70---110" Motorized Screen---Epson 8350 Projector---Unraid Network Storage---Gateway SX 2370 HTPC with 120 SSD
BCRSS is online now
post #3879 of 4206 Old 02-12-2014, 10:12 AM
Bond 007's Avatar
Liked: 2056
Can you post a link to the mount you use?
Licence to Kill
Bond 007 is offline
post #3880 of 4206 Old 02-12-2014, 10:40 AM
BCRSS's Avatar
Quoted: 250 Post(s)
Liked: 189
These are the mounts I used since the Omni mounts were not available. They work good and I have had no problems with them.
2 Pack wall mounts
BCRSS is online now
post #3881 of 4206 Old 02-12-2014, 10:51 AM
Bond 007's Avatar
Liked: 2056
Bond 007 is offline
post #3882 of 4206 Old 02-12-2014, 02:00 PM
Trace79's Avatar
Liked: 29
Trace,
I was saying that based on another person's perspective that they needed about a foot of space from the wall. I suppose everyone has preferences. The 200SE looks more attractive but I've read people prefer the 170's performance over it though. Due to my small room, a small surround without small sound is ideal. I'll have to make a custom stand for the right surround too since that wall is brick and I am not allowed to drill into it. There's furniture there as well so that's why I say custom. Hence, a smaller surround is ideal.
Trace79 is offline
post #3883 of 4206 Old 02-12-2014, 02:14 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
As surrounds, the performance difference between the 170SE and 200SE is not a deal breaker IMO.
I use the 200SE as surrounds, and they are great. I used to use 170SE, but changed to the 200SE's due to mounting and aesthetics...and they haven't missed a beat. This is with Sierra-1's up front.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #3884 of 4206 Old 02-12-2014, 02:21 PM
Billy p's Avatar
Quoted: 302 Post(s)
Liked: 665
Hey Curtis....if you go with the S2 and replace your mains will you feel the same about the surrounds?
Btw...I use the 200se with the Towers....and like them plenty enough...just not sure how I would feel with the RAAL across the front.
Ascend Acoustics Towers: STC w RAAL, 200 SE in espresso,
54" of Panny Bliss, Anthem MRX 300, Oppo BDP-103D,
Apple TV+ Giga 1800
Sub FA 18: (Santos RW)
Indian proverb: We don't inherit the earth from our ancestors but we borrow it from our children!
Billy p is offline
post #3885 of 4206 Old 02-12-2014, 02:25 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
Good question. I don't know, and will have to deal with it when the time comes. If I can swing it, I would love to have S2's all the way around.
-curtis
cschang is offline
post #3886 of 4206 Old 02-12-2014, 03:11 PM
Trace79's Avatar
Liked: 29
I haven't found the S2's on the website. Are they released yet?
Trace79 is offline
post #3887 of 4206 Old 02-12-2014, 03:23 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
They are released, but not officially on the website.
There is a thread about them on the Ascend forum, with ordering info in the first post.
http://forum.ascendacoustics.com/showthread.php?4978-Sierra-2-Development-Thread
There is also a dedicated Sierra thread here on AVS that was started with the Sierra-1 almost 7 years ago:
http://www.avsforum.com/t/849859/the-official-ascend-acoustics-sierra-thread
-curtis
cschang is offline
post #3888 of 4206 Old 02-12-2014, 04:06 PM
Bond 007's Avatar
Liked: 2056
That explains it. I saw some discussion about the S2 over at Ascend and I thought someone even said they had received them. Cant wait to see some pictures and specs.
Licence to Kill
Bond 007 is offline
post #3889 of 4206 Old 02-12-2014, 04:17 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
There are pics and specs(measurements) in the Ascend thread I linked. Also pics in the Sierra thread here at AVS....that I also linked.
-curtis
cschang is offline
post #3890 of 4206 Old 02-12-2014, 04:19 PM
Bond 007's Avatar
Liked: 2056
Ahh..sorry. I didnt even click the links. Im running around about 10 different threads right now trying to help some people. I will check it out later.
Licence to Kill
Bond 007 is offline
post #3891 of 4206 Old 02-25-2014, 06:42 AM
Skylinestar's Avatar
Quoted: 1177 Post(s)
Liked: 213
Can the CMT340SE withstand loud playback at reference level (13feet distance to listening position)? How's the dynamic? Will it be suitable as HT speakers?
Anyone play it at reference level? Clean or distort?
