Ascend SE Owner's Thread - Page 141 - AVS Forum | Home Theater Discussions And Reviews
 99Likes
post #4201 of 4206 Old 05-24-2017, 12:12 PM
Bond 007's Avatar
Quoted: 2596 Post(s)
Liked: 2061
Originally Posted by gadgtfreek View Post
Simple input needed here:
Almost 100% HT movies, what isn't is concert blu-ray
Yamaha preamp, outlaw 7140 amp
LFE dual FV15HP's
Looking at hard at CMT-340 SE for LCR. I notice the Sierra 1 and 2, but I really like the look of the 340 and from reading it seems if you are running HT the 340 is an excellent choice. Room is 20x12 and I prefer higher volumes during action flicks. Also really liked the 340 look on stands, because stand will be a must for me.
I dont see a question but Im running a 5.2.4 Atmos setup with 3060 AVR, 340 LCR, 170 x 4 and 200 x 2. LV12r and Klipsch subs.
Very happy.
Bond 007 is offline
post #4202 of 4206 Old 05-24-2017, 12:30 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 3895
Very happy.
It was really just 340 vs Sierra (LCR) for HT use. I really like the idea of matching LCR and the cost of the 340, almost hard to believe how little they cost.
gadgtfreek is online now
post #4203 of 4206 Old 05-24-2017, 12:45 PM
Bond 007's Avatar
Liked: 2061
Sierra are overkill and a waste of money for ht use imo.
gadgtfreek likes this.
Bond 007 is offline
post #4204 of 4206 Old 05-24-2017, 02:58 PM
GIEGAR's Avatar
Quoted: 782 Post(s)
Liked: 1332
Yes, the CMT-340 SE's combination of accuracy, good sensitivity and high power handling means they're the pick for clean, dynamic sounding movies at higher volumes.
GIEGAR is offline
post #4205 of 4206 Old 05-24-2017, 03:11 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 3895
Thanks. I'm guessing you would just cross the 340's at 80hz and let the subs handle the rest?
The Outlaw 7140 would have no issue driving them.
post #4206 of 4206 Old 05-24-2017, 05:38 PM
GIEGAR's Avatar
Quoted: 782 Post(s)
Liked: 1332
Yep, at least 80Hz. Higher the better to take the high excursion low bass (= distortion) away from the woofers. With familiar bass-heavy content playing, nudge the crossovers up in steps until you can begin to readily localise the subs, then back the crossovers off one notch. Done! If your subs have a good lock your room, don't be surprised if you end up at around 120Hz.
At 90dB/1W/1m sensitivity and 8Ω nom. impedance, any mid-tier AVR will happily drive them to very loud levels at typical listening distances (105dBSPL peaks per channel @ 10ft with a 100W burst). A walk in the park for your Outlaw.
GIEGAR is offline
Reply Speakers
Ascend Acoustics , Pioneer Vsx 1014txk Thx Select Av Receiver , Receivers Amplifiers , Velodyne Impact 10 10 Subwoofer
