Ascend SE Owner's Thread - Page 134 - AVS Forum
post #3991 of 3993 Unread 12-19-2014, 05:13 AM
Bond 007's Avatar
Quoted: 507 Post(s)
Liked: 919
Originally Posted by Ascend View Post
15-20 degrees downward and you are good to go. Try these:
http://www.cotytech.com/content-prod...r_sp_os02.html
Thanks for the suggestion.
While they do tilt plenty enough they do not swivel like I need them too. I ended up going with these. They only tilt 15 degrees but will rotate and swivel as well so that I can aim them directly at the LP.
http://www.htd.com/Products/Wall-Mount-Speaker-Brackets/BR-TPRX-Heavy-Duty-Brackets
I placed my order for 2 more 170s yesterday. Any reason why it might be beneficial to mount them upside down or will a standard tweeter at the top mount work fine?
Bond 007 is offline
post #3992 of 3993 Unread 12-22-2014, 05:42 AM
Bond 007's Avatar
Quoted: 507 Post(s)
Liked: 919
Any reason not to wall mount these 170s sideways using the 2 threaded inserts for front heights? Cancellation issues, construction, etc.?
I figure since I can only tilt 15 degrees I can get the maximum out of that angle by mounting them with the tweeter and midwoofer side by side since theyre not as wide as they are tall. They will be pointed directly at the MLP with the tweeters on the inside for both L and R.
No, Mr. Bond. I expect you to die!
Bond 007 is offline
post #3993 of 3993 Unread 01-10-2015, 08:18 PM
jtenn's Avatar
How would the 340's compare to these?
http://usa.yamaha.com/products/audio...=2&mode=paging
jtenn is online now
Reply Speakers
Ascend Acoustics , Pioneer Vsx 1014txk Thx Select Av Receiver , Receivers Amplifiers , Velodyne Impact 10 10 Subwoofer