Has anyone compare it against the Klipsch RB61 or RC62 or any of the Klipsch Synergy budget series?
Skylinestar is online now
post #3892 of 4206 Old 02-25-2014, 07:10 AM
pmanyon's Avatar
Quoted: 60 Post(s)
Liked: 32
I am considering these speakers (340se) to replace B & W sats. However, I am hesitant because I noticed that they haven't been refreshed in quite some time. Now I am leaning toward the new B & W refresh of the 600 series. (685's and a htm62 center). I have two questions:
1. How would the ascend 340se stack up against the B & W 685? Especially for that heavy sound and impact for HT use.
2. Do you guys think the 340se will be receiving a refresh soon? I noticed the sierra 2's just came out; aren't the 340 se's getting a little old (2005 I think). If there is no planned refresh, how do they stack up against today's bookshelf systems in the 1000-1500 dollar price range?
pmanyon is offline
post #3893 of 4206 Old 02-25-2014, 07:17 AM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3000
You do realize that speaker manufacturers like to do frequent "refreshes" to get loyal fans to upgrade more frequently. A good sounding speaker designed 10 years ago can still be a good sounding speaker today. So price/performance value is way more important than when the speaker was designed.
Also, if I am not mistaken, there is a lot of criticism of the center channels used with the B&W 600 series--you might want to look into that. On the other hand, the BEST center channel is one that is an exact match to the left and right, which is the same speaker, not the horizontal center channel that companies typically sell. With the CMT-340 SEs you get the exact same speaker in a center channel to give you a better match than you can get from manufacturer center channels like the HTM62.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3894 of 4206 Old 02-25-2014, 10:15 AM
pmanyon's Avatar
Quoted: 60 Post(s)
Liked: 32
Thanks for the response, would you say the 340se set is the best speaker for the dollar at that price? The reason I am asking about a refresh is because I would like to wait a little if there will be one soon. I do realize that these are usually marginal upgrades, but I like to buy products right when they are updated, so I don't feel like I could have made a better purchase if I waited a month.
pmanyon is offline
post #3895 of 4206 Old 02-25-2014, 10:19 AM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
The 340SE is probably Ascend's best "bang for the buck".
Something to keep in mind, for every Ascend speaker that has been "refreshed" since it's first speaker, the CBM-170, the older generation has been upgradeable to the newer generation.
-curtis
cschang is offline
post #3896 of 4206 Old 02-25-2014, 10:28 AM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
It is great for home theater...dynamic and loud.
As for "reference level"...you do realize that is 105db peaks from one speaker, right? In a typical room, you will need 300 watts per channel to achieve that. Also, "reference level" is a spec meant for actual commercial theaters. In a typical home theater, since the room is smaller, there is much more direct sound, the same "sound and feel" is achieved at much lower levels depending on the room.
Have you actually measured your listening levels? What speakers do you use now?
-curtis
cschang is offline
post #3897 of 4206 Old 02-25-2014, 10:41 AM
BCRSS's Avatar
Quoted: 250 Post(s)
Liked: 189
I play most of my movies at -10 and if I really want to impress at 0 and can tell you that the 340's will deliver great HT sound. I sit roughly 9 ft. from LP but even if I move to the back of the room, the quality and loudness is deafening. I Like it. biggrin.gif
BCRSS is online now
post #3898 of 4206 Old 02-25-2014, 10:46 AM
pmanyon's Avatar
Quoted: 60 Post(s)
Liked: 32
Is the midrange thump or impact good on the 340SE? Do they sound heavy for HT? I see that they have a lower end of 45hz, what do owners cross them over at? I have a pb2000, how will they match with that subwoofer? I am getting close to pulling the trigger on the 340se 5 speaker system.
pmanyon is offline
post #3899 of 4206 Old 02-25-2014, 10:59 AM
cel4145's Avatar
Liked: 3000
They will work great with the PB-2000. Cross them over at either 60 or 80hz, whichever sounds best to you smile.gif
cel4145 is offline
post #3900 of 4206 Old 02-25-2014, 11:04 AM
BCRSS's Avatar
Quoted: 250 Post(s)
Liked: 189
I have mine crossed at 80 but have tried 60 and find that the 80 crossover is what I like.
BCRSS is online now
Reply Speakers
Ascend Acoustics , Pioneer Vsx 1014txk Thx Select Av Receiver , Receivers Amplifiers , Velodyne Impact 10 10 Subwoofer
